Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
| NVIDIA-SMI 545.23.08 Driver Version: 545.23.08 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX 6000 Ada Gene… On | 00000000:01:00.0 Off | Off |
| 30% 38C P2 71W / 300W | 21990MiB / 49140MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX 6000 Ada Gene… On | 00000000:21:00.0 Off | Off |
| 30% 28C P8 21W / 300W | 33600MiB / 49140MiB | 0% Default |
| | | N/A |
| 2 NVIDIA RTX 6000 Ada Gene… On | 00000000:41:00.0 Off | Off |
| 30% 29C P8 32W / 300W | 20493MiB / 49140MiB | 0% Default |
| | | N/A |
| 3 NVIDIA RTX 6000 Ada Gene… On | 00000000:61:00.0 Off | Off |
| 30% 28C P8 28W / 300W | 8MiB / 49140MiB | 0% Default |
| | | N/A |
| 4 NVIDIA RTX 6000 Ada Gene… On | 00000000:81:00.0 Off | Off |
| 30% 48C P2 167W / 300W | 6378MiB / 49140MiB | 55% Default |
| | | N/A |
| 5 NVIDIA RTX 6000 Ada Gene… On | 00000000:A1:00.0 Off | Off |
| 30% 28C P8 26W / 300W | 8MiB / 49140MiB | 0% Default |
| | | N/A |
| 6 NVIDIA RTX 6000 Ada Gene… On | 00000000:C1:00.0 Off | Off |
| 30% 28C P8 22W / 300W | 8MiB / 49140MiB | 0% Default |
| | | N/A |
| 7 NVIDIA RTX 6000 Ada Gene… On | 00000000:E1:00.0 Off | Off |
| 30% 27C P8 29W / 300W | 8MiB / 49140MiB | 0% Default |
| | | N/A |
Topic Description
I’m trying to connect remote native streaming server (8 RTX 6000 Ada GPUs server) via Omniverse Streaming Client.
When I click to connect, the Client crashed and error happened as following.
It seems like something about remote GUI should be install in the server machine?
I’m running OmniGibson which is built upon Isaacsim so they should have the same underlying
Before I just successfully ran the the same streaming setting and got perfect remote visualization in a single RTX4090 workstation, but when I tried to copy this to lab server, it failed as decription.
Detailed Description
~/proj/OmniGibson$ python OG_streaming.py
[INFO] [omnigibson.simulator] ----- Starting OmniGibson. This will take 10-30 seconds... -----
Starting kit application with the following args: ['/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/isaacsim/apps/omnigibson_4_1_0.kit', '--/app/tokens/exe-path=/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/omni', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=False', '--/app/fastShutdown=True', '--ext-folder', '/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/isaacsim/exts', '--ext-folder', '/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/isaacsim/apps', '--/physics/cudaDevice=0', '--portable', '--no-window', '--/app/window/hideUi=1']
Passing the following args to the base kit application: []
Loading user config located at: '/home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.1/user.config.json'
[Info] [carb] Logging to file: /home/vla-reasoning/miniconda3/envs/omnigibson/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.1/kit_20250414_173110.log
2025-04-15 00:31:11 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.259s] [ext: omni.kit.async_engine-0.0.0] startup
[DEBUG] [asyncio] Using selector: EpollSelector
[0.477s] [ext: omni.stats-1.0.1] startup
[0.480s] [ext: omni.client-1.1.0] startup
[0.514s] [ext: omni.datastore-0.0.0] startup
[0.515s] [ext: omni.blobkey-1.1.0] startup
[0.515s] [ext: omni.ujitso.default-1.0.0] startup
[0.516s] [ext: omni.hsscclient-0.0.0] startup
[0.517s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.518s] [ext: omni.assets.plugins-0.0.0] startup
[0.521s] [ext: omni.gpu_foundation-0.0.0] startup
[0.533s] [ext: carb.windowing.plugins-1.0.0] startup
2025-04-15 00:31:11 [453ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:11 [453ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[0.535s] [ext: omni.kit.renderer.init-0.0.0] startup
2025-04-15 00:31:11 [590ms] [Warning] [omni.platforminfo.plugin] failed to open the default display. Can't verify X Server version.
