Hi @JerryChang
As per our project requirement, we are planning to use the Jetson Orin Nano Super Developer Kit carrier board/development kit.
Could you please confirm whether both the Jetson Orin NX SOM and Jetson Orin Nano SOM are compatible with this developer kit?
Also, regarding the MIPI CSI camera interface, could you please share the number of CSI interfaces/channels available, the lane distribution details for the MIPI CSI connectors, and the recommended CSI configuration to be used while building the image?
It would be helpful if you could also share the relevant PDF/documentation, carrier board schematic, or hardware design reference for this developer kit.
Thank you.
hello rahul.pp,
please refer to NVIDIA Jetson Orin Nano Super Developer Kit, the compatible modules include Orin NX 16GB/8GB and Orin Nano 8GB/4GB modules.
please refer to Jetson Orin NX Series and Orin Nano Series Design Guide , you may check [Table 10-3. CSI Configurations] for the module’s CSI pin outs.
the reference carrier board has two MIPI CSI2 22-pin camera connectors, both of them support x1 or x2 lane config.
however, if you’re working with a 4-lane camera sensor. it’s only supported by J21/CAM1 camera slots.
please see-also Jetson Orin Nano Developer Kit Carrier Board Reference Design Files for details.
Hi Rahul, hope you’re doing well!
Additionally to Jerry’s information, the Jetson Orin Nano Super Developer Kit uses essentially the same reference carrier board architecture as the standard Jetson Orin Nano Developer Kit, so the CSI connector topology and camera integration flow remain the same.
For additional reference regarding carrier boards, CSI connectors, and camera integration on Jetson Orin platforms, this RidgeRun documentation may also be usefu
Orin Nano Developer Guide
Alex Aguero
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
