Why doesn't the new version of Isaac Sim work?
My graphics card is an RTX 3070 Ti with 8GB of video memory and the driver version is 566.36. After I installed Isaac Sim version 4.5 according to the official documentation, the following error message occurred:
| Driver Version: 566.36        | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 3070 Ti       | Yes: 0 |     | 8017    MB | 10de      | 9d030100.. |
|     |                                  |        |     |            | 2207      | fe26783f.. |
|     |                                  |        |     |            | 1         |            |
| OS: Windows 11 Pro, Version: 10.0 (23H2), Build: 22631, Kernel: 10.0.22621.4890
| Processor: 13th Gen Intel(R) Core(TM) i7-13700KF
| Cores: 16 | Logical Cores: 24
| Total Memory (MB): 32581 | Free Memory: 21826
| Total Page/Swap (MB): 41957 | Free Page/Swap: 25764
[1.196s] [ext: omni.ui-2.26.5] startup
[1.209s] [ext: omni.kit.mainwindow-1.0.3] startup
[1.212s] [ext: carb.audio-0.1.0] startup
[1.213s] [ext: omni.uiaudio-1.0.0] startup
[1.217s] [ext: omni.kit.uiapp-0.0.0] startup
[1.217s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[1.224s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.230s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.234s] [ext: isaacsim.robot.schema-3.1.2] startup
[1.241s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.247s] [ext: omni.anim.graph.schema-106.5.0] startup
[1.253s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.269s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.273s] [ext: omni.usd_resolver-1.0.0] startup
[1.277s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[1.282s] [ext: usdrt.scenegraph-7.5.1] startup
[1.321s] [ext: omni.timeline-1.0.11] startup
[1.324s] [ext: omni.usd.core-1.4.2] startup
[1.325s] [ext: omni.resourcemonitor-107.0.0] startup
[1.328s] [ext: omni.activity.core-1.0.1] startup
[1.330s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[1.333s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[1.343s] [ext: omni.kit.actions.core-1.0.0] startup
[1.346s] [ext: omni.graph.exec-0.9.4] startup
[1.348s] [ext: omni.kit.commands-1.4.9] startup
[1.353s] [ext: omni.kit.usd_undo-0.1.8] startup
[1.354s] [ext: omni.kit.exec.core-0.13.4] startup
[1.357s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[1.359s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[1.362s] [ext: omni.usd-1.12.4] startup
[1.400s] [ext: omni.inspect-1.0.1] startup
[1.402s] [ext: omni.kit.notification_manager-1.0.9] startup
[1.405s] [ext: omni.graph.core-2.181.8] startup
[1.408s] [ext: isaacsim.core.deprecation_manager-0.2.2] startup
[1.416s] [ext: omni.usd.schema.forcefield-106.5.7] startup
[1.424s] [ext: omni.kit.asset_converter-2.8.3] startup
[1.434s] [ext: omni.usd.schema.isaac-3.0.2] startup
[1.434s] [ext: omni.anim.navigation.schema-106.4.0] startup
[1.439s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[1.442s] [ext: omni.usd.schema.physx-106.5.7] startup
[1.458s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.463s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[1.467s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[1.469s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[1.471s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[1.473s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[1.475s] [ext: omni.kit.widget.path_field-2.0.11] startup
[1.476s] [ext: omni.kit.search_core-1.0.6] startup
[1.478s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[1.486s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[1.490s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[1.491s] [ext: omni.graph.tools-1.79.1] startup
[1.516s] [ext: omni.kit.widget.search_delegate-1.0.6] startup
[1.518s] [ext: omni.kit.widget.options_button-1.0.3] startup
[1.520s] [ext: omni.kit.clipboard-1.0.5] startup
[1.522s] [ext: omni.graph-1.140.2] startup
[1.605s] [ext: omni.kit.menu.core-1.1.2] startup
[1.606s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[1.608s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[1.610s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[1.612s] [ext: omni.ui.scene-1.11.2] startup
