Custom Carrier Board for Jetson Orin Nano with 3 CSI Camera Connectors
Hello NVIDIA Community,
I’m designing a custom carrier board based on the Jetson Orin Nano carrier , and I need support for three MIPI CSI camera connectors. I understand the official developer kit exposes only two CSI interfaces (CSI-0 and CSI-2), but the module itself supports additional interfaces like CSI-4 and CSI-6.
My Goal:
To connect three 4-lane MIPI CSI cameras directly to the carrier board.
Questions:
  1. CSI Interface Availability:
    • Can I use CSI-4 or CSI-6 in addition to CSI-0 and CSI-2 for the third camera?
    • Are all four CSI interfaces (CSI-0, CSI-2, CSI-4, CSI-6) simultaneously usable on the Orin Nano?
  2. CSI Lane Configuration:
    • According to the Jetson Orin Nano Design Guide, each CSI port supports up to 4 lanes.
    • Is it possible to configure three CSI ports with 4 lanes each without lane conflicts?
    • Are there any lane multiplexing or routing limitations I should be aware of?
  3. Pinmux and Device Tree:
    • What are the required changes in the pinmux spreadsheet and device tree to enable CSI-4 or CSI-6?
    • Are there any reference configurations or examples for enabling more than two CSI interfaces?
  4. Hardware Design Considerations:
    • Any recommendations for connector types, signal integrity, and clock signal routing?
    • Is lane swapping supported or strictly prohibited?
  5. Alternative Approaches:
    • Would using a GMSL2 or FPD-Link III deserializer be a better approach for supporting 3+ cameras?
    • Are there NVIDIA-approved deserializer ICs or reference boards that support multiple cameras over fewer CSI lanes?
Any guidance, documentation links, or shared experiences from similar projects would be greatly appreciated.
Thanks in advance!
Best regards,
Rohith
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
hello rohith8,
please check Jetson Orin NX Series and Orin Nano Series Design Guide for [Chapter 10. MIPI CSI Video Input].
let me re-cap as below..
Orin Module brings eight MIPI CSI lanes to the connector. Up-to two quad-lane camera streams or up-to four dual-lane camera streams are supported. Each data lane has a peak bandwidth of up to 2.5 Gbps.
hence..
unfortunately, it supports up-to two quad-lane camera streams.
please check the [Orin Module CSI Pin Descriptions], there’s no CSI4, CSI6 pin outs.
