Nvidia Issac sim failing to start in Pop!_os 21.04
hello - I downloaded Omniverse Issac Sim and on starting it I get fatal logs and the application crashes.
These are the logs:
[Info] [carb] Logging to file: /home/satoshi/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20211015_151941.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.007s] Loading user config located at: '/home/satoshi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/user.config.json'
2021-10-15 09:49:41 [71ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/satoshi/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr', ext 2: '/home/satoshi/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr'
[0.082s] [ext: omni.usd.config-1.0.0] startup
[0.083s] [ext: omni.usd.libs-1.0.0] startup
[0.251s] [ext: omni.kit.pipapi-0.0.0] startup
[0.256s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.260s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.263s] [ext: omni.hydra.iray-0.1.0] startup
[0.267s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.272s] [ext: omni.kit.loop-default-0.1.0] startup
[0.272s] [ext: omni.kit.async_engine-0.0.0] startup
[0.282s] [ext: omni.stats-0.0.0] startup
[0.284s] [ext: omni.assets.plugins-0.0.0] startup
[0.286s] [ext: omni.appwindow-1.0.0] startup
[0.296s] [ext: omni.client-0.1.0] startup
[0.305s] [ext: omni.kit.test-0.0.0] startup
[0.319s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 470.63      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 3070 Laptop.. | Yes    |     | 8192    MB | 10de      | 0          |
|     |                                  |        |     |            | 249d      | 79efd99c.. |
| 1   | AMD RADV RENOIR                  |        |     | 2389    MB | 1002      | 0          |
|     |                                  |        |     |            | 1638      | 00000000.. |
| OS: Linux pop-os, Version: 5.13.9-051309-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12011000 (1.20.11.0)
| Processor: AMD Ryzen 9 5900HX with Radeon Graphics         | Cores: Unknown | Logical: 16
| Total Memory (MB): 15417 | Free Memory: 2366
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
[0.985s] [ext: omni.ui-2.1.8] startup
[1.003s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.007s] [ext: omni.kit.uiapp-0.0.0] startup
[1.007s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.015s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.034s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.048s] [ext: omni.usd.schema.isaac-0.1.0] startup
[1.072s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.084s] [ext: carb.audio-0.1.0] startup
[1.104s] [ext: omni.timeline-1.0.0] startup
[1.107s] [ext: omni.kit.commands-0.0.0] startup
[1.113s] [ext: omni.kvdb-0.0.0] startup
[1.117s] [ext: omni.usd-1.4.2] startup
[1.417s] [ext: omni.localcache-0.0.0] startup
[1.420s] [ext: omni.kit.window.drop_support-1.0.0] startup
[1.422s] [ext: omni.convexdecomposition-1.2.0] startup
[1.426s] [ext: omni.usdphysics-1.2.0] startup
[1.427s] [ext: omni.kit.menu.utils-1.0.1] startup
[1.437s] [ext: omni.physx-1.2.0-5.1] startup
2021-10-15 09:49:42 [1,530ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-10-15 09:49:42 [1,532ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!gsignal
2021-10-15 09:49:42 [1,534ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!abort
2021-10-15 09:49:42 [1,535ms] [Fatal] [carb.crashreporter-breakpad.plugin] libffi.so.8!+0x2452
2021-10-15 09:49:42 [1,535ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!PyInit__ctypes
2021-10-15 09:49:42 [1,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyLong_Fini
2021-10-15 09:49:42 [1,539ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyDict_Contains
2021-10-15 09:49:42 [1,539ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!_init
2021-10-15 09:49:42 [1,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyType_GenericAlloc
2021-10-15 09:49:42 [1,543ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,545ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,547ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,549ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,551ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-15 09:49:42 [1,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-15 09:49:42 [1,555ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyAST_ExprAsUnicode
2021-10-15 09:49:42 [1,556ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-15 09:49:42 [1,558ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-15 09:49:42 [1,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,562ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:42 [1,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,568ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,570ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,572ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,574ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,576ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,578ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,580ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,582ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-10-15 09:49:42 [1,584ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodId_SizeT
2021-10-15 09:49:42 [1,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-10-15 09:49:42 [1,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-10-15 09:49:42 [1,589ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,591ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-15 09:49:42 [1,595ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-15 09:49:42 [1,597ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyAST_ExprAsUnicode
