RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
I wanted to execute several offline generation tools for Omni Replicator in the Isaac Terminal but I always get the Error
I attached the whole log in the command prompt.
C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0>.\python.bat .\standalone_examples/replicator/offline_generation.py
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni', 'omni.kit.app._impl.telemetry_helpers'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Starting kit application with the following args:  ['C:\\Users\\KIRoPro\\AppData\\Local\\ov\\pkg\\isaac_sim-2022.2.0\\exts\\omni.isaac.kit\\omni\\isaac\\kit\\simulation_app.py', 'C:\\Users\\KIRoPro\\AppData\\Local\\ov\\pkg\\isaac_sim-2022.2.0\\apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=C:\\Users\\KIRoPro\\AppData\\Local\\ov\\pkg\\isaac_sim-2022.2.0\\kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1024', '--/app/renderer/resolution/height=1024', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', 'C:\\Users\\KIRoPro\\AppData\\Local\\ov\\pkg\\isaac_sim-2022.2.0/exts', '--ext-folder', 'C:\\Users\\KIRoPro\\AppData\\Local\\ov\\pkg\\isaac_sim-2022.2.0/apps', '--/physics/cudaDevice=0', '--portable', '--no-window']
Passing the following args to the base kit application:  []
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[Info] [carb] Logging to file: c:/users/kiropro/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/logs/Kit/Isaac-Sim/2022.2/kit_20230126_104439.log
[0.100s] [ext: omni.stats-0.0.0] startup
[0.168s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.179s] [ext: omni.assets.plugins-0.0.0] startup
[0.181s] [ext: omni.gpu_foundation-0.0.0] startup
[0.195s] [ext: carb.windowing.plugins-1.0.0] startup
[0.220s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-01-26 09:44:39 [310ms] [Warning] [gpu.foundation.plugin] Disabling auto-enabled Aftermath because of incompatible drivers, install recommended driver version.
| Driver Version: 516.40        | Graphics API: D3D12
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 3090 Ti       | Yes: 0 |     | 24336   MB | 10de      | ceaa0000.. |
|     |                                  |        |     |            | 2203      | 0          |
| OS: Windows, Version: 10.0 (21H2), Build: 19044
| Processor: 12th Gen Intel(R) Core(TM) i9-12900KF | Cores: 16 | Logical: 24
| Total Memory (MB): 65349 | Free Memory: 55491
| Total Page/Swap (MB): 75077 | Free Page/Swap: 62168
[0.786s] [ext: omni.kit.pipapi-0.0.0] startup
[0.830s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.837s] [ext: omni.kit.loop-isaac-1.0.0] startup
[0.839s] [ext: omni.kit.async_engine-0.0.0] startup
[0.841s] [ext: omni.kit.test-0.0.0] startup
[0.893s] [ext: omni.usd.config-1.0.0] startup
[0.902s] [ext: omni.usd.libs-1.0.0] startup
[1.031s] [ext: omni.isaac.core_archive-2.0.1] startup
[1.124s] [ext: omni.pip.torch-1_13_0-0.1.4] startup
[1.128s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-01-26 09:44:40 [1,173ms] [Warning] [omni.ext._impl._internal] There is already a module 'gym' in 'C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\python\lib\site-packages\gym\__init__.py'. Can't import another module with the same name in public space from 'c:\users\kiropro\appdata\local\ov\pkg\isaac_sim-2022.2.0\exts\omni.isaac.ml_archive\pip_prebundle'.
[1.201s] [ext: omni.client-0.1.1] startup
[1.210s] [ext: omni.appwindow-1.0.1] startup
[1.214s] [ext: omni.kit.renderer.core-0.0.0] startup
[1.242s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.246s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[1.297s] [ext: carb.audio-0.1.0] startup
[1.297s] [ext: omni.ui-2.12.23] startup
[1.307s] [ext: omni.uiaudio-1.0.0] startup
[1.309s] [ext: omni.kit.mainwindow-1.0.0] startup
[1.312s] [ext: omni.kit.uiapp-0.0.0] startup
[1.312s] [ext: omni.usd.schema.physics-1.0.0] startup
2023-01-26 09:44:40 [1,312ms] [Warning] [omni.ext._impl._internal] There is already a module 'pxr.UsdPhysics' in 'C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\pxr\UsdPhysics\__init__.py'. Can't import another module with the same name in public space from 'c:\users\kiropro\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics'.
