Ok, Today I tried to gather some more information. I tried everything with default fresh flash using jetpack 3.1. Always using the development kit.
This are the two part numbers that I’m trying.
P/N 135-0650-000 R2 (2017) : Works with R24 and R28.
P/N 135-0806-000 R2 (2018) : Works only with R28.
And here is the boot log for R24:
[0000.190] [TegraBoot] (version 00.00.2014.50-mobile-d44d4bf0)
[0000.196] Processing in cold boot mode Bootloader 2
[0000.200] A02 Bootrom Patch rev = 63
[0000.204] Power-up reason: reset button
[0000.207] No Battery Present
[0000.210] RamCode = 0
[0000.212] Platform has Ddr4 type ram
[0000.216] max77620 disabling SD1 Remote Sense
[0000.220] Setting Ddr voltage to 1125mv
[0000.224] Serial Number of Pmic Max77663: 0x1f0ab5
[0000.232] Entering ramdump check
[0000.235] Get RamDumpCarveOut = 0xff23f000
[0000.239] RamDumpCarveOut=0xff23f000, RamDumperFlag=0x0
[0000.244] Last reboot was clean, booting normally!
[0000.248] Sdram initialization is successful
[0000.252] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.258] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.263] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.268] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.273] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.278] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.284] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.289] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.304] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.310] Platform-DebugCarveout: 0
[0000.313] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.318] Non secure mode, and RB not enabled.
[0000.368] Using GPT Primary to query partitions
[0000.373] Loading Tboot-CPU binary
[0000.422] Verifying bootloader in OdmNonSecureSBK mode
[0000.432] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.439] Bootloader downloaded successfully.
[0000.443] Downloaded Tboot-CPU binary to 0xa0000258
[0000.448] MAX77620_GPIO1 Configured.
[0000.452] MAX77620_GPIO5 Configured.
[0000.455] CPU power rail is up
[0000.458] CPU clock enabled
[0000.462] Performing RAM repair
[0000.465] Updating A64 Warmreset Address to 0xa00002e9
[0000.493] Bootloader DTB Load Address: 0x83000000
[0000.521] Kernel DTB Load Address: 0x83100000
[0000.526] Loading cboot binary
[0000.620] Verifying bootloader in OdmNonSecureSBK mode
[0000.658] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.665] Bootloader downloaded successfully.
[0000.670] GPT: Partition NOT found !
[0000.673] Find Partition via GPT Failed
[0000.677] Find Partition via PT Failed
[0000.680] function NvTbootGetBinaryOffsets: 0x1 error
[0000.685] Error in NvTbootLoadBinary: 0x1 !
[0000.689] Next binary entry address: 0x92c00258
[0000.693] BoardId: 2180
[0000.698] dram memory type is 3
[0000.702] WB0 init successful
[0000.728] Bpmp FW successfully loaded
[0000.732] Set NvDecSticky Bits
[0000.735] GSC1 address : ff700000
[0000.738] GSC2 address ff63fffc value c0edbbcc
[0000.743] GSC2 address : ff600000
[0000.747] GSC3 address : ff500000
[0000.751] GSC4 address : ff400000
[0000.754] GSC5 address : ff300000
[0000.758] GSC MC Settings done
[0000.761] TOS plaintext Image length 28752
[0000.765] Monitor size 28752
[0000.768] OS size 0
[0000.771] *** Secure OS image signature not verified ***
[0000.776] Loading and Validation of Secure OS Successful
[0000.781] NvTbootPackSdramParams: start.
[0000.786] NvTbootPackSdramParams: done.
