Isaac Sim launch crash with rtx 4070 ti Super
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
5.0.0 ←
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11 ←
Windows 10
GPU Information
  • Model: RTX 4070 TI SUPER
  • Driver Version: 576.80
Topic Description
Detailed Description
When Isaac Sim is launched it crashes in couple of seconds. Selector software works fine until Isaac Sim is started
Steps to Reproduce
  1. launch Isaac Sim from bat, via command or with the selector software
Additional Information
What I’ve Tried
I have installed Isaac sim multiple times with Quick install, github and pip. I have also tried three different GPU drivers (576.80, 537.58 and 581.29) and disabled amd radeon integrated gpu
Error Messages
(env_isaaclab) PS C:\Users\ottol> isaacsim
[Info] [carb] Logging to file: C:/Users/ottol/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/5.0/kit_20250914_012328.log
2025-09-13T22:23:28Z [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[0.105s] [ext: omni.kit.async_engine-0.0.3] startup
[0.268s] [ext: omni.metrics.core-0.0.3] startup
[0.270s] [ext: omni.client.lib-1.1.0] startup
[0.285s] [ext: omni.blobkey-1.1.2] startup
[0.286s] [ext: omni.stats-1.0.1] startup
[0.288s] [ext: omni.datastore-0.0.0] startup
[0.290s] [ext: omni.client-1.3.0] startup
[0.296s] [ext: omni.ujitso.default-1.0.0] startup
[0.300s] [ext: omni.hsscclient-1.1.2] startup
[0.307s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.313s] [ext: omni.assets.plugins-0.0.0] startup
[0.317s] [ext: omni.gpu_foundation-0.0.0] startup
[0.340s] [ext: carb.windowing.plugins-1.0.0] startup
[0.450s] [ext: omni.kit.renderer.init-0.0.0] startup
[0.451s] [ext: omni.materialx.libs-1.0.7] startup
[0.466s] [ext: omni.usd.config-1.0.6] startup
[0.475s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.490s] [ext: omni.usd.libs-1.0.1] startup
[0.591s] [ext: omni.mdl-56.0.3] startup
[0.677s] [ext: omni.iray.libs-0.0.0] startup
[0.710s] [ext: omni.mdl.neuraylib-0.2.12] startup
[0.719s] [ext: omni.kit.usd.mdl-1.1.4] startup
[0.834s] [ext: omni.kit.telemetry-0.5.2] startup
[0.844s] [ext: omni.kit.loop-isaac-1.3.7] startup
[0.846s] [ext: omni.kit.test-2.0.1] startup
[0.924s] [ext: omni.kit.pipapi-0.0.0] startup
[0.925s] [ext: omni.appwindow-1.1.10] startup
[0.938s] [ext: omni.kit.renderer.core-1.1.0] startup
[0.944s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.949s] [ext: omni.kit.renderer.imgui-2.0.5] startup
[0.962s] [ext: omni.ui-2.26.18] startup
[0.974s] [ext: omni.kit.mainwindow-1.0.3] startup
[0.976s] [ext: carb.audio-0.1.0] startup
[0.978s] [ext: omni.uiaudio-1.0.0] startup
[0.981s] [ext: omni.kit.uiapp-0.0.0] startup
[0.981s] [ext: omni.usd.schema.metrics.assembler-107.3.1] startup
| Driver Version: 576.80 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4070 Ti SUPER | Yes: 0 | | 16063 MB | 10de | 64470100.. |
| | | | | | 2705 | 32ce0368.. |
| | | | | | 1 | |
| OS: Windows 11 Home, Version: 10.0 (24H2), Build: 26100, Kernel: 10.0.26100.6584
| Processor: AMD Ryzen 7 7700 8-Core Processor
| Cores: 8 | Logical Cores: 16
| Total Memory (MB): 31913 | Free Memory: 22923
| Total Page/Swap (MB): 49321 | Free Page/Swap: 36015
[0.987s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.015s] [ext: omni.anim.graph.schema-107.3.0] startup
[1.023s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.028s] [ext: isaacsim.robot.schema-3.5.1] startup
[1.038s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.043s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.047s] [ext: omni.usd_resolver-1.0.0] startup
[1.054s] [ext: usdrt.scenegraph-7.6.1] startup
[1.105s] [ext: omni.kit.actions.core-1.0.0] startup
[1.110s] [ext: omni.timeline-1.0.14] startup
[1.113s] [ext: omni.usd.core-1.5.3] startup
[1.115s] [ext: omni.resourcemonitor-107.0.1] startup
[1.119s] [ext: omni.activity.core-1.0.3] startup
[1.122s] [ext: omni.kit.audiodeviceenum-1.0.2] startup
[1.125s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[1.133s] [ext: omni.graph.exec-0.9.6] startup
[1.135s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[1.141s] [ext: omni.kit.exec.core-0.13.4] startup
[1.145s] [ext: omni.kit.widget.nucleus_connector-2.0.1] startup
[1.148s] [ext: omni.kit.usd_undo-0.1.8] startup
[1.149s] [ext: omni.kit.commands-1.4.10] startup
[1.156s] [ext: omni.hydra.scene_delegate-0.3.4] startup
[1.159s] [ext: omni.usd-1.13.10] startup
2025-09-13T22:23:29Z [1,146ms] [Warning] [omni.usd.audio] failed to subscribe to stage events
[1.204s] [ext: omni.kit.asset_converter-4.1.4] startup
[1.212s] [ext: omni.usd.schema.render_settings.rtx-0.0.0] startup
[1.214s] [ext: omni.usd.schema.isaac-3.0.5] startup
