Hi all,
Im trying to install the last version of isaac sim on my personal laptop on ubuntu 20.04 but im receiving this error
Error occurred during installation of Isaac Sim: stderr maxBuffer length exceeded
Does anyone know how to fix it ?
and thank you.
I reinstalled everything now i got this error:
Error occurred during installation of Isaac Sim: Command failed: “/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh”
WARNING: You are using pip version 20.1.1; however, version 22.0.2 is available.
You should consider upgrading via the ‘/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/bin/python3 -m pip install --upgrade pip’ command.
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
2022-02-03 04:04:43 [9,928ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
- For Ubuntu, it requires server-xorg-core 1.20.7+ and a display to work without --no-window.
- For Linux dockers, the setup is not complete. Install the latest driver, xServer and NVIDIA container runtime.
2022-02-03 04:04:45 [11,247ms] [Error] [carb.cudainterop.plugin] CUDA error 100: cudaErrorNoDevice - no CUDA-capable device is detected)
2022-02-03 04:04:45 [11,247ms] [Error] [carb.cudainterop.plugin] Failed to query CUDA device count.
2022-02-03 04:04:45 [11,247ms] [Error] [carb.cudainterop.plugin] Failed to set the CUDA device: -1
2022-02-03 04:04:45 [11,247ms] [Error] [carb.cudainterop.plugin] Failed to create CUDA stream.
2022-02-03 04:04:45 [11,248ms] [Error] [carb.cudainterop.plugin] CUDA error 100: cudaErrorNoDevice - no CUDA-capable device is detected)
2022-02-03 04:04:45 [11,248ms] [Error] [carb.cudainterop.plugin] Failed to set the CUDA device: -1
2022-02-03 04:04:45 [11,248ms] [Error] [carb.cudainterop.plugin] Failed to create CUDA stream.
2022-02-03 04:04:45 [11,248ms] [Error] [carb.cudainterop.plugin] Failed to query CUDA device count.
2022-02-03 04:04:46 [12,967ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
2022-02-03 04:04:46 [12,967ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2022-02-03 04:04:46 [12,967ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2022-02-03 04:04:46 [12,979ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘get_mouse_event_stream’
At:
/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.window.viewport/omni/kit/viewport/scripts/context_menu.py(27): on_startup
/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(143): _startup_ext
/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(174): startup_all_extensions_in_module
/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2022-02-03 04:04:46 [12,979ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] Failed to process python module extension in ‘/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.window.viewport/.’.
2022-02-03 04:04:47 [13,259ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.isaac.core. Error: No module named ‘omni.kit.viewport’. Traceback:
File "/home/abderrahmen/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/p
