Isaac Sim in Docker on remote Workstation
Isaac Sim Version
4.2.0 (server)
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2 (server)
1.1
1.0
Operating System
Ubuntu 22.04 (server & client)
Ubuntu 20.04
Windows 11
Windows 10
Other
  • Streaming Client V103.1.1
  • Browser: Chrome, Firefox
GPU Information
  • Model: RTX 3080 Ti
  • Driver Version: 535.183.01
Topic Description
I am currently trying to set up Isaac Sim on my workstation. I want to
  • run everything dockerized
  • be able to develop remotely, including streaming to a client PC in another network (I do have a VPN to the workstation’s network though).
While this should be possible according to what I read, I am not able to set it up. Specifically, the streaming to my client PC just isn’t working. Reading though docs and issues, I got conflicting information.
A) The streaming client seems to be deprecated
B) The streaming client is recommended
So anyways, I tried both - streaming client and WebRTC browser client, end ended up with neither working:
  1. Streaming Client not connecting
  2. The WebRTC client times out when trying to connect from the client PC. The only way to overcome this that I found so far was port forwarding and trying to access the web client locally, which led me to this issue.
Error Messages
I didn’t find any way to access/create logs for the client. I don’t see any messages about a connection attempt on the server.
High-Level Question
What is the recommended way to set up Isaac Sim in a docker on a server? The documentation doesn’t seem to mention this setup, though I believe it is a common need.
Does running Isaac Sim on the server and accessing it via VNC work?
It didn’t, but it pointed me towards the solution. There was a network-wide firewall blocking all incoming traffic on port 4000, so VNC did not work although ssh did. I eventually found a way to circumvent the firewall, which also resolved my issue with the StreamingClient.
The webrtc client still doesn’t work (timeout), but as long as the StreamingClient does, that’s not a problem for me.
tl;dr: I thought port 4000 was open, but a university-wide firewall blocked it.
