Isaac Sim: slow launch time
At first, when I only installed Isaac Sim 4.2.0, the launch time was under 10 seconds. Now it takes about 16 seconds. I was just wondering what could be the reason for such an increase. I am always comparing the performance by opening the empty scene through the Omniverse Launcher.
Operating System
[V] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify):
GPU Information
  • Model: NVIDIA GeForce RTX 3070
  • Driver Version: 550.127.05
CPU Information
Model: AMD® Ryzen 7 5700x 8-core processor × 16
Error Messages
[0.181s] [ext: omni.blobkey-1.1.2] startup
[0.182s] [ext: omni.kit.async_engine-0.0.1] startup
[0.667s] [ext: omni.stats-1.0.1] startup
[0.668s] [ext: omni.datastore-0.0.0] startup
[0.673s] [ext: omni.client-1.2.0] startup
[0.694s] [ext: omni.ujitso.default-1.0.0] startup
[0.695s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.698s] [ext: omni.hsscclient-1.1.1] startup
[0.699s] [ext: omni.assets.plugins-0.0.0] startup
[0.700s] [ext: omni.gpu_foundation-0.0.0] startup
[0.708s] [ext: carb.windowing.plugins-1.0.0] startup
[0.714s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 550.127.05    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 3070          | Yes: 0 |     | 8438    MB | 10de      | 0          |
|     |                                  |        |     |            | 2484      | c198fbe0.. |
|     |                                  |        |     |            | 4         |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-48-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 7 5700X 8-Core Processor | Cores: 8 | Logical: 16
| Total Memory (MB): 15907 | Free Memory: 10169
| Total Page/Swap (MB): 2047 | Free Page/Swap: 171
[1.321s] [ext: omni.kit.pipapi-0.0.0] startup
[1.323s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.323s] [ext: omni.pip.compute-1.4.0] startup
[1.324s] [ext: omni.materialx.libs-1.0.4] startup
[1.331s] [ext: omni.kit.telemetry-0.5.0] startup
[1.359s] [ext: omni.pip.cloud-1.1.3] startup
[1.362s] [ext: omni.isaac.core_archive-2.3.0] startup
[1.363s] [ext: omni.usd.config-1.0.4] startup
[1.367s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.367s] [ext: omni.usd.libs-1.0.1] startup
[1.436s] [ext: omni.iray.libs-0.0.0] startup
[1.442s] [ext: omni.mdl.neuraylib-0.2.8] startup
[1.443s] [ext: omni.mdl-55.0.1] startup
[1.461s] [ext: omni.kit.usd.mdl-1.0.1] startup
[1.556s] [ext: omni.kit.loop-isaac-1.2.0] startup
[1.556s] [ext: omni.kit.test-1.1.0] startup
[1.601s] [ext: omni.isaac.ml_archive-2.0.1] startup
[1.601s] [ext: omni.appwindow-1.1.8] startup
[2.186s] [ext: omni.kit.renderer.core-1.0.2] startup
[8.184s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.187s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[8.257s] [ext: omni.ui-2.25.22] startup
[8.266s] [ext: omni.kit.mainwindow-1.0.3] startup
[8.267s] [ext: carb.audio-0.1.0] startup
[8.270s] [ext: omni.uiaudio-1.0.0] startup
[8.271s] [ext: omni.kit.uiapp-0.0.0] startup
[8.271s] [ext: omni.usd.schema.metrics.assembler-106.1.0] startup
[8.278s] [ext: omni.usd.schema.physx-106.1.9] startup
[8.303s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[8.305s] [ext: omni.anim.graph.schema-106.1.0] startup
[8.310s] [ext: omni.usd.schema.anim-0.0.0] startup
[8.326s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[8.331s] [ext: omni.usd.schema.semantics-0.0.0] startup
[8.333s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[8.334s] [ext: omni.anim.navigation.schema-106.1.0] startup
[8.337s] [ext: omni.usd.schema.isaac-2.1.0] startup
[8.342s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[8.345s] [ext: omni.usd.schema.audio-0.0.0] startup
[8.348s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[8.352s] [ext: omni.graph.exec-0.9.4] startup
[8.353s] [ext: omni.kit.actions.core-1.0.0] startup
[8.354s] [ext: omni.kit.exec.core-0.13.4] startup
[8.356s] [ext: omni.kit.commands-1.4.9] startup
