Why i am seeing warnings for standalone app
I just installed and launched app
Why there are so many warnings here.
It says please update your code accordingly.I did not code anything
2025-06-26 11:59:06 [8,126ms] [Warning] [omni.isaac.block_world] ['omni.isaac.block_world'] has been deprecated in favor of ['isaacsim.asset.importer.heightmap']. Please update your code accordingly.
[8.173s] [ext: isaacsim.sensors.rtx.ui-0.1.2] startup
2025-06-26 11:59:06 [8,130ms] [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path /home/kelo/issac_sim/isaac-sim-standalone@4.5.0-rc.36+release.19112.f59b3005.gl.linux-x86_64.release/exts/isaacsim.sensors.rtx/data/lidar_configs
[8.819s] [ext: isaacsim.sensors.physics.ui-0.1.2] startup
[8.822s] [ext: omni.physx.ui-106.5.7] startup
[8.879s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[8.886s] [ext: omni.importer.onshape-0.8.1] startup
[8.932s] [ext: isaacsim.robot_setup.gain_tuner-2.0.3] startup
[8.942s] [ext: omni.usd.metrics.assembler.physics-106.5.0] startup
[8.948s] [ext: isaacsim.util.camera_inspector-1.0.4] startup
[8.953s] [ext: omni.isaac.gain_tuner-2.0.2] startup
[8.953s] [ext: isaacsim.robot_setup.grasp_editor-2.0.5] startup
[8.969s] [ext: isaacsim.asset.gen.omap-2.0.8] startup
[8.979s] [ext: omni.anim.curve.core-1.2.0] startup
[9.017s] [ext: isaacsim.robot.surface_gripper.ui-2.1.1] startup
[9.023s] [ext: omni.isaac.grasp_editor-2.0.2] startup
[9.024s] [ext: omni.isaac.occupancy_map-2.0.3] startup
2025-06-26 11:59:07 [8,980ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
[9.027s] [ext: omni.anim.curve.ui-1.4.0] startup
[9.066s] [ext: isaacsim.util.merge_mesh-2.0.6] startup
[9.078s] [ext: isaacsim.robot_setup.assembler-2.1.5] startup
[9.092s] [ext: omni.anim.curve.bundle-1.2.3] startup
[9.093s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.5] startup
[9.105s] [ext: omni.isaac.robot_assembler-2.0.2] startup
[9.105s] [ext: isaacsim.replicator.scene_blox-1.0.2] startup
[9.108s] [ext: omni.isaac.robot_description_editor-3.0.2] startup
[9.109s] [ext: isaacsim.replicator.synthetic_recorder-2.2.3] startup
[9.127s] [ext: isaacsim.core.throttling-2.0.2] startup
[9.130s] [ext: omni.isaac.scene_blox-1.0.2] startup
2025-06-26 11:59:07 [9,086ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[9.132s] [ext: omni.graph.ui_nodes-1.40.1] startup
[9.138s] [ext: omni.isaac.synthetic_recorder-2.0.2] startup
2025-06-26 11:59:07 [9,094ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[9.140s] [ext: omni.isaac.throttling-2.0.2] startup
2025-06-26 11:59:07 [9,096ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-06-26 11:59:07 [9,097ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[9.143s] [ext: omni.kit.browser.asset-1.3.11] startup
[9.191s] [ext: omni.graph.bundle.action-2.20.0] startup
[9.197s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-06-26 11:59:07 [9,155ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-06-26 11:59:07 [9,156ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[9.205s] [ext: omni.kit.core.collection-0.2.0] startup
[9.218s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[9.223s] [ext: omni.kit.preferences.animation-1.2.0] startup
[9.243s] [ext: omni.graph.window.generic-1.40.0] startup
[9.259s] [ext: omni.kit.property.collection-0.2.0] startup
[9.265s] [ext: omni.kit.property.layer-1.1.8] startup
[9.281s] [ext: omni.kit.search.files-1.0.4] startup
[9.287s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[9.294s] [ext: omni.kit.window.title-1.1.5] startup
[9.297s] [ext: omni.isaac.extension_templates-2.0.2] startup
2025-06-26 11:59:07 [9,254ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
[9.301s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[9.308s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[9.316s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[9.320s] [ext: omni.kit.browser.material-1.6.0] startup
[9.331s] [ext: omni.kit.property.material-1.10.17] startup
[9.359s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[9.370s] [ext: omni.kit.widgets.custom-1.0.9] startup
[9.406s] [ext: omni.kit.usdz_export-1.0.7] startup
[9.412s] [ext: omni.kit.window.material-1.6.2] startup
[9.434s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[9.435s] [ext: omni.kit.variant.editor-106.1.1] startup
