Warning Vulkan Isaac sim 2021.1.1 Ubuntu 2020.04
I am new to Isaac sim but when running Isaac launches with some warnings on ubuntu 2020.04. When importing some of the examples the textures of the assets look bad. After some readings I think it is related to vulkan api so these are the warnings I have:
2021-11-21 08:39:20 [10,209ms] [Warning] [carb.graphics-vulkan.plugin] Physical device with name: llvmpipe (LLVM 12.0.0, 256 bits) does not support 'Vulkan 1.1', it has api version: 1.0.
2021-11-21 08:39:20 [10,326ms] [Warning] [carb.graphics-vulkan.plugin] Physical device with name: llvmpipe (LLVM 12.0.0, 256 bits) does not support 'Vulkan 1.1', it has api version: 1.0.
When loading the output from the terminal:
[0.336s] [ext: omni.kit.test-0.0.0] startup
[0.348s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 495.29      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 3080          | Yes    |     | 10486   MB | 10de      | 0          |
|     |                                  |        |     |            | 2206      | 89aaf1db.. |
| OS: Linux hri-David, Version: 5.11.0-40-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12011000 (1.20.11.0)
| Processor: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 32026 | Free Memory: 27126
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
My system specifications are:
Ubuntu 2020.04 LTS
Isaac Sim 2021.1.1
Nvidia-driver 495.29
GPU: RTX 3080
The issue could be caused by the 495 drivers. Please try installing the 470 drivers.
Thank you for your reply! Unfortunately I tried changing to 470 drivers but the problem still exist. Here it is my full terminal logs:
[Info] [carb] Logging to file: /home/hri/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20211122_162912.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.012s] Loading user config located at: '/home/hri/.local/share/ov/data/Kit/Isaac-Sim/2021.1/user.config.json'
2021-11-22 07:29:12 [87ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/hri/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr', ext 2: '/home/hri/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr'
[0.105s] [ext: omni.usd.config-1.0.0] startup
[0.106s] [ext: omni.usd.libs-1.0.0] startup
[0.275s] [ext: omni.kit.pipapi-0.0.0] startup
[0.280s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.285s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.288s] [ext: omni.hydra.iray-0.1.0] startup
[0.299s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.304s] [ext: omni.kit.loop-default-0.1.0] startup
[0.304s] [ext: omni.kit.async_engine-0.0.0] startup
[0.312s] [ext: omni.stats-0.0.0] startup
[0.314s] [ext: omni.assets.plugins-0.0.0] startup
[0.316s] [ext: omni.appwindow-1.0.0] startup
[0.327s] [ext: omni.client-0.1.0] startup
[0.335s] [ext: omni.kit.test-0.0.0] startup
| Driver Version: 470.82      | Graphics API: Vulkan
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2206      | 89aaf1db.. |
| Total Memory (MB): 32026 | Free Memory: 26658
[1.230s] [ext: omni.ui-2.1.8] startup
[1.245s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.248s] [ext: omni.kit.uiapp-0.0.0] startup
[1.249s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.256s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.289s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.299s] [ext: omni.usd.schema.isaac-0.1.0] startup
[1.336s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.345s] [ext: carb.audio-0.1.0] startup
[1.365s] [ext: omni.timeline-1.0.0] startup
[1.368s] [ext: omni.kit.commands-0.0.0] startup
[1.372s] [ext: omni.kvdb-0.0.0] startup
[1.378s] [ext: omni.usd-1.4.2] startup
[1.399s] [ext: omni.localcache-0.0.0] startup
[1.404s] [ext: omni.kit.window.drop_support-1.0.0] startup
[1.408s] [ext: omni.convexdecomposition-1.2.0] startup
[1.414s] [ext: omni.usdphysics-1.2.0] startup
[1.417s] [ext: omni.kit.menu.utils-1.0.1] startup
[1.433s] [ext: omni.physx-1.2.0-5.1] startup
[1.470s] [ext: omni.kit.material.library-1.0.4] startup
[1.482s] [ext: omni.kit.menu.create-1.0.1] startup
[1.488s] [ext: omni.renderer-rtx-0.0.0] startup
[1.495s] [ext: omni.kit.context_menu-1.1.0] startup