[8.359s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[8.361s] [ext: omni.resourcemonitor-105.0.1] startup
[8.362s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[8.366s] [ext: omni.activity.core-1.0.1] startup
[8.367s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[8.368s] [ext: omni.timeline-1.0.10] startup
[8.370s] [ext: omni.usd_resolver-1.0.0] startup
[8.373s] [ext: usdrt.scenegraph-7.5.0] startup
[8.407s] [ext: omni.usd.core-1.4.1] startup
[8.409s] [ext: omni.kit.usd_undo-0.1.8] startup
[8.410s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[8.420s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[8.423s] [ext: omni.usd-1.12.2] startup
[8.453s] [ext: omni.kit.asset_converter-2.1.21] startup
[8.465s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[8.466s] [ext: omni.volume-0.5.0] startup
[8.468s] [ext: omni.ujitso.client-0.0.0] startup
[8.468s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[8.469s] [ext: omni.hydra.rtx-1.0.0] startup
[8.483s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[8.485s] [ext: omni.debugdraw-0.1.3] startup
[8.487s] [ext: omni.kit.clipboard-1.0.4] startup
[8.488s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[8.489s] [ext: omni.graph.tools-1.79.0] startup
[8.510s] [ext: omni.kit.widget.path_field-2.0.10] startup
[8.511s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[8.513s] [ext: omni.kit.menu.core-1.0.4] startup
[8.514s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[8.514s] [ext: omni.inspect-1.0.1] startup
[8.516s] [ext: omni.kit.widget.options_button-1.0.3] startup
[8.516s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[8.517s] [ext: omni.kit.notification_manager-1.0.9] startup
[8.518s] [ext: omni.graph.core-2.179.2] startup
[8.520s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[8.522s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[8.522s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[8.526s] [ext: omni.kit.search_core-1.0.5] startup
[8.526s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[8.527s] [ext: omni.ui.scene-1.10.3] startup
[8.532s] [ext: omni.kit.widget.versioning-1.4.7] startup
[8.534s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[8.535s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[8.536s] [ext: omni.kit.window.filepicker-2.10.40] startup
[8.545s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[8.547s] [ext: omni.kit.usd.layers-2.1.36] startup
[8.554s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[8.555s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[8.555s] [ext: omni.kit.widget.filter-1.1.4] startup
[8.556s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[8.557s] [ext: omni.kit.context_menu-1.8.1] startup
[8.558s] [ext: omni.kit.widget.settings-1.2.2] startup
[8.559s] [ext: omni.kit.menu.utils-1.5.27] startup
[8.563s] [ext: omni.kit.widget.prompt-1.0.7] startup
[8.564s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[8.565s] [ext: omni.kit.stage_template.core-1.1.22] startup
[8.566s] [ext: omni.kit.window.preferences-1.6.0] startup
[8.569s] [ext: omni.kit.window.file_importer-1.1.12] startup
[8.569s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[8.571s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[8.573s] [ext: omni.kit.window.file-1.3.54] startup
[8.575s] [ext: omni.kit.window.drop_support-1.0.3] startup
[8.575s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[8.577s] [ext: omni.kit.window.content_browser-2.9.18] startup
[8.589s] [ext: omni.kit.widget.stage-2.11.2] startup
[8.597s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[8.598s] [ext: omni.kit.widget.graph-1.12.15] startup
[8.602s] [ext: omni.kit.hydra_texture-1.3.9] startup
[8.605s] [ext: omni.kit.viewport.legacy_gizmos-1.1.0] startup
[8.606s] [ext: omni.kit.raycast.query-1.0.5] startup
[8.610s] [ext: omni.kit.material.library-1.5.6] startup
[8.614s] [ext: omni.kit.widget.viewport-106.1.0] startup