[0000.790] Tegraboot started after 170537 us
[0000.794] Basic modules init took 311138 us
[0000.798] Sec Bootdevice Read Time = 216 ms, Read Size = 9476 KB
[0000.804] Sec Bootdevice Write Time = -1940251271 ms, Write Size = -68719477 KB
[0000.811] Next stage binary read took 23848 us
[0000.815] Carveout took 207255 us
[0000.818] CPU initialization took 96686 us
[0000.822] Total time taken by TegraBoot 638927 us
[0000.827] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.2(release):cc5fd7c
NOTICE: BL31: Built : 00:37:02, Jul 20 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0000.967] RamCode = 0
[0000.989] LPDDR4 Training: Read DT: Number of tables = 10
[0000.994] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0000.999] EMC Training Skipped
[0001.002] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0001.007] EMC Training Skipped
[0001.010] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0001.015] EMC Training Skipped
[0001.018] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0001.023] EMC Training Skipped
[0001.026] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.032] EMC Training Successful
[0001.035] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.041] EMC Training Successful
[0001.044] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.055] EMC Training Successful
[0001.058] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.081] EMC Training Successful
[0001.084] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.106] EMC Training Successful
[0001.109] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.128] EMC Training Successful
[0001.132] Switching to 800000 KHz Success
[0001.141] RamCode = 0
[0001.145] DT Write: emc-table@40800 succeeded
[0001.151] DT Write: emc-table@68000 succeeded
[0001.157] DT Write: emc-table@102000 succeeded
[0001.163] DT Write: emc-table@204000 succeeded
[0001.169] DT Write: emc-table@408000 succeeded
[0001.175] DT Write: emc-table@665600 succeeded
[0001.182] DT Write: emc-table@800000 succeeded
[0001.188] DT Write: emc-table@1065600 succeeded
[0001.194] DT Write: emc-table@1331200 succeeded
[0001.200] DT Write: emc-table@1600000 succeeded
[0001.204] LPDDR4 Training: Write DT: Number of tables = 10
[0001.240]
[0001.241] Debug Init done
[0001.244] Marked DTB cacheable
[0001.247] Bootloader DTB loaded at 0x83000000
[0001.252] Marked DTB cacheable
[0001.254] Kernel DTB loaded at 0x83100000
[0001.258] DeviceTree Init done
[0001.278] Pinmux applied successfully
[0001.284] gicd_base: 0x50041000
[0001.288] gicc_base: 0x50042000
[0001.291] Interrupts Init done
[0001.297] Using base:0x60005008 & irq:33 for tick-timer
[0001.302] Using base:0x60005000 for delay-timer
[0001.306] platform_init_timer: DONE
[0001.310] Timer(tick) Init done
[0001.315] osc freq = 38400 khz
[0001.320]
[0001.321] welcome to cboot
[0001.324]
[0001.325] Cboot Version: 00.00.2014.50-t210-fadd1be5
[0001.330] calling constructors
[0001.333] initializing heap
[0001.336] initializing threads
[0001.339] initializing timers
[0001.341] creating bootstrap completion thread
[0001.346] top of bootstrap2()
[0001.349] CPU: ARM Cortex A57
[0001.352] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.356] initializing platform
[0001.403] config for ddr50 mode completed
[0001.407] sdmmc bdev is already initialized
[0001.411] Enable APE clock
[0001.413] Un-powergate APE partition
[0001.417] of_register: registering tegra_udc to of_hal
[0001.422] of_register: registering inv20628-driver to of_hal
[0001.428] of_register: registering ads1015-driver to of_hal
[0001.433] of_register: registering lp8557-bl-driver to of_hal
[0001.439] of_register: registering bq2419x_charger to of_hal
[0001.445] of_register: registering cpc to of_hal
[0001.449] of_register: registering bq27441_fuel_gauge to of_hal
[0001.469] gpio framework initialized
[0001.472] of_register: registering tca9539_gpio to of_hal
[0001.477] of_register: registering tca9539_gpio to of_hal