2023-01-26 09:44:40 [1,322ms] [Warning] [omni.ext._impl._internal] There is already a module 'usd.schema.physics' in 'C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.usd.schema.physics\usd\schema\physics\__init__.py'. Can't import another module with the same name in public space from 'c:\users\kiropro\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\extsphysics\omni.usd.schema.physics'.
[1.348s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.376s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.386s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.466s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.477s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.485s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[1.494s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.502s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.511s] [ext: omni.kit.window.popup_dialog-2.0.15] startup
[1.522s] [ext: omni.kit.widget.nucleus_connector-1.0.2] startup
[1.529s] [ext: omni.usd.core-1.0.0] startup
[1.530s] [ext: omni.kit.actions.core-1.0.0] startup
[1.535s] [ext: omni.timeline-1.0.5] startup
[1.538s] [ext: omni.kit.commands-1.4.5] startup
[1.544s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.546s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[1.548s] [ext: omni.hydra.usdrt_delegate-4.1.1] startup
[1.552s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[1.554s] [ext: omni.usd-1.6.23] startup
[1.585s] [ext: omni.kit.asset_converter-1.2.39] startup
[1.591s] [ext: omni.usd.schema.isaac-1.0.0] startup
[1.612s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[1.618s] [ext: omni.kit.usd.layers-2.0.10] startup
[1.628s] [ext: omni.kit.menu.utils-1.4.7] startup
[1.640s] [ext: omni.kit.menu.create-1.0.8] startup
[1.642s] [ext: omni.iray.libs-0.0.0] startup
[1.658s] [ext: omni.inspect-1.0.1] startup
[1.664s] [ext: omni.volume-0.1.0] startup
[1.668s] [ext: omni.mdl.neuraylib-0.1.0] startup
[1.673s] [ext: omni.graph.tools-1.17.0] startup
[1.698s] [ext: omni.graph.core-2.64.7] startup
[1.700s] [ext: omni.hydra.rtx-0.1.0] startup
[1.710s] [ext: omni.kit.primitive.mesh-1.0.6] startup
[1.716s] [ext: omni.kit.usd_undo-0.1.1] startup
[1.718s] [ext: omni.kit.stage_templates-1.1.11] startup
[1.721s] [ext: omni.kit.widget.path_field-2.0.4] startup
[1.723s] [ext: omni.graph-1.50.1] startup
[1.764s] [ext: omni.debugdraw-0.1.1] startup
[1.767s] [ext: omni.kit.widget.browser_bar-2.0.4] startup
[1.769s] [ext: omni.kit.widget.versioning-1.3.8] startup
[1.772s] [ext: omni.kvdb-0.0.0] startup
[1.776s] [ext: omni.hydra.pxr-1.1.2] startup
[1.782s] [ext: omni.localcache-0.0.0] startup
[1.786s] [ext: omni.kit.hydra_texture-1.0.11] startup
[1.790s] [ext: omni.activity.core-1.0.1] startup
[1.796s] [ext: omni.convexdecomposition-104.1.6-5.1] startup
[1.800s] [ext: omni.kit.widget.viewport-104.1.15] startup
[1.808s] [ext: omni.kit.window.drop_support-1.0.1] startup
[1.809s] [ext: omni.kit.notification_manager-1.0.4] startup
[1.815s] [ext: omni.kit.search_core-1.0.1] startup
[1.817s] [ext: omni.kit.widget.filebrowser-2.3.8] startup
[1.835s] [ext: omni.ui.scene-1.5.17] startup
