Isaacsim 4.5.0 is not responding and GPU crash
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTX 5070 TI
  • Driver Version: 570.133.07
Topic Description
Detailed Description
I have nvidia RTX 5070 TI and when I try to follow the insturction to install isaacsim, it successfully installs. However when I try to launch isaacsim I see the error message Isaacsim 4.5.0 is not responding, force quit or wait. Even when the error message is not there but I try to launch the examples, the error message appears and then after a while it crashes. My computer has ubuntu 22.04 and 32 GB ram.
Steps to Reproduce
  1. activate conda enviroment
  2. launch isaacsim by typing isaacsim
  3. error message appears that “Isaac Sim Full 4.5.0” is not responding
  4. Launching again locks the issac sim
Error Messages
25.144s] Using backup internal ROS2 humble distro
Checking to see if RMW can be loaded:
failed to get symbol ‘rmw_init_options_init’ due to Environment variable ‘AMENT_PREFIX_PATH’ is not set or empty, at /workspace/humble_ws/src/rmw_implementation/src/functions.cpp:171, at /workspace/humble_ws/src/rcl/rcl/src/rcl/init_options.c:75
RMW was not loaded
[25.149s] To use the internal libraries included with the extension please set the following environment variables to use with FastDDS (default) or CycloneDDS (ROS2 Humble only):
RMW_IMPLEMENTATION=rmw_fastrtps_cpp
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/murtaza/miniconda3/envs/env_isaaclab/lib/python3.10/site-packages/isaacsim/exts/isaacsim.ros2.bridge/humble/lib
OR
RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
Before starting Isaac Sim
2025-05-05 03:15:34 [25,140ms] [Error] [isaacsim.ros2.bridge.scripts.extension] ROS2 Bridge startup failed
[25.153s] [ext: isaacsim.ros2.bridge-4.1.15] shutdown
2025-05-05 03:15:35 [25,431ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 → <class ‘isaacsim.ros2.bridge.scripts.samples.ros_moveit_sample.Extension’>: extension object is still alive, something holds a reference on it. References: [“[0]:type: <class ‘method’>, id: 127139915388992”, “[1]:type: <class ‘method’>, id: 127139812282176”]
2025-05-05 03:15:35 [25,640ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 → <class ‘isaacsim.ros2.bridge.scripts.samples.ros_waypoint_follower_sample.Extension’>: extension object is still alive, something holds a reference on it. References: [“[0]:type: <class ‘method’>, id: 127139812288256”, “[1]:type: <class ‘method’>, id: 127139812293248”]
2025-05-05 03:15:35 [25,673ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 → <class ‘isaacsim.ros2.bridge.scripts.samples.ros_samples.Extension’>: extension object is still alive, something holds a reference on it. References: [“[0]:type: <class ‘method’>, id: 127137389492928”, “[1]:type: <class ‘method’>, id: 127138161882368”, “[2]:type: <class ‘method’>, id: 127139807971008”, “[3]:type: <class ‘method’>, id: 127137397968320”, “[4]:type: <class ‘method’>, id: 127139807668352”, ‘[*] …’]
[25.868s] [ext: omni.kit.registry.nucleus-0.0.0] startup
syncing registry: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared/v2’ Downloading 497 files…
syncing registry: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/106.5/d02c707b/v2’ Downloading 297 files…
2025-05-05 03:15:38 [29,003ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : GPU 1 (NVIDIA GeForce RTX 5070 Ti) with CUDA compute capability 12.0 is unsupported by this version of iray photoreal. Please look for an update with your software provider.
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7508933632
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7433845248
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9574251 (slope: 447, intercept: 13179904)
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287216384
2025-05-05 03:15:38 [29,108ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-05-05 03:15:40 [30,782ms] [Error] [omni.kit.renderer.plugin] IRendererImpl::updateReferenceFromTextureData getResourcesDescriptorSet failed for pool 1
[31.595s] app ready
2025-05-05 03:15:45 [36,239ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults-transient/meshlights/forceDisable’
2025-05-05 03:15:46 [37,153ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/post/dlss/execMode’
[180.011s] Isaac Sim Full App is loaded.
2025-05-05 03:18:51 [221,330ms] [Warning] [carb.graphics-vulkan.plugin] aftermath reports no active shader during GPU crash
2025-05-05 03:18:51 [221,330ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write crash dump into: /home/murtaza/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250504_231509-0.nv-gpudmp
2025-05-05 03:18:51 [221,330ms] [Error] [carb.graphics-vulkan.plugin] GPU crash dump is successfully written
2025-05-05 03:18:51 [221,568ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_DEVICE_LOST
2025-05-05 03:18:51 [221,568ms] [Error] [carb.graphics-vulkan.plugin] submitToQueueCommon failed.
2025-05-05 03:18:51 [221,568ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application…
Reasons for the failure: a device lost, out of memory, or an unexpected bug.
2025-05-05 03:18:51 [221,568ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status …
2025-05-05 03:18:51 [221,618ms] [Warning] [gpu.foundation.plugin] successfully waited and produced aftermath dump
Screenshots or Videos
Additional Information
I did had trouble installing rtx 5070 ti with other drivers so I am not sure downgrading should work but I had difficult installing and detecting nvidia-smi when using lower driver.
Are you following the installation method described in Python Environment Installation — Isaac Sim Documentation? Could you please share the full log output from when Isaac Sim fails to launch?
yes I followed all the instruction mentioned on Python Environment Installation — Isaac Sim Documentation . It also struck sometime and is not responsive even with force quit. The output is at issacsim output - Pastebin.com as the new user I was not allowed more than 4 lines reply
The page is blocked due to our company policy. Please upload the log file. Thanks.
issacsim output.txt (53.0 KB)
Please find the attached log
2025-05-05 17:03:27 [29,512ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER]   1.1   IRAY   rend warn : GPU 1 (NVIDIA GeForce RTX 5070 Ti) with CUDA compute capability 12.0 is unsupported by this version of iray photoreal. Please look for an update with your software provider.
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7508933632
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7433845248
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9574251 (slope: 447, intercept: 13179904)
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287216384
2025-05-05 17:03:27 [29,566ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
[31.738s] app ready
2025-05-05 17:03:32 [34,291ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-05 17:03:32 [34,801ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-05 17:03:32 [34,804ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-05-05 17:03:33 [35,479ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-05-05 17:03:33 [35,772ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
2025-05-05 17:03:49 [51,766ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_DEVICE_LOST
2025-05-05 17:03:49 [51,766ms] [Error] [carb.graphics-vulkan.plugin] submitToQueueCommon failed.
2025-05-05 17:03:49 [51,767ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application...
2025-05-05 17:03:49 [51,767ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status ...
2025-05-05 17:04:04 [66,732ms] [Warning] [gpu.foundation.plugin] aftermath dump failed to be produced within timeout window (15 seconds), proceeding without wait
Could you try installing the recommended Latest Production Branch Version drivers (currently 570.144)? Additionally, another user seems to successfully run Isaac Sim on RTX 5070 Ti with driver version 570.133.20. FYR.
Hello!
Best regards,