[0001.483] of_register: registering i2c_bus_driver to of_hal
[0001.488] of_register: registering i2c_bus_driver to of_hal
[0001.494] of_register: registering i2c_bus_driver to of_hal
[0001.499] pmic framework initialized
[0001.503] of_register: registering max77620_pmic to of_hal
[0001.508] regulator framework initialized
[0001.512] of_register: registering tegra_xhci to of_hal
[0001.517] initializing target
[0001.526] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.538] fixed regulator driver initialized
[0001.609] initializing OF layer
[0001.612] NCK carveout not present
[0001.616] Skipping dts_overrides
[0001.620] of_children_init: Ops found for compatible string nvidia,tegra210-xhci
[0001.628] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.659] I2C Bus Init done
[0001.662] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.676] I2C Bus Init done
[0001.679] of_children_init: Ops found for compatible string ti,tca9539
[0001.693] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0001.699] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.705] of_children_init: Ops found for compatible string ti,tca9539
[0001.719] tca9539_init: i2c bus: 2, slave addr: 0xee
[0001.725] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.731] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.746] I2C Bus Init done
[0001.749] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.764] I2C Bus Init done
[0001.767] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.782] I2C Bus Init done
[0001.784] of_children_init: Ops found for compatible string maxim,max77620
[0001.800] max77620_init using irq 118
[0001.805] register 'maxim,max77620' pmic
[0001.809] gpio_driver_register: register 'max77620-gpio' driver
[0001.815] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.830] I2C Bus Init done
[0001.835] NCK carveout not present
[0001.839] shim_invoke: No NCT, Calling dts updates
[0001.859] Find /i2c@7000c000's alias i2c0
[0001.863] get eeprom at 1-a2, size 256, type 0
[0001.868] get eeprom at 1-ae, size 256, type 0
[0001.883] Find /i2c@7000c400's alias i2c1
[0001.887] get eeprom at 2-a0, size 256, type 0
[0001.902] Find /i2c@7000c500's alias i2c2
[0001.906] get eeprom at 3-a0, size 256, type 0
[0001.911] get eeprom at 3-ae, size 256, type 0
[0001.922] Find /host1x/i2c@546c0000's alias i2c6
[0001.927] get eeprom at 7-a8, size 256, type 0
[0001.931] pm_ids_update: Updating 1,a2, size 256, type 0
[0001.936] I2C slave not started
[0001.939] I2C write failed
[0001.942] Writing offset failed
[0001.945] eeprom_init: EEPROM read failed
[0001.949] pm_ids_update: eeprom init failed
[0001.953] pm_ids_update: Updating 1,ae, size 256, type 0
[0001.958] I2C slave not started
[0001.961] I2C write failed
[0001.964] Writing offset failed
[0001.967] eeprom_init: EEPROM read failed
[0001.971] pm_ids_update: eeprom init failed
[0001.975] pm_ids_update: Updating 2,a0, size 256, type 0
[0001.980] I2C slave not started
[0001.984] I2C write failed
[0001.986] Writing offset failed
[0001.989] eeprom_init: EEPROM read failed
[0001.993] pm_ids_update: eeprom init failed
[0001.997] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.027] pm_ids_update: The pm board id is 2180-1000-400
[0002.036] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[0002.047] pm_ids_update: pm id update successful
[0002.051] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.081] pm_ids_update: The pm board id is 2597-0000-500
[0002.089] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0002.098] pm_ids_update: pm id update successful
[0002.102] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.110] I2C slave not started
[0002.113] I2C write failed
[0002.115] Writing offset failed
[0002.118] eeprom_init: EEPROM read failed
[0002.122] pm_ids_update: eeprom init failed
[0002.156] updating /chosen/nvidia,wifi-mac node 00:04:4b:79:3f:34
[0002.165] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:79:3f:35
