LAUNCH button is not responsive and Isaac Sim not launching in Omniverse
I installed Isaac Sim through the Exchange tab in Omniverse.
Clicking the LAUNCH button is not responsive.
I tried running Isaac sim directly from the terminal with /home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/isaac-sim.sh -v
but I am getting this in the terminal:
[Info] [carb] Logging to file: /home/victor/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20210727_180459.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
2021-07-28 01:04:59 [0ms] [Info] [omni.kit.app.plugin] App Name: 'Isaac-Sim', App Version: '2021.1.1', Kit Version: '101.0+release.1106.a41b6e49.teamcity'
2021-07-28 01:04:59 [0ms] [Info] [omni.kit.app.plugin] Argv: [/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/kit, /home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps/omni.isaac.sim.kit, --ext-folder, /home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/exts, --ext-folder, /home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps, -v]
2021-07-28 01:04:59 [0ms] [Info] [omni.kit.app.plugin] Applied configs: [/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/config/kit-core.json, /home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps/omni.isaac.sim.kit, /home/victor/.nvidia-omniverse/config/privacy.toml]
2021-07-28 01:04:59 [1ms] [Info] [omni.kit.app.plugin] Tokens:
    "app_documents": "/home/victor/Documents/Kit/apps/Isaac-Sim",
    "documents": "/home/victor/Documents/Kit/apps/Isaac-Sim",
    "cache": "/home/victor/.cache/ov/Kit/101.0/a41b6e49",
    "shared_documents": "/home/victor/Documents/Kit/shared",
    "logs": "/home/victor/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1",
    "omni_cache": "/home/victor/.cache/ov",
    "omni_logs": "/home/victor/.nvidia-omniverse/logs",
    "omni_data": "/home/victor/Documents/Omniverse_Data",
    "start_timestamp": "20210727_180459",
    "rtx_path": "plugins/rtx",
    "shell_ext": ".sh",
    "bindings_ext": ".so",
    "xrresources": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/xrresources",
    "lib_ext": ".so",
    "resources": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources",
    "drive": "/",
    "gfx_path": "plugins/carb_gfx",
    "cli-config-path": "/home/victor/Documents",
    "exe_ext": "",
    "glyphs": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/glyphs",
    "appcache": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/cache/Kit/101.0/a41b6e49",
    "materials": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/materials",
    "exe-path": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit",
    "local-config-path": "/home/victor/Documents",
    "exe-filename": "kit",
    "omni_documents": "/home/victor/Documents",
    "custom-config-path": "/home/victor/Documents",
    "data": "/home/victor/Documents/Omniverse_Data/Kit/Isaac-Sim/2021.1",
    "platform": "linux-x86_64",
    "app": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps",
    "lib_prefix": "lib",
    "xrcontrollers": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/xrresources/models/controllers",
    "temp": "/tmp/carb.5kkIPc",
    "fonts": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/fonts",
    "icons": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/icons",
    "sounds": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/sounds",
    "kit": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit",
    "models": "/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/resources/models",
    "config": "release"
2021-07-28 01:04:59 [1ms] [Info] [omni.kit.app.plugin] [0.009s] Loading user config located at: '/home/victor/Documents/Omniverse_Data/Kit/Isaac-Sim/2021.1/user.config.json'
2021-07-28 01:04:59 [1ms] [Info] [carb] file '/home/victor/Documents/Omniverse_Data/Kit/Isaac-Sim/2021.1/user.config.json' does not exist
2021-07-28 01:04:59 [1ms] [Info] [carb] Initializing plugin: carb.scripting-python.plugin (interfaces: [carb::scripting::IScripting v1.0]) (impl: carb.scripting-python.plugin)
2021-07-28 01:04:59 [1ms] [Info] [carb.scripting-python.plugin] Attempting to initialize Python interpreter. Failure of doing it will lead to the termination of the application.
2021-07-28 01:04:59 [9ms] [Info] [carb.scripting-python.plugin] Python interpreter was successfully initialized.
2021-07-28 01:04:59 [47ms] [Info] [carb] Initializing plugin: omni.ext.plugin (interfaces: [omni::ext::IExtensions v1.0]) (impl: omni.ext.plugin)
2021-07-28 01:04:59 [47ms] [Info] [omni.ext.plugin] [ext manager] preferLocalVersions: 1
2021-07-28 01:04:59 [49ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps' (path type: 0)
2021-07-28 01:04:59 [49ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.base-2021.1.1] registered
2021-07-28 01:04:59 [49ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.extscache-0.0.0] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.headless.base-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.headless.kitremote-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.headless.webrtc-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.headless.websocket-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.launcher-2021.1.1] registered
2021-07-28 01:04:59 [50ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.python-2021.1.1] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.splash-2021.1.1] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/apps/omni.isaac.sim.kit' (path type: 2)
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/exts' (path type: 0)
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.app.launcher-1.0.0] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.app.setup-0.0.0] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.contact_sensor-0.1.0] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.dr-0.1.6] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.dynamic_control-0.1.3] registered
2021-07-28 01:04:59 [51ms] [Info] [omni.ext.plugin] [ext: omni.isaac.manip-0.1.2] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.motion_planning-0.1.4] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.occupancy_map-0.1.0] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.onshape-0.3.7] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.python_app-0.0.0] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.range_sensor-0.1.2] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.robot_engine_bridge-0.1.0] registered
2021-07-28 01:04:59 [52ms] [Info] [omni.ext.plugin] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.ros2_bridge-0.1.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.ros_bridge-0.1.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.ros_bridge_ui-0.1.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.samples-0.1.6] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.shapenet-1.0.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.splash-1.0.0] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.step_importer-0.1.1] registered