[1.214s] [ext: omni.usd.schema.omni_lens_distortion-0.0.0] startup
[1.215s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.224s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[1.228s] [ext: omni.inspect-1.0.2] startup
[1.231s] [ext: omni.kit.notification_manager-1.0.10] startup
[1.233s] [ext: omni.graph.core-2.184.3] startup
[1.237s] [ext: isaacsim.core.deprecation_manager-0.2.7] startup
[1.238s] [ext: omni.anim.navigation.schema-107.3.0] startup
[1.243s] [ext: omni.usd.schema.flow-107.1.1] startup
[1.244s] [ext: omni.usd.schema.physx-107.3.18] startup
[1.270s] [ext: omni.usd.schema.omni_sensors-0.0.0] startup
[1.271s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.278s] [ext: omni.kit.widget.path_field-2.0.11] startup
[1.279s] [ext: omni.index.libs-380600.5717.0] startup
[1.279s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[1.281s] [ext: omni.kit.clipboard-1.0.5] startup
[1.283s] [ext: omni.index-1.0.1] startup
[1.284s] [ext: omni.kit.menu.core-1.1.2] startup
[1.285s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[1.287s] [ext: omni.kit.widget.nucleus_info-2.0.2] startup
[1.288s] [ext: omni.kit.widget.context_menu-1.2.5] startup
[1.290s] [ext: omni.kit.widget.filebrowser-2.12.2] startup
[1.299s] [ext: omni.kit.search_core-1.0.8] startup
[1.301s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[1.306s] [ext: omni.ui.scene-1.11.4] startup
[1.310s] [ext: omni.kit.widget.versioning-1.4.10] startup
[1.315s] [ext: omni.kit.widget.search_delegate-1.0.7] startup
[1.317s] [ext: omni.kit.widget.options_button-1.0.3] startup
[1.318s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[1.320s] [ext: omni.kit.window.filepicker-2.13.3] startup
[1.341s] [ext: omni.kit.collaboration.telemetry-1.1.0] startup
[1.343s] [ext: omni.kit.collaboration.channel_manager-1.0.14] startup
[1.345s] [ext: omni.volume-0.5.2] startup
[1.350s] [ext: omni.ujitso.client-0.0.0] startup
[1.351s] [ext: omni.kit.usd.layers-2.2.10] startup
[1.362s] [ext: omni.hydra.rtx-1.0.0] startup
[1.421s] [ext: omni.kit.window.file_importer-1.1.18] startup
[1.426s] [ext: omni.kit.menu.utils-2.0.3] startup
[1.436s] [ext: omni.kit.context_menu-1.8.6] startup
[1.439s] [ext: omni.kit.viewport.legacy_gizmos-1.0.18] startup
[1.441s] [ext: omni.kit.raycast.query-1.1.0] startup
[1.445s] [ext: omni.kit.material.library-2.0.7] startup
[1.452s] [ext: omni.hydra.engine.stats-1.0.3] startup
[1.454s] [ext: omni.kit.viewport.scene_camera_model-1.0.6] startup
[1.456s] [ext: omni.kit.hydra_texture-1.4.5] startup
[1.460s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[1.461s] [ext: omni.kit.window.drop_support-1.0.5] startup
[1.462s] [ext: omni.kit.widget.viewport-107.1.3] startup
[1.469s] [ext: omni.kit.viewport.registry-104.0.6] startup
[1.470s] [ext: omni.kit.widget.settings-1.2.3] startup
[1.472s] [ext: omni.kit.viewport.window-107.0.12] startup
[1.717s] [ext: omni.kit.window.preferences-1.8.0] startup
[1.727s] [ext: omni.kit.widget.toolbar-2.0.1] startup
[1.737s] [ext: omni.kit.viewport.utility-1.1.2] startup
[1.738s] [ext: omni.kit.manipulator.transform-107.0.0] startup
[1.744s] [ext: omni.kit.manipulator.tool.snap-1.5.13] startup
[1.751s] [ext: omni.kit.manipulator.selector-1.1.3] startup
[1.753s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[1.756s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[1.758s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[1.764s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[1.768s] [ext: omni.kit.manipulator.prim.core-107.0.8] startup
[1.778s] [ext: omni.fabric.commands-1.1.6] startup
[1.783s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[1.785s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[1.787s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[1.789s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[1.791s] [ext: omni.kit.widget.prompt-1.0.7] startup
[1.792s] [ext: omni.kit.stage_template.core-1.1.22] startup
[1.793s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[1.796s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[1.798s] [ext: omni.kit.window.file_exporter-1.0.33] startup
[1.799s] [ext: omni.kit.widget.live_session_management.ui-1.0.3] startup
[1.804s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[1.804s] [ext: omni.kit.window.file-2.0.5] startup
[1.809s] [ext: omni.kit.widget.filter-1.1.4] startup
[1.810s] [ext: omni.kit.collaboration.presence_layer-1.1.2] startup
[1.814s] [ext: omni.kit.window.cursor-1.1.4] startup
[1.815s] [ext: omni.kit.window.content_browser-3.1.1] startup
[1.828s] [ext: omni.kit.widget.stage-3.1.4] startup
[1.848s] [ext: omni.kit.widget.live_session_management-1.2.23] startup