[1.638s] [ext: omni.hydra.rtx-0.1.0] startup
[1.647s] [ext: omni.services.facilities.base-1.0.0] startup
[1.651s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-11-22 07:29:13 [1,644ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/hri/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-11-22 07:29:43 [31,755ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[32.332s] [ext: omni.services.core-1.1.0] startup
[32.479s] [ext: omni.services.transport.client.base-1.0.0] startup
[32.484s] [ext: omni.services.transport.server.base-1.0.0] startup
[32.488s] [ext: omni.services.client-0.2.0] startup
[32.514s] [ext: omni.services.transport.server.http-1.0.0] startup
[32.579s] [ext: omni.kit.agent-0.1.0] startup
[32.582s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[32.741s] [ext: omni.kit.widget.stage-2.4.0] startup
[32.752s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[32.758s] [ext: omni.kit.search_core-1.0.0] startup
[32.764s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[32.772s] [ext: omni.kit.widget.path_field-2.0.2] startup
[32.779s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[32.791s] [ext: omni.kit.notification_manager-1.0.0] startup
[32.798s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[32.805s] [ext: omni.kit.window.toolbar-1.0.0] startup
[32.818s] [ext: omni.kit.numpy.common-0.1.0] startup
[32.981s] [ext: omni.kit.window.filepicker-2.3.1] startup
[33.038s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[33.049s] [ext: omni.debugdraw-0.0.0] startup
[33.056s] [ext: omni.syntheticdata-0.1.5] startup
[33.220s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[33.238s] [ext: omni.isaac.ros_bridge_ui-0.1.0] startup
[33.245s] [ext: omni.isaac.range_sensor-0.1.2] startup
[33.261s] [ext: omni.isaac.utils-0.1.4] startup
[33.278s] [ext: omni.kit.stage_templates-1.0.4] startup
[33.286s] [ext: omni.isaac.ros_bridge-0.1.0] startup
Checking if ROS_MASTER_URI is set:
ROS_MASTER_URI not set, using default, ROS_MASTER_URI= http://localhost:11311
[33.440s] [ext: omni.kit.window.file-1.2.2] startup
[33.514s] [ext: omni.kit.window.property-0.0.0] startup
[33.523s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[33.590s] [ext: omni.kit.window.content_browser-2.3.1] startup
[33.640s] [ext: omni.kit.property.usd-3.9.4] startup
[33.668s] [ext: omni.kit.widget.settings-1.0.0] startup
[33.677s] [ext: omni.physx.commands-1.0.0] startup
[33.682s] [ext: omni.kit.property.material-1.6.4] startup
[33.694s] [ext: omni.kit.window.preferences-1.1.1] startup
[33.736s] [ext: omni.physx.ui-1.2.0-5.1] startup
[33.774s] [ext: omni.kit.renderer.capture-0.0.0] startup
[33.785s] [ext: omni.kit.property.physx-0.1.0] startup
[33.842s] [ext: omni.physx.demos-1.0.0] startup
[33.848s] [ext: omni.isaac.window.about-1.0.0] startup
[33.856s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[33.878s] [ext: omni.command.usd-1.0.1] startup
[33.885s] [ext: omni.physx.cct-1.2.0-5.1] startup
[33.896s] [ext: omni.kit.widget.stage_icons-1.0.1] startup
[33.905s] [ext: omni.kit.widget.layers-1.5.2] startup
[33.928s] [ext: omni.kit.menu.select-1.0.0] startup
[33.941s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[33.941s] [ext: omni.kit.window.stage-2.3.3] startup
[33.952s] [ext: omni.kit.property.layer-1.1.0] startup
[33.961s] [ext: omni.kit.tool.collect-2.0.1] startup
[33.976s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[34.021s] [ext: omni.kit.property.isaac-0.1.0] startup
[34.030s] [ext: omni.kit.usd_undo-0.1.0] startup
[34.038s] [ext: omni.kit.property.audio-1.0.4] startup
[34.048s] [ext: omni.kit.property.camera-1.0.3] startup
[34.057s] [ext: omni.kit.property.geometry-1.1.0] startup
[34.068s] [ext: omni.kit.property.light-1.0.4] startup
[34.078s] [ext: omni.kit.property.transform-1.0.2] startup
[34.089s] [ext: omni.kit.window.console-0.0.0] startup
[34.093s] [ext: omni.kit.asset_converter-1.1.22] startup
[34.137s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[34.149s] [ext: omni.kit.window.tests-0.1.0] startup
[34.232s] [ext: omni.kit.property.bundle-1.2.4] startup
[34.242s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[34.253s] [ext: omni.isaac.shapenet-1.0.0] startup