2021-07-28 01:04:59 [53ms] [Info] [omni.ext.plugin] [ext: omni.isaac.synthetic_utils-0.1.0] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.isaac.tests-0.0.0] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.isaac.urdf-0.1.4] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.isaac.utils-0.1.4] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.isaac.utils_manager-0.1.0] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.isaac.window.about-1.0.0] registered
2021-07-28 01:04:59 [54ms] [Info] [omni.ext.plugin] [ext: omni.kit.asset_converter-1.1.22] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.websocket-1.0.3] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-isaac-0.1.0] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.isaac-0.1.0] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.asset_importer-2.3.2] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.sliderbar-1.0.3] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.services.streamclient.webrtc-1.0.4] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.services.streamclient.websocket-1.1.2] registered
2021-07-28 01:04:59 [55ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.isaac-0.1.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: semantics.schema.editor-0.1.3] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/apps' (path type: 0)
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.cache_monitor-1.0.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.content_browser-1.0.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.copy_service-1.0.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.demo.progress-1.0.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.dev-1.0.0] registered
2021-07-28 01:04:59 [56ms] [Info] [omni.ext.plugin] [ext: omni.app.empty-0.1.0] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.full-1.0.1] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.hydra-0.1.0] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.mini-0.1.1] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.next-0.1.0] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.python-0.1.0] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.test_ext-1.0.0] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] [ext: omni.app.uidoc-1.0.1] registered
2021-07-28 01:04:59 [57ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts' (path type: 0)
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.ansel-0.2.0] registered
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.audioplayer-0.2.0] registered
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.audiorecorder-0.1.0] registered
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.command.usd-1.0.1] registered
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.debugdraw-0.0.0] registered
2021-07-28 01:04:59 [58ms] [Info] [omni.ext.plugin] [ext: omni.drivesim.rtdevice-sample-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.greet-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.hello-0.2.2] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.menu_hook-0.1.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.multi_app_window-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.native_ext-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.splash-1.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.standalone-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.streamclient-mini-0.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.ui-1.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.example.workspace-1.0.0] registered
2021-07-28 01:04:59 [59ms] [Info] [omni.ext.plugin] [ext: omni.flowusd-0.1.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.core-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.examples.cpp-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.examples.python-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.expression-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.nodes-1.0.0] registered
2021-07-28 01:04:59 [60ms] [Info] [omni.ext.plugin] [ext: omni.graph.test-0.0.0] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.graph.tools-1.0.0] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.graph.tutorials-1.0.0] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.graph.ui-1.0.1] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.iray.settings.core-0.6.2] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.kit.agent.watcher-0.1.0] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.kit.capture-0.4.0] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.kit.collaboration.channel_manager-1.0.2] registered
2021-07-28 01:04:59 [61ms] [Info] [omni.ext.plugin] [ext: omni.kit.collaboration.viewport.camera-1.0.1] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.compatibility_checker-0.0.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.controlport-1.0.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.debug.python-0.1.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.debug.settings-0.1.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.debug.utils-0.2.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.debug.vscode-0.1.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.editor-full-0.0.0] registered
2021-07-28 01:04:59 [62ms] [Info] [omni.ext.plugin] [ext: omni.kit.editor-mini-0.0.0] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.etm.core-0.1.1] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.example.toolbar_button-0.1.0] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.filebrowser_column.acl-1.0.0] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.filebrowser_column.tags-1.0.0] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.native-0.0.0] registered
2021-07-28 01:04:59 [63ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.webrtc-0.0.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.edit-1.0.3] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.file-1.0.2] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.select-1.0.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.notification_manager-1.0.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.numpy.common-0.1.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.primitive.mesh-1.0.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.procedural.mesh-0.0.0] registered
2021-07-28 01:04:59 [64ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.audio-1.0.4] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.bundle-1.2.4] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.camera-1.0.3] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.file-1.0.0] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.geometry-1.1.0] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.layer-1.1.0] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.light-1.0.4] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.material-1.6.4] registered
