Could not select device driver "" with capabilities: [[gpu]]
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/setup.html#isaac-sim-headless-container
I try to run the Omniverse Isaac Sim container on remote Ubuntu workstation. I was SSH into the remote workstation. when I am on step 4 – run the command “sudo docker run --entrypoint ./runheadless.websocket.sh --gpus all -e “ACCEPT_EULA=Y” --rm --network=host nvcr.io/nvidia/isaac-sim:2021.1.1” ,the error comes :
docker: Error response from daemon: could not select device driver “” with capabilities: [[gpu]].
here is my driver version:
zhengang.fu@szbd-hpc-01:~$ nvidia-smi
Thu Nov 11 12:46:11 2021
| NVIDIA-SMI 495.44 Driver Version: 495.44 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:1B:00.0 Off | N/A |
| 43% 42C P0 105W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … Off | 00000000:1C:00.0 Off | N/A |
| 42% 38C P0 96W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce … Off | 00000000:1D:00.0 Off | N/A |
| | | N/A |
| 3 NVIDIA GeForce … Off | 00000000:1E:00.0 Off | N/A |
| 42% 40C P0 102W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 4 NVIDIA GeForce … Off | 00000000:3D:00.0 Off | N/A |
| 43% 38C P0 102W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 5 NVIDIA GeForce … Off | 00000000:41:00.0 Off | N/A |
| 43% 39C P0 108W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 6 NVIDIA GeForce … Off | 00000000:42:00.0 Off | N/A |
| 43% 38C P0 100W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| 7 NVIDIA GeForce … Off | 00000000:43:00.0 Off | N/A |
| 43% 39C P0 106W / 350W | 0MiB / 12053MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Unable to find image ‘nvcr.io/nvidia/isaac-sim:2021.1.1’ locally
2021.1.1: Pulling from nvidia/isaac-sim
7ddbc47eeb70: Pulling fs layer
c1bbdc448b72: Pulling fs layer
8c3b70e39044: Pulling fs layer
45d437916d57: Pulling fs layer
d8f1569ddae6: Pulling fs layer
85386706b020: Pulling fs layer
ee9b457b77d0: Pulling fs layer
83ac96f055c5: Pulling fs layer
a34b6c089cd7: Pulling fs layer
0edc044c3944: Pulling fs layer
400337608be0: Pulling fs layer
a279b58f3937: Pulling fs layer
e38365ed3ff9: Pulling fs layer
0276e2e3a8a8: Pulling fs layer
50074675df9f: Pulling fs layer
dd5eb982acd4: Pulling fs layer
3babcb405d32: Pulling fs layer
da2dca6c0e18: Pulling fs layer
38f65230252a: Pulling fs layer
a841fa9db2af: Pulling fs layer
03984c2703d6: Pulling fs layer
509da6525813: Pulling fs layer
cdcb89aa1538: Pulling fs layer
48bde5b2bc60: Pull complete
d5feaea1965a: Pull complete
0a3bc2e804d1: Pull complete
d908e9dde506: Pull complete
25ccffea2981: Pull complete
a2016a6ce947: Pull complete
0e566ff3e71c: Pull complete
Digest: sha256:1d4bc215354ca1e47223bad3d4323b8d19f3867d9a18abb332d37f838ab367f2
Status: Downloaded newer image for nvcr.io/nvidia/isaac-sim:2021.1.1
Hi, please try running the hello world example for NVIDIA Container Toolkit:
sudo docker run --rm --gpus all nvidia/cuda:11.0-base nvidia-smi
You should see the output of nvidia-smi
If that does not work, try the 470 series drivers.
I have tried it, but the same error comes:
Unable to find image ‘nvidia/cuda:11.0-base’ locally
11.0-base: Pulling from nvidia/cuda
54ee1f796a1e: Pull complete
f7bfea53ad12: Pull complete
46d371e02073: Pull complete
b66c17bbf772: Pull complete
3642f1a6dfb3: Pull complete
e5ce55b8b4b9: Pull complete
155bc0332b0a: Pull complete
Digest: sha256:774ca3d612de15213102c2dbbba55df44dc5cf9870ca2be6c6e9c627fa63d67a
Status: Downloaded newer image for nvidia/cuda:11.0-base
here is nvidia-smi info:
narwal@szbd-hpc-01:~$ nvidia-smi
Thu Nov 11 13:32:48 2021
| | | MIG M. |
| 43% 41C P0 104W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| | | N/A |
| 43% 42C P0 104W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| | | N/A |
| 43% 37C P0 102W / 350W | 0MiB / 12053MiB | 0% Default |
| | | N/A |
| | | N/A |
| | | N/A |
| 42% 39C P0 106W / 350W | 0MiB / 12053MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
the reason is that the drivers version ? should I try the 470 drivers?
