Dear all;
I had got the cuda c code for quick sort, but there is a parameter named “depth”, what was meant by i
t, and what value i should set when i call the function??
global void cdp_simple_quicksort(unsigned int *data, int left, int right, int depth)
// If we’re too deep or there are few elements left, we use an insertion sort…
if (depth >= MAX_DEPTH || right - left <= INSERTION_SORT)
selection_sort(data, left, right);
return;
unsigned int *lptr = data + left;
unsigned int *rptr = data + right;
unsigned int pivot = data[(left + right) / 2];
// Do the partitioning.
while (lptr <= rptr)
// Find the next left- and right-hand values to swap
unsigned int lval = *lptr;
unsigned int rval = *rptr;
// Move the left pointer as long as the pointed element is smaller than the pivot.
while (lval < pivot)
lptr++;
lval = *lptr;
// Move the right pointer as long as the pointed element is larger than the pivot.
while (rval > pivot)
rptr--;
rval = *rptr;
// If the swap points are valid, do the swap!
if (lptr <= rptr)
*lptr++ = rval;
*rptr-- = lval;
// Now the recursive part
int nright = rptr - data;
int nleft = lptr - data;
// Launch a new block to sort the left part.
if (left < (rptr - data))
cudaStream_t s;
cudaStreamCreateWithFlags(&s, cudaStreamNonBlocking);
cdp_simple_quicksort << < 1, 1, 0, s >> >(data, left, nright, depth + 1);
cudaStreamDestroy(s);
// Launch a new block to sort the right part.
if ((lptr - data) < right)
cudaStream_t s1;
cudaStreamCreateWithFlags(&s1, cudaStreamNonBlocking);
cdp_simple_quicksort << < 1, 1, 0, s1 >> >(data, nleft, right, depth + 1);
cudaStreamDestroy(s1);