2021-07-28 01:04:59 [65ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.tagging-1.0.3] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.transform-1.0.2] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.usd-3.9.4] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.quicklayout-1.0.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.quicksearch.commands-1.0.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.rpc-0.1.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.search.service-0.1.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.search_core-1.0.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.search_example-1.0.0] registered
2021-07-28 01:04:59 [66ms] [Info] [omni.ext.plugin] [ext: omni.kit.selection-0.0.0] registered
2021-07-28 01:04:59 [67ms] [Info] [omni.ext.plugin] [ext: omni.kit.stage_templates-1.0.4] registered
2021-07-28 01:04:59 [67ms] [Info] [omni.ext.plugin] [ext: omni.kit.tagging-0.1.0] registered
2021-07-28 01:04:59 [67ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.images-0.1.1] registered
2021-07-28 01:04:59 [67ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.3.0] registered
2021-07-28 01:04:59 [67ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.collect-2.0.1] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.usda_edit-1.1.6] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.viewport_widgets_manager-1.0.2] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.browser_bar-2.0.1] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.etm-0.1.1] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.fast_search-0.3.0] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.filebrowser-2.2.4] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.graph-1.1.2] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.imageview-1.0.0] registered
2021-07-28 01:04:59 [68ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.layers-1.5.2] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.live-0.0.0] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.path_field-2.0.2] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.prompt-1.0.0] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.settings-1.0.0] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage-2.4.0] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage_icons-1.0.1] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.versioning-1.1.3] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.about-1.0.0] registered
2021-07-28 01:04:59 [69ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.audioplayer-1.0.1] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.audiorecorder-1.0.1] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.cache_monitor-1.0.0] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.commands-0.1.1] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.console-0.0.0] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.content-1.0.0] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.content_browser-2.3.1] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.copy_service-1.0.2] registered
2021-07-28 01:04:59 [70ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.cursor-1.0.1] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.details-1.0.0] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.drop_support-1.0.0] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.extensions-1.0.2] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.file-1.2.2] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.filepicker-2.3.1] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.hydra_viewport-0.0.0] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.images-0.0.0] registered
2021-07-28 01:04:59 [71ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.imageviewer-1.0.3] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.material_swap-1.0.2] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.movie_maker-0.4.9] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.popup_dialog-2.0.0] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.preferences-1.1.1] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.profiler-1.0.0] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.progress_monitor-1.0.0] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.property-0.0.0] registered
2021-07-28 01:04:59 [72ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.provide_feedback-1.0.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.quicksearch-1.0.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.render_farm-0.3.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.script_editor-1.5.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash_close_example-0.0.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stage-2.3.3] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stageviewer-1.0.1] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stats-0.0.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.status_bar-0.0.0] registered
2021-07-28 01:04:59 [73ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stream_viewport-0.0.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.tests-0.1.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.title-1.1.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.toolbar-1.0.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.usd_paths-1.0.3] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.xr-1.0.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.kit.xr.profile.tabletar-1.0.0] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.rtx.settings.core-0.5.4] registered
2021-07-28 01:04:59 [74ms] [Info] [omni.ext.plugin] [ext: omni.rtx.window.settings-0.6.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.config-1.0.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.log-1.0.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.workqueue-1.0.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.registry-1.0.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.thumbnails.images-1.1.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.idl_http_async-0.1.2] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.base-1.0.0] registered
2021-07-28 01:04:59 [75ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.http-1.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.https-1.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.tcp_socket-1.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.services.usd-1.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.videoencoding-0.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.volume-0.0.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extsPhysics' (path type: 0)
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.convexdecomposition-1.2.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.geometry-1.2.0-5.1] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.physx-0.1.0] registered
2021-07-28 01:04:59 [76ms] [Info] [omni.ext.plugin] [ext: omni.kvdb-0.0.0] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.localcache-0.0.0] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx-1.2.0-5.1] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.bundle-1.2.0-5.1] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.cct-1.2.0-5.1] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.commands-1.0.0] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.computegraph-1.2.0-5.1] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.demos-1.0.0] registered