[1.616s] [ext: omni.kit.widget.versioning-1.4.9] startup
[1.619s] [ext: omni.kit.usd.layers-2.2.0] startup
[1.626s] [ext: omni.kit.window.filepicker-2.11.7] startup
[1.639s] [ext: omni.kit.widget.filter-1.1.4] startup
[1.641s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[1.646s] [ext: omni.kit.context_menu-1.8.3] startup
[1.648s] [ext: omni.kit.window.file_importer-1.1.14] startup
[1.652s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[1.654s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[1.656s] [ext: omni.kit.stage_template.core-1.1.22] startup
[1.657s] [ext: omni.kit.widget.stage-2.11.6] startup
[1.669s] [ext: omni.hydra.engine.stats-1.0.3] startup
[1.671s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[1.672s] [ext: omni.kit.window.file-1.3.57] startup
[1.676s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[1.678s] [ext: omni.index.libs-380600.1777.0] startup
[1.678s] [ext: omni.volume-0.5.0] startup
[1.682s] [ext: omni.ujitso.client-0.0.0] startup
[1.683s] [ext: omni.index-1.0.1] startup
[1.684s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[1.686s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[1.687s] [ext: omni.hydra.rtx-1.0.0] startup
[1.706s] [ext: omni.kit.viewport.registry-104.0.6] startup
[1.708s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[1.709s] [ext: omni.kit.raycast.query-1.0.5] startup
[1.712s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[1.714s] [ext: omni.kit.hydra_texture-1.4.0] startup
[1.717s] [ext: omni.kit.menu.utils-1.7.7] startup
[1.722s] [ext: omni.kit.window.drop_support-1.0.4] startup
[1.724s] [ext: omni.kit.widget.viewport-107.0.7] startup
[1.729s] [ext: omni.kit.material.library-1.5.15] startup
[1.734s] [ext: omni.convexdecomposition-106.5.7] startup
[1.737s] [ext: omni.kit.viewport.window-107.0.8] startup
[1.981s] [ext: omni.kit.window.property-1.11.5] startup
[1.985s] [ext: omni.kit.window.content_browser-2.10.3] startup
2025-02-21 05:55:38 [1,938ms] [Warning] [omni.ext._impl._internal] Found class `WrappedClass` derived from `omni.ext.IExt` in module: 'omni.kit.window.content_browser', but it was imported from other extension: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/kit/kernel/py\omni\kit\app\_impl\__init__.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extscache\omni.kit.window.content_browser-2.10.3+d02c707b'. Do not import `IExt` derived class from other extension in your public namespace.
[2.000s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[2.002s] [ext: omni.kit.widget.prompt-1.0.7] startup
[2.004s] [ext: omni.kit.widget.settings-1.2.2] startup
[2.006s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[2.010s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[2.013s] [ext: omni.usdphysics-106.5.7] startup
[2.014s] [ext: omni.kvdb-106.5.7] startup
[2.017s] [ext: omni.kit.window.preferences-1.7.0] startup
[2.024s] [ext: omni.physx.foundation-106.5.7] startup
[2.033s] [ext: omni.localcache-106.5.7] startup
[2.036s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[2.039s] [ext: omni.physx.cooking-106.5.7] startup
[2.043s] [ext: omni.kit.viewport.utility-1.0.18] startup
[2.044s] [ext: omni.kit.property.usd-4.2.16] startup
[2.054s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[2.057s] [ext: omni.physx-106.5.7] startup
[2.067s] [ext: omni.ui_query-1.1.7] startup
[2.069s] [ext: omni.kit.window.extensions-1.4.25] startup
[2.076s] [ext: omni.graph.action_core-1.1.7] startup
[2.079s] [ext: isaacsim.core.version-2.0.2] startup
[2.080s] [ext: omni.graph.ui-1.91.0] startup
[2.101s] [ext: omni.physx.stageupdate-106.5.7] startup
[2.106s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.108s] [ext: isaacsim.storage.native-1.0.6] startup
[2.111s] [ext: omni.graph.action_nodes-1.40.1] startup
[2.114s] [ext: omni.isaac.dynamic_control-1.3.15] startup
2025-02-21 05:55:39 [2,069ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[2.124s] [ext: omni.kit.window.cursor-1.1.4] startup
