/omni.ext.plugin - omni.kit.manipulator.prim-104.10.5 and omni.kit.manipulator.viewport-104.0.7 setup failed!
when I run PYTHON_PATH scripts/rlgames_train.py task=Cartpole, screen is black ! some error in log below
show ext.plugin prim and viewport setup failed! please help me !
D:\Workshop\OmniIsaacGymEnvs\omniisaacgymenvs>PYTHON_PATH scripts/rlgames_train.py task=Cartpole
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\defaults_list.py:251: UserWarning: In ‘config’: Defaults list is missing _self_. See Changes to default composition order | Hydra for more information
warnings.warn(msg, UserWarning)
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\defaults_list.py:412: UserWarning: In config: Invalid overriding of hydra/job_logging:
Default list overrides requires ‘override’ keyword.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/defaults_list_override for more information.
deprecation_warning(msg)
[Warning] [omni.isaac.kit.simulation_app] Modules: [‘omniisaacgymenvs’, ‘omniisaacgymenvs.utils’, ‘omniisaacgymenvs.utils.hydra_cfg’, ‘omniisaacgymenvs.utils.hydra_cfg.hydra_utils’, ‘omniisaacgymenvs.utils.hydra_cfg.reformat’, ‘omniisaacgymenvs.utils.rlgames’, ‘omniisaacgymenvs.utils.rlgames.rlgames_utils’, ‘omniisaacgymenvs.utils.task_util’, ‘omniisaacgymenvs.utils.config_utils’, ‘omniisaacgymenvs.utils.config_utils.path_utils’, ‘omniisaacgymenvs.envs’, ‘omniisaacgymenvs.envs.vec_env_rlgames’, ‘omni’, ‘omni.isaac.gym’, ‘omni.isaac.gym.vec_env’, ‘omni.isaac.gym.vec_env.vec_env_base’, ‘omni.kit.app._impl.telemetry_helpers’, ‘omni.isaac.gym.vec_env.vec_env_mt’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Starting kit application with the following args: [‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\apps/omni.isaac.sim.python.kit’, ‘–/app/tokens/exe-path=C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–/app/fastShutdown=True’, ‘–ext-folder’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts’, ‘–ext-folder’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/apps’, ‘–/physics/cudaDevice=0’, ‘–portable’]
Passing the following args to the base kit application: [‘task=Cartpole’]
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[Info] [carb] Logging to file: c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/logs/Kit/Isaac-Sim/2022.2/kit_20230114_152443.log
[0.680s] [ext: omni.stats-0.0.0] startup
[1.857s] [ext: omni.rtx.shadercache-1.0.0] startup
[2.025s] [ext: omni.assets.plugins-0.0.0] startup
[2.045s] [ext: omni.gpu_foundation-0.0.0] startup
[2.668s] [ext: carb.windowing.plugins-1.0.0] startup
[3.035s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-01-14 07:24:47 [4,163ms] [Warning] [gpu.foundation.plugin] Disabling auto-enabled Aftermath because of incompatible drivers, install recommended driver version.
2023-01-14 07:24:48 [4,689ms] [Error] [carb.graphics-direct3d.plugin] HRESULT: 0x887a0004
2023-01-14 07:24:48 [4,690ms] [Error] [carb.graphics-direct3d.plugin] D3D12CreateDevice failed for the selected physicalDevice.
2023-01-14 07:24:48 [4,691ms] [Warning] [gpu.foundation.plugin] An unsupported driver or hardware is found. createDevice() failed for GPU: 1. Skipping this device
| Driver Version: 528.2 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2070 | Yes: 0 | | 8019 MB | 10de | df860000… |
| | | | | | 1f02 | 0 |
| 1 | Intel(R) HD Graphics 4600 | | | 112 MB | 8086 | 10b59000… |
| | | | | | 412 | 0 |
| OS: Windows, Version: 10.0, Build: 19045
| Processor: Intel(R) Core™ i7-4770S CPU @ 3.10GHz | Cores: 4 | Logical: 8
| Total Memory (MB): 32666 | Free Memory: 23195
| Total Page/Swap (MB): 34714 | Free Page/Swap: 21598
[5.916s] [ext: omni.kit.pipapi-0.0.0] startup
[6.482s] [ext: omni.kit.pip_archive-0.0.0] startup
[6.523s] [ext: omni.kit.loop-isaac-1.0.0] startup
[6.531s] [ext: omni.kit.async_engine-0.0.0] startup
[6.548s] [ext: omni.kit.test-0.0.0] startup
[6.722s] [ext: omni.usd.config-1.0.0] startup
[6.797s] [ext: omni.usd.libs-1.0.0] startup
[7.820s] [ext: omni.isaac.core_archive-2.0.1] startup
[8.047s] [ext: omni.pip.torch-1_13_0-0.1.4] startup
[8.076s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-01-14 07:24:51 [7,885ms] [Warning] [omni.ext._impl.internal] There is already a module ‘gym’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.ml_archive\pip_prebundle’.[8.084s] [ext: omni.client-0.1.1] startup
[8.157s] [ext: omni.appwindow-1.0.1] startup
[8.211s] [ext: omni.kit.renderer.core-0.0.0] startup
[8.468s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.497s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[8.908s] [ext: carb.audio-0.1.0] startup
[8.914s] [ext: omni.ui-2.12.23] startup
[9.052s] [ext: omni.uiaudio-1.0.0] startup
[9.069s] [ext: omni.kit.mainwindow-1.0.0] startup
[9.083s] [ext: omni.kit.uiapp-0.0.0] startup
[9.084s] [ext: omni.usd.schema.physics-1.0.0] startup
2023-01-14 07:24:52 [9,043ms] [Warning] [omni.ext._impl.internal] There is already a module ‘pxr.UsdPhysics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\pxr\UsdPhysics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
2023-01-14 07:24:52 [9,146ms] [Warning] [omni.ext._impl.internal] There is already a module ‘usd.schema.physics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\usd\schema\physics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
[9.339s] [ext: omni.usd.schema.physx-0.0.0] startup
[9.572s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[9.635s] [ext: omni.usd.schema.anim-0.0.0] startup
[10.220s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[10.282s] [ext: omni.usd.schema.audio-0.0.0] startup
[10.335s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[10.394s] [ext: omni.usd.schema.semantics-0.0.0] startup
[10.446s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[10.522s] [ext: omni.kit.window.popup_dialog-2.0.15] startup
[10.640s] [ext: omni.kit.widget.nucleus_connector-1.0.2] startup
[10.723s] [ext: omni.usd.core-1.0.0] startup
[10.728s] [ext: omni.kit.actions.core-1.0.0] startup
[10.765s] [ext: omni.timeline-1.0.5] startup
[10.793s] [ext: omni.kit.commands-1.4.5] startup
[10.850s] [ext: omni.gpucompute.plugins-0.0.0] startup
[10.862s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[10.883s] [ext: omni.hydra.usdrt_delegate-4.1.1] startup
[10.922s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[10.935s] [ext: omni.usd-1.6.23] startup
[11.380s] [ext: omni.kit.asset_converter-1.2.39] startup
[11.441s] [ext: omni.usd.schema.isaac-1.0.0] startup
[11.609s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[11.632s] [ext: omni.kit.usd.layers-2.0.10] startup
[11.704s] [ext: omni.kit.menu.utils-1.4.7] startup
[11.830s] [ext: omni.kit.menu.create-1.0.8] startup
[11.842s] [ext: omni.iray.libs-0.0.0] startup
[11.937s] [ext: omni.inspect-1.0.1] startup
[11.974s] [ext: omni.volume-0.1.0] startup
[11.996s] [ext: omni.mdl.neuraylib-0.1.0] startup
[12.048s] [ext: omni.graph.tools-1.17.0] startup
[12.212s] [ext: omni.graph.core-2.64.7] startup
[12.221s] [ext: omni.hydra.rtx-0.1.0] startup
[12.293s] [ext: omni.kit.primitive.mesh-1.0.6] startup
[12.329s] [ext: omni.kit.usd_undo-0.1.1] startup
[12.344s] [ext: omni.kit.stage_templates-1.1.11] startup
[12.367s] [ext: omni.kit.widget.path_field-2.0.4] startup
[12.379s] [ext: omni.graph-1.50.1] startup
[12.678s] [ext: omni.debugdraw-0.1.1] startup
[12.700s] [ext: omni.kit.widget.browser_bar-2.0.4] startup
[12.709s] [ext: omni.kit.widget.versioning-1.3.8] startup
[12.732s] [ext: omni.kvdb-0.0.0] startup
[12.765s] [ext: omni.hydra.pxr-1.1.2] startup
[12.819s] [ext: omni.localcache-0.0.0] startup
[12.870s] [ext: omni.kit.hydra_texture-1.0.11] startup
[12.906s] [ext: omni.activity.core-1.0.1] startup
[12.948s] [ext: omni.convexdecomposition-104.1.6-5.1] startup
[12.982s] [ext: omni.kit.widget.viewport-104.1.15] startup
[13.040s] [ext: omni.kit.window.drop_support-1.0.1] startup
[13.046s] [ext: omni.kit.notification_manager-1.0.4] startup
[13.063s] [ext: omni.kit.search_core-1.0.1] startup
[13.077s] [ext: omni.kit.widget.filebrowser-2.3.8] startup
[13.181s] [ext: omni.ui.scene-1.5.17] startup
[13.259s] [ext: omni.kit.viewport.registry-104.0.2] startup
[13.310s] [ext: omni.kit.viewport.legacy_gizmos-1.0.8] startup
[13.320s] [ext: omni.hydra.engine.stats-1.0.0] startup
[13.346s] [ext: omni.kit.window.filepicker-2.7.8] startup
OmniAssetFileFormat
[13.728s] [ext: omni.kit.viewport.window-104.1.18] startup
[13.855s] [ext: omni.mdl-0.1.0] startup
[14.011s] [ext: omni.kit.window.file_importer-1.0.8] startup
[14.021s] [ext: omni.kit.viewport.utility-1.0.12] startup
[14.028s] [ext: omni.kit.material.library-1.3.21] startup
[14.078s] [ext: omni.kit.clipboard-1.0.0] startup
[14.085s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[14.095s] [ext: omni.ui_query-1.1.1] startup
[14.115s] [ext: omni.kit.context_menu-1.5.10] startup
[14.152s] [ext: omni.kit.window.file-1.3.30] startup
[14.175s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[14.185s] [ext: omni.kit.ui_test-1.2.9] startup
[14.210s] [ext: omni.kit.window.property-1.8.2] startup
[14.228s] [ext: omni.kit.window.content_browser-2.6.5] startup
[14.289s] [ext: omni.kit.widget.stage-2.7.18] startup
[14.320s] [ext: omni.usdphysics-104.1.6-5.1] startup
[14.326s] [ext: omni.kit.property.usd-3.18.12] startup
[14.446s] [ext: omni.physx-104.1.6-5.1] startup
[14.596s] [ext: omni.kit.widget.settings-1.0.1] startup
[14.607s] [ext: omni.kit.widget.graph-1.5.3] startup
[14.800s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[14.834s] [ext: omni.kit.window.preferences-1.3.7] startup
[15.051s] [ext: omni.kit.window.extensions-1.1.1] startup
[15.085s] [ext: omni.kit.widget.prompt-1.0.4] startup
[15.092s] [ext: omni.physics.tensors-0.1.0] startup
[15.141s] [ext: omni.graph.ui-1.24.1] startup
[15.516s] [ext: omni.isaac.version-1.0.0] startup
[15.523s] [ext: omni.physx.tensors-0.1.0] startup
[15.541s] [ext: omni.graph.action-1.31.0] startup
[15.617s] [ext: omni.kit.numpy.common-0.1.0] startup
[15.655s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[15.695s] [ext: omni.kit.widget.searchfield-1.0.8] startup
[15.721s] [ext: omni.isaac.dynamic_control-1.2.2] startup
[15.788s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
2023-01-14 07:24:59 [15,645ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
2023-01-14 07:24:59 [15,653ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(95): startup
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\extension.py(13): on_startup
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(146): _startup_ext
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(197): startup
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(280): startup_extension
PythonExtension.cpp::startup()(2):
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(284): _start_app
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(169): init
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.gym\omni\isaac\gym\vec_env\vec_env_base.py(37): init
scripts/rlgames_train.py(93): parse_hydra_configs
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\core\utils.py(160): run_job
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\hydra.py(106): run
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(381):
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(211): run_and_report
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(378): _run_hydra
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\main.py(52): decorated_main
scripts/rlgames_train.py(139):
2023-01-14 07:24:59 [15,654ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.viewport-104.0.7] Failed to startup python extension.