[0002.175] updating /chosen/nvidia,ethernet-mac node 00:04:4b:79:3f:36
[0002.181] Plugin Manager: Parse ODM data 0x00084000
[0002.216] Find /i2c@7000c000's alias i2c0
[0002.220] get eeprom at 1-a2, size 256, type 0
[0002.225] get eeprom at 1-ae, size 256, type 0
[0002.240] Find /i2c@7000c400's alias i2c1
[0002.244] get eeprom at 2-a0, size 256, type 0
[0002.259] Find /i2c@7000c500's alias i2c2
[0002.263] get eeprom at 3-a0, size 256, type 0
[0002.268] get eeprom at 3-ae, size 256, type 0
[0002.279] Find /host1x/i2c@546c0000's alias i2c6
[0002.284] get eeprom at 7-a8, size 256, type 0
[0002.288] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.293] I2C slave not started
[0002.296] I2C write failed
[0002.299] Writing offset failed
[0002.302] eeprom_init: EEPROM read failed
[0002.306] pm_ids_update: eeprom init failed
[0002.310] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.315] I2C slave not started
[0002.318] I2C write failed
[0002.321] Writing offset failed
[0002.324] eeprom_init: EEPROM read failed
[0002.328] pm_ids_update: eeprom init failed
[0002.332] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.337] I2C slave not started
[0002.340] I2C write failed
[0002.343] Writing offset failed
[0002.346] eeprom_init: EEPROM read failed
[0002.350] pm_ids_update: eeprom init failed
[0002.354] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.384] pm_ids_update: The pm board id is 2180-1000-400
[0002.392] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[0002.399] pm_ids_update: pm id update successful
[0002.403] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.434] pm_ids_update: The pm board id is 2597-0000-500
[0002.441] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0002.448] pm_ids_update: pm id update successful
[0002.453] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.460] I2C slave not started
[0002.463] I2C write failed
[0002.466] Writing offset failed
[0002.469] eeprom_init: EEPROM read failed
[0002.473] pm_ids_update: eeprom init failed
[0002.507] Chip UID is 000000016411c7080c00000009068280
[0002.514] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03244161395170808206 androidboot.security=non-secure
[0002.538] Add serial number:03244161395170808206 as DT property
[0002.546] calling apps_init()
[0002.550] Found 18 GPT partitions in "sdmmc3_user"
[0002.555] Proceeding to Cold Boot
[0002.558] starting app android_boot_app
[0002.562] Device state: unlocked
[0002.565] display console init
[0002.571] skip-display-init in bootloader
[0002.574] set_instance_and_out_type: invalid out_type
[0002.579] display_console_init: No display init
[0002.590] Gpio keyboard init success
[0002.593] bct_init bctinit
[0002.596] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.604] BMP partition read failed!
[0002.607] blob_init: blob-partition BMP header reDT entry for leds-pwm not found
a[0002.623] d failed
[0002.624] load_bmp_blob: BMP blob initialization failed
[0002.630] Could not load/initialize BMP blob...ignoring
[0002.635] bl_battery_charging: connected to external power supply
[0002.646] fastboot: usb cable is not connected
[0002.651] display_console_ioctl: No display init
[0002.655] switch_backlight failed
[0002.658] bct_init bctinit
[0002.661] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.669] MSC Partition not found
[0002.672] bct_init bctinit
[0002.675] bct_init bctinit
[0002.678] blob_init: USP partition does not have valid Blob
[0002.684] Loading android kernel
[0002.688] Default: NOT skip verified boot.
[0002.692] Verified boot state = Orange
[0002.698] display_console_clear: No display init
[0002.702] kernel load address: 0x80080000, size: 503741 bytes
[0002.708] ramdisk load address: 0x84100000, size: 0 bytes
[0002.714] load kernel from storage
[0002.718] decompressor handler not found
[0002.728] Successfully loaded kernel and ramdisk images
[0002.736] bct_init bctinit
[0002.739] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.746] BMP partition read failed!