[2.126s] [ext: omni.graph.image.core-0.6.0] startup
[2.128s] [ext: omni.physics.tensors-106.5.7] startup
[2.134s] [ext: omni.warp.core-1.5.0] startup
[2.263s] [ext: omni.graph.image.nodes-1.3.0] startup
[2.266s] [ext: omni.physx.tensors-106.5.7] startup
[2.270s] [ext: isaacsim.core.utils-2.2.8] startup
[2.278s] [ext: omni.graph.action-1.120.0] startup
[2.282s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[2.344s] [ext: omni.graph.nodes-1.162.1] startup
[2.354s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
[3.626s] [ext: omni.kit.widget.graph-1.12.17] startup
[3.633s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[3.635s] [ext: omni.warp-1.5.0] startup
[3.641s] [ext: omni.syntheticdata-0.6.10] startup
[3.674s] [ext: isaacsim.core.prims-0.3.7] startup
[3.740s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[3.744s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[3.766s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[3.773s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[3.783s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[3.797s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[3.804s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[3.817s] [ext: omni.kit.window.stage-2.5.11] startup
[3.826s] [ext: omni.kit.ui_test-1.3.3] startup
[3.831s] [ext: omni.kit.window.material_graph-1.8.19] startup
[3.887s] [ext: omni.kit.stage_templates-1.2.6] startup
[3.890s] [ext: omni.kit.menu.stage-1.2.5] startup
[3.892s] [ext: omni.graph.scriptnode-1.40.1] startup
[3.894s] [ext: isaacsim.gui.components-1.0.9] startup
[3.901s] [ext: isaacsim.core.api-4.2.16] startup
[3.918s] [ext: omni.replicator.core-1.11.35] startup
Warp 1.5.0 initialized:
   CUDA Toolkit 11.8, Driver 12.7
   Devices:
     "cpu"      : "Intel64 Family 6 Model 183 Stepping 1, GenuineIntel"
     "cuda:0"   : "NVIDIA GeForce RTX 3070 Ti" (8 GiB, sm_86, mempool enabled)
   Kernel cache:
     C:\Users\2022\AppData\Local\NVIDIA\warp\Cache\1.5.0
2025-02-21 05:55:40 [3,932ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[3.986s] [ext: isaacsim.robot_motion.lula-4.0.4] startup
[3.995s] [ext: isaacsim.robot.surface_gripper-2.0.6] startup
[4.003s] [ext: isaacsim.core.nodes-2.1.4] startup
[4.013s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[4.019s] [ext: isaacsim.robot_motion.motion_generation-8.0.6] startup
[4.033s] [ext: isaacsim.robot.manipulators-3.0.4] startup
[4.047s] [ext: omni.kit.usd.collect-2.2.22] startup
[4.067s] [ext: omni.kit.browser.core-2.3.11] startup
[4.099s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
[4.103s] [ext: omni.kit.tool.collect-2.2.16] startup
[4.125s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[4.158s] [ext: isaacsim.cortex.framework-1.0.2] startup
[4.164s] [ext: isaacsim.examples.browser-0.1.8] startup
[4.175s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[4.177s] [ext: isaacsim.sensors.physics-0.3.5] startup
[4.188s] [ext: omni.kit.menu.create-1.0.17] startup
[4.192s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
[4.200s] [ext: omni.kit.scripting-106.5.2] startup
[4.213s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
[4.225s] [ext: isaacsim.examples.extension-2.0.6] startup
[4.231s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[4.247s] [ext: isaacsim.examples.interactive-4.4.8] startup
[4.323s] [ext: isaacsim.sensors.physics.examples-0.1.4] startup
[4.330s] [ext: isaacsim.replicator.behavior.ui-1.0.1] startup
[4.343s] [ext: isaacsim.sensors.camera-0.2.9] startup
[4.364s] [ext: isaacsim.robot.manipulators.ui-2.1.4] startup
[4.367s] [ext: isaacsim.sensors.camera.ui-0.1.4] startup
[5.287s] [ext: omni.debugdraw-0.1.3] startup
[5.294s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[5.305s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[5.311s] [ext: omni.anim.navigation.core-106.4.0] startup
[5.316s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[5.323s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[5.325s] [ext: omni.anim.navigation.recast-106.4.0] startup
