I can't log in to isaac sim from omniverse launcher
Hello.
Can somebody help me.
When launching isaac sim from omniverse launcher, the following error is displayed and it stops.
[12.159s] [ext: omni.isaac.sim.launcher-2021.1.1] shutdown
[12.159s] [ext: omni.isaac.app.launcher-1.0.0] shutdown
[12.162s] [ext: omni.kit.window.title-1.1.0] shutdown
[12.164s] [ext: omni.usd-1.4.2] shutdown
[12.178s] [ext: omni.usd.schema.physics-1.0.0] shutdown
[12.180s] [ext: carb.audio-0.1.0] shutdown
[12.180s] [ext: omni.kit.uiapp-0.0.0] shutdown
[12.180s] [ext: omni.kit.mainwindow-0.0.0] shutdown
[12.181s] [ext: omni.ui-2.1.8] shutdown
[12.182s] [ext: omni.kit.renderer.core-0.0.0] shutdown
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.webrtc.png' is not released correctly and cause leak.
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.kitremote.png' is not released correctly and cause leak.
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.websocket.png' is not released correctly and cause leak.
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Texture:'/tmp/carb.HHSeOS/copy.26x26.png' is not released correctly and cause leak.
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.png' is not released correctly and cause leak.
2021-07-13 09:22:31 [12,399ms] [Warning] [gpu.foundation.plugin] Release above leaking textures on exit.
[12.429s] [ext: omni.appwindow-1.0.0] shutdown
[12.430s] [ext: omni.client-0.1.0] shutdown
[12.441s] [ext: omni.assets.plugins-0.0.0] shutdown
[12.441s] [ext: omni.hydra.scene_delegate-0.1.0] shutdown
[12.441s] [ext: omni.kit.test-0.0.0] shutdown
[12.442s] [ext: omni.kit.async_engine-0.0.0] shutdown
[12.443s] [ext: omni.kit.commands-0.0.0] shutdown
[12.445s] [ext: omni.kit.loop-default-0.1.0] shutdown
[12.445s] [ext: omni.kit.pip_archive-0.0.0] shutdown
[12.447s] [ext: omni.kit.pipapi-0.0.0] shutdown
[12.448s] [ext: omni.stats-0.0.0] shutdown
[12.449s] [ext: omni.timeline-1.0.0] shutdown
[12.450s] [ext: omni.usd.schema.audio-0.0.0] shutdown
[12.455s] [ext: omni.usd.schema.semantics-0.0.0] shutdown
[12.456s] [ext: omni.usd.schema.anim-0.0.0] shutdown
[12.457s] [ext: omni.usd.libs-1.0.0] shutdown
[12.459s] [ext: omni.usd.config-1.0.0] shutdown
~ / .local / share / ov / pkg / isaac_sim-2021.1.1
It can be started if it is executed manually from within.
Can anyone please tell me the reason for this?
 sudo ./isaac-sim.sh --allow-root
Thank you.
Could you provide the full terminal output please ? There is no error in the current output (only warnings) which occurs after the shutdown signal. There must be something occurring before ?
Thank you for your reply!
I’m sorry, the error part was missing in the output.
The complete output is:
[Info] [carb] Logging to file: /home/demulab/.nvidia-omniverse/logs/Kit/Isaac-Sim_App_Launcher/2021.1/kit_20210714_154229.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.010s] Loading user config located at: '/home/demulab/.local/share/ov/data/Kit/Isaac-Sim_App_Launcher/2021.1/user.config.json'
2021-07-14 06:42:29 [271ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr', ext 2: '/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr'
[0.286s] [ext: omni.kit.pipapi-0.0.0] startup
[0.293s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.298s] [ext: omni.isaac.app.launcher-1.0.0] startup
[0.304s] [ext: omni.usd.config-1.0.0] startup
[0.311s] [ext: omni.usd.libs-1.0.0] startup
[0.521s] [ext: omni.kit.async_engine-0.0.0] startup
[0.544s] [ext: omni.stats-0.0.0] startup
[0.547s] [ext: omni.assets.plugins-0.0.0] startup
[0.549s] [ext: omni.kit.loop-default-0.1.0] startup
[0.549s] [ext: omni.client-0.1.0] startup
[0.579s] [ext: omni.appwindow-1.0.0] startup
[0.855s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 460.67      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | GeForce RTX 2080 Ti              | Yes    |     | 11510   MB | 10de      | 0          |
|     |                                  |        |     |            | 1e07      | f27dfbc5.. |
| OS: Linux vega, Version: 5.4.0-77-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12008000 (1.20.8.0)
| Processor: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 32051 | Free Memory: 14367
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[2.442s] [ext: omni.kit.test-0.0.0] startup
[2.506s] [ext: omni.ui-2.1.8] startup
[2.519s] [ext: omni.kit.mainwindow-0.0.0] startup
[2.538s] [ext: omni.kit.uiapp-0.0.0] startup
[2.540s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.546s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.553s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.556s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.565s] [ext: omni.kit.commands-0.0.0] startup
[2.573s] [ext: carb.audio-0.1.0] startup
[2.575s] [ext: omni.timeline-1.0.0] startup
[2.578s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[2.586s] [ext: omni.usd-1.4.2] startup
[4.465s] [ext: omni.kit.window.title-1.1.0] startup
[4.469s] [ext: omni.isaac.sim.launcher-2021.1.1] startup
[4.469s] app started
2021-07-14 06:42:30 [867ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2021-07-14 06:42:30 [867ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2021-07-14 06:42:30 [867ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2021-07-14 06:42:30 [870ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2021-07-14 06:42:30 [870ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2021-07-14 06:42:30 [870ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2021-07-14 06:42:30 [992ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2021-07-14 06:42:30 [992ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-07-14 06:42:30 [994ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-07-14 06:42:30 [994ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-07-14 06:42:30 [995ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.ext.plugin.so!carbOnPluginPostShutdown
