I want to know how to point these files to the board.conf
I’m using a custom board for AGX Orin.
Hi netkerl,
Please refer to the followin:
After you place them to correct path, please modify the board config.
Let me take example for the board config of AGX Orin devkit. (<Linux_for_Tegra>/p3701.conf.common)
- PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi";
+ PINMUX_CONFIG="pinmux.dtsi";
PMIC_CONFIG="tegra234-mb1-bct-pmic-p3701-0000.dts";
- PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi";
+ PMC_CONFIG="padvoltage.dtsi";
Dear KevinFFF,
Many thanks for your help.
How can I get Jetpack version? (I forgot)
Regards,
netkerl
Hi KevinFFF,
copy the dtsi files to the location as you mentioned, without dtc compilation?
netkerl
Dear KevinFFF,
You mentioned only for pinmux.dtsi and padvolage.dtsi modification for pin3701.conf.common file.
- How about the modification for gpio.dtsi file?
- for padvoltage.dtsi, your attached list “You do not neet to copy the padvoltage.dtsi file”
should I modify this padvoltage.dtsi also?
Reards,
netkerl
Please run the following command to check.
$ cat /etc/nv_tegra_release
gpio.dtsi is included in pinmux.dtsi, please also modify the content in pinmux.dtsi
Yes, padvoltage.dtsi is optional to be updated.
You can just put pinmux.dtsi and gpio.dtsi to the correct path.
Dear KevinFFF,
I’m using Jetpack: Jetpack 5.1.2
Custom carrier board.
Questions:
- Number of files to modify, file name, and its location (directory)
- What file(s) that needs to be converted from dts to dtb or vise versa
- which file should be modified for MGBE (AQR113C) to enable 10G function?
Regards,
netkerl
seems duplicate question as Question for Device Tree - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums, please just discuss there.
Hi KevinFFF,
Many thanks for your help, I’ll try as you mentioned.
Regards,
netkerl