[5.330s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[5.332s] [ext: omni.kit.widget.imageview-1.0.3] startup
[5.333s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[5.336s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[5.338s] [ext: omni.fabric.commands-1.1.5] startup
[5.342s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[5.349s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[5.353s] [ext: omni.anim.shared.core-106.0.2] startup
[5.358s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[5.377s] [ext: omni.kit.actions.window-1.1.1] startup
[5.385s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[5.387s] [ext: omni.graph.window.core-1.130.1] startup
[5.399s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[5.400s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
[5.407s] [ext: omni.kit.hotkeys.window-1.4.8] startup
[5.414s] [ext: omni.kit.viewport.actions-107.0.0] startup
[5.419s] [ext: omni.graph.window.action-1.40.0] startup
[5.426s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[5.427s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[5.431s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[5.436s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[5.439s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[5.442s] [ext: omni.mdl.usd_converter-1.0.24] startup
[5.444s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[5.449s] [ext: omni.sensors.tiled-0.0.6] startup
[5.450s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[5.458s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[5.464s] [ext: isaacsim.asset.importer.heightmap-2.0.3] startup
[5.470s] [ext: isaacsim.sensors.rtx-13.6.3] startup
[5.477s] [ext: omni.kit.widget.layers-1.8.2] startup
[5.494s] [ext: omni.physx.commands-106.5.7] startup
[5.497s] [ext: omni.usdphysics.ui-106.5.7] startup
[5.520s] [ext: omni.kit.stage.mdl_converter-1.0.7] startup
[5.521s] [ext: omni.isaac.block_world-2.0.2] startup
2025-02-21 05:55:42 [5,472ms] [Warning] [omni.isaac.block_world] ['omni.isaac.block_world'] has been deprecated in favor of ['isaacsim.asset.importer.heightmap']. Please update your code accordingly.
2025-02-21 05:55:42 [5,472ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.block_world', but it was imported from other extension: 'd:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.asset.importer.heightmap/isaacsim/asset/importer/heightmap/block_world.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extsdeprecated\omni.isaac.block_world'. Do not import `IExt` derived class from other extension in your public namespace.
[5.524s] [ext: isaacsim.sensors.rtx.ui-0.1.2] startup
2025-02-21 05:55:42 [5,476ms] [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path d:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.sensors.rtx\data\lidar_configs
[6.135s] [ext: isaacsim.sensors.physics.ui-0.1.2] startup
[6.140s] [ext: omni.physx.ui-106.5.7] startup
[6.162s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[6.167s] [ext: omni.importer.onshape-0.8.1] startup
[6.183s] [ext: isaacsim.robot_setup.gain_tuner-2.0.3] startup
[6.188s] [ext: omni.usd.metrics.assembler.physics-106.5.0] startup
[6.191s] [ext: isaacsim.util.camera_inspector-1.0.4] startup
[6.193s] [ext: omni.isaac.gain_tuner-2.0.2] startup
[6.196s] [ext: isaacsim.robot_setup.grasp_editor-2.0.5] startup
[6.200s] [ext: isaacsim.asset.gen.omap-2.0.8] startup
[6.207s] [ext: omni.anim.curve.core-1.2.0] startup
[6.226s] [ext: isaacsim.robot.surface_gripper.ui-2.1.1] startup
[6.231s] [ext: omni.isaac.grasp_editor-2.0.2] startup
[6.232s] [ext: omni.isaac.occupancy_map-2.0.3] startup
2025-02-21 05:55:43 [6,183ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
2025-02-21 05:55:43 [6,183ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.occupancy_map', but it was imported from other extension: 'd:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.asset.gen.omap/isaacsim/asset/gen/omap/impl/extension.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extsdeprecated\omni.isaac.occupancy_map'. Do not import `IExt` derived class from other extension in your public namespace.