[1.842s] [ext: omni.kit.viewport.registry-104.0.2] startup
[1.847s] [ext: omni.kit.viewport.legacy_gizmos-1.0.8] startup
[1.849s] [ext: omni.hydra.engine.stats-1.0.0] startup
[1.851s] [ext: omni.kit.window.filepicker-2.7.8] startup
OmniAssetFileFormat
[1.896s] [ext: omni.kit.viewport.window-104.1.18] startup
[1.937s] [ext: omni.mdl-0.1.0] startup
[1.954s] [ext: omni.kit.window.file_importer-1.0.8] startup
[1.955s] [ext: omni.kit.viewport.utility-1.0.12] startup
[1.956s] [ext: omni.kit.material.library-1.3.21] startup
[1.966s] [ext: omni.kit.clipboard-1.0.0] startup
[1.967s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[1.969s] [ext: omni.ui_query-1.1.1] startup
[1.972s] [ext: omni.kit.context_menu-1.5.10] startup
[1.976s] [ext: omni.kit.window.file-1.3.30] startup
[1.979s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[1.980s] [ext: omni.kit.ui_test-1.2.9] startup
[1.985s] [ext: omni.kit.window.property-1.8.2] startup
[1.987s] [ext: omni.kit.window.content_browser-2.6.5] startup
[1.997s] [ext: omni.kit.widget.stage-2.7.18] startup
[2.002s] [ext: omni.usdphysics-104.1.6-5.1] startup
[2.003s] [ext: omni.kit.property.usd-3.18.12] startup
[2.016s] [ext: omni.physx-104.1.6-5.1] startup
[2.045s] [ext: omni.kit.widget.settings-1.0.1] startup
[2.047s] [ext: omni.kit.widget.graph-1.5.3] startup
[2.076s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[2.078s] [ext: omni.kit.window.preferences-1.3.7] startup
[2.112s] [ext: omni.kit.window.extensions-1.1.1] startup
[2.118s] [ext: omni.kit.widget.prompt-1.0.4] startup
[2.120s] [ext: omni.physics.tensors-0.1.0] startup
[2.127s] [ext: omni.graph.ui-1.24.1] startup
[2.165s] [ext: omni.isaac.version-1.0.0] startup
[2.165s] [ext: omni.physx.tensors-0.1.0] startup
[2.169s] [ext: omni.graph.action-1.31.0] startup
[2.204s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.208s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[2.212s] [ext: omni.kit.widget.searchfield-1.0.8] startup
[2.215s] [ext: omni.isaac.dynamic_control-1.2.2] startup
[2.221s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
2023-01-26 09:44:41 [2,203ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/kiropro/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
2023-01-26 09:44:41 [2,204ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
At:
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(95): startup
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\extension.py(13): on_startup
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext\_impl\_internal.py(146): _startup_ext
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext\_impl\_internal.py(197): startup
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/kernel/py\omni\ext\_impl\_internal.py(280): startup_extension
  PythonExtension.cpp::startup()(2): <module>
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(284): _start_app
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(169): __init__
  .\standalone_examples/replicator/offline_generation.py(16): <module>
2023-01-26 09:44:41 [2,205ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.viewport-104.0.7] Failed to startup python extension.
