Isaac sim is not launching
I am trying to launch Isaac sim but it just crash, so I try run the ISAAC SIM COMPATIBILITY CHECKER and this pop up:
omni.app.mini.sh has ended with error (55): b"[Info] [carb]
Logging to file: /home/sousa/.nvidia-omniverse/logs/Kit/omni. app.mini/0.1/kit_20240730_120011.log\n[0.071s| Failed to solve some dependencies locally, syncing with extension registry…In[0.
072] [ext: omni.kit.async_engine-0.0.01 startup\n[0.073] (ext omni.client-1.1.0] startup\n(0.099s [ext: omni.kit.registry.
nucleus-0.0.0] startup Insyncing registry:
"https://ovextensionsprod.blob.core.windows.
net/exts/kit/prod/shared/v2’ Downloading 350 files… In*
running by terminal I noticed this error: 2024-07-30 15:40:01 [11,795ms] [Error] [omni.physx.plugin] PhysX error: Could not load libcuda.so: libcuda.so: cannot open shared object file: No such file or directory
, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/physx/src/gpu/PxPhysXGpuModuleLoader.cpp, LINE 200
Can you check the path and version ?
echo $LD_LIBRARY_PATH #path
sudo find /usr/ -name 'libcuda.so.*' #version
Turn off virtualization on bios
