Hello, I want to connect to Isaac sim on a docker container in a HPC running Ubuntu Server 20.04 through my desktop running Ubuntu 20.04 with the Omniverse streaming client.
I run the Isaac Sim docker container with the following command on the HPC (server-side):
docker run --name isaac-sim --entrypoint bash -it --gpus all -e "ACCEPT_EULA=Y" --rm --network=host \
-v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache/Kit:rw \
-v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw \
-v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw \
-v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw \
-v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw \
-v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw \
-v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw \
-v ~/docker/isaac-sim/documents:/root/Documents:rw \
nvcr.io/nvidia/isaac-sim:2022.2.1
And then start Isaac Sim with native livestream mode:
./runheadless.native.sh
After that I got the Isaac Sim Headless Native App is loaded. message on the server-side, I run the kit-remote.sh through terminal on my desktop (client) with the following command:
./kit-remote.sh apps/omni.create.kit \
--enable omni.services.streaming.manager \
--enable omni.kit.livestream.native \
--no-window \
--allow-root
After I enter server IP and attempt to connect, I get a black window that closes automatically after a few seconds.
The kit-remote.log file contents are as follows:
~/ov/pkg/kit_remote-103.1.1 ~/ov/pkg/kit_remote-103.1.1
[2023-04-25 18:52:48,980]=13:52:48= DEBUG [Geronimo: GeronimoRemoteConfig] {6E231140} - Cannot open config file RemoteConfig.json.
[2023-04-25 18:52:48,980]=13:52:48= INFO [Tracing] {6E231140} - Starting tracing for gfn-gamestream.
[2023-04-25 18:52:48,981]=13:52:48= INFO [OV-Streaming-Client: main] {6E231140} - Command line: "./kit-remote --width 1920 --height 1080 --server <ip_address>"
[2023-04-25 18:52:48,981]=13:52:48= INFO [OV-Streaming-Client: main] {6E231140} - Setting log level to 'E'
I-!$> [2023-04-25 18:52:49,272]=13:52:49= INFO [BifrostClient: Scheduler] {68665700} - Successfully set TLS with value 0x55ef84828060
I-!$> [2023-04-25 18:52:49,272]=13:52:49= INFO [BifrostClient: Scheduler] {68E66700} - Successfully set TLS with value 0x55ef84828060
I-!$> [2023-04-25 18:52:49,272]=13:52:49= INFO [BifrostClient: Scheduler] {69667700} - Successfully set TLS with value 0x55ef84828060
I-!$> [2023-04-25 18:52:49,272]=13:52:49= INFO [BifrostClient: Scheduler] {69E68700} - Successfully set TLS with value 0x55ef84828060
I-!$> [2023-04-25 18:52:49,273]=13:52:49= DEBUG [BifrostClient: Interface] {6E231140} - nvbCreateClient( 0x55ef84bf51a0 )
[2023-04-25 18:52:49,435]=13:52:49= ERROR [Geronimo::Analytics] {6E231140} - Failed to load dll with error: /home/fuzzy/ov/pkg/kit_remote-103.1.1//NvTelemetryAPI.so: cannot open shared object file: No such file or directory
[2023-04-25 18:52:49,706]=13:52:49= ERROR [BifrostClient: Streamer] {6E231140} - updateVideoSettingsForNVbProfile: profile 8 is not handled
[2023-04-25 18:52:49,836]=13:52:49= ERROR [NVST:ClientSession] {69E68700} - Number of channels(2) is not valid for surround configuration
[2023-04-25 18:52:49,838]=13:52:49= ERROR [NVST:NvNetworkLinux] {69E68700} - Address family 1 for Network address: 0x7fb469e64880 not supported
[2023-04-25 18:52:50,022]=13:52:50= ERROR [NVST:NattHolePunch] {4CFF9700} - NattHolePunch: Failed to receive hole punching packet
[2023-04-25 18:52:50,022]=13:52:50= ERROR [NVST:ClientSession] {69E68700} - Control channel hole punching failed.
[2023-04-25 18:52:50,039]=13:52:50= ERROR [NVST:ServerControl] {3F7FE700} - Unknown server notification
[2023-04-25 18:52:50,066]=13:52:50= ERROR [GIOInterface] {3D7FA700} - GERONIMO_ERROR 0xC0020003 GERONIMO_IOINTERFACE_INVALID_AUDIO_FUNC: Audio Renderer is NULL.
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ClientLibraryWrapper] {1BFFF700} - Stream config not updated after rtsp handshake
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ClientLibraryWrapper] {1BFFF700} - Cannot find streamEventRaised for stream.media type 1
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ClientLibraryWrapper] {1BFFF700} - Cannot find streamEventRaised for stream.media type 2
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:DataChannelBuffers] {3F7FE700} - Tried to read enet data when none is available
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ServerControlEnet] {3F7FE700} - Failed to read data from Enet socket with result 8000003C
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ServerControlEnet] {3F7FE700} - Read failed due to other enet read errors
[2023-04-25 18:52:50,308]=13:52:50= ERROR [NVST:ClientSession] {3F7FE700} - Unable to read server command due to NVST_NETERR_CLIENT_DISCONNECT_UNINTENDED (2147745797)
[2023-04-25 18:52:50,314]=13:52:50= ERROR [RemoteGridApp] {68E66700} - STREAMING: FAILED: NVB_SN_STOPPED_UNINTENTIONALLY (800e840c)
[2023-04-25 18:53:03,986]=13:53:03= ERROR [NVST:ClientLibraryWrapper] {69E68700} - Cannot find streamEventRaised for stream.media type 1
[2023-04-25 18:53:03,987]=13:53:03= ERROR [NVST:ClientLibraryWrapper] {69E68700} - Cannot find streamEventRaised for stream.media type 2
[2023-04-25 18:53:03,987]=13:53:03= ERROR [NVST:EnetSocket] {69E68700} - Failed to send message, run loop is continuing, socket is disconnecting, peer is (nil)
[2023-04-25 18:53:03,987]=13:53:03= ERROR [NVST:ClientLibraryWrapper] {69E68700} - Failed to send client session start timestamp stream 0 nvtime::sessionStartTime[us] on client: 8298075166063, error: -2146762752
I-!#>
[2023-04-25 18:53:03,990]=13:53:03= INFO [BifrostClient: Interface] {6E231140} - nvbDestroyClient(). Successfully destroyed NVbClient
[2023-04-25 18:53:03,995]=13:53:03= INFO [Tracing] {6E231140} - Sending final distributed tracing report.
[2023-04-25 18:53:03,995]=13:53:03= INFO [Tracing] {6E231140} - Distributed tracing ended.
In the following, I attached the logs when I execute ./runheadless.native.sh on HPC.
runheadless-native.log (37.1 KB)
Thanks in advance.
HPC Specs (Server-Side):
Ubuntu Server 20.04 LTS
Tesla A100 40G
NVIDIA-Driver Version: 525.60.13
Cuda Version: 12.0
Isaac-sim: 2022.2.1
Client-Side:
Omniverse Streaming Client Version: 103.1.1
GeForce GTX 1080 8G
More info: I connect to the HPC through ssh e.g. : ssh user@<ip_address> -p<port_number>