[0002.750] blob_init: blob-partition BMP header read failed
[0002.755] load_bmp_blob: BMP blob initialization failed
[0002.760] bmp blob is not loaded and initialized
[0002.765] Failed to display boot-logo
[0002.768] NCK carveout not present
[0002.772] Skipping dts_overrides
[0002.775] NCK carveout not present
[0002.778] shim_invoke: No NCT, Calling dts updates
[0002.801] Find /i2c@7000c000's alias i2c0
[0002.805] get eeprom at 1-a2, size 256, type 0
[0002.809] get eeprom at 1-ae, size 256, type 0
[0002.825] Find /i2c@7000c400's alias i2c1
[0002.829] get eeprom at 2-a0, size 256, type 0
[0002.845] Find /i2c@7000c500's alias i2c2
[0002.849] get eeprom at 3-a0, size 256, type 0
[0002.854] get eeprom at 3-ae, size 256, type 0
[0002.866] Find /host1x/i2c@546c0000's alias i2c6
[0002.870] get eeprom at 7-a8, size 256, type 0
[0002.875] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.880] I2C slave not started
[0002.883] I2C write failed
[0002.886] Writing offset failed
[0002.889] eeprom_init: EEPROM read failed
[0002.892] pm_ids_update: eeprom init failed
[0002.897] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.902] I2C slave not started
[0002.905] I2C write failed
[0002.908] Writing offset failed
[0002.911] eeprom_init: EEPROM read failed
[0002.914] pm_ids_update: eeprom init failed
[0002.919] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.924] I2C slave not started
[0002.927] I2C write failed
[0002.930] Writing offset failed
[0002.933] eeprom_init: EEPROM read failed
[0002.937] pm_ids_update: eeprom init failed
[0002.941] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.971] pm_ids_update: The pm board id is 2180-1000-400
[0002.980] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[0002.990] pm_ids_update: pm id update successful
[0002.994] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.024] pm_ids_update: The pm board id is 2597-0000-500
[0003.032] Adding plugin-manager/ids/2597-0000-500=/i2c@7000c500:module@0x57
[0003.041] pm_ids_update: pm id update successful
[0003.046] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.053] I2C slave not started
[0003.056] I2C write failed
[0003.059] Writing offset failed
[0003.062] eeprom_init: EEPROM read failed
[0003.066] pm_ids_update: eeprom init failed
[0003.100] updating /chosen/nvidia,wifi-mac node 00:04:4b:79:3f:34
[0003.109] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:79:3f:35
[0003.118] updating /chosen/nvidia,ethernet-mac node 00:04:4b:79:3f:36
[0003.125] Plugin Manager: Parse ODM data 0x00084000
[0003.146] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03244161395170808206 androidboot.security=non-secure
[0003.170] Add serial number:03244161395170808206 as DT property
[0003.178] Updated bpmp info to DTB
[0003.185] Updated initrd info to DTB
[0003.188] "proc-board" doesn't exist, creating
[0003.196] Updated board info to DTB
[0003.199] "pmu-board" doesn't exist, creating
[0003.207] Updated board info to DTB
[0003.210] "display-board" doesn't exist, creating
[0003.217] Updated board info to DTB
[0003.220] "reset" doesn't exist, creating
[0003.225] Updated reset info to DTB
[0003.228] display_console_ioctl: No display init
[0003.233] display_console_ioctl: No display init
[0003.237] display_console_ioctl: No display init
[0003.244] display_console_ioctl: No display init
[0003.252] Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03244161395170808206 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange
[0003.325] Updated bootarg info to DTB
[0003.331] Updated memory info to DTB
[0003.341] set vdd_core voltage to 1075 mv
[0003.345] setting 'vdd-core' regulator to 1075000 micro volts
[0003.350] nvdumper Carveout: Base = 0xff23f000 and Size = 0x80000
[0003.357] bct_init bctinit
[0003.360] Starting Bpmp FW
[0003.363] BPMP-FW Carveout: Base = 0xff2c0000 and Size = 0x40000
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:37:03 -0700)
TEGRA210
Model: NVIDIA P2371-2180
Board: NVIDIA P2371-2180
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
223 bytes read in 78 ms (2 KiB/s)
p2371-2180 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
0 bytes read in 68 ms (0 Bytes/s)
Retrieving file: /boot/Image
20984368 bytes read in 527 ms (38 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03244161395170808206 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831aee90
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-1576) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:41:06 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03244161395170808206 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372572K/4173824K available (11009K kernel code, 1816K rwdata, 6352K rodata, 1208K init, 644K bss, 96740K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001175000 - 0xffffffc0012a3000 ( 1208 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001174c04 ( 17364 KB)
[ 0.000000] .data : 0xffffffc0012bd000 - 0xffffffc001483230 ( 1817 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001698] Console: colour dummy device 80x25
[ 0.002568] console [tty0] enabled
[ 0.002600] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002636] pid_max: default: 32768 minimum: 301
[ 0.002725] Security Framework initialized
[ 0.002745] SELinux: Initializing.