I have fixed it by installation of the NVIDIA toolkit.
according to this link: docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]]. · Issue #1243 · NVIDIA/nvidia-docker · GitHub
NVIDIA Container Toolkit is a requirement:
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/requirements.html#isaac-sim-short-container-requirements
yes, it is my fault!! thanks!
I try to run the Omniverse Isaac Sim container on remote Ubuntu workstation. I was SSH into the remote workstation. when I am on step 4 – run the command “sudo docker run --entrypoint ./runheadless.websocket.sh --gpus all -e “ACCEPT_EULA=Y” --rm --network=host nvcr.io/nvidia/isaac-sim:2021.1.1” ,the new error comes :
[Error] [carb.windowing-glfw.plugin] GLFW initialization failed
here is the log:
2021-11-11 17:31:54 [1,107,914ms] [Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
2021-11-11 17:31:54 [1,107,914ms] [Error] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v0.1],[carb::windowing::IWindowing v1.1]) (impl: carb.windowing-glfw.plugin)
2021-11-11 17:31:54 [1,107,914ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: carb::windowing::IWindowing (pluginName: nullptr)
At:
/isaac-sim/kit/exts/omni.kit.window.cursor/omni/kit/window/cursor/cursor.py(27): on_startup
/isaac-sim/kit/plugins/bindings-python/omni/ext/impl/_internal.py(141): _startup_ext
/isaac-sim/kit/plugins/bindings-python/omni/ext/impl/_internal.py(174): startup_all_extensions_in_module
/isaac-sim/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-11-11 17:31:54 [1,107,914ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.cursor-1.0.1] Failed to process python module extension in ‘/isaac-sim/kit/exts/omni.kit.window.cursor/.’.
Checking if ROS_MASTER_URI is set:
ROS_MASTER_URI not set, using default, ROS_MASTER_URI= http://localhost:11311
2021-11-11 17:31:54 [1,107,944ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.graph.examples.python-1.0.0] (order: 0) Triggered by: omni.isaac.sim.base-2021.1.1
2021-11-11 17:31:54 [1,107,944ms] [Info] [omni.kit.app.plugin] [1107.960s] [ext: omni.graph.examples.python-1.0.0] startup
2021-11-11 17:31:55 [1,108,006ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.AbsDouble (version 1)
2021-11-11 17:31:55 [1,108,009ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.PositionToColor (version 1)
2021-11-11 17:31:55 [1,108,011ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.DeformerYAxis (version 1)
2021-11-11 17:31:55 [1,108,013ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.MultDouble (version 1)
2021-11-11 17:31:55 [1,108,015ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.DecomposeDouble3 (version 1)
2021-11-11 17:31:55 [1,108,018ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.ClampDouble (version 1)
2021-11-11 17:31:55 [1,108,020ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.SubtractDouble (version 1)
2021-11-11 17:31:55 [1,108,022ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.ComposeDouble3 (version 1)
2021-11-11 17:31:55 [1,108,024ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.IntCounter (version 1)
2021-11-11 17:31:55 [1,108,027ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.CountTo (version 1)
2021-11-11 17:31:55 [1,108,030ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.DeformerPy (version 1)
2021-11-11 17:31:55 [1,108,035ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.DeformerPyGpu (version 1)
2021-11-11 17:31:55 [1,108,037ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.VersionedDeformerPy (version 1)
2021-11-11 17:31:55 [1,108,039ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.TestInitNode (version 1)
2021-11-11 17:31:55 [1,108,042ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.BouncingCubes (version 1)
2021-11-11 17:31:55 [1,108,044ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.BouncingCubesGpu (version 1)
2021-11-11 17:31:55 [1,108,046ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.DynamicSwitch (version 1)
2021-11-11 17:31:55 [1,108,155ms] [Info] [omni.graph.core.plugin] Creating unregistered node type omni.graph.examples.python.UniversalAdd (version 1)