[16.845s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[16.882s] [ext: omni.isaac.core-1.42.0] startup
[18.117s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[18.195s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[18.206s] [ext: omni.isaac.ui-0.4.3] startup
[18.221s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-01-14 07:25:01 [18,032ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[18.226s] [ext: omni.isaac.surface_gripper-0.3.2] startup
2023-01-14 07:25:01 [18,050ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Surface Gripper *********************
2023-01-14 07:25:01 [18,051ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Surface Gripper uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.270s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[18.281s] [ext: omni.kit.graph.delegate.modern-1.6.4] startup
[18.292s] [ext: omni.isaac.manipulators-1.1.0] startup
[18.308s] [ext: omni.graph.window.core-1.41.0] startup
[18.357s] [ext: omni.isaac.mjcf-0.3.0] startup
2023-01-14 07:25:01 [18,197ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription MJCF Importer *********************
2023-01-14 07:25:01 [18,198ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] MJCF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.395s] [ext: omni.graph.window.generic-1.3.10] startup
2023-01-14 07:25:01 [18,216ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2023-01-14 07:25:01 [18,216ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Push Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:01 [18,217ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2023-01-14 07:25:01 [18,218ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Lazy Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.412s] [ext: omni.kit.widget.spinner-1.0.4] startup
[18.435s] [ext: omni.kit.window.cursor-1.1.1] startup
[18.454s] [ext: omni.isaac.lula-1.2.1] startup
[18.511s] [ext: omni.graph.nodes-1.48.3] startup
[18.696s] [ext: omni.kit.viewport.menubar.core-104.4.1] startup
[18.817s] [ext: omni.isaac.motion_planning-0.2.1] startup
[18.870s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[18.877s] [ext: omni.syntheticdata-0.2.4] startup
2023-01-14 07:25:02 [18,752ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[18.984s] [ext: omni.isaac.motion_generation-4.5.5] startup
[19.026s] [ext: omni.kit.browser.core-2.2.1] startup
[19.087s] [ext: omni.isaac.synthetic_utils-0.4.2] startup
[19.150s] [ext: omni.isaac.universal_robots-0.3.1] startup
[19.157s] [ext: omni.kit.browser.folder.core-1.7.1] startup
[19.191s] [ext: omni.isaac.urdf-0.5.4] startup
2023-01-14 07:25:02 [19,029ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription URDF Importer *********************
2023-01-14 07:25:02 [19,030ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] URDF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,040ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter URDF *********************
2023-01-14 07:25:02 [19,041ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,074ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka URDF *********************
2023-01-14 07:25:02 [19,075ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,107ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya URDF *********************
2023-01-14 07:25:02 [19,108ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,141ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 URDF *********************
2023-01-14 07:25:02 [19,142ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.366s] [ext: omni.isaac.utils-0.2.3] startup
2023-01-14 07:25:02 [19,193ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3 *********************
2023-01-14 07:25:02 [19,193ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,194ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5 *********************
2023-01-14 07:25:02 [19,194ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,195ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 *********************
2023-01-14 07:25:02 [19,196ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,196ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3e *********************
2023-01-14 07:25:02 [19,197ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,197ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5e *********************
2023-01-14 07:25:02 [19,198ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,198ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10e *********************
2023-01-14 07:25:02 [19,199ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,199ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR16e *********************
2023-01-14 07:25:02 [19,200ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR16e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,200ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 900 *********************
2023-01-14 07:25:02 [19,201ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 900 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,201ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 1300 *********************
2023-01-14 07:25:02 [19,202ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 1300 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,203ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Dofbot *********************
2023-01-14 07:25:02 [19,203ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Dofbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,204ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka *********************
2023-01-14 07:25:02 [19,204ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,206ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription A1 *********************
2023-01-14 07:25:02 [19,206ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] A1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,207ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Go1 *********************
2023-01-14 07:25:02 [19,207ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Go1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,208ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-14 07:25:02 [19,208ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,209ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-14 07:25:02 [19,210ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,210ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Crazyflie *********************
2023-01-14 07:25:02 [19,211ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Crazyflie uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,211ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Quadcopter *********************
2023-01-14 07:25:02 [19,212ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Quadcopter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,212ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V1 *********************
2023-01-14 07:25:02 [19,213ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,213ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V2 *********************
2023-01-14 07:25:02 [19,214ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V2 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,214ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetbot *********************
2023-01-14 07:25:02 [19,215ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,216ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetracer *********************
2023-01-14 07:25:02 [19,216ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetracer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,217ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya *********************
2023-01-14 07:25:02 [19,217ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,218ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Transporter *********************
2023-01-14 07:25:02 [19,219ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Transporter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,219ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Flat Grid *********************
2023-01-14 07:25:02 [19,220ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Flat Grid uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,220ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Grid Room *********************
2023-01-14 07:25:02 [19,221ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Grid Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,222ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Simple Room *********************
2023-01-14 07:25:02 [19,222ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Simple Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,223ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse *********************
2023-01-14 07:25:02 [19,223ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,224ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse With Multiple Shelves *********************
2023-01-14 07:25:02 [19,224ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse With Multiple Shelves uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,225ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Full Warehouse *********************
2023-01-14 07:25:02 [19,225ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Full Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,226ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Hospital *********************
2023-01-14 07:25:02 [19,227ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Hospital uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,227ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Office *********************
2023-01-14 07:25:02 [19,228ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Office uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,228ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription tag36h11 *********************
2023-01-14 07:25:02 [19,229ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] tag36h11 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,229ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Allegro Hand *********************
2023-01-14 07:25:02 [19,230ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Allegro Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:02 [19,231ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Shadow Hand *********************
2023-01-14 07:25:02 [19,231ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Shadow Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.426s] [ext: omni.kit.browser.sample-1.2.4] startup
[19.442s] [ext: omni.graph.scriptnode-0.9.3] startup
[19.468s] [ext: omni.command.usd-1.0.1] startup
[19.503s] [ext: omni.warp-0.6.1] startup
Warp 0.6.1 initialized:
CUDA Toolkit: 11.5, Driver: 12.0
Devices:
“cpu” | Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
“cuda:0” | NVIDIA GeForce RTX 2070 (sm_75)
Kernel cache: C:\Users\Administrator\AppData\Local\NVIDIA Corporation\warp\Cache\0.6.1
[20.716s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[20.733s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[20.784s] [ext: omni.replicator.core-1.6.4] startup
2023-01-14 07:25:04 [20,729ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[21.211s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[21.217s] [ext: omni.kit.widget.layers-1.6.9] startup
[21.287s] [ext: omni.isaac.core_nodes-0.21.0] startup
[21.387s] [ext: omni.kit.actions.window-1.1.0] startup
[21.426s] [ext: omni.isaac.debug_draw-0.2.2] startup
[21.455s] [ext: omni.kit.property.layer-1.1.3] startup
[21.478s] [ext: omni.isaac.wheeled_robots-0.6.1] startup
[21.602s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[21.641s] [ext: omni.isaac.occupancy_map-0.2.6] startup
2023-01-14 07:25:05 [21,477ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Occupancy Map *********************
2023-01-14 07:25:05 [21,478ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Occupancy Map uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:05 [21,502ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Block World Generator *********************
2023-01-14 07:25:05 [21,502ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Block World Generator uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[21.703s] [ext: omni.kit.property.audio-1.0.6] startup
[21.715s] [ext: omni.kit.property.camera-1.0.3] startup
[21.724s] [ext: omni.kit.property.geometry-1.2.2] startup
[21.738s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[21.752s] [ext: omni.kit.property.light-1.0.6] startup
[21.762s] [ext: omni.kit.property.material-1.8.16] startup
[21.781s] [ext: omni.hydra.scene_api-0.1.1] startup
[21.815s] [ext: omni.kit.window.stage-2.3.11] startup
[21.839s] [ext: omni.kit.property.render-1.1.0] startup
[21.848s] [ext: omni.kit.property.skel-1.0.1] startup
[21.860s] [ext: omni.kit.property.transform-1.3.4] startup
[21.883s] [ext: omni.kit.menu.stage-1.2.1] startup
[21.903s] [ext: omni.kit.manipulator.transform-104.6.11] startup
[21.925s] [ext: omni.kit.profiler.window-2.0.4] startup
[24.610s] [ext: omni.kit.property.bundle-1.2.6] startup
[24.619s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[24.628s] [ext: omni.kit.manipulator.tool.snap-1.2.2] startup
[24.668s] [ext: omni.kit.window.toolbar-1.3.3] startup
[24.721s] [ext: omni.kit.property.isaac-0.1.1] startup
[24.731s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[24.763s] [ext: omni.kit.manipulator.camera-104.0.22] startup
[24.765s] [ext: omni.kit.manipulator.prim-104.10.5] startup
2023-01-14 07:25:08 [24,600ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘_create_manipulator’
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(72): create_manipulator
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\prim_transform_manipulator.py(66): init
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\extension.py(24): on_startup
2023-01-14 07:25:08 [24,602ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.prim-104.10.5] Failed to startup python extension.