2025-04-15 00:31:12 [1,243ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:12 [1,243ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2025-04-15 00:31:12 [1,244ms] [Error] [carb.glinterop.plugin] GLInteropContext::init: carb::windowing is not available
| Driver Version: 545.23.08 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA RTX 6000 Ada Generation | Yes: 0 | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 9be33fd1.. |
| | | | | | 1 | |
| 1 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | aa340032.. |
| | | | | | 21 | |
| 2 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | f439cca8.. |
| | | | | | 41 | |
| 3 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 5d61f1bc.. |
| | | | | | 61 | |
| 4 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 379470db.. |
| | | | | | 81 | |
| 5 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 5357dc5f.. |
| | | | | | a1 | |
| 6 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 3b36edea.. |
| | | | | | c1 | |
| 7 | NVIDIA RTX 6000 Ada Generation | | | 49386 MB | 10de | 0 |
| | | | | | 26b1 | 3719bd35.. |
| | | | | | e1 | |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 5.15.0-130-generic
| Processor: AMD EPYC 9254 24-Core Processor | Cores: 48 | Logical: 96
| Total Memory (MB): 773768 | Free Memory: 709381
| Total Page/Swap (MB): 18431 | Free Page/Swap: 16880
[4.764s] [ext: omni.kit.pipapi-0.0.0] startup
[4.767s] [ext: omni.kit.pip_archive-0.0.0] startup
[4.768s] [ext: omni.mtlx-0.1.0] startup
[4.771s] [ext: omni.usd.config-1.0.4] startup
[4.784s] [ext: omni.gpucompute.plugins-0.0.0] startup
[4.788s] [ext: omni.usd.libs-1.0.1] startup
[5.062s] [ext: omni.kit.telemetry-0.5.0] startup
[INFO] [omni.kit.telemetry.impl.sentry_extension] sentry is disabled for external build
[5.154s] [ext: omni.kit.loop-isaac-1.2.0] startup
[5.158s] [ext: omni.kit.test-0.0.0] startup
[5.222s] [ext: omni.appwindow-1.1.8] startup
2025-04-15 00:31:16 [5,145ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,145ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[5.236s] [ext: omni.kit.renderer.core-1.0.1] startup
2025-04-15 00:31:16 [5,161ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,161ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2025-04-15 00:31:16 [5,182ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,182ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[5.269s] [ext: omni.kit.renderer.capture-0.0.0] startup
[5.275s] [ext: omni.kit.renderer.imgui-1.0.1] startup
2025-04-15 00:31:16 [5,202ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,202ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2025-04-15 00:31:16 [5,204ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,204ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2025-04-15 00:31:16 [5,205ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:16 [5,205ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[5.635s] [ext: omni.ui-2.23.11] startup
[5.682s] [ext: omni.kit.mainwindow-1.0.3] startup
[5.689s] [ext: carb.audio-0.1.0] startup
[5.729s] [ext: omni.uiaudio-1.0.0] startup
[5.731s] [ext: omni.kit.uiapp-0.0.0] startup
[5.732s] [ext: omni.usd.schema.audio-0.0.0] startup
[5.877s] [ext: omni.usd.schema.physx-106.0.20] startup
[5.940s] [ext: omni.usd.schema.forcefield-106.0.20] startup
[5.949s] [ext: omni.usd.schema.anim-0.0.0] startup
[5.979s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[5.999s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[6.017s] [ext: omni.anim.graph.schema-106.0.2] startup
[6.026s] [ext: omni.anim.navigation.schema-106.0.2] startup
[6.031s] [ext: omni.usd.schema.isaac-2.1.0] startup
[6.042s] [ext: omni.usd.schema.semantics-0.0.0] startup
[6.047s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[6.051s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[6.053s] [ext: omni.graph.exec-0.9.3] startup
[6.054s] [ext: omni.usd_resolver-1.0.0] startup
[6.066s] [ext: omni.activity.core-1.0.1] startup
[6.072s] [ext: omni.kit.usd_undo-0.1.8] startup
[6.075s] [ext: omni.kit.exec.core-0.13.2] startup
[6.079s] [ext: omni.usd.core-1.2.11] startup
[6.087s] [ext: omni.kit.actions.core-1.0.0] startup
[6.091s] [ext: omni.resourcemonitor-105.0.1] startup
