I concur with Robert Crovella’s assessment. As I recall, the alignment attributes in CUDA source files are translated into the equivalent host-compiler specific attributes before the code is sent to the host compiler. You should be able to verify this by keeping and examining the intermediate files created during compilation of a .cu file.
#include <iostream>
#include <chrono>
#include <cuda_runtime.h>
using namespace std;
template <typename T>
__global__ void _add(int N, const T* a, const T* b, T *c)
int i = threadIdx.x + blockIdx.x * blockDim.x;
if (i >= N) return;
c[i].x = a[i].x + b[i].x;
c[i].y = a[i].y + b[i].y;
c[i].z = a[i].z + b[i].z;
c[i].w = a[i].w + b[i].w;
void _test(int N, int iter)
using namespace chrono;
T *a, *b, *c;
cudaMalloc(&a, N * sizeof(T));
cudaMalloc(&b, N * sizeof(T));
cudaMalloc(&c, N * sizeof(T));
dim3 blocks, threads;
threads = { 1024, 1, 1 };
blocks = { N / threads.x + 1, 1, 1 };
auto init = steady_clock::now();
for (int i = 0; i < iter; ++i) {
_add <<< blocks, threads >>> (N, a, b, c);
cudaDeviceSynchronize();
auto elapsed = duration_cast<milliseconds>(steady_clock::now() - init);
cout << static_cast<double>(elapsed.count()) / 1000 << " seconds" << endl;
struct __align__(16) my_float4
float x, y, z, w;
int main(int argc, char *argv[])
int N = 1000000;
int iter = 20;
if (argc >= 2) N = atoi(argv[1]);
if (argc >= 3) iter = atoi(argv[2]);
if (argc >= 4) {
cout << "FAIL" << endl; ::exit(EXIT_FAILURE);
cout << "N = " << N << endl;
cout << "ITER = " << iter << endl;
cout << "Built-in float4" << endl;
_test<float4>(N, iter);
cout << "Custom float4" << endl;
_test<my_float4>(N, iter);
The test is done on Linux (Ubuntu 16.04 LTS) and RTX 2080 Ti with CUDA 11.0.
The result reveals the custom and the built-in types have no difference, as followings:
N = 100000000
ITER = 1000
Built-in float4
8.809 seconds
Custom float4
8.811 seconds
N = 100000000
ITER = 10000
Built-in float4
88.07 seconds
Custom float4
87.958 seconds
One more question. What’s a role of the attribute “device_builtin”?
If you cannot find it described in the CUDA documentation: “builtin” attributes in various tool chains typically refer to features the compiler “knows” about, and thus handles in particular ways internally. So here it presumably means that float4 is not just some user-defined type, but a built-in type that is treated much the same as float or double.