[26.000s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[26.002s] [ext: omni.kit.viewport.menubar.camera-104.1.7] startup
[26.051s] [ext: omni.kit.viewport.menubar.render-104.0.19] startup
[26.074s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[26.087s] [ext: omni.physx.commands-104.1.6-5.1] startup
[26.115s] [ext: omni.kit.viewport.menubar.settings-104.3.4] startup
[26.148s] [ext: omni.rtx.window.settings-0.6.2] startup
[26.226s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[26.253s] [ext: omni.physx.ui-104.1.6-5.1] startup
[26.642s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[26.642s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[26.673s] [ext: omni.kit.viewport.menubar.lighting-104.0.8] startup
[26.690s] [ext: omni.kit.property.physx-0.1.0] startup
[26.884s] [ext: omni.physx.demos-104.1.6-5.1] startup
[26.909s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[26.910s] [ext: omni.kit.viewport.ready-1.0.2] startup
[26.916s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[26.916s] [ext: omni.physx.camera-104.1.6-5.1] startup
[26.953s] [ext: omni.kit.selection-0.1.0] startup
[26.969s] [ext: omni.physx.cct-104.1.6-5.1] startup
[29.255s] [ext: omni.physx.supportui-104.1.6-5.1] startup
[29.674s] [ext: omni.kit.widget.live-2.0.3] startup
[29.703s] [ext: omni.physx.vehicle-104.1.6-5.1] startup
[29.789s] [ext: omni.kit.menu.edit-1.1.5] startup
2023-01-14 07:25:13 [29,628ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Grid Visibility *********************
2023-01-14 07:25:13 [29,629ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Grid Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,629ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Camera Visibility *********************
2023-01-14 07:25:13 [29,630ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Camera Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,631ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Light Visibility *********************
2023-01-14 07:25:13 [29,631ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Light Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[29.825s] [ext: omni.kit.window.commands-0.2.4] startup
[29.859s] [ext: omni.kit.window.console-0.2.3] startup
[29.893s] [ext: omni.physx.bundle-104.1.6-5.1] startup
[29.894s] [ext: omni.graph.bundle.action-1.3.0] startup
[29.894s] [ext: omni.isaac.range_sensor-0.7.0] startup
2023-01-14 07:25:13 [29,751ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Rotating *********************
2023-01-14 07:25:13 [29,752ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Rotating uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,753ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic *********************
2023-01-14 07:25:13 [29,753ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,754ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Array *********************
2023-01-14 07:25:13 [29,754ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Array uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,755ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Emitter *********************
2023-01-14 07:25:13 [29,756ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Emitter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,756ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription FiringGroup *********************
2023-01-14 07:25:13 [29,757ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] FiringGroup uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,762ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription LIDAR *********************
2023-01-14 07:25:13 [29,763ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] LIDAR uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,803ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Ultrasonic *********************
2023-01-14 07:25:13 [29,803ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Ultrasonic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [29,839ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic Range Sensor *********************
2023-01-14 07:25:13 [29,840ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic Range Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[30.092s] [ext: omni.kit.window.script_editor-1.6.4] startup
[30.111s] [ext: omni.kit.window.status_bar-0.1.5] startup
[30.143s] [ext: omni.kit.window.title-1.1.2] startup
[30.151s] [ext: omni.replicator.composer-1.2.3] startup
[30.184s] [ext: omni.replicator.isaac-1.7.3] startup
[30.300s] [ext: omni.isaac.kit-1.2.1] startup
[30.302s] [ext: omni.isaac.sensor-5.3.1] startup
2023-01-14 07:25:13 [30,144ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact Sensor *********************
2023-01-14 07:25:13 [30,145ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [30,145ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Imu Sensor *********************
2023-01-14 07:25:13 [30,146ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Imu Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [30,173ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact *********************
2023-01-14 07:25:13 [30,174ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-14 07:25:13 [30,177ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription IMU *********************
2023-01-14 07:25:13 [30,178ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] IMU uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[30.404s] [ext: omni.isaac.franka-0.4.0] startup
[30.411s] [ext: omni.resourcemonitor-1.0.0] startup
[30.452s] [ext: omni.rtx.settings.core-0.5.8] startup
[30.484s] [ext: semantics.schema.editor-0.3.2] startup
[30.522s] [ext: omni.kit.menu.file-1.1.3] startup
[30.534s] [ext: omni.isaac.quadruped-1.2.2] startup
[33.836s] [ext: omni.isaac.cortex-0.2.10] startup
[33.837s] [ext: omni.graph.window.action-1.4.0] startup
2023-01-14 07:25:17 [33,673ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2023-01-14 07:25:17 [33,674ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Action Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[33.870s] [ext: omni.kit.window.stats-0.1.2] startup
[33.878s] [ext: omni.isaac.sim.python-2022.2.0] startup
[33.882s] Simulation App Starting
[76.748s] app ready
[77.424s] RTX ready
[78.215s] Simulation App Startup Complete
task:
physics_engine: physx
env:
numEnvs: 512
envSpacing: 4.0
resetDist: 3.0
maxEffort: 400.0
clipObservations: 5.0
clipActions: 1.0
controlFrequencyInv: 2
sim:
dt: 0.0083
use_gpu_pipeline: True
gravity: [0.0, 0.0, -9.81]
add_ground_plane: True
add_distant_light: True
use_flatcache: True
enable_scene_query_support: False
disable_contact_processing: False
enable_cameras: False
default_physics_material:
static_friction: 1.0
dynamic_friction: 1.0
restitution: 0.0
physx:
worker_thread_count: 4
solver_type: 1
use_gpu: True
solver_position_iteration_count: 4
solver_velocity_iteration_count: 0
contact_offset: 0.02
rest_offset: 0.001
bounce_threshold_velocity: 0.2
friction_offset_threshold: 0.04
friction_correlation_distance: 0.025
enable_sleeping: True
enable_stabilization: True
max_depenetration_velocity: 100.0
gpu_max_rigid_contact_count: 524288
gpu_max_rigid_patch_count: 81920
gpu_found_lost_pairs_capacity: 1024
gpu_found_lost_aggregate_pairs_capacity: 262144
gpu_total_aggregate_pairs_capacity: 1024
gpu_max_soft_body_contacts: 1048576
gpu_max_particle_contacts: 1048576
gpu_heap_capacity: 67108864
gpu_temp_buffer_capacity: 16777216
gpu_max_num_partitions: 8
Cartpole:
override_usd_defaults: False
enable_self_collisions: False
enable_gyroscopic_forces: True
sleep_threshold: 0.005
stabilization_threshold: 0.001
density: -1
rest_offset: 0.001
train:
params:
seed: 42
algo:
model:
network:
separate: False
space:
continuous:
mu_activation: None
sigma_activation: None
mu_init:
sigma_init:
val: 0
fixed_sigma: True
mlp:
units: [32, 32]
activation: elu
initializer:
regularizer:
load_checkpoint: False
load_path:
config:
full_experiment_name: Cartpole
device: cuda:0
device_name: cuda:0
env_name: rlgpu
ppo: True
mixed_precision: False
normalize_input: True
normalize_value: True
num_actors: 512
reward_shaper:
scale_value: 0.1
normalize_advantage: True
gamma: 0.99
tau: 0.95
learning_rate: 0.0003
lr_schedule: adaptive
kl_threshold: 0.008
score_to_win: 20000
max_epochs: 100
save_best_after: 50
save_frequency: 25
grad_norm: 1.0
entropy_coef: 0.0
truncate_grads: True
e_clip: 0.2
horizon_length: 16
minibatch_size: 8192
mini_epochs: 8
critic_coef: 4
clip_value: True
seq_len: 4
bounds_loss_coef: 0.0001
task_name: Cartpole
experiment:
num_envs:
seed: 42
torch_deterministic: False
max_iterations:
pipeline: gpu
sim_device: gpu
device_id: 0
rl_device: cuda:0
num_threads: 4
solver_type: 1
test: False
checkpoint:
headless: False
mt_timeout: 30
wandb_activate: False
wandb_group:
wandb_name: Cartpole
wandb_entity:
wandb_project: omniisaacgymenvs
Setting seed: 42
Sim params does not have attribute: physx
Sim params does not have attribute: Cartpole
Pipeline: GPU
Pipeline Device: cuda:0
Sim Device: GPU
Task Device: cuda:0
RL device: cuda:0
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym\spaces\box.py:74: UserWarning: WARN: Box bound precision lowered by casting to float32
“Box bound precision lowered by casting to {}”.format(self.dtype)
[83.492s] [ext: omni.physx.flatcache-104.1.6-5.1] startup
~~~* Direct GPU Helper:
~~~* 512 articulations, maxLinks=3
self.seed = 42
Started to train
Exact experiment name requested from command line: Cartpole
Box([-1.], [1.], (1,), float32) Box([-inf -inf -inf -inf], [inf inf inf inf], (4,), float32)
current training device: cuda:0
build mlp: 4
RunningMeanStd: (1,)
RunningMeanStd: (4,)
[2023-01-14 15:26:28] Running RL reset
2023-01-14 07:26:28 [104,452ms] [Error] [carb.events.python] AttributeError: ‘PrimTransformManipulator’ object has no attribute ‘_manipulator’
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\prim_transform_manipulator.py(151): enabled
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.selector\omni\kit\manipulator\selector\manipulator_selector.py(100): _on_selection_changed
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.selector\omni\kit\manipulator\selector\manipulator_selector.py(85): _refresh
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extsPhysics/omni.physx.supportui-104.1.6-5.1\omni\physxsupportui\scripts\utils.py(30): refresh_manipulator_selector
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extsPhysics/omni.physx.supportui-104.1.6-5.1\omni\physxsupportui\scripts\rigid_body_transform_manipulator.py(67): _on_stage_event
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.core\omni\isaac\core\simulation_context\simulation_context.py(465): step
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.core\omni\isaac\core\world\world.py(338): step
d:\workshop\omniisaacgymenvs\omniisaacgymenvs\envs\vec_env_rlgames.py(65): step
d:\workshop\omniisaacgymenvs\omniisaacgymenvs\envs\vec_env_rlgames.py(88): reset
d:\workshop\omniisaacgymenvs\omniisaacgymenvs\utils\rlgames\rlgames_utils.py(102): reset
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\common\a2c_common.py(470): env_reset
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\common\a2c_common.py(1162): train
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\torch_runner.py(101): run_train
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\torch_runner.py(120): run
scripts/rlgames_train.py(83): run
scripts/rlgames_train.py(131): parse_hydra_configs
fps step: 5366 fps step and policy inference: 4786 fps total: 3925 epoch: 1/100
fps step: 4245 fps step and policy inference: 3800 fps total: 3393 epoch: 2/100
fps step: 4231 fps step and policy inference: 3786 fps total: 3414 epoch: 3/100
fps step: 4664 fps step and policy inference: 4155 fps total: 3617 epoch: 4/100
fps step: 4111 fps step and policy inference: 3693 fps total: 3285 epoch: 5/100
fps step: 3736 fps step and policy inference: 3331 fps total: 2888 epoch: 6/100
fps step: 3991 fps step and policy inference: 3582 fps total: 3160 epoch: 7/100
fps step: 4743 fps step and policy inference: 4227 fps total: 3778 epoch: 8/100
It looks like the actual error that’s causing the viewport to be black is this one:
Could you try the recommended driver version 527.37 for Windows? Also, have you tried launching Isaac Sim without RL first? That can help narrow down the issue.
Hi, kellyg, I also encountered the same mistake. I reinstalled the 527.37 and 527.56 drivers according to your prompt, but they did not solve the problem.
The following is the output of the terminal. Please help me see what’s wrong? Thank you.
D:\OmniIsaacGymEnvs-main\omniisaacgymenvs>C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\python.bat scripts/rlgames_train.py task=Cartpole
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\defaults_list.py:251: UserWarning: In ‘config’: Defaults list is missing self. See Changes to default composition order | Hydra for more information
[Info] [carb] Logging to file: c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/logs/Kit/Isaac-Sim/2022.2/kit_20230120_062137.log
[0.822s] [ext: omni.stats-0.0.0] startup
[2.507s] [ext: omni.rtx.shadercache-1.0.0] startup
[2.691s] [ext: omni.assets.plugins-0.0.0] startup
[2.732s] [ext: omni.gpu_foundation-0.0.0] startup
[3.183s] [ext: carb.windowing.plugins-1.0.0] startup
[3.332s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 527.56 | Graphics API: D3D12
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3090 | Yes: 0 | | 24339 MB | 10de | c1ee0000… |
| | | | | | 2204 | 0 |
| OS: Windows, Version: 10.0 (21H2), Build: 19044
| Processor: AMD FX-8370 Eight-Core Processor | Cores: 4 | Logical: 8
| Total Memory (MB): 32664 | Free Memory: 23707
| Total Page/Swap (MB): 532664 | Free Page/Swap: 519651
[4.853s] [ext: omni.kit.pipapi-0.0.0] startup
[5.673s] [ext: omni.kit.pip_archive-0.0.0] startup
[5.704s] [ext: omni.kit.loop-isaac-1.0.0] startup
[5.718s] [ext: omni.kit.async_engine-0.0.0] startup
[5.740s] [ext: omni.kit.test-0.0.0] startup
[5.952s] [ext: omni.usd.config-1.0.0] startup
[6.006s] [ext: omni.usd.libs-1.0.0] startup
[6.998s] [ext: omni.isaac.core_archive-2.0.1] startup
[7.707s] [ext: omni.pip.torch-1_13_0-0.1.4] startup
[7.741s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-01-19 22:21:45 [7,479ms] [Warning] [omni.ext._impl.internal] There is already a module ‘gym’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.ml_archive\pip_prebundle’.