[6.096s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[6.104s] [ext: omni.timeline-1.0.10] startup
[6.110s] [ext: omni.kit.commands-1.4.9] startup
[6.118s] [ext: usdrt.scenegraph-7.4.8] startup
[6.177s] [ext: omni.kit.widget.nucleus_connector-1.1.8] startup
[6.181s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[6.183s] [ext: omni.hydra.usdrt_delegate-7.4.7] startup
[6.227s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[6.242s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[6.246s] [ext: omni.usd-1.11.2] startup
[6.303s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[6.307s] [ext: omni.kit.usd.layers-2.1.31] startup
[6.321s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[6.326s] [ext: omni.kit.window.cursor-1.1.2] startup
[6.331s] [ext: omni.kit.menu.utils-1.5.27] startup
[6.360s] [ext: omni.iray.libs-0.0.0] startup
[6.373s] [ext: omni.kit.primitive.mesh-1.0.16] startup
[6.382s] [ext: omni.mdl.neuraylib-0.2.5] startup
[6.386s] [ext: omni.hydra.engine.stats-1.0.2] startup
[6.396s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[6.399s] [ext: omni.kit.widget.path_field-2.0.9] startup
[6.402s] [ext: omni.kit.clipboard-1.0.3] startup
[6.406s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[6.407s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[6.409s] [ext: omni.kit.notification_manager-1.0.8] startup
[6.412s] [ext: omni.volume-0.5.0] startup
[6.418s] [ext: omni.ujitso.client-0.0.0] startup
[6.418s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[6.420s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[6.420s] [ext: omni.kit.widget.filebrowser-2.10.48] startup
[6.426s] [ext: omni.kit.search_core-1.0.5] startup
[6.429s] [ext: omni.kit.widget.options_menu-1.1.4] startup
[6.431s] [ext: omni.ui.scene-1.9.3] startup
[6.442s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[6.444s] [ext: omni.kit.widget.options_button-1.0.2] startup
[6.447s] [ext: omni.kit.widget.context_menu-1.2.1] startup
[6.449s] [ext: omni.kit.hotkeys.core-1.3.3] startup
[6.451s] [ext: omni.kit.window.filepicker-2.10.34] startup
[6.462s] [ext: omni.hydra.rtx-0.2.0] startup
[6.497s] [ext: omni.kit.context_menu-1.8.0] startup
[6.499s] [ext: omni.mdl-52.0.1] startup
[6.525s] [ext: omni.kit.window.file_importer-1.1.11] startup
[6.528s] [ext: omni.kit.raycast.query-1.0.5] startup
[6.558s] [ext: omni.kit.viewport.registry-104.0.6] startup
[6.563s] [ext: omni.kit.viewport.legacy_gizmos-1.0.15] startup
[6.573s] [ext: omni.kit.material.library-1.4.4] startup
[6.581s] [ext: omni.kit.window.file_exporter-1.0.29] startup
[6.582s] [ext: omni.kit.hydra_texture-1.2.6] startup
[6.594s] [ext: omni.kit.window.drop_support-1.0.2] startup
[6.595s] [ext: omni.kit.widget.viewport-106.0.3] startup
[6.606s] [ext: omni.kit.widget.filter-1.1.4] startup
[6.612s] [ext: omni.kit.viewport.window-106.0.8] startup
[6.634s] [ext: omni.kit.widget.settings-1.1.1] startup
[6.638s] [ext: omni.kit.widget.prompt-1.0.7] startup
[6.639s] [ext: omni.kit.viewport.utility-1.0.17] startup
[6.641s] [ext: omni.kit.window.preferences-1.5.3] startup
[6.675s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[6.685s] [ext: omni.kit.viewport.actions-106.0.3] startup
[6.695s] [ext: omni.kit.widget.stage-2.10.26] startup
[6.715s] [ext: omni.kit.stage_template.core-1.1.21] startup
[6.718s] [ext: omni.kit.widget.live_session_management-1.2.18] startup
[6.721s] [ext: omni.kit.viewport.menubar.core-106.0.2] startup
[6.745s] [ext: omni.kit.manipulator.transform-104.7.5] startup
[6.749s] [ext: omni.kit.stage_templates-1.2.3] startup
[6.753s] [ext: omni.debugdraw-0.1.3] startup
[6.768s] [ext: omni.kit.viewport.menubar.display-106.0.2] startup
[6.775s] [ext: omni.kvdb-106.0.20] startup
[6.777s] [ext: omni.inspect-1.0.1] startup
[6.779s] [ext: omni.kit.window.file-1.3.52] startup
[6.782s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[6.782s] [ext: omni.usdphysics-106.0.20] startup
[6.789s] [ext: omni.convexdecomposition-106.0.20] startup
[6.796s] [ext: omni.kit.window.content_browser-2.9.14] startup
[6.811s] [ext: omni.usdphysics.ui-106.0.20] startup
[6.850s] [ext: omni.localcache-106.0.20] startup
[6.852s] [ext: omni.physx.foundation-106.0.20] startup
