I am installing Isaac Sim from the ommniverse-launcher. I followed the steps in: 2. Basic Isaac Sim Installation — Omniverse Robotics documentation
After a few minutes trying to install, I get the following notification:
Error occurred during installation of Isaac Sim: Command failed: “/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh”
2021-11-24 04:49:56 [2,479ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
- For Ubuntu, it requires server-xorg-core 1.20.7+ and a display to work without --no-window.
- For Linux dockers, the setup is not complete. Install the latest driver, xServer and NVIDIA container runtime.
2021-11-24 04:50:00 [6,068ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
2021-11-24 04:50:00 [6,068ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2021-11-24 04:50:00 [6,068ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2021-11-24 04:50:00 [6,078ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘get_mouse_event_stream’
At:
/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/extscore/omni.kit.window.viewport/omni/kit/viewport/scripts/context_menu.py(27): on_startup
/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(143): _startup_ext
/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(174): startup_all_extensions_in_module
/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-11-24 04:50:00 [6,078ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] Failed to process python module extension in ‘/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/extscore/omni.kit.window.viewport/.’.
2021-11-24 04:50:00 [6,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2021-11-24 04:50:00 [6,350ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::)(unsigned int, int, carb::cpp20::latch), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-11-24 04:50:00 [6,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-11-24 04:50:00 [6,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.physxui.plugin.so!carbOnPluginStartup
2021-11-24 04:50:00 [6,380ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2021-11-24 04:50:00 [6,388ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2021-11-24 04:50:00 [6,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2021-11-24 04:50:00 [6,401ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2021-11-24 04:50:00 [6,406ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!_init
2021-11-24 04:50:00 [6,409ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocatorstd::string >::_M_realloc_insertstd::string&(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocatorstd::string > >, std::string&)
2021-11-24 04:50:00 [6,413ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2021-11-24 04:50:00 [6,416ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)
2021-11-24 04:50:00 [6,419ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2021-11-24 04:50:00 [6,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2021-11-24 04:50:00 [6,424ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2021-11-24 04:50:00 [6,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-11-24 04:50:00 [6,429ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)
2021-11-24 04:50:00 [6,431ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-11-24 04:50:00 [6,431ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-11-24 04:50:00 [6,434ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-11-24 04:50:00 [6,434ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
/home/rbenavid/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh: line 4: 4809 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
I am running this on Ubuntu 18.04. Here is my nvidia-smi output:
Any tips on how to troubleshoot this issue?