[7.754s] [ext: omni.client-0.1.1] startup
[7.857s] [ext: omni.appwindow-1.0.1] startup
[7.908s] [ext: omni.kit.renderer.core-0.0.0] startup
[8.126s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.292s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[8.838s] [ext: carb.audio-0.1.0] startup
[8.850s] [ext: omni.ui-2.12.23] startup
[8.907s] [ext: omni.uiaudio-1.0.0] startup
[8.933s] [ext: omni.kit.mainwindow-1.0.0] startup
[8.951s] [ext: omni.kit.uiapp-0.0.0] startup
[8.952s] [ext: omni.usd.schema.physics-1.0.0] startup
2023-01-19 22:21:46 [8,836ms] [Warning] [omni.ext._impl.internal] There is already a module ‘pxr.UsdPhysics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\pxr\UsdPhysics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
2023-01-19 22:21:46 [8,975ms] [Warning] [omni.ext._impl.internal] There is already a module ‘usd.schema.physics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\usd\schema\physics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
[9.243s] [ext: omni.usd.schema.physx-0.0.0] startup
[9.378s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[9.450s] [ext: omni.usd.schema.anim-0.0.0] startup
[9.945s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[10.006s] [ext: omni.usd.schema.audio-0.0.0] startup
[10.057s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[10.111s] [ext: omni.usd.schema.semantics-0.0.0] startup
[10.165s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[10.234s] [ext: omni.kit.window.popup_dialog-2.0.15] startup
[10.413s] [ext: omni.kit.widget.nucleus_connector-1.0.2] startup
[10.636s] [ext: omni.usd.core-1.0.0] startup
[10.643s] [ext: omni.kit.actions.core-1.0.0] startup
[10.700s] [ext: omni.timeline-1.0.5] startup
[10.734s] [ext: omni.kit.commands-1.4.5] startup
[10.799s] [ext: omni.gpucompute.plugins-0.0.0] startup
[10.819s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[10.844s] [ext: omni.hydra.usdrt_delegate-4.1.1] startup
[10.919s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[10.944s] [ext: omni.usd-1.6.23] startup
[11.266s] [ext: omni.kit.asset_converter-1.2.39] startup
[11.343s] [ext: omni.usd.schema.isaac-1.0.0] startup
[11.475s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[11.501s] [ext: omni.kit.usd.layers-2.0.10] startup
[11.574s] [ext: omni.kit.menu.utils-1.4.7] startup
[11.664s] [ext: omni.kit.menu.create-1.0.8] startup
[11.683s] [ext: omni.iray.libs-0.0.0] startup
[12.980s] [ext: omni.inspect-1.0.1] startup
[13.028s] [ext: omni.volume-0.1.0] startup
[13.057s] [ext: omni.mdl.neuraylib-0.1.0] startup
[13.102s] [ext: omni.graph.tools-1.17.0] startup
[13.330s] [ext: omni.graph.core-2.64.7] startup
[13.343s] [ext: omni.hydra.rtx-0.1.0] startup
[13.478s] [ext: omni.kit.primitive.mesh-1.0.6] startup
[13.526s] [ext: omni.kit.usd_undo-0.1.1] startup
[13.540s] [ext: omni.kit.stage_templates-1.1.11] startup
[13.565s] [ext: omni.kit.widget.path_field-2.0.4] startup
[13.578s] [ext: omni.graph-1.50.1] startup
[13.789s] [ext: omni.debugdraw-0.1.1] startup
[13.822s] [ext: omni.kit.widget.browser_bar-2.0.4] startup
[13.835s] [ext: omni.kit.widget.versioning-1.3.8] startup
[13.867s] [ext: omni.kvdb-0.0.0] startup
[13.905s] [ext: omni.hydra.pxr-1.1.2] startup
[13.965s] [ext: omni.localcache-0.0.0] startup
[14.007s] [ext: omni.kit.hydra_texture-1.0.11] startup
[14.049s] [ext: omni.activity.core-1.0.1] startup
[14.101s] [ext: omni.convexdecomposition-104.1.6-5.1] startup
[14.141s] [ext: omni.kit.widget.viewport-104.1.15] startup
[14.193s] [ext: omni.kit.window.drop_support-1.0.1] startup
[14.201s] [ext: omni.kit.notification_manager-1.0.4] startup
[14.222s] [ext: omni.kit.search_core-1.0.1] startup
[14.241s] [ext: omni.kit.widget.filebrowser-2.3.8] startup
[14.355s] [ext: omni.ui.scene-1.5.17] startup
[14.397s] [ext: omni.kit.viewport.registry-104.0.2] startup
[14.462s] [ext: omni.kit.viewport.legacy_gizmos-1.0.8] startup
[14.478s] [ext: omni.hydra.engine.stats-1.0.0] startup
[14.496s] [ext: omni.kit.window.filepicker-2.7.8] startup
OmniAssetFileFormat
[14.863s] [ext: omni.kit.viewport.window-104.1.18] startup
[15.020s] [ext: omni.mdl-0.1.0] startup
[15.086s] [ext: omni.kit.window.file_importer-1.0.8] startup
[15.098s] [ext: omni.kit.viewport.utility-1.0.12] startup
[15.104s] [ext: omni.kit.material.library-1.3.21] startup
[15.144s] [ext: omni.kit.clipboard-1.0.0] startup
[15.152s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[15.164s] [ext: omni.ui_query-1.1.1] startup
[15.183s] [ext: omni.kit.context_menu-1.5.10] startup
[15.221s] [ext: omni.kit.window.file-1.3.30] startup
[15.255s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[15.265s] [ext: omni.kit.ui_test-1.2.9] startup
[15.299s] [ext: omni.kit.window.property-1.8.2] startup
[15.325s] [ext: omni.kit.window.content_browser-2.6.5] startup
[15.379s] [ext: omni.kit.widget.stage-2.7.18] startup
[15.422s] [ext: omni.usdphysics-104.1.6-5.1] startup
[15.435s] [ext: omni.kit.property.usd-3.18.12] startup
[15.572s] [ext: omni.physx-104.1.6-5.1] startup
[16.099s] [ext: omni.kit.widget.settings-1.0.1] startup
[16.114s] [ext: omni.kit.widget.graph-1.5.3] startup
[16.478s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[16.497s] [ext: omni.kit.window.preferences-1.3.7] startup
[16.648s] [ext: omni.kit.window.extensions-1.1.1] startup
[16.698s] [ext: omni.kit.widget.prompt-1.0.4] startup
[16.708s] [ext: omni.physics.tensors-0.1.0] startup
[16.765s] [ext: omni.graph.ui-1.24.1] startup
[17.082s] [ext: omni.isaac.version-1.0.0] startup
[17.089s] [ext: omni.physx.tensors-0.1.0] startup
[17.109s] [ext: omni.graph.action-1.31.0] startup
[17.197s] [ext: omni.kit.numpy.common-0.1.0] startup
[17.221s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[17.279s] [ext: omni.kit.widget.searchfield-1.0.8] startup
[17.311s] [ext: omni.isaac.dynamic_control-1.2.2] startup
[17.369s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
2023-01-19 22:21:55 [17,163ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
2023-01-19 22:21:55 [17,169ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
At:
scripts/rlgames_train.py(138):
2023-01-19 22:21:55 [17,170ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.viewport-104.0.7] Failed to startup python extension.
[18.087s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[18.127s] [ext: omni.isaac.core-1.42.0] startup
[19.206s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[19.287s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[19.303s] [ext: omni.isaac.ui-0.4.3] startup
[19.326s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-01-19 22:21:56 [19,066ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[19.334s] [ext: omni.isaac.surface_gripper-0.3.2] startup
2023-01-19 22:21:56 [19,096ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Surface Gripper *********************
2023-01-19 22:21:56 [19,098ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Surface Gripper uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.401s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[19.415s] [ext: omni.kit.graph.delegate.modern-1.6.4] startup
[19.434s] [ext: omni.isaac.manipulators-1.1.0] startup
[19.458s] [ext: omni.graph.window.core-1.41.0] startup
[19.521s] [ext: omni.isaac.mjcf-0.3.0] startup
2023-01-19 22:21:57 [19,302ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription MJCF Importer *********************
2023-01-19 22:21:57 [19,304ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] MJCF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.576s] [ext: omni.graph.window.generic-1.3.10] startup
2023-01-19 22:21:57 [19,328ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2023-01-19 22:21:57 [19,329ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Push Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:57 [19,330ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2023-01-19 22:21:57 [19,331ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Lazy Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.597s] [ext: omni.kit.widget.spinner-1.0.4] startup
[19.619s] [ext: omni.kit.window.cursor-1.1.1] startup
[19.637s] [ext: omni.isaac.lula-1.2.1] startup
[19.702s] [ext: omni.graph.nodes-1.48.3] startup
[19.993s] [ext: omni.kit.viewport.menubar.core-104.4.1] startup
[20.158s] [ext: omni.isaac.motion_planning-0.2.1] startup
[20.257s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[20.270s] [ext: omni.syntheticdata-0.2.4] startup
2023-01-19 22:21:57 [20,089ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[20.413s] [ext: omni.isaac.motion_generation-4.5.5] startup
[20.485s] [ext: omni.kit.browser.core-2.2.1] startup
[20.573s] [ext: omni.isaac.synthetic_utils-0.4.2] startup
[20.834s] [ext: omni.isaac.universal_robots-0.3.1] startup
[20.847s] [ext: omni.kit.browser.folder.core-1.7.1] startup
[20.896s] [ext: omni.isaac.urdf-0.5.4] startup
2023-01-19 22:21:58 [20,685ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription URDF Importer *********************
2023-01-19 22:21:58 [20,687ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] URDF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,704ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter URDF *********************
2023-01-19 22:21:58 [20,705ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,728ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka URDF *********************
2023-01-19 22:21:58 [20,731ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,753ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya URDF *********************
2023-01-19 22:21:58 [20,754ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,778ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 URDF *********************
2023-01-19 22:21:58 [20,780ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[21.065s] [ext: omni.isaac.utils-0.2.3] startup
2023-01-19 22:21:58 [20,828ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3 *********************
2023-01-19 22:21:58 [20,830ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,831ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5 *********************
2023-01-19 22:21:58 [20,832ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,832ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 *********************
2023-01-19 22:21:58 [20,833ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,834ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3e *********************
2023-01-19 22:21:58 [20,835ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,836ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5e *********************
2023-01-19 22:21:58 [20,836ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,837ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10e *********************
2023-01-19 22:21:58 [20,837ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,838ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR16e *********************
2023-01-19 22:21:58 [20,839ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR16e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,840ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 900 *********************
2023-01-19 22:21:58 [20,841ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 900 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,842ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 1300 *********************
2023-01-19 22:21:58 [20,842ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 1300 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,843ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Dofbot *********************
2023-01-19 22:21:58 [20,844ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Dofbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,844ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka *********************
2023-01-19 22:21:58 [20,845ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,846ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription A1 *********************
2023-01-19 22:21:58 [20,846ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] A1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,847ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Go1 *********************
2023-01-19 22:21:58 [20,848ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Go1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,849ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-19 22:21:58 [20,849ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,854ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-19 22:21:58 [20,855ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,855ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Crazyflie *********************
2023-01-19 22:21:58 [20,856ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Crazyflie uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,857ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Quadcopter *********************
2023-01-19 22:21:58 [20,857ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Quadcopter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,858ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V1 *********************
2023-01-19 22:21:58 [20,859ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,860ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V2 *********************
2023-01-19 22:21:58 [20,860ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V2 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,861ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetbot *********************
2023-01-19 22:21:58 [20,861ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,862ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetracer *********************
2023-01-19 22:21:58 [20,863ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetracer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,863ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya *********************
2023-01-19 22:21:58 [20,864ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,865ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Transporter *********************
2023-01-19 22:21:58 [20,868ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Transporter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,869ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Flat Grid *********************
2023-01-19 22:21:58 [20,870ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Flat Grid uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,870ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Grid Room *********************
2023-01-19 22:21:58 [20,871ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Grid Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,872ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Simple Room *********************
2023-01-19 22:21:58 [20,872ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Simple Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,873ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse *********************
2023-01-19 22:21:58 [20,874ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,875ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse With Multiple Shelves *********************
2023-01-19 22:21:58 [20,875ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse With Multiple Shelves uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,876ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Full Warehouse *********************
2023-01-19 22:21:58 [20,877ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Full Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,878ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Hospital *********************
2023-01-19 22:21:58 [20,878ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Hospital uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,879ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Office *********************
