Warnings and error during startup
Hi there, I’ve a bunch of warnings I just want to be sure the installation is correct.
I installed isaacsim directly from the omniverse launcher (is this alright or would it be better to use the other installer?)
When I launch the app and load the simple environment I get the following
| Driver Version: 460.91      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | Quadro RTX 5000                  | Yes    |     | 16630   MB | 10de      | 0          |
|     |                                  |        |     |            | 1eb0      | aaf1ac48.. |
| OS: Linux ps101, Version: 5.4.0-80-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12008000 (1.20.8.0)
| Processor: Intel(R) Xeon(R) W-2133 CPU @ 3.60GHz | Cores: Unknown | Logical: 12
| Total Memory (MB): 64002 | Free Memory: 53248
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[1.334s] [ext: omni.kit.test-0.0.0] startup
[1.370s] [ext: omni.ui-2.1.8] startup
[1.390s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.395s] [ext: omni.kit.uiapp-0.0.0] startup
[1.396s] [ext: omni.usd.schema.physics-1.0.0] startup
2021-08-26 14:31:33 [1,401ms] [Warning] [carb.python] There is already a module 'pxr.UsdPhysics' in '/home/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.physics/pxr/UsdPhysics/__init__.py'. Can't import another module with the same name in public space from '/home/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extsPhysics/omni.usd.schema.physics'.
2021-08-26 14:31:33 [1,404ms] [Warning] [carb.python] There is already a module 'usd.schema.physics' in '/home/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.physics/usd/schema/physics/__init__.py'. Can't import another module with the same name in public space from '/home/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extsPhysics/omni.usd.schema.physics'.
[1.414s] [ext: omni.usd.schema.isaac-0.1.0] startup
[1.473s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.481s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.490s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.524s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.549s] [ext: omni.services.facilities.base-1.0.0] startup
[1.560s] [ext: omni.services.core-1.1.0] startup
[1.820s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.822s] [ext: omni.services.transport.server.http-1.0.0] startup
[2.168s] [ext: omni.kit.notification_manager-1.0.0] startup
[2.172s] [ext: omni.services.transport.client.base-1.0.0] startup
[2.173s] [ext: omni.kit.agent-0.1.0] startup
[2.174s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[2.179s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[2.190s] [ext: omni.services.client-0.2.0] startup
[2.268s] [ext: carb.audio-0.1.0] startup
[2.289s] [ext: omni.timeline-1.0.0] startup
[2.295s] [ext: omni.kit.commands-0.0.0] startup
[2.305s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[2.694s] [ext: omni.kit.search_core-1.0.0] startup
[2.696s] [ext: omni.kit.widget.path_field-2.0.2] startup
[2.702s] [ext: omni.usd-1.4.2] startup
[2.747s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[2.752s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[2.759s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[2.763s] [ext: omni.kit.stage_templates-1.0.4] startup
[2.771s] [ext: omni.kit.window.filepicker-2.3.1] startup
[2.967s] [ext: omni.kit.window.file-1.2.2] startup
[3.079s] [ext: omni.renderer-rtx-0.0.0] startup
[3.080s] [ext: omni.kvdb-0.0.0] startup
[3.091s] [ext: omni.usdphysics-1.2.0] startup
[3.093s] [ext: omni.convexdecomposition-1.2.0] startup
[3.104s] [ext: omni.localcache-0.0.0] startup
[3.116s] [ext: omni.kit.menu.utils-1.0.1] startup
[3.126s] [ext: omni.physx-1.2.0-5.1] startup
[3.163s] [ext: omni.kit.material.library-1.0.4] startup
[3.188s] [ext: omni.kit.menu.create-1.0.1] startup
[3.191s] [ext: omni.kit.window.drop_support-1.0.0] startup
[3.196s] [ext: omni.kit.context_menu-1.1.0] startup
[3.283s] [ext: omni.hydra.rtx-0.1.0] startup
[3.287s] [ext: omni.kit.window.content_browser-2.3.1] startup
[3.372s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-08-26 14:31:35 [3,368ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-08-26 14:31:36 [4,465ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[4.823s] [ext: omni.physx.commands-1.0.0] startup
[4.835s] [ext: omni.kit.widget.stage-2.4.0] startup
[4.846s] [ext: omni.kit.window.property-0.0.0] startup
[4.848s] [ext: omni.kit.widget.settings-1.0.0] startup
[4.850s] [ext: omni.kit.property.usd-3.9.4] startup
[4.902s] [ext: omni.kit.window.preferences-1.1.1] startup
[4.938s] [ext: omni.debugdraw-0.0.0] startup
[4.944s] [ext: omni.kit.property.material-1.6.4] startup
[4.949s] [ext: omni.physx.ui-1.2.0-5.1] startup
[4.976s] [ext: omni.kit.numpy.common-0.1.0] startup
[5.173s] [ext: omni.kit.property.physx-0.1.0] startup
[5.258s] [ext: omni.kit.window.toolbar-1.0.0] startup
[5.266s] [ext: omni.physx.demos-1.0.0] startup
[5.278s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[5.296s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[5.332s] [ext: omni.physx.cct-1.2.0-5.1] startup
[5.347s] [ext: omni.isaac.utils-0.1.4] startup
[5.360s] [ext: omni.syntheticdata-0.1.5] startup
[5.564s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[5.564s] [ext: omni.isaac.range_sensor-0.1.2] startup
[5.571s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[5.574s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[5.579s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
[6.011s] [ext: omni.kit.window.console-0.0.0] startup