[1.853s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[1.854s] [ext: omni.kit.viewport.menubar.core-107.1.5] startup
[1.875s] [ext: omni.kit.viewport.actions-107.0.2] startup
[1.881s] [ext: omni.kit.window.property-1.12.1] startup
[1.885s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[1.887s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[1.889s] [ext: omni.kit.property.usd-4.5.11] startup
[1.903s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[1.903s] [ext: omni.debugdraw-0.1.4] startup
[1.907s] [ext: omni.kvdb-107.3.18] startup
[1.910s] [ext: omni.usdphysics-107.3.18] startup
[1.913s] [ext: omni.physx.foundation-107.3.18] startup
[1.920s] [ext: omni.localcache-107.3.18] startup
[1.924s] [ext: omni.convexdecomposition-107.3.18] startup
[1.927s] [ext: omni.kit.widget.layers-1.8.6] startup
[1.945s] [ext: omni.physx.cooking-107.3.18] startup
[1.950s] [ext: omni.usdphysics.ui-107.3.18] startup
[1.972s] [ext: omni.physx-107.3.18] startup
[1.982s] [ext: omni.physics-107.3.18] startup
[1.988s] [ext: omni.kit.numpy.common-0.1.2] startup
[1.990s] [ext: omni.physx.commands-107.3.18] startup
[1.996s] [ext: omni.physics.stageupdate-107.3.18] startup
[2.000s] [ext: omni.physics.physx-107.3.18] startup
[2.002s] [ext: omni.kit.widget.graph-2.0.0] startup
[2.010s] [ext: omni.kit.widget.stage_icons-1.0.8] startup
[2.012s] [ext: omni.kit.widget.zoombar-1.0.6] startup
[2.014s] [ext: omni.kit.window.stage-2.6.1] startup
[2.018s] [ext: omni.kit.browser.core-2.3.13] startup
[2.024s] [ext: omni.kit.menu.stage-1.2.7] startup
[2.026s] [ext: omni.kit.browser.folder.core-1.10.9] startup
[2.034s] [ext: omni.kit.usd.collect-2.4.5] startup
[2.038s] [ext: omni.graph.tools-1.79.2] startup
[2.072s] [ext: omni.kit.widget.text_editor-1.1.1] startup
[2.075s] [ext: omni.kit.usdz_export-1.0.9] startup
[2.078s] [ext: omni.ui_query-1.1.8] startup
[2.079s] [ext: omni.kit.window.extensions-1.4.26] startup
[2.088s] [ext: omni.graph-1.141.2] startup
[2.138s] [ext: omni.kit.tool.asset_importer-4.3.2] startup
[2.150s] [ext: omni.graph.ui-1.101.6] startup
[2.179s] [ext: omni.graph.action_core-1.1.7] startup
[2.183s] [ext: omni.usd.metrics.assembler-107.3.1] startup
[2.191s] [ext: omni.graph.action_nodes-1.50.4] startup
[2.195s] [ext: omni.kit.ui_test-1.3.6] startup
[2.201s] [ext: omni.graph.visualization.nodes-2.1.3] startup
[2.217s] [ext: omni.graph.action-1.130.0] startup
[2.220s] [ext: omni.kit.tool.collect-2.2.18] startup
[2.226s] [ext: isaacsim.gui.components-1.1.9] startup
[2.235s] [ext: isaacsim.examples.browser-0.1.12] startup
[2.245s] [ext: isaacsim.asset.importer.urdf-2.4.19] startup
[2.341s] [ext: omni.isaac.dynamic_control-2.0.7] startup
2025-09-13T22:23:30Z [2,306ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[2.353s] [ext: omni.physx.ui-107.3.18] startup
[2.380s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[2.383s] [ext: omni.usd.metrics.assembler.physics-107.3.18] startup
[2.386s] [ext: isaacsim.core.version-2.0.6] startup
[2.389s] [ext: omni.physics.tensors-107.3.18] startup
[2.396s] [ext: omni.warp.core-1.7.1] startup
[2.542s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[2.547s] [ext: omni.kit.stage_templates-2.0.0] startup
[2.551s] [ext: isaacsim.storage.native-1.2.8] startup
[2.554s] [ext: omni.physx.tensors-107.3.18] startup
[2.557s] [ext: isaacsim.core.utils-3.4.5] startup
[2.561s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[2.564s] [ext: isaacsim.core.simulation_manager-1.3.2] startup
[4.172s] [ext: omni.graph.image.core-0.6.1] startup
[4.174s] [ext: isaacsim.test.docstring-1.1.0] startup
[4.178s] [ext: isaacsim.core.experimental.utils-0.2.0] startup
[4.181s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[4.184s] [ext: omni.graph.scriptnode-1.50.0] startup
[4.186s] [ext: isaacsim.core.prims-0.5.1] startup
[4.211s] [ext: omni.graph.image.nodes-1.3.1] startup
[4.214s] [ext: isaacsim.core.experimental.prims-0.6.2] startup
[4.238s] [ext: omni.kit.window.material_graph-1.8.23] startup
[4.281s] [ext: omni.kit.selection-0.1.6] startup
[4.284s] [ext: isaacsim.core.api-4.6.10] startup
[4.302s] [ext: omni.syntheticdata-0.6.13] startup
[4.317s] [ext: isaacsim.core.experimental.materials-0.3.0] startup
[4.327s] [ext: omni.graph.nodes-1.170.10] startup
[4.339s] [ext: omni.graph.ui_nodes-1.50.5] startup
[4.349s] [ext: isaacsim.gui.menu-2.3.17] startup
[4.656s] [ext: isaacsim.robot.surface_gripper-3.2.6] startup
[4.663s] [ext: omni.kit.widget.imageview-1.0.4] startup
[4.665s] [ext: omni.warp-1.7.1] startup
[4.674s] [ext: omni.videoencoding-0.1.2] startup
[4.681s] [ext: isaacsim.robot.surface_gripper.ui-3.0.2] startup