2023-01-19 22:21:58 [20,879ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Office uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,880ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription tag36h11 *********************
2023-01-19 22:21:58 [20,884ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] tag36h11 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,885ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Allegro Hand *********************
2023-01-19 22:21:58 [20,885ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Allegro Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:21:58 [20,886ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Shadow Hand *********************
2023-01-19 22:21:58 [20,887ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Shadow Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[21.155s] [ext: omni.kit.browser.sample-1.2.4] startup
[21.173s] [ext: omni.graph.scriptnode-0.9.3] startup
[21.210s] [ext: omni.command.usd-1.0.1] startup
[21.245s] [ext: omni.warp-0.6.1] startup
Devices:
“cpu” | AMD64 Family 21 Model 2 Stepping 0, AuthenticAMD
“cuda:0” | NVIDIA GeForce RTX 3090 (sm_86)
[22.445s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[22.471s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[22.526s] [ext: omni.replicator.core-1.6.4] startup
2023-01-19 22:22:00 [22,445ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[23.113s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[23.123s] [ext: omni.kit.widget.layers-1.6.9] startup
[23.216s] [ext: omni.isaac.core_nodes-0.21.0] startup
[23.349s] [ext: omni.kit.actions.window-1.1.0] startup
[23.400s] [ext: omni.isaac.debug_draw-0.2.2] startup
[23.444s] [ext: omni.kit.property.layer-1.1.3] startup
[23.472s] [ext: omni.isaac.wheeled_robots-0.6.1] startup
[23.628s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[23.686s] [ext: omni.isaac.occupancy_map-0.2.6] startup
2023-01-19 22:22:01 [23,466ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Occupancy Map *********************
2023-01-19 22:22:01 [23,468ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Occupancy Map uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:01 [23,489ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Block World Generator *********************
2023-01-19 22:22:01 [23,490ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Block World Generator uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[23.761s] [ext: omni.kit.property.audio-1.0.6] startup
[23.777s] [ext: omni.kit.property.camera-1.0.3] startup
[23.790s] [ext: omni.kit.property.geometry-1.2.2] startup
[23.810s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[23.829s] [ext: omni.kit.property.light-1.0.6] startup
[23.846s] [ext: omni.kit.property.material-1.8.16] startup
[23.872s] [ext: omni.hydra.scene_api-0.1.1] startup
[23.912s] [ext: omni.kit.window.stage-2.3.11] startup
[23.942s] [ext: omni.kit.property.render-1.1.0] startup
[23.952s] [ext: omni.kit.property.skel-1.0.1] startup
[23.971s] [ext: omni.kit.property.transform-1.3.4] startup
[23.997s] [ext: omni.kit.menu.stage-1.2.1] startup
[24.014s] [ext: omni.kit.manipulator.transform-104.6.11] startup
[24.043s] [ext: omni.kit.profiler.window-2.0.4] startup
[26.242s] [ext: omni.kit.property.bundle-1.2.6] startup
[26.256s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[26.272s] [ext: omni.kit.manipulator.tool.snap-1.2.2] startup
[26.326s] [ext: omni.kit.window.toolbar-1.3.3] startup
[26.389s] [ext: omni.kit.property.isaac-0.1.1] startup
[26.401s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[26.430s] [ext: omni.kit.manipulator.camera-104.0.22] startup
[26.431s] [ext: omni.kit.manipulator.prim-104.10.5] startup
2023-01-19 22:22:04 [26,203ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘_create_manipulator’
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(146): _startup_ext
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(197): startup
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext_impl_internal.py(280): startup_extension
PythonExtension.cpp::startup()(2):
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(284): _start_app
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(169): init
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.gym\omni\isaac\gym\vec_env\vec_env_base.py(37): init
scripts/rlgames_train.py(93): parse_hydra_configs
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\core\utils.py(160): run_job
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\hydra.py(106): run
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(381):
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(211): run_and_report
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(378): _run_hydra
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\main.py(52): decorated_main
2023-01-19 22:22:04 [26,207ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.prim-104.10.5] Failed to startup python extension.
[27.460s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[27.461s] [ext: omni.kit.viewport.menubar.camera-104.1.7] startup
[27.509s] [ext: omni.kit.viewport.menubar.render-104.0.19] startup
[27.535s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[27.553s] [ext: omni.physx.commands-104.1.6-5.1] startup
[27.573s] [ext: omni.kit.viewport.menubar.settings-104.3.4] startup
[27.613s] [ext: omni.rtx.window.settings-0.6.2] startup
[27.683s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[27.705s] [ext: omni.physx.ui-104.1.6-5.1] startup
[27.811s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[27.812s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[27.839s] [ext: omni.kit.viewport.menubar.lighting-104.0.8] startup
[27.861s] [ext: omni.kit.property.physx-0.1.0] startup
[28.011s] [ext: omni.physx.demos-104.1.6-5.1] startup
[28.026s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[28.027s] [ext: omni.kit.viewport.ready-1.0.2] startup
[28.036s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[28.037s] [ext: omni.physx.camera-104.1.6-5.1] startup
[28.086s] [ext: omni.kit.selection-0.1.0] startup
[28.100s] [ext: omni.physx.cct-104.1.6-5.1] startup
[30.724s] [ext: omni.physx.supportui-104.1.6-5.1] startup
[31.031s] [ext: omni.kit.widget.live-2.0.3] startup
[31.063s] [ext: omni.physx.vehicle-104.1.6-5.1] startup
[31.151s] [ext: omni.kit.menu.edit-1.1.5] startup
2023-01-19 22:22:08 [30,916ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Grid Visibility *********************
2023-01-19 22:22:08 [30,917ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Grid Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [30,918ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Camera Visibility *********************
2023-01-19 22:22:08 [30,919ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Camera Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [30,919ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Light Visibility *********************
2023-01-19 22:22:08 [30,920ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Light Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[31.186s] [ext: omni.kit.window.commands-0.2.4] startup
[31.212s] [ext: omni.kit.window.console-0.2.3] startup
[31.248s] [ext: omni.physx.bundle-104.1.6-5.1] startup
[31.249s] [ext: omni.graph.bundle.action-1.3.0] startup
[31.251s] [ext: omni.isaac.range_sensor-0.7.0] startup
2023-01-19 22:22:08 [31,041ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Rotating *********************
2023-01-19 22:22:08 [31,043ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Rotating uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,044ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic *********************
2023-01-19 22:22:08 [31,045ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,045ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Array *********************
2023-01-19 22:22:08 [31,046ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Array uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,047ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Emitter *********************
2023-01-19 22:22:08 [31,048ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Emitter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,048ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription FiringGroup *********************
2023-01-19 22:22:08 [31,049ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] FiringGroup uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,056ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription LIDAR *********************
2023-01-19 22:22:08 [31,057ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] LIDAR uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,084ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Ultrasonic *********************
2023-01-19 22:22:08 [31,086ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Ultrasonic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:08 [31,111ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic Range Sensor *********************
2023-01-19 22:22:08 [31,112ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic Range Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[31.429s] [ext: omni.kit.window.script_editor-1.6.4] startup
[31.459s] [ext: omni.kit.window.status_bar-0.1.5] startup
[31.502s] [ext: omni.kit.window.title-1.1.2] startup
[31.512s] [ext: omni.replicator.composer-1.2.3] startup
[31.541s] [ext: omni.replicator.isaac-1.7.3] startup
[31.728s] [ext: omni.isaac.kit-1.2.1] startup
[31.729s] [ext: omni.isaac.sensor-5.3.1] startup
2023-01-19 22:22:09 [31,513ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact Sensor *********************
2023-01-19 22:22:09 [31,515ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:09 [31,515ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Imu Sensor *********************
2023-01-19 22:22:09 [31,517ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Imu Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:09 [31,557ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact *********************
2023-01-19 22:22:09 [31,559ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-19 22:22:09 [31,564ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription IMU *********************
2023-01-19 22:22:09 [31,565ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] IMU uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[31.875s] [ext: omni.isaac.franka-0.4.0] startup
[31.887s] [ext: omni.resourcemonitor-1.0.0] startup
[31.935s] [ext: omni.rtx.settings.core-0.5.8] startup
[31.968s] [ext: semantics.schema.editor-0.3.2] startup
[32.002s] [ext: omni.kit.menu.file-1.1.3] startup
[32.018s] [ext: omni.isaac.quadruped-1.2.2] startup
[35.456s] [ext: omni.isaac.cortex-0.2.10] startup
[35.456s] [ext: omni.graph.window.action-1.4.0] startup
2023-01-19 22:22:13 [35,222ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2023-01-19 22:22:13 [35,223ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Action Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[35.489s] [ext: omni.kit.window.stats-0.1.2] startup
[35.500s] [ext: omni.isaac.sim.python-2022.2.0] startup
[35.503s] Simulation App Starting
[64.246s] app ready
[64.633s] RTX ready
[65.079s] Simulation App Startup Complete
task:
env:
numEnvs: 512
envSpacing: 4.0
resetDist: 3.0
maxEffort: 400.0
clipActions: 1.0
sim:
dt: 0.0083
use_flatcache: True
restitution: 0.0
physx:
solver_type: 1
use_gpu: True
rest_offset: 0.001
Cartpole:
fixed_base: False
density: -1
rest_offset: 0.001
train:
params:
seed: 42
algo:
model:
network:
separate: False
space:
continuous:
mu_activation: None
mu_init:
sigma_init:
val: 0
fixed_sigma: True
mlp:
units: [32, 32]
activation: elu
initializer:
regularizer:
load_path:
config:
device: cuda:0
device_name: cuda:0
env_name: rlgpu
ppo: True
num_actors: 512
reward_shaper:
scale_value: 0.1
gamma: 0.99
tau: 0.95
kl_threshold: 0.008
score_to_win: 20000
max_epochs: 100
save_best_after: 50
save_frequency: 25
grad_norm: 1.0
entropy_coef: 0.0
e_clip: 0.2
horizon_length: 16
mini_epochs: 8
critic_coef: 4
clip_value: True
seq_len: 4
task_name: Cartpole
experiment:
num_envs:
seed: 42
max_iterations:
pipeline: gpu
sim_device: gpu
device_id: 0
rl_device: cuda:0
num_threads: 4
solver_type: 1
test: False
checkpoint:
headless: False
wandb_group:
wandb_entity:
Pipeline: GPU
Sim Device: GPU
Task Device: cuda:0
RL device: cuda:0
[67.985s] [ext: omni.physx.flatcache-104.1.6-5.1] startup
2023-01-19 22:22:53 [75,416ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
Error executing job with overrides: [‘task=Cartpole’]
File “scripts/rlgames_train.py”, line 104, in parse_hydra_configs
task = initialize_task(cfg_dict, env)
File “d:\omniisaacgymenvs-main\omniisaacgymenvs\utils\task_util.py”, line 70, in initialize_task
env.set_task(task=task, sim_params=sim_config.get_physics_params(), backend=“torch”, init_sim=init_sim)
File “d:\omniisaacgymenvs-main\omniisaacgymenvs\envs\vec_env_rlgames.py”, line 51, in set_task
super().set_task(task, backend, sim_params, init_sim)
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.gym\omni\isaac\gym\vec_env\vec_env_base.py”, line 80, in set_task
self._world.reset()
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.core\omni\isaac\core\world\world.py”, line 275, in reset
task.set_up_scene(self.scene)
File “d:\omniisaacgymenvs-main\omniisaacgymenvs\tasks\cartpole.py”, line 70, in set_up_scene
super().set_up_scene(scene)
File “d:\omniisaacgymenvs-main\omniisaacgymenvs\tasks\base\rl_task.py”, line 129, in set_up_scene
self.set_initial_camera_params(camera_position=[10, 10, 3], camera_target=[0, 0, 0])
File “d:\omniisaacgymenvs-main\omniisaacgymenvs\tasks\base\rl_task.py”, line 135, in set_initial_camera_params
viewport = omni.kit.viewport_legacy.get_default_viewport_window()
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.window.viewport\omni\kit\viewport_legacy\scripts\viewport.py”, line 22, in get_default_viewport_window
viewport = get_viewport_interface()
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.window.viewport\omni\kit\viewport_legacy\scripts\viewport.py”, line 15, in get_viewport_interface
get_viewport_interface.viewport = acquire_viewport_interface()
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Exception ignored in: <function _make_registry…_Registry.del at 0x000001E9BF3AB288>
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.viewport.registry\omni\kit\viewport\registry\registry.py”, line 103, in del
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.viewport.registry\omni\kit\viewport\registry\registry.py”, line 98, in destroy
TypeError: ‘NoneType’ object is not callable
Exception ignored in: <function _make_registry…Registry.del at 0x000001E9BF3AB288>
Exception ignored in: <function SettingChangeSubscription.del at 0x000001E961C77438>
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\kit\app_impl_init.py”, line 114, in del
AttributeError: ‘NoneType’ object has no attribute ‘get_settings’
Exception ignored in: <function RegisteredActions.del at 0x000001E9C92A40D8>
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.kit.viewport.menubar.lighting-104.0.8\omni\kit\viewport\menubar\lighting\actions.py”, line 345, in del
File “C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.kit.viewport.menubar.lighting-104.0.8\omni\kit\viewport\menubar\lighting\actions.py”, line 351, in destroy
Hi there, could you please make sure you are on the latest version of GitHub - NVIDIA-Omniverse/OmniIsaacGymEnvs: Reinforcement Learning Environments for Omniverse Isaac Gym? We made an update to the Viewport code in the last release.