[8.617s] [ext: omni.kit.viewport.registry-104.0.6] startup
[8.618s] [ext: omni.hydra.engine.stats-1.0.2] startup
[8.620s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[8.620s] [ext: omni.kit.viewport.window-107.0.6] startup
[8.633s] [ext: omni.kit.window.property-1.11.3] startup
[8.634s] [ext: omni.kit.viewport.utility-1.0.17] startup
[8.635s] [ext: omni.kit.property.usd-4.2.8] startup
[8.642s] [ext: omni.graph-1.140.0] startup
[8.747s] [ext: omni.kit.window.extensions-1.4.11] startup
[8.752s] [ext: omni.ui_query-1.1.4] startup
[8.753s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[8.755s] [ext: omni.graph.action_core-1.1.6] startup
[8.758s] [ext: omni.kvdb-106.1.9] startup
[8.759s] [ext: omni.graph.ui-1.70.2] startup
[8.774s] [ext: omni.physx.foundation-106.1.9] startup
[8.778s] [ext: omni.usdphysics-106.1.9] startup
[8.781s] [ext: omni.localcache-106.1.9] startup
[8.782s] [ext: omni.graph.action_nodes-1.24.0] startup
[8.787s] [ext: omni.convexdecomposition-106.1.9] startup
[8.791s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[8.795s] [ext: omni.physx.cooking-106.1.9] startup
[8.805s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[8.810s] [ext: omni.graph.action-1.102.1] startup
[8.811s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[8.814s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[8.830s] [ext: omni.physx-106.1.9] startup
[8.842s] [ext: omni.kit.stage_templates-1.2.5] startup
[8.845s] [ext: omni.kit.window.cursor-1.1.2] startup
[8.846s] [ext: omni.graph.image.core-0.4.5] startup
[8.847s] [ext: omni.isaac.version-1.1.0] startup
[8.848s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[8.860s] [ext: omni.graph.image.nodes-1.1.0] startup
[8.862s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[8.864s] [ext: omni.isaac.nucleus-0.3.1] startup
[8.868s] [ext: omni.syntheticdata-0.6.9] startup
[8.891s] [ext: omni.kit.window.material_graph-1.8.18] startup
[9.012s] [ext: omni.physics.tensors-106.1.9] startup
[9.020s] [ext: omni.physx.stageupdate-106.1.9] startup
[9.022s] [ext: omni.kit.numpy.common-0.1.2] startup
[9.023s] [ext: omni.warp.core-1.2.1] startup
[9.025s] [ext: omni.physx.tensors-106.1.9] startup
[9.028s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[9.034s] [ext: omni.graph.nodes-1.146.1] startup
[9.043s] [ext: omni.isaac.core-3.19.5] startup
[10.252s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[10.255s] [ext: omni.warp-1.2.1] startup
[10.259s] [ext: omni.graph.scriptnode-1.20.1] startup
[10.263s] [ext: omni.kit.ui_test-1.3.2] startup
[10.268s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[10.300s] [ext: omni.replicator.core-1.11.20] startup
2024-11-07 07:17:31 [10,291ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
   CUDA Toolkit 11.8, Driver 12.4
   Devices:
     "cpu"      : "x86_64"
     "cuda:0"   : "NVIDIA GeForce RTX 3070" (8 GiB, sm_86, mempool enabled)
   Kernel cache:
     /home/tim/.cache/warp/1.2.1
[10.507s] [ext: omni.isaac.ui-0.16.0] startup
[10.518s] [ext: omni.isaac.core_nodes-1.16.3] startup
[10.534s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[10.541s] [ext: omni.isaac.lula-3.0.1] startup
[10.552s] [ext: omni.isaac.motion_generation-7.1.0] startup
[10.582s] [ext: omni.isaac.manipulators-2.1.0] startup
[10.594s] [ext: omni.isaac.universal_robots-0.3.5] startup
[10.599s] [ext: omni.isaac.franka-0.4.1] startup
[10.609s] [ext: omni.isaac.examples_nodes-0.1.3] startup
[10.615s] [ext: omni.isaac.grasp_editor-1.3.0] startup
[10.673s] [ext: omni.importer.onshape-0.7.3] startup
[10.714s] [ext: omni.isaac.scene_blox-0.1.2] startup
[10.715s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[10.724s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[10.727s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[10.731s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[10.736s] [ext: omni.kit.widget.imageview-1.0.3] startup