[4.684s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[4.696s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[4.698s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[4.702s] [ext: omni.replicator.core-1.12.16] startup
2025-09-13T22:23:33Z [4,677ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
Warp 1.7.1 initialized:
CUDA Toolkit 12.8, Driver 12.9
Devices:
“cpu” : “AMD64 Family 25 Model 97 Stepping 2, AuthenticAMD”
“cuda:0” : “NVIDIA GeForce RTX 4070 Ti SUPER” (16 GiB, sm_89, mempool enabled)
Kernel cache:
C:\Users\ottol\AppData\Local\NVIDIA\warp\Cache\1.7.1
2025-09-13T22:23:33Z [4,807ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[4.855s] [ext: omni.graph.window.core-2.0.0] startup
[4.876s] [ext: isaacsim.core.nodes-3.2.16] startup
[4.888s] [ext: omni.graph.window.generic-1.50.2] startup
[4.902s] [ext: isaacsim.sensors.camera-1.3.1] startup
[4.916s] [ext: isaacsim.core.throttling-2.1.10] startup
[4.924s] [ext: isaacsim.sensors.camera.ui-0.2.0] startup
[4.927s] [ext: isaacsim.sensors.physics-0.3.27] startup
[4.938s] [ext: omni.anim.navigation.core-107.3.0] startup
[4.947s] [ext: isaacsim.robot.policy.examples-4.1.11] startup
[4.956s] [ext: omni.anim.navigation.meshtools-107.3.0] startup
[4.973s] [ext: omni.isaac.quadruped-3.0.7] startup
2025-09-13T22:23:33Z [4,930ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[4.979s] [ext: isaacsim.robot_motion.lula-4.0.8] startup
[5.003s] [ext: isaacsim.asset.browser-1.3.19] startup
[5.017s] [ext: isaacsim.robot.manipulators-3.3.5] startup
[5.030s] [ext: isaacsim.robot_motion.motion_generation-8.0.25] startup
[5.060s] [ext: omni.isaac.asset_browser-1.0.6] startup
2025-09-13T22:23:33Z [5,018ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[5.067s] [ext: isaacsim.core.cloner-1.4.9] startup
[5.079s] [ext: isaacsim.robot.manipulators.examples-1.0.17] startup
[5.082s] [ext: omni.isaac.assets_check-0.3.13] startup
2025-09-13T22:23:33Z [5,039ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[5.085s] [ext: omni.isaac.cloner-1.0.7] startup
2025-09-13T22:23:33Z [5,042ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[5.088s] [ext: isaacsim.cortex.framework-1.0.12] startup
[5.091s] [ext: omni.isaac.core-4.0.7] startup
2025-09-13T22:23:33Z [5,049ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-09-13T22:23:33Z [5,050ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-09-13T22:23:33Z [5,051ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-09-13T22:23:33Z [5,051ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[5.097s] [ext: isaacsim.core.experimental.objects-0.2.4] startup
[5.110s] [ext: isaacsim.cortex.behaviors-2.0.12] startup
[5.114s] [ext: omni.isaac.cortex-1.0.5] startup
2025-09-13T22:23:33Z [5,072ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
[5.118s] [ext: isaacsim.simulation_app-2.9.2] startup
[5.120s] [ext: omni.isaac.cortex.sample_behaviors-2.0.5] startup
2025-09-13T22:23:33Z [5,076ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[5.121s] [ext: omni.kit.viewport.menubar.render-107.0.9] startup
[5.132s] [ext: omni.isaac.kit-2.0.6] startup
2025-09-13T22:23:33Z [5,088ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[5.133s] [ext: omni.sensors.nv.common-2.7.0-coreapi] startup
[5.171s] [ext: omni.isaac.franka-1.0.7] startup
2025-09-13T22:23:33Z [5,128ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-09-13T22:23:33Z [5,130ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-09-13T22:23:33Z [5,142ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[5.187s] [ext: omni.isaac.lula-4.0.6] startup
2025-09-13T22:23:33Z [5,146ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[5.199s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.12] startup
[5.203s] [ext: omni.sensors.nv.materials-1.6.0-coreapi] startup
[5.217s] [ext: omni.sensors.nv.wpm-2.5.0-coreapi] startup
[5.223s] [ext: omni.sensors.net-0.4.0-coreapi] startup
[5.236s] [ext: omni.isaac.lula_test_widget-1.0.6] startup
2025-09-13T22:23:33Z [5,193ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[5.238s] [ext: isaacsim.util.debug_draw-3.1.0] startup
[5.250s] [ext: omni.sensors.nv.radar-2.8.0-coreapi] startup
[5.295s] [ext: omni.sensors.nv.lidar-2.7.0-coreapi] startup
[5.307s] [ext: omni.sensors.nv.ids-1.5.0-coreapi] startup
[5.312s] [ext: isaacsim.gui.sensors.icon-2.0.3] startup
[5.330s] [ext: isaacsim.sensors.physx-2.2.27] startup
[5.371s] [ext: isaacsim.sensors.rtx-15.5.0] startup
[5.400s] [ext: isaacsim.gui.content_browser-0.1.9] startup
[5.429s] [ext: omni.isaac.range_sensor-4.0.6] startup
2025-09-13T22:23:33Z [5,388ms] [Warning] [omni.isaac.range_sensor] omni.isaac.range_sensor has been deprecated in favor of isaacsim.sensors.physx. Please update your code accordingly.