Hi,kellyg, I downloaded the latest version of OmniIsaacGymEnvs from GitHub. The simulation can run correctly, but there are still two red error messages in the terminal:
No1.
2023-01-20 10:46:47 [16,176ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(95): startup
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\extension.py(13): on_startup
scripts/rlgames_train.py(139):
2023-01-20 10:46:47 [16,178ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.viewport-104.0.7] Failed to startup python extension.
No2.
2023-01-20 10:46:56 [25,223ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘_create_manipulator’
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(72): create_manipulator
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\prim_transform_manipulator.py(66): init
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\extension.py(24): on_startup
2023-01-20 10:46:56 [25,225ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.prim-104.10.5] Failed to startup python extension.
The following is all the terminal output information. Please help me to see. What is the reason for the error? Thank you.
D:\OmniIsaacGymEnvs-main-2023-1-20\omniisaacgymenvs>C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\python.bat scripts/rlgames_train.py task=Cartpole
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\defaults_list.py:251: UserWarning: In ‘config’: Defaults list is missing _self_. See Changes to default composition order | Hydra for more information
warnings.warn(msg, UserWarning)
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\defaults_list.py:412: UserWarning: In config: Invalid overriding of hydra/job_logging:
Default list overrides requires ‘override’ keyword.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/defaults_list_override for more information.
deprecation_warning(msg)
[Warning] [omni.isaac.kit.simulation_app] Modules: [‘omniisaacgymenvs’, ‘omniisaacgymenvs.utils’, ‘omniisaacgymenvs.utils.hydra_cfg’, ‘omniisaacgymenvs.utils.hydra_cfg.hydra_utils’, ‘omniisaacgymenvs.utils.hydra_cfg.reformat’, ‘omniisaacgymenvs.utils.rlgames’, ‘omniisaacgymenvs.utils.rlgames.rlgames_utils’, ‘omniisaacgymenvs.utils.task_util’, ‘omniisaacgymenvs.utils.config_utils’, ‘omniisaacgymenvs.utils.config_utils.path_utils’, ‘omniisaacgymenvs.envs’, ‘omniisaacgymenvs.envs.vec_env_rlgames’, ‘omni’, ‘omni.isaac.gym’, ‘omni.isaac.gym.vec_env’, ‘omni.isaac.gym.vec_env.vec_env_base’, ‘omni.kit.app._impl.telemetry_helpers’, ‘omni.isaac.gym.vec_env.vec_env_mt’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Starting kit application with the following args: [‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\apps/omni.isaac.sim.python.kit’, ‘–/app/tokens/exe-path=C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–/app/fastShutdown=True’, ‘–ext-folder’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts’, ‘–ext-folder’, ‘C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/apps’, ‘–/physics/cudaDevice=0’, ‘–portable’]
Passing the following args to the base kit application: [‘task=Cartpole’]
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[Info] [carb] Logging to file: c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/logs/Kit/Isaac-Sim/2022.2/kit_20230120_184631.log
[0.764s] [ext: omni.stats-0.0.0] startup
[2.427s] [ext: omni.rtx.shadercache-1.0.0] startup
[2.619s] [ext: omni.assets.plugins-0.0.0] startup
[2.661s] [ext: omni.gpu_foundation-0.0.0] startup
[3.149s] [ext: carb.windowing.plugins-1.0.0] startup
[3.303s] [ext: omni.kit.renderer.init-0.0.0] startup
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | 2204 | 0 |
| Total Memory (MB): 32664 | Free Memory: 22610
| Total Page/Swap (MB): 532664 | Free Page/Swap: 516898
[5.038s] [ext: omni.kit.pipapi-0.0.0] startup
[5.874s] [ext: omni.kit.pip_archive-0.0.0] startup
[5.911s] [ext: omni.kit.loop-isaac-1.0.0] startup
[5.926s] [ext: omni.kit.async_engine-0.0.0] startup
[5.950s] [ext: omni.kit.test-0.0.0] startup
[6.151s] [ext: omni.usd.config-1.0.0] startup
[6.208s] [ext: omni.usd.libs-1.0.0] startup
[6.866s] [ext: omni.isaac.core_archive-2.0.1] startup
[7.257s] [ext: omni.pip.torch-1_13_0-0.1.4] startup
[7.291s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-01-20 10:46:38 [7,064ms] [Warning] [omni.ext._impl.internal] There is already a module ‘gym’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.ml_archive\pip_prebundle’.
[7.303s] [ext: omni.client-0.1.1] startup
[7.405s] [ext: omni.appwindow-1.0.1] startup
[7.458s] [ext: omni.kit.renderer.core-0.0.0] startup
[7.670s] [ext: omni.kit.renderer.capture-0.0.0] startup
[7.727s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[8.268s] [ext: carb.audio-0.1.0] startup
[8.278s] [ext: omni.ui-2.12.23] startup
[8.334s] [ext: omni.uiaudio-1.0.0] startup
[8.361s] [ext: omni.kit.mainwindow-1.0.0] startup
[8.381s] [ext: omni.kit.uiapp-0.0.0] startup
[8.381s] [ext: omni.usd.schema.physics-1.0.0] startup
2023-01-20 10:46:39 [8,326ms] [Warning] [omni.ext._impl.internal] There is already a module ‘pxr.UsdPhysics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\pxr\UsdPhysics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
2023-01-20 10:46:39 [8,476ms] [Warning] [omni.ext._impl.internal] There is already a module ‘usd.schema.physics’ in 'C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\usd\schema\physics_init.py’. Can’t import another module with the same name in public space from ‘c:\users\administrator\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics’.