[10.739s] [ext: omni.kit.browser.core-2.3.11] startup
[10.752s] [ext: omni.kit.window.stage-2.5.10] startup
[10.765s] [ext: omni.kit.usd.collect-2.2.21] startup
[10.773s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[10.786s] [ext: omni.kit.browser.folder.core-1.9.13] startup
[10.805s] [ext: omni.kit.menu.stage-1.2.5] startup
[10.810s] [ext: omni.kit.tool.collect-2.2.14] startup
[10.823s] [ext: omni.graph.window.core-1.113.1] startup
[10.860s] [ext: omni.isaac.extension_templates-1.7.0] startup
[10.863s] [ext: omni.importer.urdf-1.14.1] startup
[10.922s] [ext: omni.kit.browser.asset-1.3.10] startup
[10.930s] [ext: omni.graph.window.action-1.28.0] startup
[10.937s] [ext: omni.isaac.kit-1.13.2] startup
[10.939s] [ext: omni.anim.shared.core-106.0.1] startup
[10.944s] [ext: omni.anim.curve.core-1.1.14] startup
[10.961s] [ext: omni.isaac.manipulators.ui-1.2.1] startup
2024-11-07 07:17:31 [10,897ms] [Warning] [pxr.OmniGraphSchema] pxr.OmniGraphSchema is deprecated - please use OmniGraphSchema instead
[10.968s] [ext: omni.kit.preferences.animation-1.1.8] startup
[10.975s] [ext: omni.isaac.menu-0.7.3] startup
[10.982s] [ext: omni.anim.curve.ui-1.3.17] startup
[10.990s] [ext: omni.isaac.asset_browser-0.5.1] startup
[10.995s] [ext: omni.anim.curve.bundle-1.2.3] startup
[10.995s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[10.999s] [ext: omni.kit.property.audio-1.0.14] startup
[11.003s] [ext: omni.hydra.scene_api-0.1.2] startup
[11.007s] [ext: omni.kit.property.light-1.0.10] startup
[11.009s] [ext: omni.kit.property.material-1.10.8] startup
[11.018s] [ext: omni.kit.property.render-1.1.2] startup
[11.021s] [ext: omni.kit.property.transform-1.5.9] startup
[11.026s] [ext: omni.kit.property.geometry-1.3.1] startup
[11.030s] [ext: omni.kit.property.camera-1.0.8] startup
[11.032s] [ext: omni.isaac.debug_draw-1.1.0] startup
[11.036s] [ext: omni.isaac.block_world-1.0.0] startup
[11.041s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[11.054s] [ext: omni.kit.property.bundle-1.3.1] startup
[11.057s] [ext: omni.isaac.occupancy_map-1.0.3] startup
[11.063s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[11.074s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[11.076s] [ext: omni.isaac.occupancy_map.ui-1.1.1] startup
[11.084s] [ext: omni.isaac.merge_mesh-1.0.2] startup
[11.088s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[11.093s] [ext: omni.physx.commands-106.1.9] startup
[11.097s] [ext: omni.kit.viewport.actions-106.0.2] startup
[11.102s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[11.114s] [ext: omni.fabric.commands-1.1.5] startup
[11.118s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[11.120s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[11.123s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[11.125s] [ext: omni.usdphysics.ui-106.1.9] startup
[11.147s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[11.152s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[11.152s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[11.154s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[11.165s] [ext: omni.physx.ui-106.1.9] startup
[11.215s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[11.225s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[11.235s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[11.253s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[11.257s] [ext: omni.kit.property.physx-106.1.9] startup
[11.338s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[11.339s] [ext: omni.physx.demos-106.1.9] startup
[11.409s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[11.411s] [ext: omni.isaac.range_sensor-3.1.2] startup
[11.453s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[11.459s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
[11.473s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[11.483s] [ext: omni.physx.vehicle-106.1.9] startup