[9.492s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[9.602s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[9.613s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[9.617s] [ext: omni.kit.usda_edit-1.1.14] startup
[9.638s] [ext: omni.kit.variant.presenter-107.0.0] startup
[9.654s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[9.678s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[9.696s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[9.715s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[9.731s] [ext: omni.rtx.window.settings-0.6.17] startup
[9.744s] [ext: isaacsim.asset.gen.omap.ui-2.0.4] startup
[9.756s] [ext: omni.scene.optimizer.core-106.1.10] startup
[9.837s] [ext: omni.kit.widget.live-2.1.8] startup
[9.843s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[9.843s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[9.844s] [ext: omni.isaac.occupancy_map.ui-2.0.3] startup
2025-06-26 11:59:08 [9,799ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
[9.850s] [ext: omni.kit.converter.common-503.2.1] startup
[9.902s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[9.907s] [ext: omni.kit.widget.cache_indicator-3.0.1] startup
2025-06-26 11:59:08 [9,862ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
[10.052s] [ext: omni.isaac.physics_inspector-0.1.7] startup
2025-06-26 11:59:08 [10,007ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
2025-06-26 11:59:08 [10,007ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[10.054s] [ext: isaacsim.util.physics-1.1.2] startup
[10.061s] [ext: omni.kit.converter.dgn_core-503.3.2] startup
[10.110s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[10.111s] [ext: omni.kit.converter.hoops_core-504.4.1] startup
[10.120s] [ext: omni.kit.window.script_editor-1.7.8] startup
[10.125s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[10.130s] [ext: isaacsim.asset.browser-1.3.4] startup
[10.216s] [ext: omni.simready.explorer-1.1.1] startup
[10.272s] [ext: isaacsim.core.cloner-1.3.4] startup
[10.285s] [ext: omni.kit.converter.dgn-503.3.1] startup
[10.300s] [ext: omni.kit.converter.hoops-504.4.3] startup
[10.307s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[10.410s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[10.797s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-06-26 11:59:09 [10,753ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[10.799s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-06-26 11:59:09 [10,756ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[10.802s] [ext: omni.isaac.cloner-1.0.2] startup
2025-06-26 11:59:09 [10,760ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[10.806s] [ext: omni.kit.widget.calendar-1.0.8] startup
[10.808s] [ext: omni.kit.selection-0.1.5] startup
[10.811s] [ext: omni.isaac.core-4.0.3] startup
2025-06-26 11:59:09 [10,766ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-06-26 11:59:09 [10,766ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-06-26 11:59:09 [10,767ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-06-26 11:59:09 [10,767ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[10.813s] [ext: isaacsim.simulation_app-2.4.2] startup
[10.816s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-06-26 11:59:09 [10,771ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[10.817s] [ext: omni.isaac.cortex-1.0.2] startup
[10.819s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[10.828s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[10.848s] [ext: isaacsim.gui.menu-2.0.9] startup
[10.863s] [ext: omni.isaac.franka-1.0.2] startup
2025-06-26 11:59:09 [10,819ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-06-26 11:59:09 [10,820ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-06-26 11:59:09 [10,820ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[10.866s] [ext: omni.isaac.kit-2.0.3] startup
2025-06-26 11:59:09 [10,822ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[10.868s] [ext: omni.isaac.lula-4.0.2] startup
2025-06-26 11:59:09 [10,823ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[10.869s] [ext: isaacsim.sensors.physx-2.2.4] startup
[10.880s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-06-26 11:59:09 [10,836ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[10.882s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-06-26 11:59:09 [10,838ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,838ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,838ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,838ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-06-26 11:59:09 [10,839ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[10.885s] [ext: omni.isaac.menu-1.0.2] startup
