I want to open usd file that I saved last time, but failed. sometimes is shows error log in the terminal.
> DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
> terminate called after throwing an instance of 'NvOFException'
> what(): DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
> 2023-05-14 03:38:24 [14,579ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
> 2023-05-14 03:38:24 [14,579ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
> 2023-05-14 03:38:24 [14,579ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip' for upload.
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip' svr:'https://services.nvidia.com/submit'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1684035489'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '15'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'New_extention-1.0.0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '530.41'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 44.5269/62.6444GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] stageUrl = '/home/petrus/simWorkspace/myfirstsim.usd'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
> | Driver Version: 530.41.03 | Graphics API: Vulkan
> | GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
> | | | | | | Device-ID | UUID |
> | 0 | NVIDIA GeForce RTX 4070 | Yes: 0 | | 12528 MB | 10de | 0 |
> | | | | | | 2786 | 56206a93.. |
> | OS: Linux petrus-Z790-UD, Version: 5.19.0-41-generic
> | XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
> | Processor: 13th Gen Intel(R) Core(TM) i7-13700KF | Cores: Unknown | Logical: 24
> | Total Memory (MB): 64147 | Free Memory: 50512
> | Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '15768585498905110097'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = '782365867@qq.com'
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
> 2023-05-14 03:38:24 [14,772ms] [Warning] [carb.crashreporter-breakpad.plugin] upload_file_minidump = '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip'
> 2023-05-14 03:38:26 [16,812ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip', code:200, response:
> 2023-05-14 03:38:26 [16,812ms] [Warning] [carb.crashreporter-breakpad.plugin] 00000187348fe6bd-162ced
> 2023-05-14 03:38:26 [16,812ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
> 2023-05-14 03:38:26 [16,812ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4.dmp.zip'
> 2023-05-14 03:38:26 [16,812ms] [Error] [carb.crashreporter-breakpad.plugin] the dump file was deleted due to a successful upload. Its originalsize was 503967 bytes and was readable.
> 2023-05-14 03:38:26 [16,813ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 23372 thread 23372
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'b4fc32a9-6020-4c3d-1d4a69a0-ba0af5f4'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1684035489'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '15'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'New_extention-1.0.0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '530.41'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 44.5269/62.6444GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] stageUrl = '/home/petrus/simWorkspace/myfirstsim.usd'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
> | | | | | | Device-ID | UUID |
> | | | | | | 2786 | 56206a93.. |
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '15768585498905110097'
> 2023-05-14 03:38:26 [16,813ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = '782365867@qq.com'
> 2023-05-14 03:38:26 [16,813ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 23372 backtrace follows:
> 2023-05-14 03:38:26 [16,919ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
> 2023-05-14 03:38:26 [17,019ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!pthread_kill+0x12c (./nptl/pthread_kill.c:44)
> 2023-05-14 03:38:26 [17,118ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!raise+0x16 (./signal/../sysdeps/posix/raise.c:27)
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libc.so.6!abort+0xd3 (./stdlib/abort.c:81 (discriminator 21))
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: 192!+0x102905
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: 192!+0x100e66
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: 192!+0x100ea1
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: 192!+0x100d03
> 2023-05-14 03:38:26 [17,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: 192!+0xf9be2
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: 192!+0xf593f
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: 192!+0xfab47
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: 192!+0xd1690
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: 192!+0xd4110
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: 192!+0xb55c8
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: 192!+0x92cdd
> 2023-05-14 03:38:26 [17,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: 192!+0x6e9cd
> 2023-05-14 03:38:27 [17,289ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x7187 (??:?)
> 2023-05-14 03:38:27 [17,358ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x640e (??:?)
> 2023-05-14 03:38:27 [17,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: librtx.postprocessing.plugin.so!_init+0x1de80 (??:0)
> 2023-05-14 03:38:27 [17,495ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: librtx.postprocessing.plugin.so!_init+0x2027a (??:0)
> 2023-05-14 03:38:27 [17,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: librtx.postprocessing.plugin.so!_init+0x207c3 (??:0)
> 2023-05-14 03:38:27 [17,634ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0xdb39 (??:?)
> 2023-05-14 03:38:27 [17,703ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x142be (??:?)
> 2023-05-14 03:38:27 [17,773ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1b4c9 (??:?)
> 2023-05-14 03:38:27 [17,842ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1bb63 (??:?)
> 2023-05-14 03:38:27 [17,911ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4a7db (??:?)
> 2023-05-14 03:38:27 [17,981ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4e21b (??:?)
> 2023-05-14 03:38:27 [18,051ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.scenerenderer-rtx.plugin.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned int, false>*)+0x1a917 (??:?)
> 2023-05-14 03:38:27 [18,120ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0x78e4 (??:?)
> 2023-05-14 03:38:27 [18,188ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0xae01 (??:?)
> 2023-05-14 03:38:27 [18,257ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x5e7a (??:?)
> 2023-05-14 03:38:28 [18,327ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xbfe1 (??:?)
> 2023-05-14 03:38:28 [18,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xc9c6 (??:?)
> 2023-05-14 03:38:28 [18,465ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xcf41 (??:?)
> 2023-05-14 03:38:28 [18,535ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.usd.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)+0x4f9f (??:?)
> 2023-05-14 03:38:28 [18,606ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x188c (??:?)
> 2023-05-14 03:38:28 [18,676ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x2026 (??:?)
> 2023-05-14 03:38:28 [18,746ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0x8ac (??:?)
> 2023-05-14 03:38:28 [18,816ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0xe8e3 (??:?)
> 2023-05-14 03:38:28 [18,886ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libomni.kit.app.plugin.so!_init+0x28c7 (??:0)
> 2023-05-14 03:38:28 [18,958ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x907 (??:?)
> 2023-05-14 03:38:28 [19,025ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: kit!_init+0x635 (??:0)
> 2023-05-14 03:38:28 [19,123ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
> 2023-05-14 03:38:28 [19,222ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
> 2023-05-14 03:38:29 [19,290ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: kit!_init+0x9cb (??:0)
then the app is stoped.
and sometimes it shows "isaac sim " is not responding in the GUI like picture below.
maybe there was a error when I launched the isaac sim APP,but I don’t known how to solve the problem.
[Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file: '/home/petrus/.local/share/ov/data/Kit/Isaac-Sim/2022.2/54242a82-865d-4868-b1dea1bc-dcfd2e7b.dmp.zip', code: 0, error: 'Couldn't resolve proxy name', response:
[Error] [carb.crashreporter-breakpad.plugin] {status = SendFailed (5)}