2021-07-28 01:04:59 [77ms] [Info] [omni.ext.plugin] [ext: omni.physx.internal-1.2.0-5.1] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.tests-1.0.0] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.tests.visual-1.0.0] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.ui-1.2.0-5.1] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.vehicle-1.2.0-5.1] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.vehicle.tests-0.1.0] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.zerogravity-1.2.0-5.1] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.physx.zerogravity.tests-1.0.0] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.physics-1.0.0] registered
2021-07-28 01:04:59 [78ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.physx-0.0.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.usdphysics-1.2.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.usdphysics.tests-1.2.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore' (path type: 0)
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: carb.audio-0.1.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-1.0.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.assets-0.0.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.assets.plugins-0.0.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] registered
2021-07-28 01:04:59 [79ms] [Info] [omni.ext.plugin] [ext: omni.hydra.examples-1.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.hydra.iray-0.1.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.hydra.pxr-1.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.hydra.rtx-0.1.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.hydra.scene_delegate-0.1.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.hydra.ui-0.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.kit.agent-0.1.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.kit.async_engine-0.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.kit.autocapture-0.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.kit.commands-0.0.0] registered
2021-07-28 01:04:59 [80ms] [Info] [omni.ext.plugin] [ext: omni.kit.console-0.0.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.context_menu-1.1.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.core.tests-0.1.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.core-0.0.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.mainwindow-0.0.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.material.library-1.0.4] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.create-1.0.1] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.utils-1.0.1] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.pip_archive-0.0.0] registered
2021-07-28 01:04:59 [81ms] [Info] [omni.ext.plugin] [ext: omni.kit.pipapi-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.profile_python-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.registry.nucleus-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.capture-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.splash-0.2.1] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.test-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.test_helpers_gfx-0.0.0] registered
2021-07-28 01:04:59 [82ms] [Info] [omni.ext.plugin] [ext: omni.kit.uiapp-0.0.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.kit.usd_undo-0.1.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash-0.0.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.kit.xr-1.0.0] registered
2021-07-28 01:04:59 [83ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr', ext 2: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr'
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] Unregistered extension: omni.kit.xr-1.0.0
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.renderer-rtx-0.0.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.renderer-ui-0.0.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.services.client-0.2.0] registered
2021-07-28 01:04:59 [83ms] [Info] [omni.ext.plugin] [ext: omni.services.core-1.1.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.base-1.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.base-1.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.http_async-1.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.https_async-1.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.stats-0.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.syntheticdata-0.1.5] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.timeline-1.0.0] registered
2021-07-28 01:04:59 [84ms] [Info] [omni.ext.plugin] [ext: omni.ui-2.1.8] registered
2021-07-28 01:04:59 [85ms] [Info] [omni.ext.plugin] [ext: omni.usd-1.4.2] registered
2021-07-28 01:04:59 [85ms] [Info] [omni.ext.plugin] [ext: omni.usd.config-1.0.0] registered
2021-07-28 01:04:59 [85ms] [Info] [omni.ext.plugin] [ext: omni.usd.libs-1.0.0] registered
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.anim-0.0.0] registered
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.audio-0.0.0] registered
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.physics-0.0.0] registered
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] [ext: omni.usd.schema.semantics-0.0.0] registered
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/Documents/Kit/apps/Isaac-Sim/exts' (path type: 0)
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/Documents/Kit/shared/exts' (path type: 0)
2021-07-28 01:04:59 [86ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/victor/Documents/Omniverse_Data/Kit/Isaac-Sim/2021.1/exts/2' (path type: 1)
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim-2021.1.1] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.isaac.sim.base-2021.1.1] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.isaac.app.setup-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.movie_maker-0.4.9] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.script_editor-1.5.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.sliderbar-1.0.3] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.videoencoding-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.console-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.extensions-1.0.2] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.tests-0.1.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.isaac.robot_engine_bridge-0.1.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.isaac.ros_bridge-0.1.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.ansel-0.2.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.3.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.content_browser-2.3.1] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.property-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.file-1.2.2] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.filepicker-2.3.1] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.images-0.1.1] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.http-1.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage-2.4.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.usd-1.4.2] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.mainwindow-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.test-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-1.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.async_engine-0.0.0] applying settings