2021-07-14 06:42:30 [996ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [997ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2021-07-14 06:42:30 [998ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)
2021-07-14 06:42:30 [999ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,000ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] _extensions.cpython-37m-x86_64-linux-gnu.so!PyInit__extensions
2021-07-14 06:42:30 [1,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] _extensions.cpython-37m-x86_64-linux-gnu.so!std::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >::~basic_stringbuf()
2021-07-14 06:42:30 [1,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] _extensions.cpython-37m-x86_64-linux-gnu.so!std::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >::~basic_stringbuf()
2021-07-14 06:42:30 [1,008ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallKeywords
2021-07-14 06:42:30 [1,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallKeywords
2021-07-14 06:42:30 [1,010ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-07-14 06:42:30 [1,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-07-14 06:42:30 [1,012ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-07-14 06:42:30 [1,013ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-07-14 06:42:30 [1,014ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-07-14 06:42:30 [1,015ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-07-14 06:42:30 [1,016ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-07-14 06:42:30 [1,017ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-07-14 06:42:30 [1,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-07-14 06:42:30 [1,019ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-07-14 06:42:30 [1,020ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-07-14 06:42:30 [1,021ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-07-14 06:42:30 [1,022ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-07-14 06:42:30 [1,023ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-07-14 06:42:30 [1,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-07-14 06:42:30 [1,025ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-07-14 06:42:30 [1,026ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,027ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)
2021-07-14 06:42:30 [1,029ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,030ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-07-14 06:42:30 [1,031ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-07-14 06:42:30 [1,032ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-07-14 06:42:30 [1,032ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-07-14 06:42:30 [1,033ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-07-14 06:42:30 [1,033ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
[5.907s] [ext: omni.isaac.sim.launcher-2021.1.1] shutdown
[5.907s] [ext: omni.isaac.app.launcher-1.0.0] shutdown
[5.911s] [ext: omni.kit.window.title-1.1.0] shutdown
[5.914s] [ext: omni.usd-1.4.2] shutdown
[5.928s] [ext: omni.usd.schema.physics-1.0.0] shutdown
[5.930s] [ext: carb.audio-0.1.0] shutdown
[5.930s] [ext: omni.kit.uiapp-0.0.0] shutdown
[5.930s] [ext: omni.kit.mainwindow-0.0.0] shutdown
[5.932s] [ext: omni.ui-2.1.8] shutdown
[5.940s] [ext: omni.kit.renderer.core-0.0.0] shutdown
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Texture:'/tmp/carb.WFqokQ/copy.26x26.png' is not released correctly and cause leak.
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.webrtc.png' is not released correctly and cause leak.
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.kitremote.png' is not released correctly and cause leak.
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.headless.websocket.png' is not released correctly and cause leak.
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Texture:'/home/demulab/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher/icons/omni.isaac.sim.png' is not released correctly and cause leak.
2021-07-14 06:40:23 [6,059ms] [Warning] [gpu.foundation.plugin] Release above leaking textures on exit.
[6.113s] [ext: omni.appwindow-1.0.0] shutdown
[6.115s] [ext: omni.client-0.1.0] shutdown
[6.117s] [ext: omni.assets.plugins-0.0.0] shutdown
[6.117s] [ext: omni.hydra.scene_delegate-0.1.0] shutdown
[6.117s] [ext: omni.kit.test-0.0.0] shutdown
[6.118s] [ext: omni.kit.async_engine-0.0.0] shutdown
[6.119s] [ext: omni.kit.commands-0.0.0] shutdown
[6.120s] [ext: omni.kit.loop-default-0.1.0] shutdown
[6.120s] [ext: omni.kit.pip_archive-0.0.0] shutdown
[6.122s] [ext: omni.kit.pipapi-0.0.0] shutdown
[6.125s] [ext: omni.stats-0.0.0] shutdown
[6.126s] [ext: omni.timeline-1.0.0] shutdown
[6.127s] [ext: omni.usd.schema.audio-0.0.0] shutdown
[6.128s] [ext: omni.usd.schema.semantics-0.0.0] shutdown
[6.129s] [ext: omni.usd.schema.anim-0.0.0] shutdown
[6.130s] [ext: omni.usd.libs-1.0.0] shutdown
[6.131s] [ext: omni.usd.config-1.0.0] shutdown
This is the full text.
Thank you.
Hi mri_y
What is your OS? it seems you are not on Ubuntu 18.04
Kindly,
Liila
My os is ubuntu 18.04.
When I checked the version, 18.04 was included.
However, this launcher file is manually output from within .local by the following method.
sudo  ./.local/share/ov/pkg/isaac_sim-2021.1.1/isaac-sim.sh --allow-root
Also, I use omniverse-launcher-linux.AppImage, even if you press launch, it will not proceed at all.
Can you see why omniverse can’t recognize Ubuntu 18.04?
Thank you.
Hi, try adding --allow-root in the Extra Args text box in the App Launcher then click Launch.
Sorry for my late reply.
When I wrote --allow-root to [ExtraArgs], I was able to launch successfully.
You came up with a great idea!
Thank you.