2025-09-13T22:23:33Z [5,390ms] [Warning] [omni.isaac.range_sensor.commands] omni.isaac.range_sensor.commands has been deprecated in favor of isaacsim.sensors.physx.commands. Please update your code accordingly.
[5.437s] [ext: omni.isaac.sensor-13.0.7] startup
2025-09-13T22:23:33Z [5,395ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-09-13T22:23:33Z [5,396ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-09-13T22:23:33Z [5,399ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-09-13T22:23:33Z [5,401ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-09-13T22:23:33Z [5,402ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-09-13T22:23:33Z [5,405ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-09-13T22:23:33Z [5,406ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-09-13T22:23:33Z [5,409ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-09-13T22:23:33Z [5,417ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-09-13T22:23:33Z [5,418ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-09-13T22:23:33Z [5,421ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[5.467s] [ext: isaacsim.robot.wheeled_robots-4.0.23] startup
[5.487s] [ext: omni.isaac.surface_gripper-2.0.6] startup
2025-09-13T22:23:33Z [5,444ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
2025-09-13T22:23:33Z [5,445ms] [Warning] [omni.ext._impl._internal] Found class Extension derived from omni.ext.IExt in module: ‘omni.isaac.surface_gripper’, but it was imported from other extension: ‘c:/users/ottol/miniconda3/envs/env_isaaclab/lib/site-packages/isaacsim/exts/isaacsim.robot.surface_gripper/isaacsim/robot/surface_gripper/impl/extension.py’, which is not a subpath to: ‘c:\users\ottol\miniconda3\envs\env_isaaclab\lib\site-packages\isaacsim\extsdeprecated\omni.isaac.surface_gripper’. Do not import IExt derived class from other extension in your public namespace.
[5.491s] [ext: omni.isaac.universal_robots-1.0.6] startup
2025-09-13T22:23:33Z [5,447ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,448ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,451ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[5.497s] [ext: omni.isaac.utils-2.0.6] startup
[5.501s] [ext: omni.isaac.version-2.0.7] startup
2025-09-13T22:23:33Z [5,458ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[5.508s] [ext: omni.isaac.wheeled_robots-3.0.7] startup
2025-09-13T22:23:33Z [5,464ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,464ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,465ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,466ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,466ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,467ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,467ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,468ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,468ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,469ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,469ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-13T22:23:33Z [5,471ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[5.517s] [ext: omni.kit.menu.create-2.0.1] startup
[5.523s] [ext: omni.kit.property.audio-1.0.16] startup
[5.527s] [ext: omni.kit.property.camera-1.0.10] startup
[5.530s] [ext: omni.kit.property.geometry-2.0.4] startup
[5.538s] [ext: omni.hydra.scene_api-0.1.2] startup
[5.543s] [ext: omni.kit.property.light-1.0.12] startup
[5.555s] [ext: isaacsim.app.about-2.0.11] startup
[5.561s] [ext: omni.kit.property.material-1.11.9] startup
[5.573s] [ext: omni.kit.property.render-1.2.1] startup
[5.576s] [ext: omni.kit.property.transform-1.5.12] startup
[5.581s] [ext: isaacsim.gui.property-1.1.3] startup
[5.585s] [ext: omni.isaac.window.about-2.0.7] startup
2025-09-13T22:23:33Z [5,546ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-09-13T22:23:33Z [5,547ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[5.593s] [ext: omni.kit.manipulator.camera-106.0.4] startup
[5.599s] [ext: omni.isaac.core_nodes-2.0.6] startup
2025-09-13T22:23:33Z [5,556ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[5.602s] [ext: omni.kit.property.bundle-1.4.1] startup
[5.607s] [ext: omni.kit.property.isaac-1.0.6] startup
2025-09-13T22:23:33Z [5,563ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-09-13T22:23:33Z [5,564ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[5.609s] [ext: omni.kit.scripting-107.3.1] startup
[5.617s] [ext: omni.isaac.manipulators-3.0.7] startup
2025-09-13T22:23:33Z [5,573ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,574ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,574ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,576ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,576ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,577ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,577ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,577ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,578ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-13T22:23:33Z [5,578ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[5.624s] [ext: omni.kit.viewport.menubar.camera-107.0.3] startup