[6.853s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[6.854s] [ext: omni.graph.core-2.170.3] startup
[6.859s] [ext: omni.kit.widget.searchfield-1.1.6] startup
[6.860s] [ext: omni.physx.cooking-106.0.20] startup
[6.882s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[6.885s] [ext: omni.graph.image.core-0.3.2] startup
[6.898s] [ext: omni.kit.window.property-1.11.1] startup
[6.900s] [ext: omni.physx-106.0.20] startup
[6.930s] [ext: omni.kit.widget.toolbar-1.6.2] startup
[6.943s] [ext: omni.kit.property.usd-3.21.28] startup
[6.963s] [ext: omni.physx.stageupdate-106.0.20] startup
[6.966s] [ext: omni.physx.commands-106.0.20] startup
[6.980s] [ext: omni.kit.manipulator.tool.snap-1.4.5] startup
[6.989s] [ext: omni.graph.tools-1.78.0] startup
[DEBUG] [AutoNode] Defining data type 'any' as 'Any'
[DEBUG] [AutoNode] Defining data type 'bool' as 'Bool' and array 'BoolArray
[DEBUG] [AutoNode] Defining data type 'bundle' as 'Bundle'
[DEBUG] [AutoNode] Defining data type 'colord[3]' as 'Color3d' and array 'Color3dArray
[DEBUG] [AutoNode] Defining data type 'colorf[3]' as 'Color3f' and array 'Color3fArray
[DEBUG] [AutoNode] Defining data type 'colorh[3]' as 'Color3h' and array 'Color3hArray
[DEBUG] [AutoNode] Defining data type 'colord[4]' as 'Color4d' and array 'Color4dArray
[DEBUG] [AutoNode] Defining data type 'colorf[4]' as 'Color4f' and array 'Color4fArray
[DEBUG] [AutoNode] Defining data type 'colorh[4]' as 'Color4h' and array 'Color4hArray
[DEBUG] [AutoNode] Defining data type 'double' as 'Double' and array 'DoubleArray
[DEBUG] [AutoNode] Defining data type 'double[2]' as 'Double2' and array 'Double2Array
[DEBUG] [AutoNode] Defining data type 'double[3]' as 'Double3' and array 'Double3Array
[DEBUG] [AutoNode] Defining data type 'double[4]' as 'Double4' and array 'Double4Array
[DEBUG] [AutoNode] Defining data type 'execution' as 'Execution'
[DEBUG] [AutoNode] Defining data type 'float' as 'Float' and array 'FloatArray
[DEBUG] [AutoNode] Defining data type 'float[2]' as 'Float2' and array 'Float2Array
[DEBUG] [AutoNode] Defining data type 'float[3]' as 'Float3' and array 'Float3Array
[DEBUG] [AutoNode] Defining data type 'float[4]' as 'Float4' and array 'Float4Array
[DEBUG] [AutoNode] Defining data type 'frame[4]' as 'Frame' and array 'FrameArray
[DEBUG] [AutoNode] Defining data type 'half' as 'Half' and array 'HalfArray
[DEBUG] [AutoNode] Defining data type 'half[2]' as 'Half2' and array 'Half2Array
[DEBUG] [AutoNode] Defining data type 'half[3]' as 'Half3' and array 'Half3Array
[DEBUG] [AutoNode] Defining data type 'half[4]' as 'Half4' and array 'Half4Array
[DEBUG] [AutoNode] Defining data type 'int' as 'Int' and array 'IntArray
[DEBUG] [AutoNode] Defining data type 'int[2]' as 'Int2' and array 'Int2Array
[DEBUG] [AutoNode] Defining data type 'int[3]' as 'Int3' and array 'Int3Array
[DEBUG] [AutoNode] Defining data type 'int[4]' as 'Int4' and array 'Int4Array
[DEBUG] [AutoNode] Defining data type 'int64' as 'Int64' and array 'Int64Array
[DEBUG] [AutoNode] Defining data type 'matrixd[2]' as 'Matrix2d' and array 'Matrix2dArray
[DEBUG] [AutoNode] Defining data type 'matrixd[3]' as 'Matrix3d' and array 'Matrix3dArray
[DEBUG] [AutoNode] Defining data type 'matrixd[4]' as 'Matrix4d' and array 'Matrix4dArray
[DEBUG] [AutoNode] Defining data type 'normald[3]' as 'Normal3d' and array 'Normal3dArray
[DEBUG] [AutoNode] Defining data type 'normalf[3]' as 'Normal3f' and array 'Normal3fArray
[DEBUG] [AutoNode] Defining data type 'normalh[3]' as 'Normal3h' and array 'Normal3hArray
[DEBUG] [AutoNode] Defining data type 'objectId' as 'ObjectId' and array 'ObjectIdArray
[DEBUG] [AutoNode] Defining data type 'path' as 'Path'
[DEBUG] [AutoNode] Defining data type 'pointd[3]' as 'Point3d' and array 'Point3dArray
[DEBUG] [AutoNode] Defining data type 'pointf[3]' as 'Point3f' and array 'Point3fArray
[DEBUG] [AutoNode] Defining data type 'pointh[3]' as 'Point3h' and array 'Point3hArray
[DEBUG] [AutoNode] Defining data type 'quatd[4]' as 'Quatd' and array 'QuatdArray
[DEBUG] [AutoNode] Defining data type 'quatf[4]' as 'Quatf' and array 'QuatfArray
[DEBUG] [AutoNode] Defining data type 'quath[4]' as 'Quath' and array 'QuathArray
[DEBUG] [AutoNode] Defining data type 'string' as 'String'