[11.987s] [ext: omni.sensors.tiled-0.0.6] startup
[11.990s] [ext: omni.isaac.surface_gripper.ui-1.0.0] startup
[11.991s] [ext: omni.kit.widget.layers-1.8.0] startup
[12.007s] [ext: omni.kit.window.toolbar-1.6.1] startup
[12.011s] [ext: omni.isaac.physics_inspector-0.1.5] startup
[12.015s] [ext: omni.physx.camera-106.1.9] startup
[12.029s] [ext: omni.isaac.sensor-12.9.1] startup
[12.092s] [ext: omni.physx.cct-106.1.9] startup
[12.107s] [ext: omni.physx.graph-106.1.9] startup
[12.142s] [ext: omni.physx.supportui-106.1.9] startup
[12.159s] [ext: omni.physx.telemetry-106.1.9] startup
[12.162s] [ext: omni.isaac.physics_utilities-0.1.4] startup
[12.168s] [ext: omni.isaac.camera_inspector-0.2.2] startup
[12.172s] [ext: omni.graph.window.generic-1.26.0] startup
[12.182s] [ext: omni.isaac.synthetic_recorder-1.8.1] startup
[12.187s] [ext: omni.isaac.throttling-1.1.0] startup
[12.189s] [ext: omni.isaac.utils-1.0.1] startup
[12.192s] [ext: omni.physx.bundle-106.1.9] startup
[12.193s] [ext: omni.isaac.gain_tuner-1.1.2] startup
[12.197s] [ext: omni.isaac.window.about-1.1.0] startup
[12.201s] [ext: omni.kit.actions.window-1.1.1] startup
[12.204s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[12.206s] [ext: omni.kit.selection-0.1.4] startup
[12.210s] [ext: omni.isaac.import_wizard-0.5.2] startup
[12.212s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[12.225s] [ext: omni.kit.menu.aov-1.1.4] startup
[12.226s] [ext: omni.kit.menu.edit-1.1.24] startup
[12.229s] [ext: omni.kit.menu.file-1.1.14] startup
[12.234s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[12.237s] [ext: omni.kit.core.collection-0.1.7] startup
[12.239s] [ext: omni.kit.window.title-1.1.5] startup
[12.240s] [ext: omni.kit.menu.create-1.0.16] startup
[12.241s] [ext: omni.isaac.range_sensor.examples-1.0.1] startup
[12.259s] [ext: omni.kit.property.collection-0.1.17] startup
[12.267s] [ext: omni.kit.property.isaac-0.2.3] startup
[12.269s] [ext: omni.mdl.usd_converter-1.0.21] startup
[12.272s] [ext: omni.kit.property.layer-1.1.8] startup
[12.274s] [ext: omni.kit.scripting-106.1.1] startup
[12.278s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[12.282s] [ext: omni.kit.search.files-1.0.4] startup
[12.283s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[12.285s] [ext: omni.kit.stage.mdl_converter-1.0.6] startup
[12.286s] [ext: omni.kit.browser.material-1.6.0] startup
[12.289s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[12.291s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[12.293s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[12.295s] [ext: omni.isaac.range_sensor.ui-1.0.1] startup
[12.296s] [ext: omni.isaac.cloner-0.8.1] startup
[12.299s] [ext: omni.kit.window.material-1.6.2] startup
[12.303s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[12.305s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[12.306s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[12.394s] [ext: omni.kit.tool.asset_exporter-1.3.3] startup
[12.398s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[12.399s] [ext: omni.isaac.robot_assembler-1.5.1] startup
[12.402s] [ext: omni.rtx.window.settings-0.6.17] startup
[12.407s] [ext: omni.kit.widget.live-2.1.8] startup
[12.409s] [ext: omni.kit.widget.calendar-1.0.8] startup
[12.411s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[12.413s] [ext: omni.kit.widget.collection-0.1.18] startup
[12.416s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[12.417s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[12.418s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[12.464s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[12.472s] [ext: omni.kit.widget.timeline-105.0.1] startup
[12.477s] [ext: omni.graph.ui_nodes-1.26.0] startup
[12.481s] [ext: omni.kit.window.collection-0.1.22] startup
[12.483s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[12.493s] [ext: omni.kit.window.commands-0.2.6] startup
[12.498s] [ext: omni.kit.usda_edit-1.1.14] startup