env var SHAPENET_LOCAL_DIR not set, using default data dir /home/hri/.local/share/ov/data/Kit/Isaac-Sim/2021.1/shapenet
omni.isaac.shapenet's receiver for external messages has started. on ('localhost', '7011')
[34.316s] [ext: semantics.schema.editor-0.1.3] startup
[34.320s] [ext: omni.isaac.tests-0.0.0] startup
[34.329s] [ext: omni.graph.tools-1.0.0] startup
[34.350s] [ext: omni.graph.core-1.0.0] startup
[34.358s] [ext: omni.kit.widget.fast_search-0.3.0] startup
[34.369s] [ext: omni.kit.widget.graph-1.1.2] startup
[34.383s] [ext: omni.kit.widget.prompt-1.0.0] startup
[34.392s] [ext: omni.kit.widget.imageview-1.0.0] startup
[34.403s] [ext: omni.graph-1.0.0] startup
[34.464s] [ext: omni.isaac.dr-0.1.6] startup
[34.480s] [ext: omni.kit.widget.live-0.0.0] startup
[34.482s] [ext: omni.rtx.window.settings-0.6.0] startup
[34.493s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[34.506s] [ext: omni.graph.ui-1.0.1] startup
[34.584s] [ext: omni.kit.menu.file-1.0.2] startup
[34.595s] [ext: omni.kit.window.cursor-1.0.1] startup
[34.608s] [ext: omni.rtx.settings.core-0.5.4] startup
[34.621s] [ext: omni.kit.window.status_bar-0.0.0] startup
[34.623s] [ext: omni.kit.window.script_editor-1.5.0] startup
[34.625s] [ext: omni.videoencoding-0.0.0] startup
[34.632s] [ext: omni.kit.tagging-0.1.0] startup
[34.751s] [ext: omni.kit.widget.sliderbar-1.0.3] startup
[34.763s] [ext: omni.iray.settings.core-0.6.2] startup
[34.773s] [ext: omni.kit.capture-0.4.0] startup
[34.785s] [ext: omni.kit.window.commands-0.1.1] startup
[34.796s] [ext: omni.kit.menu.edit-1.0.3] startup
[34.808s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[34.819s] [ext: omni.kit.window.movie_maker-0.4.9] startup
[34.833s] [ext: omni.kit.tool.asset_importer-2.3.2] startup
[34.848s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[34.859s] [ext: omni.kit.window.title-1.1.0] startup
[34.869s] [ext: omni.isaac.motion_planning-0.1.4] startup
[34.896s] [ext: omni.isaac.manip-0.1.2] startup
[34.908s] [ext: omni.kit.search.service-0.1.0] startup
[34.926s] [ext: omni.isaac.step_importer-0.1.1] startup
[35.043s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
[35.632s] [ext: omni.isaac.urdf-0.1.4] startup
[35.658s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[35.712s] [ext: omni.isaac.samples-0.1.6] startup
[35.745s] [ext: omni.kit.selection-0.0.0] startup
[35.755s] [ext: omni.ansel-0.2.0] startup
2021-11-22 07:29:47 [35,744ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] Failed to load plugins, folder doesn't exist: '/home/hri/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin'.
2021-11-22 07:29:47 [35,744ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] '/home/hri/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
[35.763s] [ext: omni.kit.window.extensions-1.0.2] startup
[35.779s] [ext: omni.graph.examples.python-1.0.0] startup
[35.847s] [ext: omni.kit.window.profiler-1.0.0] startup
[35.859s] [ext: omni.isaac.utils_manager-0.1.0] startup
[35.871s] [ext: omni.isaac.app.setup-0.0.0] startup
[35.883s] [ext: omni.kit.window.stats-0.0.0] startup
[35.895s] [ext: omni.isaac.sim.base-2021.1.1] startup
[35.895s] [ext: omni.isaac.sim-2021.1.1] startup
[35.895s] app started
2021-11-22 07:30:07 [55,778ms] [Warning] [carb.graphics-vulkan.plugin] Physical device with name: llvmpipe (LLVM 12.0.0, 256 bits) does not support 'Vulkan 1.1', it has api version: 1.0.
2021-11-22 07:30:08 [55,912ms] [Warning] [carb.graphics-vulkan.plugin] Physical device with name: llvmpipe (LLVM 12.0.0, 256 bits) does not support 'Vulkan 1.1', it has api version: 1.0.
Isaac Sim App is loaded.
Checking for Isaac Sim assets on nucleus server
Check successful
And Here it is a picture of how it looks for example importing the UR10 robot.
One update here. I installed the recently released new version of isaac sim 2021.2 and the appearance is better. However the warning still appears in the logs. I also tried running the examples in isaac gym but the rendering its ok. The visual now look like this:
I don’t know if I can work with this, or if there is a solution out there. Thanks in advance.
This looks visually correct now