[DEBUG] [AutoNode] Defining data type 'target' as 'Target'
[DEBUG] [AutoNode] Defining data type 'texcoordd[2]' as 'TexCoord2d' and array 'TexCoord2dArray
[DEBUG] [AutoNode] Defining data type 'texcoordf[2]' as 'TexCoord2f' and array 'TexCoord2fArray
[DEBUG] [AutoNode] Defining data type 'texcoordh[2]' as 'TexCoord2h' and array 'TexCoord2hArray
[DEBUG] [AutoNode] Defining data type 'texcoordd[3]' as 'TexCoord3d' and array 'TexCoord3dArray
[DEBUG] [AutoNode] Defining data type 'texcoordf[3]' as 'TexCoord3f' and array 'TexCoord3fArray
[DEBUG] [AutoNode] Defining data type 'texcoordh[3]' as 'TexCoord3h' and array 'TexCoord3hArray
[DEBUG] [AutoNode] Defining data type 'timecode' as 'Timecode' and array 'TimecodeArray
[DEBUG] [AutoNode] Defining data type 'token' as 'Token' and array 'TokenArray
[DEBUG] [AutoNode] Defining data type 'uchar' as 'UChar' and array 'UCharArray
[DEBUG] [AutoNode] Defining data type 'uint' as 'UInt' and array 'UIntArray
[DEBUG] [AutoNode] Defining data type 'uint64' as 'UInt64' and array 'UInt64Array
[DEBUG] [AutoNode] Defining data type 'vectord[3]' as 'Vector3d' and array 'Vector3dArray
[DEBUG] [AutoNode] Defining data type 'vectorf[3]' as 'Vector3f' and array 'Vector3fArray
[DEBUG] [AutoNode] Defining data type 'vectorh[3]' as 'Vector3h' and array 'Vector3hArray
[7.021s] [ext: omni.physx.ui-106.0.20] startup
[7.065s] [ext: omni.graph-1.135.0] startup
[7.116s] [ext: omni.physx.demos-106.0.20] startup
[7.146s] [ext: omni.graph.image.nodes-1.0.2] startup
[7.155s] [ext: omni.graph.action_core-1.1.4] startup
[7.178s] [ext: omni.isaac.version-1.1.0] startup
[7.182s] [ext: omni.syntheticdata-0.6.7] startup
[7.211s] [ext: omni.physx.graph-106.0.20] startup
[7.243s] [ext: omni.isaac.nucleus-0.3.0] startup
[7.247s] [ext: omni.physx.telemetry-106.0.20] startup
[7.253s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[7.278s] [ext: omni.ui_query-1.1.2] startup
[7.288s] [ext: omni.kit.widget.graph-1.12.8] startup
[7.304s] [ext: omni.kit.property.material-1.9.4] startup
[7.310s] [ext: omni.kit.window.extensions-1.4.9] startup
[7.332s] [ext: omni.kit.property.physx-106.0.20] startup
[7.524s] [ext: omni.graph.ui-1.70.0] startup
[7.557s] [ext: omni.physx.vehicle-106.0.20] startup
[7.588s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[7.591s] [ext: omni.kit.viewport.manipulator.transform-106.0.1] startup
[7.596s] [ext: omni.kit.ui_test-1.2.18] startup
[7.598s] [ext: omni.graph.action_nodes-1.23.0] startup
[7.615s] [ext: omni.physx.camera-106.0.20] startup
[7.639s] [ext: omni.fabric.commands-1.1.4] startup
[7.656s] [ext: omni.kit.manipulator.prim.core-107.0.3] startup
[7.668s] [ext: omni.physx.cct-106.0.20] startup
[7.692s] [ext: omni.graph.action-1.102.1] startup
[7.699s] [ext: omni.graph.nodes-1.143.0] startup
Warning: Possible version incompatibility. Attempting to load omni::fabric::IPath with version v0.2 against v0.1.
[7.727s] [ext: omni.graph.ui_nodes-1.25.1] startup
[7.783s] [ext: omni.kit.manipulator.prim.fabric-106.0.1] startup
[7.792s] [ext: omni.physics.tensors-106.0.20] startup
[7.865s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[7.866s] [ext: omni.kit.manipulator.prim.usd-106.0.1] startup
[7.885s] [ext: omni.graph.bundle.action-2.0.4] startup
[7.889s] [ext: omni.command.usd-1.0.3] startup
[7.904s] [ext: omni.physx.tensors-106.0.20] startup
[7.941s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[7.960s] [ext: omni.kit.manipulator.prim-106.0.0] startup
[7.961s] [ext: omni.kit.manipulator.selection-104.0.9] startup
[7.980s] [ext: omni.kit.widget.layers-1.7.9] startup
[8.137s] [ext: omni.kit.window.toolbar-1.6.1] startup
[8.161s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[8.173s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[8.195s] [ext: omni.physx.supportui-106.0.20] startup
[8.235s] [ext: omni.warp.core-1.2.1] startup
[8.365s] [ext: omni.kit.window.material_graph-1.8.15] startup
[8.655s] [ext: omni.kit.numpy.common-0.1.2] startup
[8.662s] [ext: omni.warp-1.2.1] startup
[8.669s] [ext: omni.sensors.tiled-0.0.4] startup
[8.683s] [ext: omni.physx.bundle-106.0.20] startup
[8.695s] [ext: omni.graph.scriptnode-1.19.1] startup
[8.702s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[8.744s] [ext: omni.replicator.core-1.11.14] startup