2025-06-26 11:59:09 [10,841ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[10.887s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-06-26 11:59:09 [10,842ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,842ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,843ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,844ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,844ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,844ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,844ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-06-26 11:59:09 [10,844ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[10.890s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-06-26 11:59:09 [10,846ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-06-26 11:59:09 [10,846ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[10.892s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-06-26 11:59:09 [10,847ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[10.893s] [ext: omni.isaac.range_sensor-4.0.2] startup
[10.895s] [ext: omni.isaac.sensor-13.0.3] startup
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-06-26 11:59:09 [10,851ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-06-26 11:59:09 [10,852ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-06-26 11:59:09 [10,852ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-06-26 11:59:09 [10,852ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-06-26 11:59:09 [10,852ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[10.898s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-06-26 11:59:09 [10,855ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[10.901s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-06-26 11:59:09 [10,860ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-06-26 11:59:09 [10,861ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-06-26 11:59:09 [10,861ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[10.907s] [ext: omni.isaac.utils-2.0.2] startup
[10.910s] [ext: omni.kit.property.audio-1.0.16] startup
[10.915s] [ext: omni.kit.property.camera-1.0.9] startup
[10.917s] [ext: omni.hydra.scene_api-0.1.2] startup
[10.922s] [ext: omni.kit.property.physx-106.5.7] startup
[10.969s] [ext: omni.physx.demos-106.5.7] startup
[11.040s] [ext: omni.kit.property.geometry-1.3.3] startup
[11.047s] [ext: isaacsim.app.about-2.0.7] startup
[11.050s] [ext: omni.kit.property.light-1.0.11] startup
[11.052s] [ext: omni.kit.property.render-1.1.3] startup
[11.082s] [ext: omni.kit.property.transform-1.5.10] startup
[11.100s] [ext: omni.isaac.version-2.0.2] startup
2025-06-26 11:59:09 [11,055ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[11.101s] [ext: omni.physx.vehicle-106.5.7] startup
[11.149s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-06-26 11:59:09 [11,105ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,105ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,105ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,106ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,107ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,107ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-06-26 11:59:09 [11,107ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[11.153s] [ext: omni.isaac.window.about-2.0.2] startup
2025-06-26 11:59:09 [11,109ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-06-26 11:59:09 [11,110ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[11.156s] [ext: isaacsim.sensors.physx.examples-2.2.4] startup
[11.160s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[11.169s] [ext: omni.kit.property.bundle-1.3.2] startup
[11.173s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[11.178s] [ext: omni.physx.camera-106.5.7] startup
[11.191s] [ext: omni.kit.window.toolbar-1.6.2] startup
[11.207s] [ext: omni.kit.widget.timeline-105.0.1] startup
[11.230s] [ext: omni.isaac.range_sensor.examples-2.0.3] startup
2025-06-26 11:59:09 [11,185ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-06-26 11:59:09 [11,185ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-06-26 11:59:09 [11,185ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[11.231s] [ext: isaacsim.replicator.writers-1.0.1] startup