[6.013s] [ext: omni.isaac.motion_planning-0.1.4] startup
[6.020s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[6.026s] [ext: omni.kit.widget.prompt-1.0.0] startup
[6.029s] [ext: omni.kit.asset_converter-1.1.22] startup
[6.058s] [ext: omni.kit.window.script_editor-1.5.0] startup
[6.059s] [ext: omni.kit.window.status_bar-0.0.0] startup
[6.061s] [ext: omni.rtx.window.settings-0.6.0] startup
[6.068s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[6.081s] [ext: omni.kit.widget.graph-1.1.2] startup
[6.088s] [ext: omni.kit.window.profiler-1.0.0] startup
[6.093s] [ext: omni.rtx.settings.core-0.5.4] startup
[6.099s] [ext: omni.isaac.dr-0.1.6] startup
[6.107s] [ext: omni.kit.window.extensions-1.0.2] startup
[6.118s] [ext: omni.isaac.urdf-0.1.4] startup
[6.133s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[6.140s] [ext: omni.isaac.python_app-0.0.0] startup
[6.141s] [ext: omni.isaac.sim.python-2021.1.1] startup
[6.141s] app started
OmniKitHelper Starting up ...
OmniKitHelper Startup Complete
2021-08-26 14:31:55 [23,150ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,151ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,151ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,152ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,199ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,200ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,201ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,201ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,205ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Parquet_Floor.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,206ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Parquet_Floor.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,207ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Parquet_Floor.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,211ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,212ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,213ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,213ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,224ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,226ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,226ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,227ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,242ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,244ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,245ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,246ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,257ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,258ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,259ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,259ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,268ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,269ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,269ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,270ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,282ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,283ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,284ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,285ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,304ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,306ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,306ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,307ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,328ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve math.mdl
2021-08-26 14:31:55 [23,329ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve state.mdl
2021-08-26 14:31:55 [23,329ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve tex.mdl
2021-08-26 14:31:55 [23,331ms] [Warning] [rtx.neuraylib.plugin] Unable to resolve anno.mdl
2021-08-26 14:31:55 [23,335ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Table.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,336ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Table.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,337ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Table.mdl(29,21): unused parameter 'AO'
2021-08-26 14:31:55 [23,337ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/Isaac/Environments/Simple_Room/Materials/MI_Table.mdl(29,21): unused parameter 'AO'
Loading stage...
Loading Complete
Is everything ok? I’m especially worried about those missing mdl and the double definition of modules
Yes. Installation through the Launcher is recommended on a workstation with a display.
It looks fine. You can ignore those warnings. I did not see any errors in your log. Did you have any issues loading the scene?
Not really, but I tried to load the scene through the OmniKitHelper (load_scene.py) and add the Orc (NVIDIA->Assets->Char->Real->Orc) and the simulation stopped/freezed once I open the folder (not when I load the asset). I thought initially it might be related to that, but then I noticed also the issue from @eliabntt94 (Unable to import NVIDIA usds) so maybe there’s something more that I’m missing.
I’ve a related question thought that is the same that @eliabntt94 had: is it possible through OmniKitHelper to launch the simulation as it was launched by isaac-sim.sh? Bc I notice that the interface is different and many components and menu options are disabled. Also, the isaac-sim.sh launch the beta, while OmniKitHelper launches the release IDK if there’s a difference in there.
Sorry for the late reply. You can run Isaac Sim environment/UI similar to the full app using the omni.isaac.sim.kit “experience” file.