2025-04-15 00:31:19 [8,752ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
CUDA Toolkit 11.8, Driver 12.3
Devices:
"cpu" : "x86_64"
"cuda:0" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:1" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:2" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:3" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:4" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:5" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:6" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
"cuda:7" : "NVIDIA RTX 6000 Ada Generation" (47 GiB, sm_89, mempool enabled)
CUDA peer access:
Supported fully (all-directional)
Kernel cache:
/home/vla-reasoning/.cache/warp/1.2.1
[9.124s] [ext: omni.isaac.core-3.18.1] startup
[9.514s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[9.525s] [ext: omni.isaac.core_nodes-1.16.1] startup
[9.554s] [ext: omni.isaac.cloner-0.8.1] startup
[9.556s] [ext: omni.isaac.ui-0.16.0] startup
[9.571s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[9.593s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[9.597s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[9.613s] [ext: omni.isaac.gym-0.11.3] startup
[9.634s] [ext: omni.graph.window.core-1.109.0] startup
[9.659s] [ext: omni.isaac.debug_draw-1.1.0] startup
[9.685s] [ext: omni.isaac.block_world-1.0.0] startup
[9.718s] [ext: omni.graph.window.generic-1.24.0] startup
[9.736s] [ext: omni.isaac.menu-0.5.0] startup
[9.743s] [ext: omni.isaac.occupancy_map-1.0.2] startup
[9.803s] [ext: omni.importer.mjcf-1.1.1] startup
[9.851s] [ext: omni.graph.window.action-1.26.0] startup
[9.874s] [ext: omni.kit.widget.calendar-1.0.8] startup
[9.881s] [ext: omni.kit.actions.window-1.1.1] startup
[9.892s] [ext: omni.sensors.nv.common-1.2.2-isaac] startup
[9.946s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[9.967s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[9.972s] [ext: omni.kit.selection-0.1.4] startup
[9.974s] [ext: omni.sensors.nv.materials-1.2.1-isaac] startup
[9.980s] [ext: omni.isaac.kit-1.13.0] startup
[9.980s] [ext: omni.kit.menu.create-1.0.13] startup
[9.983s] [ext: omni.kit.menu.edit-1.1.24] startup
[9.986s] [ext: omni.isaac.range_sensor-3.1.1] startup
[10.007s] [ext: omni.sensors.nv.lidar-1.2.2-isaac] startup
[10.017s] [ext: omni.sensors.nv.wpm-1.2.1-isaac] startup
[10.021s] [ext: omni.kit.property.audio-1.0.11] startup
[10.024s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[10.026s] [ext: omni.kit.property.geometry-1.3.0] startup
[10.034s] [ext: omni.kit.property.camera-1.0.6] startup
[10.038s] [ext: omni.sensors.nv.radar-1.2.1-isaac] startup
[10.051s] [ext: omni.hydra.scene_api-0.1.2] startup
[10.068s] [ext: omni.kit.window.stage-2.5.10] startup
[10.075s] [ext: omni.kit.property.render-1.1.1] startup
[10.079s] [ext: omni.kit.property.light-1.0.8] startup
[10.082s] [ext: omni.kit.menu.file-1.1.10] startup
[10.088s] [ext: omni.kit.property.transform-1.5.1] startup
[10.099s] [ext: omni.kit.menu.stage-1.2.5] startup
[10.103s] [ext: omni.kit.profiler.window-2.2.1] startup
[WARNING] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
2025-04-15 00:31:21 [10,075ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
[10.166s] [ext: omni.kit.property.bundle-1.2.11] startup
[10.171s] [ext: omni.isaac.sensor-12.7.1] startup
[10.276s] [ext: omni.kit.property.layer-1.1.6] startup
[10.301s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[10.319s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[10.327s] [ext: omni.isaac.scene_blox-0.1.2] startup
[10.345s] [ext: omni.isaac.quadruped-1.4.5] startup
[10.378s] [ext: omni.kit.viewport.menubar.camera-105.1.8] startup
[10.390s] [ext: omni.isaac.lula-3.0.1] startup
[10.413s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[10.425s] [ext: omni.kit.viewport.menubar.settings-106.0.1] startup
[10.435s] [ext: omni.kit.viewport.menubar.render-106.1.3] startup
[10.447s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[10.453s] [ext: omni.isaac.motion_generation-7.1.0] startup
[10.463s] [ext: omni.isaac.manipulators-2.1.0] startup
[10.466s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[10.469s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[10.480s] [ext: omni.isaac.universal_robots-0.3.5] startup