[5.635s] [ext: omni.kit.viewport.menubar.lighting-107.3.1] startup
[5.640s] [ext: isaacsim.replicator.writers-1.0.15] startup
[5.666s] [ext: omni.isaac.menu-1.0.6] startup
2025-09-13T22:23:33Z [5,623ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[5.669s] [ext: isaacsim.replicator.behavior-1.1.14] startup
[5.674s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[5.684s] [ext: omni.kit.window.console-1.1.4] startup
[5.692s] [ext: isaacsim.replicator.domain_randomization-1.0.16] startup
[5.700s] [ext: isaacsim.replicator.examples-1.1.31] startup
[5.705s] [ext: omni.ocio-0.1.1] startup
[5.709s] [ext: omni.rtx.window.settings-0.6.19] startup
[5.719s] [ext: omni.kit.window.status_bar-0.1.8] startup
[5.729s] [ext: omni.kit.window.toolbar-2.0.0] startup
[5.734s] [ext: omni.replicator.isaac-2.0.8] startup
2025-09-13T22:23:34Z [5,690ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[5.737s] [ext: omni.replicator.replicator_yaml-2.0.11] startup
[5.776s] [ext: omni.rtx.settings.core-0.6.5] startup
[5.784s] [ext: omni.usd.metrics.assembler.ui-107.3.1] startup
[5.799s] [ext: omni.isaac.motion_generation-8.0.7] startup
2025-09-13T22:23:34Z [5,755ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,756ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,757ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,757ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,758ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,759ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,760ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,760ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,761ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,762ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,762ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,762ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,763ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,763ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,764ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-13T22:23:34Z [5,764ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[5.810s] [ext: semantics.schema.editor-2.0.1] startup
[5.818s] [ext: isaacsim.examples.extension-2.0.12] startup
[5.820s] [ext: omni.kit.ui.actions-1.0.5] startup
[5.823s] [ext: semantics.schema.property-2.0.1] startup
[5.827s] [ext: omni.isaac.nucleus-1.0.6] startup
2025-09-13T22:23:34Z [5,782ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-09-13T22:23:34Z [5,783ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-09-13T22:23:34Z [5,783ms] [Warning] [omni.ext._impl._internal] Found class Extension derived from omni.ext.IExt in module: ‘omni.isaac.nucleus’, but it was imported from other extension: ‘c:/users/ottol/miniconda3/envs/env_isaaclab/lib/site-packages/isaacsim/exts/isaacsim.storage.native/isaacsim/storage/native/impl/extension.py’, which is not a subpath to: ‘c:\users\ottol\miniconda3\envs\env_isaaclab\lib\site-packages\isaacsim\extsdeprecated\omni.isaac.nucleus’. Do not import IExt derived class from other extension in your public namespace.
[5.829s] [ext: omni.anim.curve.core-1.3.1] startup
[5.842s] [ext: isaacsim.asset.importer.mjcf-2.5.8] startup
[5.850s] [ext: isaacsim.examples.interactive-4.6.10] startup
[5.896s] [ext: omni.kit.menu.common-2.0.0] startup
[5.911s] [ext: isaacsim.exp.base-5.0.0] startup
[5.912s] [ext: omni.kit.stage.copypaste-1.2.4] startup
[5.927s] [ext: isaacsim.sensors.physics.ui-0.1.12] startup
[5.935s] [ext: isaacsim.sensors.physics.examples-0.1.15] startup
[5.941s] [ext: isaacsim.replicator.behavior.ui-1.0.5] startup
[5.948s] [ext: omni.anim.curve.ui-1.4.1] startup
[5.956s] [ext: isaacsim.robot.manipulators.ui-2.1.22] startup
[5.959s] [ext: isaacsim.util.physics-1.1.5] startup
[5.965s] [ext: omni.anim.curve.bundle-1.2.3] startup
[5.967s] [ext: omni.kit.browser.asset-1.3.12] startup
[5.971s] [ext: omni.anim.shared.core-107.0.1] startup
[5.978s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.23] startup
[5.982s] [ext: isaacsim.asset.importer.heightmap-2.0.6] startup
[5.988s] [ext: omni.graph.window.action-1.50.2] startup
[6.000s] [ext: omni.simready.explorer-1.1.3] startup
[6.019s] [ext: omni.importer.onshape-1.0.0] startup
[6.034s] [ext: isaacsim.robot_setup.gain_tuner-3.0.5] startup
[6.047s] [ext: omni.isaac.block_world-2.0.6] startup
2025-09-13T22:23:34Z [6,005ms] [Warning] [omni.isaac.block_world] [‘omni.isaac.block_world’] has been deprecated in favor of [‘isaacsim.asset.importer.heightmap’]. Please update your code accordingly.