[2.308s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[2.313s] [ext: omni.isaac.core-1.42.0] startup
[3.057s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[3.068s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[3.070s] [ext: omni.isaac.ui-0.4.3] startup
[3.073s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-01-26 09:44:42 [3,048ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[3.074s] [ext: omni.isaac.surface_gripper-0.3.2] startup
2023-01-26 09:44:42 [3,051ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Surface Gripper *********************
2023-01-26 09:44:42 [3,051ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Surface Gripper uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.080s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[3.081s] [ext: omni.kit.graph.delegate.modern-1.6.4] startup
[3.083s] [ext: omni.isaac.manipulators-1.1.0] startup
[3.085s] [ext: omni.graph.window.core-1.41.0] startup
[3.094s] [ext: omni.isaac.mjcf-0.3.0] startup
2023-01-26 09:44:42 [3,073ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription MJCF Importer *********************
2023-01-26 09:44:42 [3,074ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] MJCF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.100s] [ext: omni.graph.window.generic-1.3.10] startup
2023-01-26 09:44:42 [3,076ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2023-01-26 09:44:42 [3,077ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Push Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,077ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2023-01-26 09:44:42 [3,077ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Lazy Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.103s] [ext: omni.kit.widget.spinner-1.0.4] startup
[3.107s] [ext: omni.kit.window.cursor-1.1.1] startup
[3.110s] [ext: omni.isaac.lula-1.2.1] startup
[3.120s] [ext: omni.graph.nodes-1.48.3] startup
[3.136s] [ext: omni.kit.viewport.menubar.core-104.4.1] startup
[3.211s] [ext: omni.isaac.motion_planning-0.2.1] startup
[3.219s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[3.220s] [ext: omni.syntheticdata-0.2.4] startup
2023-01-26 09:44:42 [3,206ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[3.237s] [ext: omni.isaac.motion_generation-4.5.5] startup
[3.244s] [ext: omni.kit.browser.core-2.2.1] startup
[3.252s] [ext: omni.isaac.synthetic_utils-0.4.2] startup
[3.263s] [ext: omni.isaac.universal_robots-0.3.1] startup
[3.264s] [ext: omni.kit.browser.folder.core-1.7.1] startup
[3.270s] [ext: omni.isaac.urdf-0.5.4] startup
2023-01-26 09:44:42 [3,249ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription URDF Importer *********************
2023-01-26 09:44:42 [3,249ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] URDF Importer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,251ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter URDF *********************
2023-01-26 09:44:42 [3,251ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,257ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka URDF *********************
2023-01-26 09:44:42 [3,257ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,263ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya URDF *********************
2023-01-26 09:44:42 [3,263ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,269ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 URDF *********************
2023-01-26 09:44:42 [3,269ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 URDF uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.300s] [ext: omni.isaac.utils-0.2.3] startup
2023-01-26 09:44:42 [3,277ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3 *********************
2023-01-26 09:44:42 [3,278ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,278ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5 *********************
2023-01-26 09:44:42 [3,278ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,278ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10 *********************
2023-01-26 09:44:42 [3,278ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,279ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR3e *********************
2023-01-26 09:44:42 [3,279ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR3e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,279ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR5e *********************
2023-01-26 09:44:42 [3,279ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR5e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR10e *********************
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR10e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription UR16e *********************
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] UR16e uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 900 *********************
2023-01-26 09:44:42 [3,280ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 900 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,281ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Cobotta Pro 1300 *********************
2023-01-26 09:44:42 [3,281ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Cobotta Pro 1300 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,281ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Dofbot *********************
2023-01-26 09:44:42 [3,281ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Dofbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,281ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Franka *********************
2023-01-26 09:44:42 [3,282ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Franka uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,282ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription A1 *********************
2023-01-26 09:44:42 [3,282ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] A1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,282ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Go1 *********************
2023-01-26 09:44:42 [3,282ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Go1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,283ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription ANYmal C *********************
2023-01-26 09:44:42 [3,283ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ANYmal C uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,284ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Crazyflie *********************
2023-01-26 09:44:42 [3,284ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Crazyflie uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,284ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Quadcopter *********************
2023-01-26 09:44:42 [3,284ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Quadcopter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,284ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V1 *********************