[6.234s] [ext: omni.anim.curve.ui-1.4.0] startup
[6.242s] [ext: isaacsim.util.merge_mesh-2.0.6] startup
[6.246s] [ext: isaacsim.robot_setup.assembler-2.1.5] startup
[6.251s] [ext: omni.anim.curve.bundle-1.2.3] startup
[6.252s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.5] startup
[6.254s] [ext: omni.isaac.robot_assembler-2.0.2] startup
[6.256s] [ext: isaacsim.replicator.scene_blox-1.0.2] startup
[6.257s] [ext: omni.isaac.robot_description_editor-3.0.2] startup
[6.258s] [ext: isaacsim.replicator.synthetic_recorder-2.2.3] startup
[6.264s] [ext: isaacsim.core.throttling-2.0.2] startup
[6.268s] [ext: omni.isaac.scene_blox-1.0.2] startup
2025-02-21 05:55:43 [6,218ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[6.269s] [ext: omni.graph.ui_nodes-1.40.1] startup
[6.274s] [ext: omni.isaac.synthetic_recorder-2.0.2] startup
2025-02-21 05:55:43 [6,225ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[6.276s] [ext: omni.isaac.throttling-2.0.2] startup
2025-02-21 05:55:43 [6,227ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-02-21 05:55:43 [6,227ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[6.278s] [ext: omni.kit.browser.asset-1.3.11] startup
[6.282s] [ext: omni.graph.bundle.action-2.20.0] startup
[6.287s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-02-21 05:55:43 [6,238ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-02-21 05:55:43 [6,239ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[6.289s] [ext: omni.kit.core.collection-0.2.0] startup
[6.293s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[6.297s] [ext: omni.kit.preferences.animation-1.2.0] startup
[6.302s] [ext: omni.graph.window.generic-1.40.0] startup
[6.312s] [ext: omni.kit.property.collection-0.2.0] startup
[6.315s] [ext: omni.kit.property.layer-1.1.8] startup
[6.319s] [ext: omni.kit.search.files-1.0.4] startup
[6.321s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[6.325s] [ext: omni.kit.window.title-1.1.5] startup
[6.343s] [ext: omni.isaac.extension_templates-2.0.2] startup
2025-02-21 05:55:43 [6,294ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
2025-02-21 05:55:43 [6,294ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.extension_templates', but it was imported from other extension: 'd:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.examples.extension/isaacsim/examples/extension/extension.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extsdeprecated\omni.isaac.extension_templates'. Do not import `IExt` derived class from other extension in your public namespace.
[6.347s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[6.358s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[6.370s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[6.384s] [ext: omni.kit.browser.material-1.6.0] startup
[6.395s] [ext: omni.kit.property.material-1.10.17] startup
[6.412s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[6.418s] [ext: omni.kit.widgets.custom-1.0.9] startup
[6.435s] [ext: omni.kit.usdz_export-1.0.7] startup
[6.438s] [ext: omni.kit.window.material-1.6.2] startup
[6.447s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[6.447s] [ext: omni.kit.variant.editor-106.1.1] startup
[6.465s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[6.506s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[6.514s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[6.516s] [ext: omni.kit.usda_edit-1.1.14] startup
[6.525s] [ext: omni.kit.variant.presenter-107.0.0] startup
[6.529s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[6.538s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[6.544s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[6.551s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[6.556s] [ext: omni.rtx.window.settings-0.6.17] startup
[6.563s] [ext: isaacsim.asset.gen.omap.ui-2.0.4] startup
[6.570s] [ext: omni.scene.optimizer.core-106.1.10] startup
[6.598s] [ext: omni.kit.widget.live-2.1.8] startup
[6.601s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[6.602s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[6.603s] [ext: omni.isaac.occupancy_map.ui-2.0.3] startup
2025-02-21 05:55:43 [6,553ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
2025-02-21 05:55:43 [6,553ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.occupancy_map.ui', but it was imported from other extension: 'd:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.asset.gen.omap.ui/isaacsim/asset/gen/omap/ui/extension.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extsdeprecated\omni.isaac.occupancy_map.ui'. Do not import `IExt` derived class from other extension in your public namespace.