[6.050s] [ext: isaacsim.asset.gen.omap-2.0.28] startup
[6.063s] [ext: isaacsim.robot_setup.grasp_editor-2.0.18] startup
[6.071s] [ext: omni.isaac.extension_templates-2.0.7] startup
2025-09-13T22:23:34Z [6,028ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
[6.073s] [ext: omni.isaac.gain_tuner-2.0.5] startup
[6.075s] [ext: isaacsim.sensors.physx.examples-2.2.15] startup
[6.079s] [ext: omni.isaac.occupancy_map-2.0.8] startup
2025-09-13T22:23:34Z [6,039ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
[6.086s] [ext: omni.isaac.grasp_editor-2.0.7] startup
2025-09-13T22:23:34Z [6,042ms] [Warning] [omni.isaac.grasp_editor] omni.isaac.grasp_editor has been deprecated in favor of isaacsim.robot_setup.grasp_editor. Please update your code accordingly.
[6.089s] [ext: isaacsim.sensors.rtx.ui-1.1.4] startup
[6.092s] [ext: isaacsim.robot_setup.assembler-3.0.8] startup
[6.100s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.11] startup
[6.104s] [ext: omni.isaac.range_sensor.examples-2.0.6] startup
2025-09-13T22:23:34Z [6,062ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-09-13T22:23:34Z [6,062ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-09-13T22:23:34Z [6,063ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[6.108s] [ext: isaacsim.util.merge_mesh-2.0.15] startup
[6.116s] [ext: isaacsim.replicator.scene_blox-1.0.8] startup
2025-09-13T22:23:34Z [6,072ms] [Warning] [isaacsim.replicator.scene_blox] isacsim.replicator.scene_blox has been deprecated since Isaac Sim 5.0.0.
[6.118s] [ext: isaacsim.replicator.synthetic_recorder-2.2.15] startup
[6.123s] [ext: omni.isaac.robot_assembler-2.0.8] startup
2025-09-13T22:23:34Z [6,080ms] [Warning] [omni.isaac.robot_assembler] omni.isaac.robot_assembler has been deprecated in favor of isaacsim.robot_setup.assembler. Please update your code accordingly.
[6.126s] [ext: omni.isaac.robot_description_editor-3.0.5] startup
[6.128s] [ext: isaacsim.asset.gen.omap.ui-2.2.1] startup
[6.130s] [ext: omni.kit.actions.window-1.1.3] startup
[6.141s] [ext: omni.isaac.scene_blox-1.0.6] startup
2025-09-13T22:23:34Z [6,097ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[6.142s] [ext: omni.isaac.synthetic_recorder-2.0.6] startup
2025-09-13T22:23:34Z [6,099ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[6.144s] [ext: omni.isaac.throttling-2.0.7] startup
2025-09-13T22:23:34Z [6,101ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-09-13T22:23:34Z [6,102ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[6.148s] [ext: omni.kit.core.collection-0.2.0] startup
[6.151s] [ext: omni.isaac.occupancy_map.ui-2.0.8] startup
2025-09-13T22:23:34Z [6,107ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
[6.152s] [ext: omni.kit.hotkeys.window-1.4.9] startup
[6.168s] [ext: omni.kit.mesh.raycast-107.0.1] startup
[6.172s] [ext: omni.kit.preferences.animation-1.2.0] startup
[6.177s] [ext: omni.graph.bundle.action-2.30.0] startup
[6.181s] [ext: omni.kit.property.collection-0.2.0] startup
[6.184s] [ext: omni.mdl.usd_converter-1.0.30] startup
[6.188s] [ext: omni.kit.property.layer-1.1.9] startup
[6.193s] [ext: omni.kit.stagerecorder.core-107.0.3] startup
[6.199s] [ext: omni.kit.search.files-1.0.4] startup
[6.201s] [ext: omni.kit.browser.material-1.6.2] startup
[6.207s] [ext: omni.kit.window.title-1.1.7] startup
[6.212s] [ext: omni.kit.stage.mdl_converter-1.0.8] startup
[6.215s] [ext: omni.kit.widgets.custom-1.0.13] startup
[6.231s] [ext: omni.kit.stagerecorder.ui-107.0.1] startup
[6.238s] [ext: omni.kit.tool.remove_unused.core-0.1.3] startup
[6.241s] [ext: omni.kit.window.material-1.6.3] startup
[6.253s] [ext: omni.kit.stage_column.payload-2.0.3] startup
[6.257s] [ext: omni.kit.stage_column.variant-1.0.17] startup
[6.262s] [ext: omni.kit.variant.editor-107.3.0] startup
[6.284s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[6.284s] [ext: omni.kit.tool.asset_exporter-3.1.1] startup
[6.291s] [ext: omni.kit.tool.remove_unused.controller-0.1.4] startup
[6.294s] [ext: omni.kit.usda_edit-1.1.18] startup
[6.306s] [ext: omni.kit.widget.live-2.1.11] startup
[6.309s] [ext: omni.kit.variant.presenter-107.0.0] startup
[6.315s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[6.316s] [ext: omni.kit.widget.calendar-1.0.9] startup
[6.320s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[6.320s] [ext: omni.kit.viewport_widgets_manager-1.0.9] startup
[6.323s] [ext: omni.kit.widget.cache_indicator-3.0.6] startup
2025-09-13T22:23:34Z [6,279ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.6 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn’t do anything and can be removed.