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V1 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Carter V2 *********************
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Carter V2 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetbot *********************
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetbot uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,285ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Jetracer *********************
2023-01-26 09:44:42 [3,286ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Jetracer uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,286ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Kaya *********************
2023-01-26 09:44:42 [3,286ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Kaya uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,286ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Transporter *********************
2023-01-26 09:44:42 [3,286ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Transporter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Flat Grid *********************
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Flat Grid uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Grid Room *********************
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Grid Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Simple Room *********************
2023-01-26 09:44:42 [3,287ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Simple Room uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse *********************
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Small Warehouse With Multiple Shelves *********************
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Small Warehouse With Multiple Shelves uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Full Warehouse *********************
2023-01-26 09:44:42 [3,288ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Full Warehouse uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,289ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Hospital *********************
2023-01-26 09:44:42 [3,289ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Hospital uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,289ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Office *********************
2023-01-26 09:44:42 [3,289ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Office uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,289ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription tag36h11 *********************
2023-01-26 09:44:42 [3,290ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] tag36h11 uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,290ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Allegro Hand *********************
2023-01-26 09:44:42 [3,290ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Allegro Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,290ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Shadow Hand *********************
2023-01-26 09:44:42 [3,290ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Shadow Hand uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.317s] [ext: omni.kit.browser.sample-1.2.4] startup
[3.320s] [ext: omni.graph.scriptnode-0.9.3] startup
[3.323s] [ext: omni.command.usd-1.0.1] startup
[3.327s] [ext: omni.warp-0.6.1] startup
Warp 0.6.1 initialized:
   CUDA Toolkit: 11.5, Driver: 11.7
   Devices:
     "cpu"    | Intel64 Family 6 Model 151 Stepping 2, GenuineIntel
     "cuda:0" | NVIDIA GeForce RTX 3090 Ti (sm_86)
   Kernel cache: C:\Users\KIRoPro\AppData\Local\NVIDIA Corporation\warp\Cache\0.6.1
[3.492s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[3.496s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[3.504s] [ext: omni.replicator.core-1.6.4] startup
2023-01-26 09:44:42 [3,596ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[3.670s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[3.672s] [ext: omni.kit.widget.layers-1.6.9] startup
[3.686s] [ext: omni.isaac.core_nodes-0.21.0] startup
[3.702s] [ext: omni.kit.actions.window-1.1.0] startup
[3.709s] [ext: omni.isaac.debug_draw-0.2.2] startup
[3.713s] [ext: omni.kit.property.layer-1.1.3] startup
[3.728s] [ext: omni.isaac.wheeled_robots-0.6.1] startup
[3.747s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[3.755s] [ext: omni.isaac.occupancy_map-0.2.6] startup
2023-01-26 09:44:42 [3,734ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Occupancy Map *********************
2023-01-26 09:44:42 [3,735ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Occupancy Map uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:42 [3,739ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Block World Generator *********************
2023-01-26 09:44:42 [3,740ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Block World Generator uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[3.767s] [ext: omni.kit.property.audio-1.0.6] startup
[3.769s] [ext: omni.kit.property.camera-1.0.3] startup
[3.771s] [ext: omni.kit.property.geometry-1.2.2] startup
[3.773s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[3.775s] [ext: omni.kit.property.light-1.0.6] startup
[3.777s] [ext: omni.kit.property.material-1.8.16] startup
[3.781s] [ext: omni.hydra.scene_api-0.1.1] startup
[3.786s] [ext: omni.kit.window.stage-2.3.11] startup
[3.790s] [ext: omni.kit.property.render-1.1.0] startup
[3.792s] [ext: omni.kit.property.skel-1.0.1] startup
[3.794s] [ext: omni.kit.property.transform-1.3.4] startup
[3.799s] [ext: omni.kit.menu.stage-1.2.1] startup
[3.802s] [ext: omni.kit.manipulator.transform-104.6.11] startup
[3.806s] [ext: omni.kit.profiler.window-2.0.4] startup
[4.007s] [ext: omni.kit.property.bundle-1.2.6] startup
[4.009s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[4.011s] [ext: omni.kit.manipulator.tool.snap-1.2.2] startup
[4.018s] [ext: omni.kit.window.toolbar-1.3.3] startup
[4.026s] [ext: omni.kit.property.isaac-0.1.1] startup
[4.027s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[4.031s] [ext: omni.kit.manipulator.camera-104.0.22] startup
[4.031s] [ext: omni.kit.manipulator.prim-104.10.5] startup
2023-01-26 09:44:43 [4,010ms] [Error] [carb.scripting-python.plugin] AttributeError: 'NoneType' object has no attribute '_create_manipulator'
At:
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.kit.manipulator.viewport\omni\kit\manipulator\viewport\manipulator_factory.py(72): create_manipulator
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\prim_transform_manipulator.py(66): __init__
  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.manipulator.prim\omni\kit\manipulator\prim\extension.py(24): on_startup
2023-01-26 09:44:43 [4,011ms] [Error] [omni.ext.plugin] [ext: omni.kit.manipulator.prim-104.10.5] Failed to startup python extension.