[6.609s] [ext: omni.kit.converter.common-503.2.1] startup
[6.656s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[6.659s] [ext: omni.kit.widget.cache_indicator-3.0.1] startup
2025-02-21 05:55:43 [6,609ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
2025-02-21 05:55:43 [6,675ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File C:/Users/2022/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
[6.726s] [ext: omni.isaac.physics_inspector-0.1.7] startup
2025-02-21 05:55:43 [6,676ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[6.727s] [ext: isaacsim.util.physics-1.1.2] startup
[6.732s] [ext: omni.kit.converter.dgn_core-503.3.2] startup
[6.738s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[6.739s] [ext: omni.kit.converter.hoops_core-504.4.1] startup
[6.746s] [ext: omni.kit.window.script_editor-1.7.8] startup
[6.751s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[6.752s] [ext: isaacsim.asset.browser-1.3.4] startup
[6.911s] [ext: omni.simready.explorer-1.1.1] startup
[6.926s] [ext: isaacsim.core.cloner-1.3.4] startup
[6.929s] [ext: omni.kit.converter.dgn-503.3.1] startup
[6.935s] [ext: omni.kit.converter.hoops-504.4.3] startup
[6.941s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[7.323s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[7.344s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-02-21 05:55:44 [7,295ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[7.346s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-02-21 05:55:44 [7,297ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[7.347s] [ext: omni.isaac.cloner-1.0.2] startup
2025-02-21 05:55:44 [7,298ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[7.349s] [ext: omni.kit.widget.calendar-1.0.8] startup
[7.357s] [ext: omni.kit.selection-0.1.5] startup
[7.359s] [ext: omni.isaac.core-4.0.3] startup
2025-02-21 05:55:44 [7,310ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-02-21 05:55:44 [7,310ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-02-21 05:55:44 [7,311ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-02-21 05:55:44 [7,311ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[7.361s] [ext: isaacsim.simulation_app-2.4.2] startup
[7.363s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-02-21 05:55:44 [7,314ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[7.365s] [ext: omni.isaac.cortex-1.0.2] startup
[7.366s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[7.370s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[7.381s] [ext: isaacsim.gui.menu-2.0.9] startup
[7.389s] [ext: omni.isaac.franka-1.0.2] startup
2025-02-21 05:55:44 [7,340ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-02-21 05:55:44 [7,340ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-02-21 05:55:44 [7,340ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[7.391s] [ext: omni.isaac.kit-2.0.3] startup
2025-02-21 05:55:44 [7,343ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[7.394s] [ext: omni.isaac.lula-4.0.2] startup
2025-02-21 05:55:44 [7,344ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[7.395s] [ext: isaacsim.sensors.physx-2.2.4] startup
[7.400s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-02-21 05:55:44 [7,351ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[7.402s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-02-21 05:55:44 [7,353ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,353ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,354ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,354ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,354ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,354ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,355ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,355ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,356ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-02-21 05:55:44 [7,357ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[7.408s] [ext: omni.isaac.menu-1.0.2] startup
2025-02-21 05:55:44 [7,359ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[7.410s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-02-21 05:55:44 [7,362ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,362ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,362ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,363ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,363ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,364ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,364ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,364ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,365ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,366ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,366ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,366ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,367ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,367ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,367ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-02-21 05:55:44 [7,368ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[7.419s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-02-21 05:55:44 [7,370ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-02-21 05:55:44 [7,370ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[7.421s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-02-21 05:55:44 [7,371ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[7.423s] [ext: omni.isaac.range_sensor-4.0.2] startup
[7.428s] [ext: omni.isaac.sensor-13.0.3] startup
2025-02-21 05:55:44 [7,379ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-02-21 05:55:44 [7,379ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-02-21 05:55:44 [7,380ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-02-21 05:55:44 [7,380ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-02-21 05:55:44 [7,380ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-02-21 05:55:44 [7,381ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-02-21 05:55:44 [7,381ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-02-21 05:55:44 [7,381ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-02-21 05:55:44 [7,382ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-02-21 05:55:44 [7,382ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-02-21 05:55:44 [7,383ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[7.433s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-02-21 05:55:44 [7,385ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[7.436s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-02-21 05:55:44 [7,387ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,391ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,392ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[7.443s] [ext: omni.isaac.utils-2.0.2] startup