2021-11-11 17:31:55 [1,108,159ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.isaac.ros_bridge-0.1.0] (order: 0) Triggered by: omni.isaac.sim.base-2021.1.1
2021-11-11 17:31:55 [1,108,159ms] [Info] [omni.kit.app.plugin] [1108.175s] [ext: omni.isaac.ros_bridge-0.1.0] startup
2021-11-11 17:31:55 [1,108,159ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/isaac-sim/exts/omni.isaac.ros_bridge/bin’ Filename: ‘*.plugin’
2021-11-11 17:31:55 [1,108,171ms] [Info] [carb] Registered plugin: omni.isaac.ros_bridge.plugin (interfaces: [omni::isaac::ros_bridge::RosBridge v0.1]) (impl: omni.isaac.ros_bridge.plugin)
2021-11-11 17:31:55 [1,108,183ms] [Info] [carb.python] [py stdout]: Checking if ROS_MASTER_URI is set:
2021-11-11 17:31:55 [1,108,183ms] [Info] [carb.python] [py stdout]: ROS_MASTER_URI not set, using default, ROS_MASTER_URI= http://localhost:11311
2021-11-11 17:31:55 [1,108,183ms] [Info] [carb] Initializing plugin: omni.isaac.ros_bridge.2021-11-11 17:31:56 [1,109,162ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.crashreporter-breakpad.plugin.so!_init
2021-11-11 17:31:55 [1,108,183ms] [Info] [omni.isaac.ros_bridge.plugin] ros::init()
2021-11-11 17:31:55 [1,108,188ms] [Info] [omni.isaac.ros_bridge.plugin] ROS will use simulation time for publishers
2021-11-11 17:31:55 [1,108,455ms] [Info] [carb.python] [/isaac-sim/exts/omni.isaac.ros_bridge/noetic/lib/python3/dist-packages/rospy/topics.py:1132] topicmanager initialized
2021-11-11 17:31:55 [1,108,476ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.livestream.core-0.0.0] (order: 0) Triggered by: omni.isaac.sim.headless.base-2021.1.1, omni.kit.livestream.websocket-1.0.3
2021-11-11 17:31:55 [1,108,476ms] [Info] [omni.kit.app.plugin] [1108.492s] [ext: omni.kit.livestream.core-0.0.0] startup
2021-11-11 17:31:55 [1,108,476ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/isaac-sim/kit/extscore/omni.kit.livestream.core/bin/linux-x86_64/release’ Filename: ‘*.plugin’
2021-11-11 17:31:55 [1,108,477ms] [Info] [carb] Registered plugin: omni.kit.livestream.plugin (interfaces: [omni::kit::livestream::ILivestream v0.1]) (impl: omni.kit.livestream.plugin)
2021-11-11 17:31:55 [1,108,489ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.window.stats-0.0.0] (order: 1000) Triggered by: omni.isaac.sim.base-2021.1.1
2021-11-11 17:31:55 [1,108,489ms] [Info] [omni.kit.app.plugin] [1108.505s] [ext: omni.kit.window.stats-0.0.0] startup
2021-11-11 17:31:55 [1,108,503ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.isaac.app.setup-0.0.0] (order: 1000) Triggered by: omni.isaac.sim.base-2021.1.1
2021-11-11 17:31:55 [1,108,503ms] [Info] [omni.kit.app.plugin] [1108.519s] [ext: omni.isaac.app.setup-0.0.0] startup
2021-11-11 17:31:55 [1,108,517ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.isaac.sim.base-2021.1.1] (order: 0) Triggered by: omni.isaac.sim.headless.base-2021.1.1
2021-11-11 17:31:55 [1,108,517ms] [Info] [omni.kit.app.plugin] [1108.533s] [ext: omni.isaac.sim.base-2021.1.1] startup
2021-11-11 17:31:55 [1,108,517ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.livestream.websocket-1.0.3] (order: 0) Triggered by: omni.services.streamclient.websocket-1.1.2
2021-11-11 17:31:55 [1,108,517ms] [Info] [omni.kit.app.plugin] [1108.533s] [ext: omni.kit.livestream.websocket-1.0.3] startup
2021-11-11 17:31:55 [1,108,517ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/isaac-sim/exts/omni.kit.livestream.websocket-1.0.3+lx64.r.cp37/plugins’ Filename: ‘omni.livestream-websocket.plugin’
2021-11-11 17:31:55 [1,108,518ms] [Info] [carb] Registered plugin: omni.livestream-websocket.plugin (interfaces: [carb::livestream::Vision v0.3]) (impl: omni.livestream-websocket.plugin)
2021-11-11 17:31:55 [1,108,529ms] [Info] [carb.python] Starting up the websocket livestream server
2021-11-11 17:31:55 [1,108,529ms] [Info] [carb] Initializing plugin: omni.kit.livestream.plugin (interfaces: [omni::kit::livestream::ILivestream v0.1]) (impl: omni.kit.livestream.plugin)
2021-11-11 17:31:55 [1,108,539ms] [Info] [carb] Initializing plugin: omni.livestream-websocket.plugin (interfaces: [carb::livestream::Vision v0.3]) (impl: omni.livestream-websocket.plugin)
