Failed to set the CUDA device -1 running Isaac Sim on Fedora
Ran isaac-sim binary on a Fedora desktop machine, the UI came up but have a constant spew of
2021-02-19 21:39:54 [45,943ms] [Error] [carb.cudainterop.plugin] CUDA error 999: cudaErrorUnknown - unknown error)
2021-02-19 21:39:54 [45,943ms] [Error] [carb.cudainterop.plugin] Failed to set the CUDA device: -1
Nvidia-SMI:
| NVIDIA-SMI 460.39 Driver Version: 460.39 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce RTX 2080 Off | 00000000:65:00.0 On | N/A |
| 25% 33C P8 2W / 215W | 433MiB / 7979MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 28186 G /usr/libexec/Xorg 217MiB |
| 0 N/A N/A 29751 G /usr/bin/gnome-shell 112MiB |
| 0 N/A N/A 189791 G …gAAAAAAAAA --shared-files 97MiB |
| 0 N/A N/A 215727 G gnome-control-center 2MiB |
What could be wrong?
I’m not sure. Can you try uninstall the NVIDIA drivers and CUDA toolkit if you have it installed and then reinstall just the NVIDIA drivers. I would recommend installing version 450.X or 455.X,
@hcreal Is your issue resolved? were you able to successfully install Isaac Sim?
Yes reinstalling the drivers fixed the cuda error