2021-10-15 09:49:42 [1,599ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-15 09:49:42 [1,601ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-15 09:49:42 [1,603ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,606ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:42 [1,608ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,612ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,614ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,616ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,622ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:42 [1,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-10-15 09:49:42 [1,626ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodId_SizeT
2021-10-15 09:49:42 [1,627ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-10-15 09:49:42 [1,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-10-15 09:49:42 [1,631ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,633ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,635ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-15 09:49:42 [1,637ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-15 09:49:42 [1,639ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyAST_ExprAsUnicode
2021-10-15 09:49:42 [1,641ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-15 09:49:42 [1,642ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-15 09:49:42 [1,644ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,646ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:42 [1,648ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:42 [1,650ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:42 [1,652ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:43 [1,654ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,656ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:43 [1,658ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,659ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:43 [1,661ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,663ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:43 [1,665ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,667ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,669ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,671ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,673ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,674ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,676ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,678ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2021-10-15 09:49:43 [1,680ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,682ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,684ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,686ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,688ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,689ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,691ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,693ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,695ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,697ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,699ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,701ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-15 09:49:43 [1,702ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-15 09:49:43 [1,704ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-15 09:49:43 [1,706ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-15 09:49:43 [1,708ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-15 09:49:43 [1,710ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-10-15 09:49:43 [1,712ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-10-15 09:49:43 [1,714ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-15 09:49:43 [1,715ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-15 09:49:43 [1,717ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)
2021-10-15 09:49:43 [1,719ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-15 09:49:43 [1,721ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-15 09:49:43 [1,723ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-10-15 09:49:43 [1,725ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-10-15 09:49:43 [1,725ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-10-15 09:49:43 [1,727ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-10-15 09:49:43 [1,727ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Aborted (core dumped)
My system meets the system requirements. Here is my neofetch for details:
             /////////////                satoshi@pop-os
      ///////*767////////////////         OS: Pop!_OS 21.04 x86_64
    //////7676767676*//////////////       Host: ROG Strix G513QR_G513QR 1.0
   /////76767//7676767//////////////      Kernel: 5.13.9-051309-generic
  /////767676///*76767///////////////     Uptime: 14 hours, 18 mins
 ///////767676///76767.///7676*///////    Packages: 2436 (dpkg), 49 (flatpak), 4 (snap)
/////////767676//76767///767676////////   Shell: bash 5.1.4
//////////76767676767////76767/////////   Resolution: 1920x1080
///////////76767676//////7676//////////   DE: GNOME 3.38.4
////////////,7676,///////767///////////   WM: Mutter
/////////////*7676///////76////////////   WM Theme: Pop
///////////////7676////////////////////   Theme: Nordic-darker [GTK2/3]
 ///////////////7676///767////////////    Icons: Nordic-Darker [GTK2/3]
  //////////////////////'////////////     Terminal: deepin-terminal
   //////.7676767676767676767,//////      Terminal Font: DejaVu Sans Mono 11
    /////767676767676767676767/////       CPU: AMD Ryzen 9 5900HX with Radeon Graphics (16) @ 3.300GHz
      ///////////////////////////         GPU: AMD ATI 05:00.0 Cezanne
         /////////////////////            GPU: NVIDIA GeForce RTX 3070 Mobile / Max-Q
             /////////////                Memory: 5515MiB / 15417MiB
How do I fix this? Am I missing some dependencies?
Same [Fatal] error messages here on my side (Ubuntu 21.04, RTX A5000) - see appended console output. error_msgs (17.9 KB)
Help would be highly appreciated!
Hi, we support Ubuntu 18.04 with partial support of Ubuntu 20.04 on this current version.
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/requirements.html