[7.445s] [ext: omni.kit.property.audio-1.0.16] startup
[7.447s] [ext: omni.kit.property.camera-1.0.9] startup
[7.449s] [ext: omni.hydra.scene_api-0.1.2] startup
[7.452s] [ext: omni.kit.property.physx-106.5.7] startup
[7.478s] [ext: omni.physx.demos-106.5.7] startup
[7.501s] [ext: omni.kit.property.geometry-1.3.3] startup
[7.505s] [ext: isaacsim.app.about-2.0.7] startup
[7.509s] [ext: omni.kit.property.light-1.0.11] startup
[7.511s] [ext: omni.kit.property.render-1.1.3] startup
[7.513s] [ext: omni.kit.property.transform-1.5.10] startup
[7.517s] [ext: omni.isaac.version-2.0.2] startup
2025-02-21 05:55:44 [7,467ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[7.518s] [ext: omni.physx.vehicle-106.5.7] startup
[7.536s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-02-21 05:55:44 [7,487ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,487ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,488ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,488ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,488ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,489ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,489ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,489ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,489ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,490ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,490ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-02-21 05:55:44 [7,490ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[7.541s] [ext: omni.isaac.window.about-2.0.2] startup
2025-02-21 05:55:44 [7,493ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-02-21 05:55:44 [7,493ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[7.544s] [ext: isaacsim.sensors.physx.examples-2.2.4] startup
[7.546s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[7.552s] [ext: omni.kit.property.bundle-1.3.2] startup
[7.554s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[7.558s] [ext: omni.physx.camera-106.5.7] startup
[7.570s] [ext: omni.kit.window.toolbar-1.6.2] startup
[7.575s] [ext: omni.kit.widget.timeline-105.0.1] startup
[7.580s] [ext: omni.isaac.range_sensor.examples-2.0.3] startup
2025-02-21 05:55:44 [7,530ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-02-21 05:55:44 [7,530ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-02-21 05:55:44 [7,531ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[7.582s] [ext: isaacsim.replicator.writers-1.0.1] startup
[7.618s] [ext: isaacsim.gui.property-1.0.4] startup
[7.622s] [ext: omni.physx.cct-106.5.7] startup
[7.639s] [ext: omni.physx.graph-106.5.7] startup
[7.659s] [ext: omni.physx.supportui-106.5.7] startup
[7.677s] [ext: omni.physx.telemetry-106.5.7] startup
[7.680s] [ext: isaacsim.replicator.examples-1.1.2] startup
[7.682s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-02-21 05:55:44 [7,633ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-02-21 05:55:44 [7,634ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
2025-02-21 05:55:44 [7,634ms] [Warning] [omni.ext._impl._internal] Found class `IsaacPropertyWidgets` derived from `omni.ext.IExt` in module: 'omni.kit.property.isaac', but it was imported from other extension: 'd:/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release/exts/isaacsim.gui.property/isaacsim/gui/property/widgets.py', which is not a subpath to: 'd:\isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.windows-x86_64.release\extsdeprecated\omni.kit.property.isaac'. Do not import `IExt` derived class from other extension in your public namespace.
[7.687s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[7.691s] [ext: omni.kit.window.console-0.2.14] startup
[7.710s] [ext: omni.kit.window.status_bar-0.1.7] startup
[7.738s] [ext: omni.kit.widget.collection-0.1.18] startup
[7.761s] [ext: omni.physx.bundle-106.5.7] startup
[7.763s] [ext: omni.replicator.isaac-2.0.3] startup
2025-02-21 05:55:44 [7,716ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[7.767s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[7.799s] [ext: omni.rtx.settings.core-0.6.3] startup
[7.834s] [ext: omni.kit.converter.jt_core-503.2.2] startup
[7.852s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[7.856s] [ext: omni.kit.window.collection-0.2.0] startup
[7.859s] [ext: isaacsim.sensors.physx.ui-2.2.1] startup
[7.861s] [ext: semantics.schema.editor-0.3.10] startup
[7.864s] [ext: omni.kit.ui.actions-1.0.2] startup
[7.866s] [ext: semantics.schema.property-1.0.5] startup
[7.868s] [ext: omni.kit.converter.jt-503.2.2] startup
[7.870s] [ext: omni.kit.quicklayout-1.0.8] startup
[7.872s] [ext: omni.kit.window.commands-0.2.7] startup
[7.874s] [ext: omni.isaac.range_sensor.ui-2.0.2] startup
2025-02-21 05:55:44 [7,824ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-02-21 05:55:44 [7,824ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[7.875s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.5] startup
[7.878s] [ext: omni.kit.menu.common-1.1.9] startup
[7.881s] [ext: isaacsim.exp.base-4.5.0] startup
[7.881s] [ext: omni.kit.converter.cad-202.2.0] startup
[7.882s] [ext: omni.kit.window.stats-0.1.7] startup
[7.883s] [ext: isaacsim.app.setup-1.3.5] startup
[7.885s] Isaac Sim Full Version: 4.5.0-rc.36
[7.885s] [ext: omni.kit.profiler.window-2.3.1] startup
[7.893s] [ext: isaacsim.exp.full-4.5.0] startup
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7374781440
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7301033856
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9748724 (slope: 439, intercept: 13179904)
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287352704
2025-02-21 05:55:45 [8,170ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
[8.221s] app ready
2025-02-21 05:55:46 [9,477ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-02-21 05:55:47 [10,078ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
2025-02-21 05:55:47 [10,883ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/raytracing/Translucency.rgs.hlsl'.