[10.492s] [ext: omni.kit.ui.actions-1.0.1] startup
[10.505s] [ext: omni.kit.widget.timeline-105.0.1] startup
[10.524s] [ext: omni.kit.window.commands-0.2.5] startup
[10.529s] [ext: omni.kit.window.console-0.2.12] startup
[10.560s] [ext: omni.kit.window.script_editor-1.7.6] startup
[10.568s] [ext: omni.kit.menu.common-1.1.5] startup
[10.573s] [ext: omni.kit.window.status_bar-0.1.6] startup
[10.588s] [ext: omni.rtx.window.settings-0.6.16] startup
[10.598s] [ext: omni.kit.window.title-1.1.3] startup
2025-04-15 00:31:21 [10,518ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:21 [10,518ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2025-04-15 00:31:21 [10,522ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2025-04-15 00:31:21 [10,523ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[10.608s] [ext: omni.isaac.franka-0.4.1] startup
[10.616s] [ext: omni.replicator.isaac-1.15.0] startup
[10.646s] [ext: omni.replicator.replicator_yaml-2.0.5] startup
[10.661s] [ext: omni.rtx.settings.core-0.6.0] startup
[10.679s] [ext: omni.kit.widget.live-2.1.6] startup
[10.688s] [ext: omni.isaac.cortex-0.3.8] startup
[10.701s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[10.701s] [ext: semantics.schema.editor-0.3.6] startup
[10.723s] [ext: semantics.schema.property-1.0.3] startup
[10.729s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
2025-04-15 00:31:21 [10,651ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File /home/vla-reasoning/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
[10.735s] [ext: omni.isaac.utils-1.0.1] startup
[10.747s] [ext: omni.isaac.cortex.sample_behaviors-1.0.5] startup
[10.753s] [ext: omni.importer.urdf-1.14.1] startup
[10.818s] [ext: omni.kit.window.stats-0.1.6] startup
[10.822s] [ext: omnigibson_4_1_0-4.1.0] startup
[10.827s] Simulation App Starting
[17.723s] app ready
2025-04-15 00:31:28 [17,878ms] [Warning] [omni.kit.imgui_renderer.plugin] _createExtendCursor: No windowing.
[19.526s] Simulation App Startup Complete
[19.792s] [ext: omni.usd.schema.flow-106.0.8] startup
[19.796s] [ext: omni.flowusd-106.0.15] startup
2025-04-15 00:31:30 [19,728ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[19.834s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[19.840s] [ext: omni.scene.visualization.core-105.4.13] startup
2025-04-15 00:31:30 [19,767ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[19.869s] [ext: omni.ramp-105.1.15] startup
[19.884s] [ext: omni.kit.browser.core-2.3.11] startup
[19.893s] [ext: omni.particle.system.core-105.1.6] startup
2025-04-15 00:31:30 [19,824ms] [Warning] [omni.particle.system.core.scripts.extension]
ATTENTION!: omni.particle.system.core is currently undergoing extensive (breaking) changes.
Please be aware that systems built with the existing extension will need to be rebuilt in
the USD Composer 2023.2 release.
[19.923s] [ext: omni.kit.browser.folder.core-1.9.12] startup
[19.934s] [ext: omni.particle.system.ui-105.1.10] startup
[20.122s] [ext: omni.graph.window.particle.system-105.1.18] startup
DYNAMICS_TODO:
Make sure "omni.particle.system.core2" is a proper dependency.
For now, it can just be set to autoload.
DYNAMICS_TODO:
[20.192s] [ext: omni.particle.system.bundle-105.1.0] startup
[20.213s] [ext: omni.anim.behavior.schema-106.0.1] startup
[20.235s] [ext: omni.kit.widget.imageview-1.0.3] startup
[20.243s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[20.251s] [ext: omni.genproc.core-105.1.9] startup
[20.309s] [ext: omni.curve.creator-105.0.4] startup
[20.320s] [ext: omni.anim.asset-106.0.3] startup
[20.340s] [ext: omni.anim.retarget.core-106.0.1] startup
[20.363s] [ext: omni.anim.graph.core-106.0.6] startup
2025-04-15 00:31:31 [20,328ms] [Warning] [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - 'NoneType' object is not subscriptable. Aborting Python node registration
[20.410s] [ext: omni.curve.manipulator-105.2.6] startup
[20.511s] [ext: omni.graph.io-1.9.1] startup
2025-04-15 00:31:31 [20,431ms] [Warning] [omni.graph.io._impl.extension] omni.graph.io is deprecated. Nodes in this extension have been moved to omni.graph.nodes. Update any dependencies accordingly.
