Isaac_sim crashed on launch (isaac_sim-2022.2.1 and isaac_sim-2022.2.0)
I am developing an application for a robot and want to create a simulation in Isaac Sim.
I had exactly the same problem Isaac_sim crashed when I clicke "load world" in my extension when running isaac_sim-2022.2.1 and isaac_sim-2022.2.0
The driver has been installed.
I am using ubuntu 20.04
When I use command “isaac_sim-2022.2.1/isaac-sim.sh -v”, then I get an error:
2023-07-22 15:13:34 [17,864ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '11215649194962136733'
2023-07-22 15:13:34 [17,864ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = '_hUPMlBpQh6HIwJnnRmaipR2eMAWy_HysjP4h6KUUK4'
2023-07-22 15:13:34 [17,864ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 18598 backtrace follows:
2023-07-22 15:13:34 [17,901ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
2023-07-22 15:13:34 [17,928ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libomni.activity.freeze_monitor.plugin.so!std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release()+0x27a3 (??:?)
2023-07-22 15:13:34 [17,954ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libomni.activity.freeze_monitor.plugin.so!_init+0x1b8d (??:0)
2023-07-22 15:13:34 [17,988ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libcarb.so!omniCoreStart+0x2b396 (??:?)
2023-07-22 15:13:34 [18,014ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.so!omniCoreStart+0x2bfaa (??:?)
2023-07-22 15:13:34 [18,050ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libcarb.so!quickReleaseFrameworkAndTerminate+0xad9c (??:?)
2023-07-22 15:13:34 [18,087ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libcarb.so!quickReleaseFrameworkAndTerminate+0xb98a (??:?)
2023-07-22 15:13:34 [18,123ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)+0x2d1e (??:?)
2023-07-22 15:13:34 [18,157ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libomni.ext.plugin.so!std::pair<std::__detail::_Node_iterator<std::string, true, true>, bool> std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::_M_insert<std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > >(std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > const&, std::integral_constant<bool, true>)+0x2b89 (??:?)
2023-07-22 15:13:34 [18,194ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)+0x1800b (??:?)
2023-07-22 15:13:34 [18,230ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.ext.plugin.so!carbOnPluginShutdown+0x6358 (??:?)
2023-07-22 15:13:34 [18,265ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.ext.plugin.so!carbOnPluginShutdown+0xd883 (??:?)
2023-07-22 15:13:34 [18,302ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.ext.plugin.so!carbOnPluginShutdown+0xf099 (??:?)
2023-07-22 15:13:34 [18,337ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.kit.app.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&&)+0x12de2 (??:?)
2023-07-22 15:13:34 [18,371ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.kit.app.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&&)+0x135b3 (??:?)
2023-07-22 15:13:34 [18,407ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.kit.app.plugin.so!_init+0x4e9e (??:0)
2023-07-22 15:13:34 [18,431ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x6f6 (??:?)
2023-07-22 15:13:34 [18,460ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: kit!_init+0x630 (??:0)
/usr/bin/addr2line: DWARF error: section .debug_info is larger than its filesize! (0x93ef57 vs 0x530ea0)
2023-07-22 15:13:34 [18,496ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libc.so.6!__libc_start_main+0xf3 (??:?)
2023-07-22 15:13:34 [18,518ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: kit!_init+0x9cb (??:0)
Logs
logs-isaac.zip (1.2 MB)
Hi. There is an error in your logs.
2023-07-22 14:45:49 [1,285ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display, TCC mode or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
- For Ubuntu, it requires server-xorg-core 1.20.7+ and a display to work without --no-window.
- For Linux dockers, the setup is not complete. Install the latest driver, xServer and NVIDIA container runtime.
What GPU are and drivers are you using?
Please reinstall the “Latest Production Branch Version” drivers.
Thank you. Indeed, there were problems with the video card. The ticket can be closed.