2025-02-21 05:55:47 [10,883ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/Translucency.rgs.hlsl
2025-02-21 05:55:52 [15,916ms] [Error] [gpu.foundation.plugin] checkShaderLoading() failed for shader handle: 0000000100000111
2025-02-21 05:55:52 [15,916ms] [Error] [carb.graphics-vulkan.plugin] VkResult: UNKNOWN_ERROR
2025-02-21 05:55:52 [15,919ms] [Error] [carb.graphics-vulkan.plugin] vkCreateShaderModule failed.
2025-02-21 05:55:52 [15,952ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2025-02-21 05:55:52 [15,952ms] [Error] [carb.graphics-vulkan.plugin] vkCreateRayTracingPipelinesKHR failed.
Here is the screenshot of the error message after running the sim:
Isaac Sim Version
4.5.0
Operating System
Windows 11
GPU Information
  • Model: NVIDIA GeForce RTX 3070 Ti
  • Driver Version: 566.36
In addition, I downloaded Omniverse version 4.2 and uninstalled it. I also used the launcher - cleanup tool, but I’m not sure if it was completely uninstalled. After downloading the latest Isaac Sim application, due to insufficient space on the system drive, I placed it on a non - system drive. Currently, when I run the isaac - sim.bat file, the above error message appears and the interface freezes. I’d be extremely grateful if you could tell me how to fix this error.
Complete log
kit_20250127_201949.log (108.7 KB)
Please try installing the NVIDIA driver version 537.70, as recommended in Isaac Sim Requirements — Isaac Sim Documentation.
Additionally, please verify compatibility by using the Isaac Sim Compatibility Checker tool. This will help ensure that your system meets the requirements for optimal performance.
Thank you for your response, it was helpful. Although I couldn’t find the 537.70 version of the driver, I downgraded to version 537.58, which aligns with the recommendations in the documentation. There are still some warnings, but display is now normal.
Sorry, the error occurred again. After changing the graphics card driver to the recommended version, the situation only improved a little. After Isaac Sim has been open for some time, the program still reports an error and crashes:
2025-02-26 02:12:13 [6,846ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/raytracing/DirectLightingSampled.rgs.hlsl'.
2025-02-26 02:12:13 [6,847ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/DirectLightingSampled.rgs.hlsl
2025-02-26 02:12:13 [7,552ms] [Error] [gpu.foundation.plugin] checkShaderLoading() failed for shader handle: 00000001000000D3
2025-02-26 02:12:13 [7,552ms] [Error] [carb.graphics-vulkan.plugin] VkResult: UNKNOWN_ERROR
2025-02-26 02:12:13 [7,552ms] [Error] [carb.graphics-vulkan.plugin] vkCreateShaderModule failed.
2025-02-26 02:12:16 [10,424ms] [Error]
It seems to be random and can occur at any time after launching Isaac Sim. I need help.
Please check if the solution in Isaac sim install issue - #3 by omnitest2023 works on your side.