2021-07-28 01:04:59 [89ms] [Info] [omni.ext.plugin] [ext: omni.kit.pipapi-0.0.0] applying settings
2021-07-28 01:04:59 [90ms] [Info] [omni.ext.plugin] [ext: omni.usd.config-1.0.0] applying settings
2021-07-28 01:04:59 [90ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd.config-1.0.0] (order: 0) Triggered by: omni.usd.libs-1.0.0
2021-07-28 01:04:59 [90ms] [Info] [omni.kit.app.plugin] [0.098s] [ext: omni.usd.config-1.0.0] startup
2021-07-28 01:04:59 [91ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd.libs-1.0.0] (order: -1000) Triggered by: omni.client-0.1.0, omni.graph.tools-1.0.0, omni.hydra.iray-0.1.0, omni.hydra.rtx-0.1.0, omni.hydra.scene_delegate-0.1.0, omni.kit.menu.utils-1.0.1, omni.kit.usd_undo-0.1.0, omni.kit.widget.graph-1.1.2, omni.kit.window.imageviewer-1.0.3, omni.kit.window.stats-0.0.0, omni.physx-1.2.0-5.1, omni.usd-1.4.2, omni.usd.schema.anim-0.0.0, omni.usd.schema.audio-0.0.0, omni.usd.schema.isaac-0.1.0, omni.usd.schema.physics-1.0.0, omni.usd.schema.physx-0.0.0, omni.usd.schema.semantics-0.0.0, omni.usdphysics-1.2.0
2021-07-28 01:04:59 [91ms] [Info] [omni.kit.app.plugin] [0.099s] [ext: omni.usd.libs-1.0.0] startup
2021-07-28 01:04:59 [280ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.pipapi-0.0.0] (order: -1000) Triggered by: omni.graph.examples.python-1.0.0, omni.graph.ui-1.0.1, omni.isaac.shapenet-1.0.0, omni.kit.pip_archive-0.0.0, omni.services.core-1.1.0, omni.ui-2.1.8
2021-07-28 01:04:59 [280ms] [Info] [omni.kit.app.plugin] [0.288s] [ext: omni.kit.pipapi-0.0.0] startup
2021-07-28 01:04:59 [286ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd.schema.semantics-0.0.0] (order: -100) Triggered by: omni.hydra.iray-0.1.0, omni.hydra.rtx-0.1.0, omni.hydra.scene_delegate-0.1.0, omni.usd-1.4.2
2021-07-28 01:04:59 [286ms] [Info] [omni.kit.app.plugin] [0.294s] [ext: omni.usd.schema.semantics-0.0.0] startup
2021-07-28 01:04:59 [290ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd.schema.audio-0.0.0] (order: -100) Triggered by: omni.hydra.iray-0.1.0, omni.hydra.rtx-0.1.0, omni.hydra.scene_delegate-0.1.0, omni.usd-1.4.2
2021-07-28 01:04:59 [290ms] [Info] [omni.kit.app.plugin] [0.298s] [ext: omni.usd.schema.audio-0.0.0] startup
2021-07-28 01:04:59 [293ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.hydra.iray-0.1.0] (order: -1000) Triggered by: omni.isaac.sim.base-2021.1.1
2021-07-28 01:04:59 [293ms] [Info] [omni.kit.app.plugin] [0.301s] [ext: omni.hydra.iray-0.1.0] startup
2021-07-28 01:04:59 [293ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx' Filename: 'carb.scenerenderer-mux.plugin'
2021-07-28 01:04:59 [293ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx' Filename: 'carb.scenerenderer-iray.plugin'
2021-07-28 01:04:59 [293ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx' Filename: 'rtx.neuraylib.plugin'
2021-07-28 01:04:59 [293ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.iray/bin' Filename: '*.plugin'
2021-07-28 01:04:59 [294ms] [Info] [carb] Registered plugin: carb.scenerenderer-mux.plugin (interfaces: [carb::renderer::SceneRenderer v0.13]) (impl: carb.scenerenderer-mux.plugin)
2021-07-28 01:04:59 [294ms] [Info] [carb] Registered plugin: carb.scenerenderer-iray.plugin (interfaces: [carb::renderer::SceneRenderer v0.13]) (impl: carb.scenerenderer-iray.plugin)
2021-07-28 01:04:59 [294ms] [Info] [carb] Registered plugin: rtx.neuraylib.plugin (interfaces: [rtx::neuray::NeurayLib v0.2]) (impl: rtx.neuraylib.plugin)
2021-07-28 01:04:59 [296ms] [Info] [carb] Registered plugin: omni.hydra.iray (interfaces: [omni::ext::IExt v0.1]) (impl: omni.hydra.iray)
2021-07-28 01:04:59 [296ms] [Info] [carb] Initializing plugin: omni.hydra.iray (interfaces: [omni::ext::IExt v0.1]) (impl: omni.hydra.iray)
2021-07-28 01:04:59 [296ms] [Info] [omni.ext.plugin] [ext: omni.hydra.iray-0.1.0] Starting ext::IExt in '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.iray/bin/libomni.hydra.iray.plugin.so'
2021-07-28 01:04:59 [296ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.pip_archive-0.0.0] (order: -1000) Triggered by: omni.graph-1.0.0, omni.isaac.contact_sensor-0.1.0, omni.isaac.dynamic_control-0.1.3, omni.isaac.occupancy_map-0.1.0, omni.isaac.range_sensor-0.1.2, omni.isaac.robot_engine_bridge-0.1.0, omni.isaac.ros_bridge-0.1.0, omni.isaac.step_importer-0.1.1, omni.isaac.synthetic_utils-0.1.0, omni.isaac.tests-0.0.0, omni.isaac.urdf-0.1.4, omni.kit.context_menu-1.1.0, omni.kit.numpy.common-0.1.0, omni.kit.search.service-0.1.0, omni.kit.tagging-0.1.0, omni.kit.thumbnails.usd-0.3.0, omni.kit.window.commands-0.1.1, omni.kit.window.content_browser-2.3.1, omni.kit.window.file-1.2.2, omni.kit.window.filepicker-2.3.1, omni.services.client-0.2.0, omni.services.core-1.1.0, omni.services.transport.client.http_async-1.0.0, omni.syntheticdata-0.1.5
2021-07-28 01:04:59 [296ms] [Info] [omni.kit.app.plugin] [0.304s] [ext: omni.kit.pip_archive-0.0.0] startup
2021-07-28 01:04:59 [296ms] [Info] [carb.python] [omni.kit.pipapi] Add archive dir: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.pip_archive/pip_archive'
2021-07-28 01:04:59 [301ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.async_engine-0.0.0] (order: 0) Triggered by: omni.client-0.1.0, omni.graph-1.0.0, omni.kit.test-0.0.0, omni.kit.window.extensions-1.0.2
2021-07-28 01:04:59 [301ms] [Info] [omni.kit.app.plugin] [0.309s] [ext: omni.kit.async_engine-0.0.0] startup
2021-07-28 01:04:59 [309ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.stats-0.0.0] (order: 0) Triggered by: omni.appwindow-1.0.0, omni.isaac.sim.base-2021.1.1, omni.kit.window.stats-0.0.0, omni.renderer-rtx-0.0.0
2021-07-28 01:04:59 [309ms] [Info] [omni.kit.app.plugin] [0.318s] [ext: omni.stats-0.0.0] startup
2021-07-28 01:04:59 [309ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.stats.plugin'
2021-07-28 01:04:59 [310ms] [Info] [carb] Registered plugin: carb.stats.plugin (interfaces: [carb::stats::IStats v0.2]) (impl: carb.stats.plugin)
2021-07-28 01:04:59 [311ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.assets.plugins-0.0.0] (order: 0) Triggered by: omni.client-0.1.0, omni.convexdecomposition-1.2.0, omni.kit.renderer.core-0.0.0, omni.renderer-rtx-0.0.0, omni.usd-1.4.2, omni.videoencoding-0.0.0
2021-07-28 01:04:59 [311ms] [Info] [omni.kit.app.plugin] [0.320s] [ext: omni.assets.plugins-0.0.0] startup
2021-07-28 01:04:59 [311ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.assets.plugins/bin' Filename: 'carb.assets.plugin'
2021-07-28 01:04:59 [312ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.assets.plugins/bin' Filename: 'carb.datasource-file.plugin'
2021-07-28 01:04:59 [312ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.assets.plugins/bin' Filename: 'carb.tasking.plugin'
2021-07-28 01:04:59 [312ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.imaging.plugin'
