The Community Edition 19.4 was just installed. A small test on OpenAcc was performed:
program testOpenAcc
implicit none
integer::i
integer::N
real(8)::a(10000)
a=0.0D+00
N=1000
write(*,*)a(1:5)
write(*,*)'Hello world!'
!$acc data copyin(N,i,a(1:N))
!$acc parallel loop
do i=1,N
a(i)=1.0D+00
enddo
!$acc end parallel loop
!$acc update self(a(1:N))
!$acc end data
write(*,*)a(1:5)
end program testOpenAcc
The output was as follows:
0.000000000000000 0.000000000000000 0.000000000000000
Hello world!
Failing in Thread:1
call to cuStreamSynchronize returned error 719: Launch failed (often invalid pointer dereference)
Failing in Thread:1
call to cuMemFreeHost returned error 719: Launch failed (often invalid pointer dereference)
The directive ‘!$acc parallel loop’ can work on Community Edition 18.4, but it can not work on the present version, i.e., Community Edition 19.4.
Can you help find the reason?
Thanks a lot!
Jingbo
Hi Jingbo,
It looks like a problem where the compiler isn’t ignoring the “i” in the data clause. It should since the loop index variable is implicitly private and making it shared (the default behavior of a data clause) would cause this type of runtime error. I added a problem report TPR#27410 and sent it to our engineers to investigate.
The work around is to remove “i” from the copyin clause (N isn’t needed either so I removed it as well).
% cat test.f90
program testOpenAcc
implicit none
integer::i
integer::N
real(8)::a(10000)
a=0.0D+00
N=1000
write(*,*)a(1:5)
!$acc data copyin(a(1:N))
!$acc parallel loop
do i=1,N
a(i)=1.0D+00
enddo
!$acc end data
write(*,*)a(1:5)
% pgf90 test.f90 -ta=tesla -Minfo=accel -V19.4; a.out
testopenacc:
11, Generating copyin(a(:n))
12, Generating Tesla code
13, !$acc loop gang, vector(128) ! blockidx%x threadidx%x
18, Generating update self(a(:n))
Hello world!
1.000000000000000 1.000000000000000 1.000000000000000
Hope this helps,
Mat
Dear Mat,
Thank you for your comments!
It works very well!
Regards,
Jingbo
TPR 27410 is resolved w/20.1
