Isaac Sim Version
4.2.0
Isaac Lab Version (if applicable)
1.2
Operating System
Ubuntu 22.04
GPU Information
- Model: NVIDIA GeForce RTX 4090 x2
- Driver Version: 555.42.06
Topic Description
Detailed Description
I installed isaacsim and isaaclab in a conda environment following the steps on the official website. However, I cannot run
from isaacsim import SimulationApp
simulation_app = SimulationApp({"headless": True})
or
./isaaclab.sh -p source/standalone/tutorials/00_sim/create_empty.py
Steps to Reproduce
- Install isaac following https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_python.html. on Ubuntu
- Install the extra packages
- Run the above scipts
Error Messages
[Error] [omni.physx.plugin] PhysX error: Could not load libcuda.so: libcuda.so: cannot open shared object file: No such file or directory,
FILE /builds/omniverse/physics/physx/source/physx/src/gpu/PxPhysXGpuModuleLoader.cpp, LINE 200
Fatal Python error: Segmentation fault
Additional Information
What I’ve Tried
- Reboot machine
- Create a new conda environment and reinstall everything from start.
- Search for libcuda.so, and found existence
/usr/lib/x86_64-linux-gnu/libcuda.so.555.42.06
/usr/lib/x86_64-linux-gnu/libcuda.so.1
- set
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/x86_64-linux-gnu/libcuda.so.1and ran again. - set
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/x86_64-linux-gnu/libcuda.so.555.42.06and ran again
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
nvidia-smi
| NVIDIA-SMI 555.42.06 Driver Version: 555.42.06 CUDA Version: 12.5 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 Off | 00000000:01:00.0 On | Off |
| 31% 37C P8 12W / 450W | 736MiB / 24564MiB | 7% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 4090 Off | 00000000:03:00.0 Off | Off |
| 0% 38C P8 4W / 450W | 16MiB / 24564MiB | 0% Default |
| | | N/A |
Ubuntu version check
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