[4.193s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[4.193s] [ext: omni.kit.viewport.menubar.camera-104.1.7] startup
[4.200s] [ext: omni.kit.viewport.menubar.render-104.0.19] startup
[4.203s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[4.205s] [ext: omni.physx.commands-104.1.6-5.1] startup
[4.209s] [ext: omni.kit.viewport.menubar.settings-104.3.4] startup
[4.214s] [ext: omni.rtx.window.settings-0.6.2] startup
[4.225s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[4.228s] [ext: omni.physx.ui-104.1.6-5.1] startup
[4.249s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[4.250s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[4.255s] [ext: omni.kit.viewport.menubar.lighting-104.0.8] startup
[4.257s] [ext: omni.kit.property.physx-0.1.0] startup
[4.291s] [ext: omni.physx.demos-104.1.6-5.1] startup
[4.294s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[4.295s] [ext: omni.kit.viewport.ready-1.0.2] startup
[4.296s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[4.296s] [ext: omni.physx.camera-104.1.6-5.1] startup
[4.302s] [ext: omni.kit.selection-0.1.0] startup
[4.304s] [ext: omni.physx.cct-104.1.6-5.1] startup
[4.505s] [ext: omni.physx.supportui-104.1.6-5.1] startup
[4.555s] [ext: omni.kit.widget.live-2.0.3] startup
[4.561s] [ext: omni.physx.vehicle-104.1.6-5.1] startup
[4.573s] [ext: omni.kit.menu.edit-1.1.5] startup
2023-01-26 09:44:43 [4,552ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Grid Visibility *********************
2023-01-26 09:44:43 [4,553ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Grid Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,553ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Camera Visibility *********************
2023-01-26 09:44:43 [4,553ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Camera Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,553ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Toggle Light Visibility *********************
2023-01-26 09:44:43 [4,554ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Toggle Light Visibility uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[4.580s] [ext: omni.kit.window.commands-0.2.4] startup
[4.584s] [ext: omni.kit.window.console-0.2.3] startup
[4.590s] [ext: omni.physx.bundle-104.1.6-5.1] startup
[4.590s] [ext: omni.graph.bundle.action-1.3.0] startup
[4.590s] [ext: omni.isaac.range_sensor-0.7.0] startup
2023-01-26 09:44:43 [4,573ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Rotating *********************
2023-01-26 09:44:43 [4,573ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Rotating uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,573ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic *********************
2023-01-26 09:44:43 [4,573ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,574ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Array *********************
2023-01-26 09:44:43 [4,574ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Array uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,574ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Emitter *********************
2023-01-26 09:44:43 [4,574ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Emitter uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,574ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription FiringGroup *********************
2023-01-26 09:44:43 [4,575ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] FiringGroup uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,576ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription LIDAR *********************
2023-01-26 09:44:43 [4,576ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] LIDAR uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,583ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Ultrasonic *********************
2023-01-26 09:44:43 [4,583ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Ultrasonic uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,590ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Generic Range Sensor *********************
2023-01-26 09:44:43 [4,591ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Generic Range Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[4.628s] [ext: omni.kit.window.script_editor-1.6.4] startup
[4.631s] [ext: omni.kit.window.status_bar-0.1.5] startup
[4.634s] [ext: omni.kit.window.title-1.1.2] startup
[4.635s] [ext: omni.replicator.composer-1.2.3] startup
[4.655s] [ext: omni.replicator.isaac-1.7.3] startup
[4.673s] [ext: omni.isaac.kit-1.2.1] startup
[4.674s] [ext: omni.isaac.sensor-5.3.1] startup
2023-01-26 09:44:43 [4,655ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact Sensor *********************
2023-01-26 09:44:43 [4,655ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,655ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Imu Sensor *********************
2023-01-26 09:44:43 [4,655ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Imu Sensor uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,660ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Contact *********************