2025-09-13T22:23:34Z [6,668ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File C:/Users/ottol/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
[6.717s] [ext: omni.kit.property.physx-107.3.18] startup
[6.817s] [ext: omni.physx.demos-107.3.18] startup
[7.177s] [ext: omni.kit.widget.extended_searchfield-1.0.31] startup
[7.198s] [ext: omni.kit.widget.schema_api-1.0.3] startup
[7.201s] [ext: omni.asset_validator.core-0.25.4] startup
[7.245s] [ext: omni.scene.optimizer.core-107.3.9] startup
[7.280s] [ext: omni.usdex.libs-1.0.2] startup
[7.289s] [ext: omni.physx.vehicle-107.3.18] startup
[7.311s] [ext: omni.kit.window.commands-0.2.9] startup
[7.315s] [ext: omni.kit.widget.timeline-107.0.1] startup
[7.319s] [ext: omni.kit.window.script_editor-2.0.1] startup
[7.324s] [ext: omni.asset_validator.ui-0.25.4] startup
[7.338s] [ext: omni.physx.asset_validator-107.3.18] startup
[7.352s] [ext: omni.kit.converter.common-506.3.1] startup
[7.356s] [ext: isaacsim.sensors.physx.ui-2.2.12] startup
[7.359s] [ext: omni.physx.camera-107.3.18] startup
[7.369s] [ext: omni.physx.cct-107.3.18] startup
[7.381s] [ext: omni.physx.graph-107.3.18] startup
[7.398s] [ext: omni.physx.supportui-107.3.18] startup
[7.421s] [ext: omni.physx.telemetry-107.3.18] startup
[7.427s] [ext: omni.kit.converter.dgn_core-509.0.1] startup
[7.438s] [ext: omni.isaac.range_sensor.ui-2.0.5] startup
2025-09-13T22:23:35Z [7,394ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-09-13T22:23:35Z [7,395ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[7.440s] [ext: omni.kit.converter.hoops_core-508.0.2] startup
[7.451s] [ext: omni.kit.converter.jt_core-507.0.1] startup
[7.463s] [ext: omni.kit.window.usd_paths-1.0.8] startup
[7.466s] [ext: omni.kit.widget.collection-0.2.3] startup
[7.470s] [ext: omni.physx.bundle-107.3.18] startup
[7.471s] [ext: omni.kit.converter.dgn-508.0.1] startup
[7.475s] [ext: isaacsim.replicator.grasping-1.0.9] startup
[7.949s] [ext: omni.kit.converter.hoops-508.0.1] startup
[7.954s] [ext: omni.kit.converter.jt-507.0.1] startup
[7.956s] [ext: omni.kit.quicklayout-1.0.8] startup
[7.959s] [ext: omni.kit.window.collection-0.2.3] startup
[7.961s] [ext: omni.isaac.physics_inspector-0.1.11] startup
2025-09-13T22:23:36Z [7,917ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[7.963s] [ext: isaacsim.util.camera_inspector-1.0.15] startup
[7.965s] [ext: isaacsim.replicator.grasping.ui-1.0.8] startup
[7.968s] [ext: isaacsim.asset.validation-1.0.3] startup
[7.995s] [ext: omni.kit.converter.cad-203.2.1] startup
[7.996s] [ext: omni.kit.window.stats-0.1.7] startup
[7.998s] [ext: isaacsim.app.setup-1.4.10] startup
[8.000s] Isaac Sim Full Version: 5.0.0-rc.45
[8.000s] [ext: omni.kit.profiler.window-2.3.5] startup
[8.011s] [ext: isaacsim.exp.full-5.0.0] startup
Crash report:
kit_20250914_012328.log (1.2 MB)
@otto.m with Window OS, one thing you could try is to launch with Directx instead of Vulkan, though i didn’t see any errors related to this but might be worth a shot. below is from another thread in which the mod mentioned the way to set it:
Your log mentions isaaclab. Could you also try following the installation instructions on Workstation Installation — Isaac Sim Documentation.
Thanks for the advice but unfortunately adding vulkan = false line to the kit file didn’t resolve the issue
Yes, on my last attempt I installed both Isaac Lab and Isaac Sim via pip
Here is the log file when installed using the basic “workstation Installation” instructions with newest drivers:
kit_20250917_112626.log (1.1 MB)
I have also tested Isaac Sim 4.5 but it crashes during startup as well
@otto.m can you try disabling the AMD graphic driver via Device Manager and see if the crashing persists?
I have already tried that earlier but just to check, I did it again and unfortunately, the software still crashes on launch.
Here is the info table without AMD integrated gpu:
| Driver Version: 581.29 | Graphics API: Vulkan
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4070 Ti SUPER | Yes: 0 | | 16063 MB | 10de | 823f0100.. |
| | | | | | 2705 | 32ce0368.. |
| | | | | | 1 | |
| Total Memory (MB): 31913 | Free Memory: 24005
| Total Page/Swap (MB): 48297 | Free Page/Swap: 35275
After disabling MSI afterburner everything started working
thanks for reporting back, didn’t realize OC compromises the launch of kit apps. this is good to know!
Thank you for updating us after finding a solution.
On Windows, a “fatal exception: int divide by zero” error was previously resolved by other users disabling MSI Afterburner in Windows fatal exception: int divide by zero. However, I did not see this error message in your log. Could you please double-check whether the error message appear in any of your logs?
I replicated the issue and after the crash I couldn’t find keywords “divide” or “zero” from the isaac sim full log file