2021-07-28 01:04:59 [312ms] [Info] [carb] Registered plugin: carb.assets.plugin (interfaces: [carb::assets::IAssets v1.0],[carb::assets::IAssetsBlob v0.1]) (impl: carb.assets.plugin)
2021-07-28 01:04:59 [312ms] [Info] [carb] Registered plugin: carb.datasource-file.plugin (interfaces: [carb::datasource::IDataSource v0.3]) (impl: carb.datasource-file.plugin)
2021-07-28 01:04:59 [312ms] [Info] [carb] Registered plugin: carb.tasking.plugin (interfaces: [carb::tasking::ITasking v1.6],[carb::tasking::IThreadPool v0.1]) (impl: carb.tasking.plugin)
2021-07-28 01:04:59 [313ms] [Info] [carb] Registered plugin: carb.imaging.plugin (interfaces: [carb::imaging::IImaging v0.4]) (impl: carb.imaging.plugin)
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.loop-default-0.1.0] (order: 0) Triggered by: omni.appwindow-1.0.0, omni.kit.test-0.0.0, omni.services.core-1.1.0
2021-07-28 01:04:59 [313ms] [Info] [omni.kit.app.plugin] [0.321s] [ext: omni.kit.loop-default-0.1.0] startup
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.loop-default/bin' Filename: '*.plugin'
2021-07-28 01:04:59 [313ms] [Info] [carb] Registered plugin: omni.kit.loop-default.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.loop-default.plugin)
2021-07-28 01:04:59 [313ms] [Info] [carb] Initializing plugin: omni.kit.loop-default.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.loop-default.plugin)
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] Starting ext::IExt in '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.loop-default/bin/libomni.kit.loop-default.plugin.so'
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.client-0.1.0] (order: 0) Triggered by: omni.graph-1.0.0, omni.graph.core-1.0.0, omni.isaac.dr-0.1.6, omni.isaac.window.about-1.0.0, omni.kit.asset_converter-1.1.22, omni.kit.menu.file-1.0.2, omni.kit.property.layer-1.1.0, omni.kit.property.material-1.6.4, omni.kit.property.usd-3.9.4, omni.kit.renderer.core-0.0.0, omni.kit.search.service-0.1.0, omni.kit.tagging-0.1.0, omni.kit.thumbnails.images-0.1.1, omni.kit.thumbnails.usd-0.3.0, omni.kit.tool.asset_importer-2.3.2, omni.kit.tool.collect-2.0.1, omni.kit.widget.filebrowser-2.2.4, omni.kit.widget.layers-1.5.2, omni.kit.widget.live-0.0.0, omni.kit.widget.stage-2.4.0, omni.kit.window.content_browser-2.3.1, omni.kit.window.extensions-1.0.2, omni.kit.window.file-1.2.2, omni.kit.window.filepicker-2.3.1, omni.kit.window.preferences-1.1.1, omni.kit.window.property-0.0.0, omni.renderer-rtx-0.0.0, omni.usd-1.4.2
2021-07-28 01:04:59 [313ms] [Info] [omni.kit.app.plugin] [0.321s] [ext: omni.client-0.1.0] startup
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.client/bin' Filename: '*.plugin'
2021-07-28 01:04:59 [313ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.datasource-omniclient.plugin'
2021-07-28 01:04:59 [316ms] [Info] [carb] Registered plugin: carb.messaging-omniclient.plugin (interfaces: [carb::messaging::IMessaging v0.3]) (impl: carb.messaging-omniclient.plugin)
2021-07-28 01:04:59 [317ms] [Info] [carb] Registered plugin: omni.client.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.client.plugin)
2021-07-28 01:04:59 [317ms] [Info] [carb] Registered plugin: carb.datasource-omniclient.plugin (interfaces: [carb::datasource::IDataSource v0.3],[carb::omniclient::IOmniClient v1.11]) (impl: carb.datasource-omniclient.plugin)
2021-07-28 01:04:59 [317ms] [Info] [carb] Initializing plugin: omni.client.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.client.plugin)
2021-07-28 01:04:59 [317ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] Starting ext::IExt in '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.client/bin/libomni.ext-client.plugin.so'
2021-07-28 01:04:59 [317ms] [Info] [omni.client.plugin]  Main: omniclient: Initializing Version 1.11.21-main.1924+tc.50eba982
2021-07-28 01:04:59 [318ms] [Info] [carb] Initializing plugin: carb.datasource-omniclient.plugin (interfaces: [carb::datasource::IDataSource v0.3],[carb::omniclient::IOmniClient v1.11]) (impl: carb.datasource-omniclient.plugin)
2021-07-28 01:04:59 [318ms] [Info] [carb] Initializing plugin: carb.tasking.plugin (interfaces: [carb::tasking::ITasking v1.6],[carb::tasking::IThreadPool v0.1]) (impl: carb.tasking.plugin)
2021-07-28 01:04:59 [323ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.appwindow-1.0.0] (order: 0) Triggered by: omni.kit.renderer.core-0.0.0, omni.kit.widget.fast_search-0.3.0, omni.kit.window.cursor-1.0.1, omni.kit.window.drop_support-1.0.0, omni.kit.window.title-1.1.0, omni.physx.cct-1.2.0-5.1, omni.ui-2.1.8
2021-07-28 01:04:59 [323ms] [Info] [omni.kit.app.plugin] [0.331s] [ext: omni.appwindow-1.0.0] startup
2021-07-28 01:04:59 [323ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.appwindow/bin' Filename: '*.plugin'
2021-07-28 01:04:59 [323ms] [Info] [carb] Registered plugin: carb.input.plugin (interfaces: [carb::input::IInput v1.0]) (impl: carb.input.plugin)
2021-07-28 01:04:59 [323ms] [Info] [carb] Registered plugin: carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v0.1],[carb::windowing::IWindowing v1.1]) (impl: carb.windowing-glfw.plugin)
2021-07-28 01:04:59 [323ms] [Info] [carb] Registered plugin: omni.appwindow.plugin (interfaces: [omni::ext::IExt v0.1],[omni::kit::IAppWindowFactory v2.0]) (impl: omni.appwindow.plugin)
2021-07-28 01:04:59 [323ms] [Info] [carb] Initializing plugin: omni.appwindow.plugin (interfaces: [omni::ext::IExt v0.1],[omni::kit::IAppWindowFactory v2.0]) (impl: omni.appwindow.plugin)
2021-07-28 01:04:59 [323ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-1.0.0] Starting ext::IExt in '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.appwindow/bin/libomni.appwindow.plugin.so'
2021-07-28 01:04:59 [323ms] [Info] [omni.appwindow.plugin] [Graphics API] Vulkan
2021-07-28 01:04:59 [323ms] [Info] [carb] Initializing plugin: carb.graphics-vulkan.plugin (interfaces: [carb::graphics::Graphics v1.17],[carb::ngx::Ngx v0.2]) (impl: carb.graphics-vulkan.plugin)
2021-07-28 01:04:59 [324ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_SDK_PATH =
2021-07-28 01:04:59 [324ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VULKAN_SDK =
2021-07-28 01:04:59 [324ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_LAYER_PATH =
2021-07-28 01:04:59 [324ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_INSTANCE_LAYERS =
2021-07-28 01:04:59 [324ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VULKAN_HEADERS_INSTALL_DIR =
2021-07-28 01:04:59 [324ms] [Info] [carb] Initializing plugin: carb.profiler.gpu.plugin (interfaces: [carb::profiler::IGpuProfiler v0.2]) (impl: carb.profiler.gpu.plugin)
2021-07-28 01:04:59 [324ms] [Info] [carb] Initializing plugin: carb.stats.plugin (interfaces: [carb::stats::IStats v0.2]) (impl: carb.stats.plugin)
2021-07-28 01:04:59 [324ms] [Info] [carb] Initializing plugin: carb.input.plugin (interfaces: [carb::input::IInput v1.0]) (impl: carb.input.plugin)
2021-07-28 01:04:59 [324ms] [Info] [carb] Initializing plugin: carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v0.1],[carb::windowing::IWindowing v1.1]) (impl: carb.windowing-glfw.plugin)
2021-07-28 01:04:59 [332ms] [Info] [omni.appwindow.plugin] Created window: width=1440,height=900.