2023-01-26 09:44:43 [4,660ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Contact uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
2023-01-26 09:44:43 [4,661ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription IMU *********************
2023-01-26 09:44:43 [4,661ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] IMU uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[4.691s] [ext: omni.isaac.franka-0.4.0] startup
[4.693s] [ext: omni.resourcemonitor-1.0.0] startup
[4.699s] [ext: omni.rtx.settings.core-0.5.8] startup
[4.705s] [ext: semantics.schema.editor-0.3.2] startup
[4.710s] [ext: omni.kit.menu.file-1.1.3] startup
[4.712s] [ext: omni.isaac.quadruped-1.2.2] startup
[5.111s] [ext: omni.isaac.cortex-0.2.10] startup
[5.111s] [ext: omni.graph.window.action-1.4.0] startup
2023-01-26 09:44:44 [5,091ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2023-01-26 09:44:44 [5,091ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Action Graph uses onclick_fn and/or unclick_fn which are deprecated. Use onclick_action and unclick_action instead which use omni.kit.actions.core
[5.117s] [ext: omni.kit.window.stats-0.1.2] startup
[5.119s] [ext: omni.isaac.sim.python-2022.2.0] startup
[5.120s] Simulation App Starting
[10.109s] app ready
[10.280s] RTX ready
[10.537s] Simulation App Startup Complete
Loading Stage /Isaac/Environments/Simple_Warehouse/full_warehouse.usd
2023-01-26 09:45:34 [55,659ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=000001631cd61000(61,8): C181 unused variable 'Local15'
2023-01-26 09:45:34 [55,661ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=000001631cd61000(61,8): C181 unused variable 'Local15'
2023-01-26 09:45:34 [55,662ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=000001631cd61000(61,8): C181 unused variable 'Local15'
2023-01-26 09:45:39 [59,947ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:46:39 [120,105ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:46:39 [120,106ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,835ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedPallet/SM_PaletteA_01. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,835ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_0/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,836ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_1/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,837ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_2/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,837ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_3/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,838ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_4/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,838ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_5/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,838ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_6/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,839ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_7/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-01-26 09:48:54 [255,843ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,845ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,848ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,856ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,863ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:54 [255,916ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
2023-01-26 09:48:59 [260,010ms] [Warning] [omni.physx.plugin] PhysX warning: TriangleMesh: triangles are too big, reduce their size to increase simulation stability!, FILE C:\b\w\f25a4639a4b1bdc1\source\geomutils\src\cooking\GuCookingTriangleMesh.cpp, LINE 202
Simulation stopped after 95 steps
2023-01-26 09:49:01 [262,285ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/kiropro/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
2023-01-26 09:49:01 [262,294ms] [Error] [omni.kit.commands.command] Failed to execute a command: MovePrim.
  File ".\standalone_examples/replicator/offline_generation.py", line 332, in <module>
    main()
  File ".\standalone_examples/replicator/offline_generation.py", line 263, in main
    register_scatter_boxes(pallet_prim)
  File ".\standalone_examples/replicator/offline_generation.py", line 74, in register_scatter_boxes
    scale=plane_scale, position=plane_pos_gf, rotation=plane_rot_euler_deg, visible=False
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\utils\utils.py", line 324, in __call__
    return ReplicatorItem(self.__fn, *args, **kwargs)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\utils\utils.py", line 342, in __init__
    self.node = self.__fn(*args, **kwargs)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\create.py", line 475, in plane
    name=name,
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\create.py", line 93, in _create_prim
    omni.kit.commands.execute("MovePrim", path_from=tmp_prim_path, path_to=prim_path)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.commands\omni\kit\commands\command.py", line 459, in execute
    result = omni.kit.undo.execute(command, name, kwargs)
[...skipped...]