2021-11-11 17:31:55 [1,108,539ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [carb::imgui::ImGui v1.0] (plugin: (null)), by client: omni.livestream-websocket.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2021-11-11 17:31:56 [1,109,171ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!std::rethrow_exception(std::__exception_ptr::exception_ptr)
2021-11-11 17:31:56 [1,109,181ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__cxa_throw_bad_array_new_length
2021-11-11 17:31:56 [1,109,190ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__gxx_personality_v0
2021-11-11 17:31:56 [1,109,199ms] [Fatal] [carb.crashreporter-breakpad.plugin] libgcc_s.so.1!_Unwind_GetTextRelBase
2021-11-11 17:31:56 [1,109,209ms] [Fatal] [carb.crashreporter-breakpad.plugin] libgcc_s.so.1!_Unwind_RaiseException
2021-11-11 17:31:56 [1,109,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__cxa_throw
2021-11-11 17:31:56 [1,109,218ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!carbOnPluginShutdown
2021-11-11 17:31:56 [1,109,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!std::istreambuf_iterator<char, std::char_traits >::equal(std::istreambuf_iterator<char, std::char_traits > const&) const
2021-11-11 17:31:56 [1,109,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!std::ctype::do_widen(char) const
2021-11-11 17:31:56 [1,109,228ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!std::error_code::default_error_condition() const
2021-11-11 17:31:56 [1,109,237ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!start_thread
2021-11-11 17:31:56 [1,109,247ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!clone
terminate called after throwing an instance of ‘websocketpp::exception’
what(): Underlying Transport Error
2021-11-11 17:31:56 [1,109,419ms] [Error] [carb.crashreporter-breakpad.plugin] failed to write .dmp to: ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2021.1/1ef56a05-a5c0-4917-74274eb7-4f643f20.dmp’
2021-11-11 17:31:56 [1,109,429ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-11-11 17:31:56 [1,109,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!gsignal
2021-11-11 17:31:56 [1,109,448ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!abort
2021-11-11 17:31:56 [1,109,458ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!+0x8c957
2021-11-11 17:31:56 [1,109,467ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.crashreporter-breakpad.plugin.so!_init
2021-11-11 17:31:56 [1,109,476ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!std::rethrow_exception(std::__exception_ptr::exception_ptr)
2021-11-11 17:31:56 [1,109,485ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__cxa_throw_bad_array_new_length
2021-11-11 17:31:56 [1,109,495ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__gxx_personality_v0
2021-11-11 17:31:56 [1,109,504ms] [Fatal] [carb.crashreporter-breakpad.plugin] libgcc_s.so.1!_Unwind_GetTextRelBase
2021-11-11 17:31:56 [1,109,513ms] [Fatal] [carb.crashreporter-breakpad.plugin] libgcc_s.so.1!_Unwind_RaiseException
2021-11-11 17:31:56 [1,109,523ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!__cxa_throw
2021-11-11 17:31:56 [1,109,524ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!carbOnPluginShutdown
2021-11-11 17:31:56 [1,109,524ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!std::istreambuf_iterator<char, std::char_traits >::equal(std::istreambuf_iterator<char, std::char_traits > const&) const
2021-11-11 17:31:56 [1,109,525ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.livestream-websocket.plugin.so!std::ctype::do_widen(char) const
2021-11-11 17:31:56 [1,109,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!std::error_code::default_error_condition() const
2021-11-11 17:31:56 [1,109,551ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!start_thread
2021-11-11 17:31:56 [1,109,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!clone
Aborted (core dumped)
Have you tried installing the 470.x drivers?
has not yet , i will try it right now