[8.705s] [ext: omni.usd.schema.physx-0.0.0] startup
[8.835s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[8.901s] [ext: omni.usd.schema.anim-0.0.0] startup
[9.380s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[9.441s] [ext: omni.usd.schema.audio-0.0.0] startup
[9.494s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[9.547s] [ext: omni.usd.schema.semantics-0.0.0] startup
[9.598s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[9.667s] [ext: omni.kit.window.popup_dialog-2.0.15] startup
[9.832s] [ext: omni.kit.widget.nucleus_connector-1.0.2] startup
[10.034s] [ext: omni.usd.core-1.0.0] startup
[10.042s] [ext: omni.kit.actions.core-1.0.0] startup
[10.091s] [ext: omni.timeline-1.0.5] startup
[10.123s] [ext: omni.kit.commands-1.4.5] startup
[10.184s] [ext: omni.gpucompute.plugins-0.0.0] startup
[10.202s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[10.227s] [ext: omni.hydra.usdrt_delegate-4.1.1] startup
[10.292s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[10.313s] [ext: omni.usd-1.6.23] startup
[10.631s] [ext: omni.kit.asset_converter-1.2.39] startup
[10.705s] [ext: omni.usd.schema.isaac-1.0.0] startup
[10.830s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[10.856s] [ext: omni.kit.usd.layers-2.0.10] startup
[10.920s] [ext: omni.kit.menu.utils-1.4.7] startup
[11.003s] [ext: omni.kit.menu.create-1.0.8] startup
[11.017s] [ext: omni.iray.libs-0.0.0] startup
[12.332s] [ext: omni.inspect-1.0.1] startup
[12.381s] [ext: omni.volume-0.1.0] startup
[12.409s] [ext: omni.mdl.neuraylib-0.1.0] startup
[12.455s] [ext: omni.graph.tools-1.17.0] startup
[12.667s] [ext: omni.graph.core-2.64.7] startup
[12.683s] [ext: omni.hydra.rtx-0.1.0] startup
[12.825s] [ext: omni.kit.primitive.mesh-1.0.6] startup
[12.867s] [ext: omni.kit.usd_undo-0.1.1] startup
[12.879s] [ext: omni.kit.stage_templates-1.1.11] startup
[12.900s] [ext: omni.kit.widget.path_field-2.0.4] startup
[12.914s] [ext: omni.graph-1.50.1] startup
[13.110s] [ext: omni.debugdraw-0.1.1] startup
[13.141s] [ext: omni.kit.widget.browser_bar-2.0.4] startup
[13.152s] [ext: omni.kit.widget.versioning-1.3.8] startup
[13.180s] [ext: omni.kvdb-0.0.0] startup
[13.218s] [ext: omni.hydra.pxr-1.1.2] startup
[13.282s] [ext: omni.localcache-0.0.0] startup
[13.328s] [ext: omni.kit.hydra_texture-1.0.11] startup
[13.370s] [ext: omni.activity.core-1.0.1] startup
[13.424s] [ext: omni.convexdecomposition-104.1.6-5.1] startup
[13.465s] [ext: omni.kit.widget.viewport-104.1.15] startup
[13.517s] [ext: omni.kit.window.drop_support-1.0.1] startup
[13.524s] [ext: omni.kit.notification_manager-1.0.4] startup
[13.544s] [ext: omni.kit.search_core-1.0.1] startup
[13.563s] [ext: omni.kit.widget.filebrowser-2.3.8] startup
[13.666s] [ext: omni.ui.scene-1.5.17] startup
[13.712s] [ext: omni.kit.viewport.registry-104.0.2] startup
[13.776s] [ext: omni.kit.viewport.legacy_gizmos-1.0.8] startup
[13.793s] [ext: omni.hydra.engine.stats-1.0.0] startup
[13.810s] [ext: omni.kit.window.filepicker-2.7.8] startup
OmniAssetFileFormat
[14.218s] [ext: omni.kit.viewport.window-104.1.18] startup
[14.360s] [ext: omni.mdl-0.1.0] startup
[14.436s] [ext: omni.kit.window.file_importer-1.0.8] startup
[14.446s] [ext: omni.kit.viewport.utility-1.0.12] startup
[14.452s] [ext: omni.kit.material.library-1.3.21] startup
[14.489s] [ext: omni.kit.clipboard-1.0.0] startup
[14.497s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[14.507s] [ext: omni.ui_query-1.1.1] startup
[14.522s] [ext: omni.kit.context_menu-1.5.10] startup
[14.558s] [ext: omni.kit.window.file-1.3.30] startup
[14.583s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[14.592s] [ext: omni.kit.ui_test-1.2.9] startup
[14.621s] [ext: omni.kit.window.property-1.8.2] startup
[14.643s] [ext: omni.kit.window.content_browser-2.6.5] startup
[14.691s] [ext: omni.kit.widget.stage-2.7.18] startup
[14.728s] [ext: omni.usdphysics-104.1.6-5.1] startup
[14.740s] [ext: omni.kit.property.usd-3.18.12] startup
[14.874s] [ext: omni.physx-104.1.6-5.1] startup
[15.063s] [ext: omni.kit.widget.settings-1.0.1] startup
[15.077s] [ext: omni.kit.widget.graph-1.5.3] startup
[15.420s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[15.440s] [ext: omni.kit.window.preferences-1.3.7] startup
[15.586s] [ext: omni.kit.window.extensions-1.1.1] startup
[15.634s] [ext: omni.kit.widget.prompt-1.0.4] startup
[15.646s] [ext: omni.physics.tensors-0.1.0] startup
[15.717s] [ext: omni.graph.ui-1.24.1] startup
[16.001s] [ext: omni.isaac.version-1.0.0] startup
[16.009s] [ext: omni.physx.tensors-0.1.0] startup
[16.031s] [ext: omni.graph.action-1.31.0] startup
[16.125s] [ext: omni.kit.numpy.common-0.1.0] startup
[16.152s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[16.208s] [ext: omni.kit.widget.searchfield-1.0.8] startup
[16.238s] [ext: omni.isaac.dynamic_control-1.2.2] startup
[16.299s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
2023-01-20 10:46:47 [16,169ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/administrator/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
At:
[17.125s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[17.160s] [ext: omni.isaac.core-1.42.0] startup
[18.211s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[18.293s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[18.308s] [ext: omni.isaac.ui-0.4.3] startup
[18.331s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-01-20 10:46:49 [18,107ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[18.337s] [ext: omni.isaac.surface_gripper-0.3.2] startup
2023-01-20 10:46:49 [18,133ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Surface Gripper *********************
2023-01-20 10:46:49 [18,134ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Surface Gripper uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.404s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[18.415s] [ext: omni.kit.graph.delegate.modern-1.6.4] startup
[18.431s] [ext: omni.isaac.manipulators-1.1.0] startup
[18.451s] [ext: omni.graph.window.core-1.41.0] startup
[18.506s] [ext: omni.isaac.mjcf-0.3.0] startup
2023-01-20 10:46:49 [18,327ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription MJCF Importer *********************
2023-01-20 10:46:49 [18,329ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] MJCF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.564s] [ext: omni.graph.window.generic-1.3.10] startup
2023-01-20 10:46:49 [18,353ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2023-01-20 10:46:49 [18,354ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Push Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:49 [18,355ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2023-01-20 10:46:49 [18,355ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Lazy Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[18.584s] [ext: omni.kit.widget.spinner-1.0.4] startup
[18.610s] [ext: omni.kit.window.cursor-1.1.1] startup
[18.629s] [ext: omni.isaac.lula-1.2.1] startup
[18.701s] [ext: omni.graph.nodes-1.48.3] startup
[18.920s] [ext: omni.kit.viewport.menubar.core-104.4.1] startup
[19.065s] [ext: omni.isaac.motion_planning-0.2.1] startup
[19.164s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[19.176s] [ext: omni.syntheticdata-0.2.4] startup
2023-01-20 10:46:50 [19,026ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[19.307s] [ext: omni.isaac.motion_generation-4.5.5] startup
[19.368s] [ext: omni.kit.browser.core-2.2.1] startup
[19.447s] [ext: omni.isaac.synthetic_utils-0.4.2] startup
[19.708s] [ext: omni.isaac.universal_robots-0.3.1] startup
[19.720s] [ext: omni.kit.browser.folder.core-1.7.1] startup
[19.773s] [ext: omni.isaac.urdf-0.5.4] startup
2023-01-20 10:46:50 [19,585ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription URDF Importer *********************
2023-01-20 10:46:50 [19,587ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] URDF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,600ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter URDF *********************
2023-01-20 10:46:50 [19,601ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,623ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka URDF *********************
2023-01-20 10:46:50 [19,624ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,646ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya URDF *********************
2023-01-20 10:46:50 [19,648ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,670ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 URDF *********************
2023-01-20 10:46:50 [19,671ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[19.920s] [ext: omni.isaac.utils-0.2.3] startup
2023-01-20 10:46:50 [19,721ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3 *********************
2023-01-20 10:46:50 [19,723ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,723ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5 *********************
2023-01-20 10:46:50 [19,724ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,725ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 *********************
2023-01-20 10:46:50 [19,726ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,726ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3e *********************
2023-01-20 10:46:50 [19,727ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,728ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5e *********************
2023-01-20 10:46:50 [19,728ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,729ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10e *********************
2023-01-20 10:46:50 [19,730ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,730ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR16e *********************
2023-01-20 10:46:50 [19,731ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR16e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:50 [19,732ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 900 *********************
2023-01-20 10:46:50 [19,732ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 900 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,733ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 1300 *********************
2023-01-20 10:46:51 [19,734ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 1300 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,735ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Dofbot *********************
2023-01-20 10:46:51 [19,738ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Dofbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,739ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka *********************
2023-01-20 10:46:51 [19,740ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,741ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription A1 *********************
2023-01-20 10:46:51 [19,741ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] A1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,742ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Go1 *********************
2023-01-20 10:46:51 [19,743ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Go1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,743ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-20 10:46:51 [19,744ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,745ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-20 10:46:51 [19,746ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,746ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Crazyflie *********************
2023-01-20 10:46:51 [19,747ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Crazyflie uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,748ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Quadcopter *********************
2023-01-20 10:46:51 [19,748ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Quadcopter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,749ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V1 *********************
2023-01-20 10:46:51 [19,750ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,750ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V2 *********************
2023-01-20 10:46:51 [19,754ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V2 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,755ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetbot *********************
2023-01-20 10:46:51 [19,756ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,756ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetracer *********************
2023-01-20 10:46:51 [19,757ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetracer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,758ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya *********************
2023-01-20 10:46:51 [19,758ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,759ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Transporter *********************
2023-01-20 10:46:51 [19,760ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Transporter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,761ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Flat Grid *********************
2023-01-20 10:46:51 [19,761ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Flat Grid uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,762ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Grid Room *********************
2023-01-20 10:46:51 [19,763ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Grid Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,764ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Simple Room *********************
2023-01-20 10:46:51 [19,764ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Simple Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,765ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse *********************
2023-01-20 10:46:51 [19,766ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,767ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse With Multiple Shelves *********************
2023-01-20 10:46:51 [19,771ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse With Multiple Shelves uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,772ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Full Warehouse *********************
2023-01-20 10:46:51 [19,772ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Full Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,773ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Hospital *********************
2023-01-20 10:46:51 [19,774ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Hospital uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,774ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Office *********************
2023-01-20 10:46:51 [19,775ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Office uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,776ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription tag36h11 *********************
2023-01-20 10:46:51 [19,777ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] tag36h11 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,777ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Allegro Hand *********************
2023-01-20 10:46:51 [19,778ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Allegro Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:51 [19,779ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Shadow Hand *********************
2023-01-20 10:46:51 [19,779ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Shadow Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[20.010s] [ext: omni.kit.browser.sample-1.2.4] startup
[20.027s] [ext: omni.graph.scriptnode-0.9.3] startup
[20.062s] [ext: omni.command.usd-1.0.1] startup
[20.099s] [ext: omni.warp-0.6.1] startup