[12.513s] [ext: omni.scene.optimizer.core-106.1.1] startup
[12.590s] [ext: omni.kit.window.console-0.2.13] startup
[12.598s] [ext: omni.graph.bundle.action-2.4.1] startup
[12.601s] [ext: omni.kit.window.script_editor-1.7.6] startup
[12.606s] [ext: omni.isaac.wheeled_robots.ui-1.1.1] startup
[12.612s] [ext: omni.kit.window.status_bar-0.1.7] startup
[12.615s] [ext: omni.usd.metrics.assembler-106.1.0] startup
[12.621s] [ext: omni.kit.converter.common-500.0.10] startup
[12.646s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[12.647s] [ext: omni.replicator.isaac-1.15.2] startup
[12.662s] [ext: semantics.schema.property-1.0.4] startup
[12.666s] [ext: omni.rtx.settings.core-0.6.3] startup
[12.672s] [ext: omni.simready.explorer-1.1.1] startup
[12.684s] [ext: omni.usd.metrics.assembler.physics-106.1.0] startup
[12.686s] [ext: omni.kit.converter.dgn_core-500.0.19] startup
[12.740s] [ext: omni.kit.ui.actions-1.0.2] startup
[12.742s] [ext: omni.kit.tool.asset_importer-2.5.5] startup
[12.743s] [ext: omni.kit.widgets.custom-1.0.8] startup
[12.749s] [ext: omni.isaac.cortex-0.3.9] startup
[12.750s] [ext: omni.usd.metrics.assembler.ui-106.1.0] startup
[12.754s] [ext: omni.kit.converter.hoops_core-500.0.17] startup
[12.758s] [ext: omni.kit.converter.jt_core-500.0.16] startup
[12.774s] [ext: omni.kit.menu.common-1.1.7] startup
[12.775s] [ext: omni.kit.converter.dgn-500.0.6] startup
[12.777s] [ext: omni.kit.variant.editor-106.1.0] startup
[12.787s] [ext: omni.isaac.cortex.sample_behaviors-1.0.6] startup
[12.788s] [ext: omni.isaac.quadruped-2.0.1] startup
[12.801s] [ext: omni.kit.converter.hoops-500.0.7] startup
[12.803s] [ext: omni.kit.converter.jt-500.0.7] startup
[12.807s] [ext: omni.kit.quicklayout-1.0.7] startup
[12.808s] [ext: semantics.schema.editor-0.3.8] startup
[12.810s] [ext: omni.kit.variant.presenter-106.0.0] startup
[12.812s] [ext: omni.isaac.robot_description_editor-2.5.0] startup
[12.814s] [ext: omni.isaac.examples-3.0.2] startup
[12.928s] [ext: omni.importer.mjcf-1.1.1] startup
[12.948s] [ext: omni.kit.converter.cad-201.1.0] startup
[12.950s] [ext: omni.kit.window.stats-0.1.6] startup
[12.963s] [ext: omni.isaac.app.setup-0.14.0] startup
[12.964s] Isaac Sim Version: 4.2.0-rc.17
[12.965s] Writing Isaac Sim icon file
[12.965s] [ext: omni.isaac.assets_check-0.3.5] startup
[12.967s] [ext: omni.kit.profiler.window-2.2.3] startup
[12.973s] [ext: omni.isaac.sim.base-4.2.0] startup
[12.975s] [ext: omni.isaac.sim-4.2.0] startup
[13.128s] [ext: omni.isaac.ros2_bridge-2.32.6] startup
[13.179s] Attempting to load system rclpy
[13.207s] rclpy loaded
[15.020s] app ready
[15.716s] Isaac Sim App is loaded.
Additional Information
What I’ve Tried
I tried to even reinstall Ubuntu, but the result is same here. I changed several times CUDA version and Drivers.
Additional Context
Should I change the driver or the CUDA version. Why does it say “CUDA Toolkit 11.8” even if I built the CUDA 12.6 for 550 driver.
Could you elaborate on what changes caused the increase in launch time from 10 seconds to 16 seconds? Were any additional extensions enabled?
The only extension used is ROS2 bridge. I dont think I enabled anything else.
Could you provide the detailed steps that occurred between seeing the 10-second and 16-second launch times?
No additional steps happening except the terminal output I provided above. It is during the Isaac Sim launch.
The increase in Isaac Sim’s launch time from 10 to 16 seconds could be due to factors like additional cache files, background processes, updates, or system changes (e.g., drivers or resource contention). It’s like waiting for your lunchtime results—sometimes delays happen due to extra checks or processes in the background. To troubleshoot, verify the installation, clear unnecessary cache files, ensure GPU drivers are up to date, and check for system load or recently added plugins causing the slowdown.