[11.273s] [ext: isaacsim.gui.property-1.0.4] startup
[11.283s] [ext: omni.physx.cct-106.5.7] startup
[11.309s] [ext: omni.physx.graph-106.5.7] startup
[11.334s] [ext: omni.physx.supportui-106.5.7] startup
[11.371s] [ext: omni.physx.telemetry-106.5.7] startup
[11.376s] [ext: isaacsim.replicator.examples-1.1.2] startup
[11.382s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-06-26 11:59:09 [11,337ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-06-26 11:59:09 [11,338ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[11.385s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[11.395s] [ext: omni.kit.window.console-0.2.14] startup
[11.412s] [ext: omni.kit.window.status_bar-0.1.7] startup
[11.416s] [ext: omni.kit.widget.collection-0.1.18] startup
[11.424s] [ext: omni.physx.bundle-106.5.7] startup
[11.425s] [ext: omni.replicator.isaac-2.0.3] startup
2025-06-26 11:59:09 [11,379ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[11.426s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[11.435s] [ext: omni.rtx.settings.core-0.6.3] startup
[11.458s] [ext: omni.kit.converter.jt_core-503.2.2] startup
[11.470s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[11.477s] [ext: omni.kit.window.collection-0.2.0] startup
[11.480s] [ext: isaacsim.sensors.physx.ui-2.2.1] startup
[11.482s] [ext: semantics.schema.editor-0.3.10] startup
[11.489s] [ext: omni.kit.ui.actions-1.0.2] startup
[11.492s] [ext: semantics.schema.property-1.0.5] startup
[11.494s] [ext: omni.kit.converter.jt-503.2.2] startup
[11.497s] [ext: omni.kit.quicklayout-1.0.8] startup
[11.499s] [ext: omni.kit.window.commands-0.2.7] startup
[11.504s] [ext: omni.isaac.range_sensor.ui-2.0.2] startup
2025-06-26 11:59:09 [11,459ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-06-26 11:59:09 [11,459ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[11.505s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.5] startup
[11.510s] [ext: omni.kit.menu.common-1.1.9] startup
[11.513s] [ext: isaacsim.exp.base-4.5.0] startup
[11.514s] [ext: omni.kit.converter.cad-202.2.0] startup
[11.514s] [ext: omni.kit.window.stats-0.1.7] startup
[11.516s] [ext: isaacsim.app.setup-1.3.5] startup
[11.518s] Isaac Sim Full Version: 4.5.0-rc.36
[11.519s] Writing Isaac Sim icon file
[11.519s] [ext: omni.kit.profiler.window-2.3.1] startup
[11.536s] [ext: isaacsim.exp.full-4.5.0] startup
[11.665s] [ext: isaacsim.ros2.bridge-4.1.15] startup
2025-06-26 11:59:10 [11,634ms] [Warning] [isaacsim.ros2.bridge.scripts.extension] ROS_DISTRO env var not found, Please source Humble, before enabling this extension
[11.680s] Using backup internal ROS2 humble distro
[11.696s] Attempting to load system rclpy
[11.696s] Could not import system rclpy: No module named 'rclpy'
[11.696s] Attempting to load internal rclpy
[11.725s] rclpy loaded
@chaitanyagumudala961 as another user, i’ve found that as long as the program launches fine, you can ignore those warnings. not all warnings leads to an error; but all errors will often have warnings preceding them.
but just out of curiosity, what’s your setup (OS, GPU, drivers), should the devs/mods take a closer look at the reports you’ve posted and have more technical insights to provide here.
99% of that is normal log. White is just log, yellow is possible warnings about minor things like updating, or future updating. RED IS BAD. Anything red you need to tell us about. But the rest you can ignore.
Okay.
Thank you for your assistance
This is my setup. I use it in Ubuntu 22
| NVIDIA-SMI 535.230.02             Driver Version: 535.230.02   CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 4070 ...    Off | 00000000:01:00.0  On |                  N/A |
| 31%   28C    P8               8W / 285W |    432MiB / 16376MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A      1272      G   /usr/lib/xorg/Xorg                           93MiB |
|    0   N/A  N/A      1549    C+G   ...libexec/gnome-remote-desktop-daemon      211MiB |
|    0   N/A  N/A      1605      G   /usr/bin/gnome-shell                         34MiB |
|    0   N/A  N/A      3947      G   /opt/teamviewer/tv_bin/TeamViewer            18MiB |
|    0   N/A  N/A     41837      G   ...unt_omniveXNUyS2/omniverse-launcher       44MiB |