Warp 0.6.1 initialized:
CUDA Toolkit: 11.5, Driver: 12.0
Devices:
Kernel cache: C:\Users\Administrator\AppData\Local\NVIDIA Corporation\warp\Cache\0.6.1
[21.329s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[21.350s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[21.399s] [ext: omni.replicator.core-1.6.4] startup
2023-01-20 10:46:52 [21,351ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[21.951s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[21.964s] [ext: omni.kit.widget.layers-1.6.9] startup
[22.063s] [ext: omni.isaac.core_nodes-0.21.0] startup
[22.204s] [ext: omni.kit.actions.window-1.1.0] startup
[22.258s] [ext: omni.isaac.debug_draw-0.2.2] startup
[22.300s] [ext: omni.kit.property.layer-1.1.3] startup
[22.324s] [ext: omni.isaac.wheeled_robots-0.6.1] startup
[22.499s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[22.558s] [ext: omni.isaac.occupancy_map-0.2.6] startup
2023-01-20 10:46:53 [22,379ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Occupancy Map *********************
2023-01-20 10:46:53 [22,381ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Occupancy Map uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:46:53 [22,400ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Block World Generator *********************
2023-01-20 10:46:53 [22,401ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Block World Generator uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[22.634s] [ext: omni.kit.property.audio-1.0.6] startup
[22.649s] [ext: omni.kit.property.camera-1.0.3] startup
[22.661s] [ext: omni.kit.property.geometry-1.2.2] startup
[22.677s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[22.693s] [ext: omni.kit.property.light-1.0.6] startup
[22.707s] [ext: omni.kit.property.material-1.8.16] startup
[22.727s] [ext: omni.hydra.scene_api-0.1.1] startup
[22.770s] [ext: omni.kit.window.stage-2.3.11] startup
[22.796s] [ext: omni.kit.property.render-1.1.0] startup
[22.805s] [ext: omni.kit.property.skel-1.0.1] startup
[22.821s] [ext: omni.kit.property.transform-1.3.4] startup
[22.843s] [ext: omni.kit.menu.stage-1.2.1] startup
[22.860s] [ext: omni.kit.manipulator.transform-104.6.11] startup
[22.887s] [ext: omni.kit.profiler.window-2.0.4] startup
[25.250s] [ext: omni.kit.property.bundle-1.2.6] startup
[25.261s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[25.275s] [ext: omni.kit.manipulator.tool.snap-1.2.2] startup
[25.323s] [ext: omni.kit.window.toolbar-1.3.3] startup
[25.377s] [ext: omni.kit.property.isaac-0.1.1] startup
[25.389s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[25.417s] [ext: omni.kit.manipulator.camera-104.0.22] startup
[25.418s] [ext: omni.kit.manipulator.prim-104.10.5] startup
At:
[26.492s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[26.493s] [ext: omni.kit.viewport.menubar.camera-104.1.7] startup
[26.543s] [ext: omni.kit.viewport.menubar.render-104.0.19] startup
[26.566s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[26.581s] [ext: omni.physx.commands-104.1.6-5.1] startup
[26.603s] [ext: omni.kit.viewport.menubar.settings-104.3.4] startup
[26.640s] [ext: omni.rtx.window.settings-0.6.2] startup
[26.710s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[26.734s] [ext: omni.physx.ui-104.1.6-5.1] startup
[26.844s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[26.845s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[26.872s] [ext: omni.kit.viewport.menubar.lighting-104.0.8] startup
[26.890s] [ext: omni.kit.property.physx-0.1.0] startup
[27.079s] [ext: omni.physx.demos-104.1.6-5.1] startup
[27.095s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[27.095s] [ext: omni.kit.viewport.ready-1.0.2] startup
[27.103s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[27.103s] [ext: omni.physx.camera-104.1.6-5.1] startup
[27.152s] [ext: omni.kit.selection-0.1.0] startup
[27.164s] [ext: omni.physx.cct-104.1.6-5.1] startup
[29.628s] [ext: omni.physx.supportui-104.1.6-5.1] startup
[29.920s] [ext: omni.kit.widget.live-2.0.3] startup
[29.952s] [ext: omni.physx.vehicle-104.1.6-5.1] startup
[30.044s] [ext: omni.kit.menu.edit-1.1.5] startup
2023-01-20 10:47:01 [29,842ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Grid Visibility *********************
2023-01-20 10:47:01 [29,843ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Grid Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,844ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Camera Visibility *********************
2023-01-20 10:47:01 [29,845ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Camera Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,845ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Light Visibility *********************
2023-01-20 10:47:01 [29,846ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Light Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[30.074s] [ext: omni.kit.window.commands-0.2.4] startup
[30.095s] [ext: omni.kit.window.console-0.2.3] startup
[30.128s] [ext: omni.physx.bundle-104.1.6-5.1] startup
[30.129s] [ext: omni.graph.bundle.action-1.3.0] startup
[30.131s] [ext: omni.isaac.range_sensor-0.7.0] startup
2023-01-20 10:47:01 [29,954ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Rotating *********************
2023-01-20 10:47:01 [29,956ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Rotating uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,957ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic *********************
2023-01-20 10:47:01 [29,957ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,958ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Array *********************
2023-01-20 10:47:01 [29,959ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Array uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,960ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Emitter *********************
2023-01-20 10:47:01 [29,960ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Emitter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,961ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription FiringGroup *********************
2023-01-20 10:47:01 [29,962ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] FiringGroup uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,968ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription LIDAR *********************
2023-01-20 10:47:01 [29,969ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] LIDAR uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [29,991ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Ultrasonic *********************
2023-01-20 10:47:01 [29,992ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Ultrasonic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [30,018ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic Range Sensor *********************
2023-01-20 10:47:01 [30,019ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic Range Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[30.296s] [ext: omni.kit.window.script_editor-1.6.4] startup
[30.323s] [ext: omni.kit.window.status_bar-0.1.5] startup
[30.364s] [ext: omni.kit.window.title-1.1.2] startup
[30.373s] [ext: omni.replicator.composer-1.2.3] startup
[30.403s] [ext: omni.replicator.isaac-1.7.3] startup
[30.567s] [ext: omni.isaac.kit-1.2.1] startup
[30.569s] [ext: omni.isaac.sensor-5.3.1] startup
2023-01-20 10:47:01 [30,386ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact Sensor *********************
2023-01-20 10:47:01 [30,388ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [30,389ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Imu Sensor *********************
2023-01-20 10:47:01 [30,389ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Imu Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [30,420ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact *********************
2023-01-20 10:47:01 [30,422ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-20 10:47:01 [30,425ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription IMU *********************
2023-01-20 10:47:01 [30,425ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] IMU uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[30.703s] [ext: omni.isaac.franka-0.4.0] startup
[30.711s] [ext: omni.resourcemonitor-1.0.0] startup
[30.757s] [ext: omni.rtx.settings.core-0.5.8] startup
[30.786s] [ext: semantics.schema.editor-0.3.2] startup
[30.821s] [ext: omni.kit.menu.file-1.1.3] startup
[30.834s] [ext: omni.isaac.quadruped-1.2.2] startup
[33.961s] [ext: omni.isaac.cortex-0.2.10] startup
[33.962s] [ext: omni.graph.window.action-1.4.0] startup
2023-01-20 10:47:05 [33,763ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2023-01-20 10:47:05 [33,765ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Action Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[33.994s] [ext: omni.kit.window.stats-0.1.2] startup
[34.002s] [ext: omni.isaac.sim.python-2022.2.0] startup
[34.007s] Simulation App Starting
2023-01-20 10:47:08 [37,525ms] [Warning] [omni.client.plugin] HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for https://omniverse-content-production.s3.us-west-2.amazonaws.com/.cloudfront.toml
2023-01-20 10:47:08 [37,528ms] [Warning] [omni.client.plugin] HTTP Client: omniclient: CC-873: Bypassing cache until the application is restarted
[67.526s] app ready
[67.898s] RTX ready
[68.345s] Simulation App Startup Complete
task:
physics_engine: physx
env:
numEnvs: 512
envSpacing: 4.0
resetDist: 3.0
maxEffort: 400.0
clipObservations: 5.0
clipActions: 1.0
controlFrequencyInv: 2
sim:
dt: 0.0083
use_gpu_pipeline: True
gravity: [0.0, 0.0, -9.81]
add_ground_plane: True
add_distant_light: True
use_flatcache: True
enable_scene_query_support: False
disable_contact_processing: False
enable_cameras: False
default_physics_material:
static_friction: 1.0
dynamic_friction: 1.0
restitution: 0.0
physx:
worker_thread_count: 4
solver_type: 1
use_gpu: True
solver_position_iteration_count: 4
solver_velocity_iteration_count: 0
contact_offset: 0.02
rest_offset: 0.001
bounce_threshold_velocity: 0.2
friction_offset_threshold: 0.04
friction_correlation_distance: 0.025
enable_sleeping: True
enable_stabilization: True
max_depenetration_velocity: 100.0
gpu_max_rigid_contact_count: 524288
gpu_max_rigid_patch_count: 81920
gpu_found_lost_pairs_capacity: 1024
gpu_found_lost_aggregate_pairs_capacity: 262144
gpu_total_aggregate_pairs_capacity: 1024
gpu_max_soft_body_contacts: 1048576
gpu_max_particle_contacts: 1048576
gpu_heap_capacity: 67108864
gpu_temp_buffer_capacity: 16777216
gpu_max_num_partitions: 8
Cartpole:
override_usd_defaults: False
enable_self_collisions: False
enable_gyroscopic_forces: True
sleep_threshold: 0.005
stabilization_threshold: 0.001
density: -1
rest_offset: 0.001
train:
params:
seed: 42
algo:
model:
network:
separate: False
space:
continuous:
mu_activation: None
sigma_activation: None
mu_init:
sigma_init:
val: 0
fixed_sigma: True
mlp:
units: [32, 32]
activation: elu
initializer:
regularizer:
load_checkpoint: False
load_path:
config:
full_experiment_name: Cartpole
device: cuda:0
device_name: cuda:0
env_name: rlgpu
ppo: True
mixed_precision: False
normalize_input: True
normalize_value: True
num_actors: 512
reward_shaper:
scale_value: 0.1
normalize_advantage: True
gamma: 0.99
tau: 0.95
learning_rate: 0.0003
lr_schedule: adaptive
kl_threshold: 0.008
score_to_win: 20000
max_epochs: 100
save_best_after: 50
save_frequency: 25
grad_norm: 1.0
entropy_coef: 0.0
truncate_grads: True
e_clip: 0.2
horizon_length: 16
minibatch_size: 8192
mini_epochs: 8
critic_coef: 4
clip_value: True
seq_len: 4
bounds_loss_coef: 0.0001
task_name: Cartpole
experiment:
num_envs:
seed: 42
torch_deterministic: False
max_iterations:
pipeline: gpu
sim_device: gpu
device_id: 0
rl_device: cuda:0
num_threads: 4
solver_type: 1
test: False
checkpoint:
headless: False
mt_timeout: 30
wandb_activate: False
wandb_group:
wandb_name: Cartpole
wandb_entity:
wandb_project: omniisaacgymenvs
Setting seed: 42
Sim params does not have attribute: physx
Sim params does not have attribute: Cartpole
Pipeline: GPU
Pipeline Device: cuda:0
Sim Device: GPU
Task Device: cuda:0
RL device: cuda:0
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym\spaces\box.py:74: UserWarning: WARN: Box bound precision lowered by casting to float32
“Box bound precision lowered by casting to {}”.format(self.dtype)
[71.916s] [ext: omni.physx.flatcache-104.1.6-5.1] startup
2023-01-20 10:47:46 [75,556ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
2023-01-20 10:47:51 [79,846ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
~~~* Direct GPU Helper:
~~~* 512 articulations, maxLinks=3
self.seed = 42
Started to train
Exact experiment name requested from command line: Cartpole
Box([-1.], [1.], (1,), float32) Box([-inf -inf -inf -inf], [inf inf inf inf], (4,), float32)
current training device: cuda:0
build mlp: 4
RunningMeanStd: (1,)
RunningMeanStd: (4,)
[2023-01-20 18:47:58] Running RL reset
2023-01-20 10:47:58 [86,848ms] [Error] [carb.events.python] AttributeError: ‘PrimTransformManipulator’ object has no attribute ‘_manipulator’
At:
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\prim_transform_manipulator.py(151): enabled
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.selector\omni\kit\manipulator\selector\manipulator_selector.py(100): _on_selection_changed
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.selector\omni\kit\manipulator\selector\manipulator_selector.py(85): _refresh
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extsPhysics/omni.physx.supportui-104.1.6-5.1\omni\physxsupportui\scripts\utils.py(30): refresh_manipulator_selector
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extsPhysics/omni.physx.supportui-104.1.6-5.1\omni\physxsupportui\scripts\rigid_body_transform_manipulator.py(67): _on_stage_event
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.core\omni\isaac\core\simulation_context\simulation_context.py(465): step
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.core\omni\isaac\core\world\world.py(338): step
d:\omniisaacgymenvs-main-2023-1-20\omniisaacgymenvs\envs\vec_env_rlgames.py(65): step
d:\omniisaacgymenvs-main-2023-1-20\omniisaacgymenvs\envs\vec_env_rlgames.py(88): reset
d:\omniisaacgymenvs-main-2023-1-20\omniisaacgymenvs\utils\rlgames\rlgames_utils.py(102): reset
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\common\a2c_common.py(470): env_reset
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\common\a2c_common.py(1162): train
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\torch_runner.py(101): run_train
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\rl_games\torch_runner.py(120): run
scripts/rlgames_train.py(83): run
scripts/rlgames_train.py(131): parse_hydra_configs
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\core\utils.py(160): run_job
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\hydra.py(106): run
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(381):
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(211): run_and_report
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra_internal\utils.py(378): _run_hydra
C:\Users\Administrator\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\hydra\main.py(52): decorated_main
BTW !!! ext.plugin prim and viewport can be load successfully from isaac sim app , but can not load from scripts/rlgames_train.py(actually can not load from SimulationApp), there must be some difference between isaac sim app and simluationApp
These two errors are coming from a different extension and shouldn’t interfere with executing RL training in Isaac Sim. We use a different app file when launching from script to improve performance. The errors will be fixed in the next release, it’s safe to ignore them for now.