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.commands\omni\kit\undo\undo.py", line 77, in execute
    result = _execute(command, name, level, history_key)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.commands\omni\kit\undo\undo.py", line 454, in _execute
    raise error
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.commands\omni\kit\undo\undo.py", line 415, in _execute
    result = command.do()
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.usd\omni\usd\commands\usd_commands.py", line 2939, in do
    self._move(self._path_from, self._path_to, False)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.usd.libs\pxr\Trace\__init__.py", line 78, in invoke
    return func(*args, **kwargs)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.usd\omni\usd\commands\usd_commands.py", line 2827, in _move
    rename_handler = MovePrimCommand.RenameHandler(path_from)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.usd\omni\usd\commands\usd_commands.py", line 2764, in __init__
    vp_iface = vp_legacy.get_viewport_interface()
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.kit.window.viewport\omni\kit\viewport_legacy\scripts\viewport.py", line 15, in get_viewport_interface
    get_viewport_interface.viewport = acquire_viewport_interface()
 <class 'RuntimeError'> Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
2023-01-26 09:49:01 [262,397ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Replicator/SDGPipeline/OgnGroup_06.inputs:prims has multiple targets, which is not supported
Outputting data to  C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/_output_headless
2023-01-26 09:49:01 [262,526ms] [Warning] [carb] [Plugin: omni.structuredlog.plugin.dll] Module c:/users/kiropro/appdata/local/ov/pkg/isaac_sim-2022.2.0/kit/omni.structuredlog.plugin.dll remained loaded after unload request
2023-01-26 09:49:01 [262,527ms] [Error] [__main__] Exception: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
    main()
  File ".\standalone_examples/replicator/offline_generation.py", line 324, in main
    writer.attach([driver_rp, forklift_rp, pallet_rp])
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\writers.py", line 330, in attach
    WriterRegistry.attach(self, render_products)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\writers.py", line 457, in attach
    writer_node = cls._attach(writer, active_writer_id, render_products, **combined_kwargs)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\writers.py", line 597, in _attach
    annotator = annotator.attach([render_product])
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\scripts\annotators.py", line 379, in attach
    self.template_name, 0, render_products, attributes=self._init_params
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.syntheticdata\omni\syntheticdata\scripts\SyntheticData.py", line 1385, in activate_node_template
    SyntheticData._add_rendervar(rp, rv, stage)
  File "C:\Users\KIRoPro\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/extscore/omni.syntheticdata\omni\syntheticdata\scripts\SyntheticData.py", line 694, in _add_rendervar
    vp_iface = omni.kit.viewport_legacy.get_viewport_interface()
[262.830s] Simulation App Shutting Down
can you check if nvidia-smi works ? sometimes I need to reboot the computer.
Reboot did not work unfortunately. The crash happens nonetheless
Have you installed a local nucleus server? I recall having the same issue, but it disappeared after I set up nucleus Installation — Omniverse Nucleus documentation
Yes I did on my first day using Omniverse and it should be running.
I have a realy similar issue with the same Error trying to run the replicator composer tutorial script on Windows 10 on RTX3080 with CUDA Toolkit 11.5 and driver version: 12.0. Any solutions yet?
Not from my side. But since I saw the error a few times in the forum in the last days/week this seems to be a bug in the viewport extension of some sort.
Thanks for the fast reply. I just tried using the recommended Driver Version “527.37 Game Ready” instead of the newest version but the Error still exists. Let’s hope for a quick fix or workaround.
I seem to have fixed it. You have to navigate to the viewport_legacy folder:
 C:\Users\<Your Username here>\AppData\Local\ov\pkg\isaac_sim-2022.2.0\kit\extscore\omni.kit.window.viewport\omni\kit\viewport_legacy
Step 1
Fill in the start of the path according to where you installed Isaac Sim. After that I renamed the
 _viewport_legacy.cp37-win_amd64.pyd ==to==> _viewport_legacy.cp37_win_amd64.pyd
and
 _viewport_legacy.cp37-win_amd64.lib ==to==> _viewport_legacy.cp37_win_amd64.lib
depending on your CPU Architekture the names might be different.
Step 2
After that I changed in the scripts\viewport.py file the import statements in row 7 and 8 to:
 from .._viewport_legacy import * ==to==> from .._viewport_legacy.cp37_win_amd64 import *
and
 from .._viewport_legacy import HydraEngineStats, get_mem_stats ==to==> from .._viewport_legacy.cp37_win_amd64 import HydraEngineStats, get_mem_stats
Here you have to use the same endings for .._viewport_legacy.cp37_win_amd64 as you did in the step above which might be different depending on your CPU architecture.
Please let me know if this fixed it for you too or if anything is unclear.
Yes fixed it for me! Thank you. I will see if I will run into any problems with ISAAC after editing these lines. When I do, I will let you know.