[20.517s] [ext: omni.kit.browser.sample-1.4.7] startup
[20.625s] [ext: omni.anim.graph.ui-106.0.1] startup
[20.844s] [ext: omni.anim.graph.bundle-106.0.3] startup
[20.848s] [ext: omni.kit.quicklayout-1.0.7] startup
[20.941s] [ext: omni.anim.navigation.core-106.0.2] startup
[20.956s] [ext: omni.anim.navigation.ui-106.0.2] startup
[21.093s] [ext: omni.anim.navigation.bundle-106.0.1] startup
[21.095s] [ext: omni.anim.skelJoint-106.0.1] startup
[21.118s] [ext: omni.anim.retarget.ui-106.0.1] startup
[21.194s] [ext: omni.anim.retarget.bundle-106.0.1] startup
[21.199s] [ext: omni.kit.scripting-106.0.1] startup
[21.208s] [ext: omni.anim.people-0.4.1] startup
[21.270s] [ext: omni.anim.curve.core-1.1.13] startup
[21.322s] [ext: omni.anim.timeline-105.0.23] startup
[21.507s] [ext: omni.kit.streamsdk.plugins-3.2.1] startup
[21.521s] [ext: omni.kit.renderer.cuda_interop-1.0.1] startup
[21.527s] [ext: omni.kit.livestream.core-3.2.0] startup
[21.555s] [ext: omni.kit.livestream.native-4.1.0] startup
Active user not found. Using default user [kiosk]Streaming server started.
Now streaming on 169.235.18.44 via Omniverse Streaming Client
Warning: Possible version incompatibility. Attempting to load omni::fabric::IStageReaderWriter with version v0.10 against v0.9.
2025-04-15 00:31:35 [24,362ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2025-04-15 00:31:35 [24,661ms] [Warning] [omni.fabric.plugin] removePath called on non-existent path /Render/RenderProduct_Replicator/PostRender/SDGPipeline/RenderProduct_Replicator_GpuInteropEntry
____________
/ / /__
/__________/ /__/ \
\ _____ \ \__\ /
\ \ / \ \ \_/ /
\ \/___\ \ /
\__________\_/
___ _ ____ _ _
/ _ \ _ __ ___ _ __ (_)/ ___(_) |__ ___ ___ _ __
| | | | '_ ` _ \| '_ \| | | _| | '_ \/ __|/ _ \| '_ \
| |_| | | | | | | | | | | |_| | | |_) \__ \ (_) | | | |
\___/|_| |_| |_|_| |_|_|\____|_|_.__/|___/\___/|_| |_|
[INFO] [omnigibson.simulator] ---------- Welcome to OmniGibson! ----------
2025-04-15 00:31:40 [29,700ms] [Warning] [omni.syntheticdata.plugin] SdRenderVarPtr missing valid input renderVar LdrColorSDhost
2025-04-15 00:31:40 [29,853ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[INFO] [omnigibson.simulator] Imported scene 0.
[WARNING] [omnigibson.robots.fetch] Fetch wheel links are post-processed to use sphere approximation collision meshes. Please ignore any previous errors about these collision meshes.
2025-04-15 00:31:51 [40,841ms] [Warning] [omnigibson.robots.fetch] Fetch wheel links are post-processed to use sphere approximation collision meshes. Please ignore any previous errors about these collision meshes.
2025-04-15 00:31:51 [40,842ms] [Warning] [omnigibson.robots.fetch] Fetch wheel links are post-processed to use sphere approximation collision meshes. Please ignore any previous errors about these collision meshes.
CameraMover! Commands:
Right Click + Drag: Rotate camera
W / S : Move camera forward / backward
A / D : Move camera left / right
T / G : Move camera up / down
9 / 0 : Increase / decrease the lights
P : Print current camera pose
O: Save the current camera view as an image
main: thread_init: already added for thread
[OpenH264] this = 0x0x7fe3d0fe4810, Warning:ParamValidation(), AdaptiveQuant(1) is not supported yet for screen content, auto turned off
[OpenH264] this = 0x0x7fe3d0fe4810, Warning:AUTO CORRECT: Invalid settings in input frame rate(60.000000) and output frame rate(1.000000) of layer #0 config file: iResult of output frame rate divided by input frame rate should be power of 2(i.e,in/pOut=2^n).
Auto correcting Output Framerate to Input Framerate 60.000000!
[OpenH264] this = 0x0x7fe3d0fe4810, Warning:Change QP Range from(0,17) to (26,35)
[OpenH264] this = 0x0x7fe3d0fe4810, Warning:iNumRefFrame(0) setting does not support the temporal and LTR setting, will be reset to 2
[OpenH264] this = 0x0x7fe3d0fe4810, Error:WelsCheckRefFrameLimitation failed
[OpenH264] this = 0x0x7fe3d0fe4810, Error:WelsInitEncoderExt(), ParamValidationExt failed return 16.
[OpenH264] this = 0x0x7fe3d0fe4810, Error:CWelsH264SVCEncoder::Initialize(), WelsInitEncoderExt failed.
Error Messages
These are highlighted errors of above:
1. [590ms] [Warning] [omni.platforminfo.plugin] failed to open the default display. Can't verify X Server version.
2. [1,244ms] [Error] [carb.glinterop.plugin] GLInteropContext::init: carb::windowing is not available
3. [5,145ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
4. [5,202ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
5. main: thread_init: already added for thread
