I am trying to run Isaac sim through omniverse, build 2021.1.1 is installed but when I click on launch, it just loads for sometime and stops.
Specs:
RTX2080
16gb ram
i7 processor
Specs:
RTX2080
16gb ram
i7 processor
Hi, you should be able to run Issac Sim with that specs. Can you share your logs? Itâs located at ~/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1.
This is the log file
kit_20210721_214527.log (190.5 KB)
The log looks fine. Did it crashed or hanged when it stops?
Can you try running Isaac Sim with the -v or -vv flag and share the log please? You can either run it via terminal or add the flag in the Extra Args text box in the Isaac Sim App Launcher.
When you click Launch, the Isaac Sim App Launcher window should appear, then click Launch again.
You can run Isaac Sim directly with /home/krishna/.local/share/ov/pkg/isaac_sim-2021.1.1/isaac-sim.sh -v from terminal.
When I click on launch in the image I attached nothing happens.
But I tried the terminal command you sent, that works.
I havenât setup nucleus yet, so will set it up and see if everything is working.
@sheikh-nv
I created an account in Nucleus,
I am following this documentation.
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/setup.html#isaac-sim-setup-nucleus-add-assets
But there is no option to create a folder
See step #4. Currently, we can only create the folder in Isaac Sim.
Can I take a look at the other logs below? There could be an error in the Isaac Sim App Launcher or the Omniverse Launcher itself.
~/.nvidia-omniverse/logs/Kit/Isaac-Sim_App_Launcher/2021.1
~/.nvidia-omniverse/logs/launcher.log
Ya in the steps mentioned the create a folder in a UI right, Where can I find it and where should download the asset file to.
Becuse right now I have ânucleus service not configured warning nowâ
Log files:
kit_20210722_105105.log (37.6 KB)
launcher.log (51.7 KB)
Looks like the Isaac Sim App Launcher exited with this error:
2021-07-22 05:21:05 [93ms] [Error] [carb.scripting-python.plugin] TypeError: launch_app() missing 1 required positional argument: âapp_versionâ
Can you try check the top right bell icon on the Omniverse Launcher if you have an update. Then try reinstall Isaac Sim.
There are not updates and I have already uninstalled it and installed it. Still the same issue persists
This command works and opes isaac sim.
But I was trying to run Jetbot basic example and Isaac sim crashed.
Please share the log file at ~/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1.
Have you installed Nucleus and uploaded the Isaac folder before running the Jetbot sample?
Yes
Isaac sim crashed because it filled the entire 16gb ram.
I upgraded my ram to 32 gb ram.
Now the environments are getting loaded.
But now when I try to move the bot in Jetbot sample I get this error:
2021-07-30 05:28:01 [68,641ms] [Error] [carb.events.python] RuntimeError: Accessed <pxr.Usd.Object object at 0x7f69b59f80a0>
At:
/home/krishna/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/semantics.schema.editor-0.1.3+cp37/semantics/schema/editor/semantics_schema_editor.py(149): get_semantics
/home/krishna/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/semantics.schema.editor-0.1.3+cp37/semantics/schema/editor/semantics_schema_editor.py(131): _add_prim_entry
/home/krishna/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/semantics.schema.editor-0.1.3+cp37/semantics/schema/editor/semantics_schema_editor.py(70): _build_window_ui
/home/krishna/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/semantics.schema.editor-0.1.3+cp37/semantics/schema/editor/semantics_schema_editor.py(142): on_stage_event
2021-07-30 05:28:03 [70,809ms] [Warning] [omni.client.plugin] Main: usd_plugin: Ill-formed SdfPath <>: syntax error
2021-07-30 05:28:03 [70,809ms] [Warning] [omni.usd] Warning: in SdfPath at line 97 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/sdf/path.cpp â Ill-formed SdfPath <>: syntax error
2021-07-30 05:28:06 [73,283ms] [Error] [carb.events.python] RuntimeError: Accessed <pxr.Usd.Object object at 0x7f696dd78b90>
At:
2021-07-30 05:28:07 [73,916ms] [Warning] [omni.client.plugin] Main: usd_plugin: Ill-formed SdfPath <>: syntax error
2021-07-30 05:28:07 [73,916ms] [Warning] [omni.usd] Warning: in SdfPath at line 97 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/sdf/path.cpp â Ill-formed SdfPath <>: syntax error
Bot doesnât move as well
I tried reinstalling isaac sim, but the launching issues is still there
I can only launch it from terminal using
Which version of the Launcher are you one. There should be a new version 1.2.10 with some fixes.
Please also post the full log with the error. There may be other clues in the log file.
Are you able to run the other samples like Franka Block Stacking and UR10 Palletizing from the Isaac Examples menu?
from where can I download the 1.2.10 version?
No after upgrading my ram 32gb I am able to run stuff on isaac sim.
But one issue I encountered while trying kaya joystick, when I used the joystick the camera in isaac sim started rotating and never stopped.