2021-07-28 01:04:59 [335ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.renderer.core-0.0.0] (order: 0) Triggered by: omni.isaac.window.about-1.0.0, omni.kit.renderer.capture-0.0.0, omni.kit.uiapp-0.0.0,
2021-07-28 01:04:59 [335ms] [Info] [omni.kit.app.plugin] [0.343s] [ext: omni.kit.renderer.core-0.0.0] startup
2021-07-28 01:04:59 [335ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.renderer.core/bin' Filename: '*.plugin'
2021-07-28 01:04:59 [335ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.shadercompiler-slang.plugin'
2021-07-28 01:04:59 [336ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'gpu.foundation'
2021-07-28 01:04:59 [336ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.blockcompression.plugin'
2021-07-28 01:04:59 [337ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.cudainterop.plugin'
2021-07-28 01:04:59 [337ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.glinterop.plugin'
2021-07-28 01:04:59 [337ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.imgui.plugin'
2021-07-28 01:04:59 [338ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.imguizmo.plugin'
2021-07-28 01:04:59 [338ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins' Filename: 'omni.ui.windowmanager.plugin'
2021-07-28 01:04:59 [339ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins' Filename: 'omni.ui.glyphmanager.plugin'
2021-07-28 01:04:59 [339ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.svg-nanosvg.plugin'
2021-07-28 01:04:59 [339ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/carb_gfx' Filename: 'carb.xr.plugin'
2021-07-28 01:04:59 [340ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx' Filename: 'rtx.xrtools.plugin'
2021-07-28 01:04:59 [340ms] [Info] [carb] Registered plugin: omni.kit.renderer.plugin (interfaces: [omni::kit::renderer::IGpuFoundation v0.2],[omni::kit::renderer::IRenderer v1.0]) (impl: omni.kit.renderer.plugin)
2021-07-28 01:04:59 [340ms] [Info] [carb] Registered plugin: omni.kit.imgui_renderer_test.plugin (interfaces: [omni::kit::renderer::IImGuiRendererTest v0.1]) (impl: omni.kit.imgui_renderer_test.plugin)
2021-07-28 01:04:59 [340ms] [Info] [carb] Registered plugin: omni.kit.renderer.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.renderer.ext.plugin)
2021-07-28 01:04:59 [341ms] [Info] [carb] Registered plugin: omni.kit.imgui_renderer.plugin (interfaces: [omni::kit::renderer::IImGuiRenderer v1.0]) (impl: omni.kit.imgui_renderer.plugin)
2021-07-28 01:04:59 [341ms] [Info] [carb] Registered plugin: omni.kit.renderer_test.plugin (interfaces: [omni::kit::renderer::IRendererTest v0.1]) (impl: omni.kit.renderer_test.plugin)
2021-07-28 01:04:59 [341ms] [Info] [carb] Registered plugin: carb.shadercompiler-slang.plugin (interfaces: [carb::shadercompiler::ShaderCompiler v0.5]) (impl: carb.shadercompiler-slang.plugin)
2021-07-28 01:04:59 [341ms] [Info] [carb] Registered plugin: gpu.foundation.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9],[gpu::foundation::GpuFoundation v0.1],[rtx::psodb::PsoDb v0.2],[rtx::rendergraph::RenderGraphBuilder v0.6],[rtx::resourcemanager::ResourceManager v0.13],[rtx::shaderdb::ShaderDb v0.7]) (impl: gpu.foundation.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.blockcompression.plugin (interfaces: [carb::blockcompression::BlockCompression v0.1]) (impl: carb.blockcompression.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.cudainterop.plugin (interfaces: [carb::cudainterop::CudaInterop v0.4]) (impl: carb.cudainterop.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.glinterop.plugin (interfaces: [carb::glinterop::GLInterop v0.1]) (impl: carb.glinterop.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.imgui.plugin (interfaces: [carb::imgui::ImGui v1.0]) (impl: carb.imgui.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.imguizmo.plugin (interfaces: [carb::imguizmo::ImGuizmo v1.0]) (impl: carb.imguizmo.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: omni.ui.windowmanager.plugin (interfaces: [omni::ui::windowmanager::IWindowCallbackManager v0.3]) (impl: omni.ui.windowmanager.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: omni.ui.glyphmanager.plugin (interfaces: [omni::ui::IGlyphManager v1.0]) (impl: omni.ui.glyphmanager.plugin)
2021-07-28 01:04:59 [342ms] [Info] [carb] Registered plugin: carb.svg.plugin (interfaces: [carb::svg::Svg v0.1]) (impl: carb.svg.plugin)
2021-07-28 01:04:59 [343ms] [Info] [carb] Registered plugin: carb.xr.plugin (interfaces: [carb::xr::XRContext v0.5]) (impl: carb.xr.plugin)
2021-07-28 01:04:59 [343ms] [Info] [carb] Registered plugin: rtx.xrtools.plugin (interfaces: [rtx::xrtools::XRTools v0.1]) (impl: rtx.xrtools.plugin)
2021-07-28 01:04:59 [343ms] [Info] [carb] Initializing plugin: omni.kit.renderer.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.renderer.ext.plugin)
2021-07-28 01:04:59 [343ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] Starting ext::IExt in '/home/victor/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.renderer.core/bin/libomni.kit.renderer.ext.plugin.so'
2021-07-28 01:04:59 [343ms] [Info] [carb] Initializing plugin: omni.kit.renderer.plugin (interfaces: [omni::kit::renderer::IGpuFoundation v0.2],[omni::kit::renderer::IRenderer v1.0]) (impl: omni.kit.renderer.plugin)
2021-07-28 01:04:59 [343ms] [Info] [carb] Initializing plugin: omni.kit.imgui_renderer.plugin (interfaces: [omni::kit::renderer::IImGuiRenderer v1.0]) (impl: omni.kit.imgui_renderer.plugin)
2021-07-28 01:04:59 [343ms] [Info] [omni.kit.renderer.plugin] Added dataSource connection for prefix '/'
2021-07-28 01:04:59 [343ms] [Info] [carb] Initializing plugin: gpu.foundation.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9],[gpu::foundation::GpuFoundation v0.1],[rtx::psodb::PsoDb v0.2],[rtx::rendergraph::RenderGraphBuilder v0.6],[rtx::resourcemanager::ResourceManager v0.13],[rtx::shaderdb::ShaderDb v0.7]) (impl: gpu.foundation.plugin)
2021-07-28 01:04:59 [365ms] [Info] [carb.graphics-vulkan.plugin] Instance extension VK_KHR_get_physical_device_properties2 required by NGX.
2021-07-28 01:04:59 [517ms] [Info] [carb.graphics-vulkan.plugin] Active GPU: NVIDIA GeForce RTX 3090
2021-07-28 01:04:59 [525ms] [Info] [carb.graphics-vulkan.plugin] Device extension VK_NVX_binary_import required by NGX.
2021-07-28 01:04:59 [525ms] [Info] [carb.graphics-vulkan.plugin] Device extension VK_NVX_image_view_handle required by NGX.
2021-07-28 01:04:59 [525ms] [Info] [carb.graphics-vulkan.plugin] Device extension VK_EXT_buffer_device_address required by NGX.
2021-07-28 01:04:59 [525ms] [Info] [carb.graphics-vulkan.plugin] Device extension VK_KHR_push_descriptor required by NGX.
2021-07-28 01:05:00 [1,188ms] [Info] [gpu.foundation.plugin]
| Driver Version: 470.57      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 3090          | Yes    |     | 24822   MB | 10de      | 0          |
|     |                                  |        |     |            | 2204      | fbee9bba.. |
| OS: Linux iman-desktop, Version: 5.4.0-80-generic
| Processor: AMD Ryzen Threadripper 3960X 24-Core Processor  | Cores: Unknown | Logical: 48
| Total Memory (MB): 257675 | Free Memory: 167409
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2021-07-28 01:05:00 [1,188ms] [Info] [carb] Initializing plugin: carb.assets.plugin (interfaces: [carb::assets::IAssets v1.0],[carb::assets::IAssetsBlob v0.1]) (impl: carb.assets.plugin)
2021-07-28 01:05:00 [1,188ms] [Info] [carb] Initializing plugin: carb.datasource-file.plugin (interfaces: [carb::datasource::IDataSource v0.3]) (impl: carb.datasource-file.plugin)
2021-07-28 01:05:00 [1,188ms] [Info] [carb] Initializing plugin: carb.imaging.plugin (interfaces: [carb::imaging::IImaging v0.4]) (impl: carb.imaging.plugin)
2021-07-28 01:05:00 [1,188ms] [Info] [carb] Initializing plugin: carb.cudainterop.plugin (interfaces: [carb::cudainterop::CudaInterop v0.4]) (impl: carb.cudainterop.plugin)
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 0 to 1 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 0 to 2 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 0 to 3 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 1 to 0 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 1 to 2 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 1 to 3 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 2 to 0 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 2 to 1 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 2 to 3 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 3 to 0 is NOT supported.
2021-07-28 01:05:00 [1,192ms] [Info] [carb.cudainterop.plugin] Peer access from 3 to 1 is NOT supported.
2021-07-28 01:05:00 [1,193ms] [Info] [carb.cudainterop.plugin] Peer access from 3 to 2 is NOT supported.
2021-07-28 01:05:00 [1,193ms] [Info] [carb] Initializing plugin: carb.glinterop.plugin (interfaces: [carb::glinterop::GLInterop v0.1]) (impl: carb.glinterop.plugin)
X Error of failed request:  GLXBadFBConfig
  Major opcode of failed request:  150 (GLX)
  Minor opcode of failed request:  34 ()
  Serial number of failed request:  224
  Current serial number in output stream:  222
Here are my log files. Would greatly appreciate it if someone can help.
kit_20210727_180523.log (64.0 KB)
launcher.log (76.7 KB)
Hi, did you check the documentation ? I can see the error here on Q8 : Linux Troubleshooting — Omniverse Nucleus documentation (nvidia.com).
I would advise you to use the .sh from Nvidia’s support to install the drivers.
Hi, do you see the same error when running Create app?
When I click on launch to run Create app, it shows the loading screen.
Running /home/victor/.local/share/ov/pkg/create-2021.3.1/omni.create.sh -v in the terminal gives the same lauding screen, and below is the terminal output:
terminal_output.txt (187.8 KB)
and
  Serial number of failed request:  232
  Current serial number in output stream:  230
Here is the log file after running Create:
kit_20210728_143340.log (187.1 KB)
Thank you
Do you have a display connected and is this on a remote machine?
Please see Q8 and Q6 of the troubleshooting guide that @Danny_Sauval posted.
https://docs.omniverse.nvidia.com/prod_kit/prod_kit/linux-troubleshooting.html#q6-startup-failure-with-glfw-initialization-failed
I am using my display for this machine and I am connecting to it using Microsoft Remote Desktop.
I just reach Q6. Is there a way to let it work without plugging the display directly into the GPU?
I’m afraid it’s currently not supported. An alternative is to use the livestreaming method.
where can I find the .sh file to install the drivers.
I normally use the .run file for here NVIDIA DRIVERS Linux x64 (AMD64/EM64T) Display Driver
Yes, those drivers will work.