[ 0.002856] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002881] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003552] Initializing cgroup subsys freezer
[ 0.003581] Initializing cgroup subsys debug
[ 0.003848] CPU0 ipc=1024
[ 0.003884] CPU1 ipc=1024
[ 0.003915] CPU2 ipc=1024
[ 0.003946] CPU3 ipc=1024
[ 0.004014] ASID allocator initialised with 65536 entries
[ 0.026952] tegra-id: chipid=22117.
[ 0.026981] tegra-id: opt_subrevision=0.
[ 0.027012] Tegra Speedo/IDDQ fuse revision 4
[ 0.027032] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.027052] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.027073] Tegra: CPU Speedo Value 2051, SoC Speedo Value 1975, GPU Speedo Value 2071
[ 0.027101] Tegra: CPU IDDQ Value 1856, SoC IDDQ Value 2232, GPU IDDQ Value 2745
[ 0.027143] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 1
[ 0.028533] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.028582] DTB Build time: Jul 20 2017 00:41:47
[ 0.044789] CPU1: Booted secondary processor [411fd071]
[ 0.056755] CPU2: Booted secondary processor [411fd071]
[ 0.068759] CPU3: Booted secondary pro[0000.140] [TegraBoot] (version 24.00.2015.42-mobile-ec3b827e)
[0000.146] Processing in cold boot mode Bootloader 2
[0000.150] A02 Bootrom Patch rev = 255
[0000.154] Power-up reason: on button
[0000.157] No Battery Present
[0000.160] RamCode = 0
[0000.162] Platform has Ddr4 type ram
[0000.165] max77620 disabling SD1 Remote Sense
[0000.170] Setting Ddr voltage to 1125mv
[0000.174] Serial Number of Pmic Max77663: 0xa09c1
[0000.181] Entering ramdump check
[0000.184] Get RamDumpCarveOut = 0x0
[0000.187] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.193] Last reboot was clean, booting normally!
[0000.197] Sdram initialization is successful
[0000.201] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.207] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.212] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.217] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.227] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.232] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.238] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.253] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.258] Platform-DebugCarveout: 0
[0000.262] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.267] Non secure mode. Disable rollback prevention
[0000.272] AOTAG Init Done
[0000.309] Using GPT Primary to query partitions
[0000.315] Loading Tboot-CPU binary
[0000.364] Verifying bootloader in OdmNonSecureSBK mode
[0000.373] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.380] Bootloader downloaded successfully.
[0000.385] Downloaded Tboot-CPU binary to 0xa0000258
[0000.390] MAX77620_GPIO1 Configured.
[0000.393] MAX77620_GPIO5 Configured.
[0000.397] CPU power rail is up
[0000.399] CPU clock enabled
[0000.403] Performing RAM repair
[0000.406] Updating A64 Warmreset Address to 0xa00002e9
[0000.423] Bootloader DTB Load Address: 0x83000000
[0000.440] Kernel DTB Load Address: 0x83080000
[0000.445] Loading cboot binary
[0000.539] Verifying bootloader in OdmNonSecureSBK mode
[0000.633] Bootloader load address is 0x8010fda8, entry address is 0x80110000
[0000.640] Bootloader downloaded successfully.
[0000.644] GPT: Partition NOT found !
[0000.648] Find Partition via GPT Failed
[0000.651] Find Partition via PT Failed
[0000.655] function NvTbootGetBinaryOffsets: 0x1 error
[0000.660] Error in NvTbootLoadBinary: 0x1 !
[0000.664] Next binary entry address: 0x80110000
[0000.668] BoardId: 2180
[0000.694] NvTbootI2cProbe(): error code 0x00045100 Error while read
[0000.700] Display board id is not available
[0000.705] dram memory type is 3
[0000.708] WB0 init successful
[0000.734] Bpmp FW successfully loaded
[0000.738] Set NvDecSticky Bits
[0000.741] GSC1 address : ff700000
[0000.745] GSC2 address ff63fffc value c0edbbcc
[0000.749] GSC2 address : ff600000
[0000.753] GSC3 address : ff500000
[0000.757] GSC4 address : ff400000
[0000.760] GSC5 address : ff300000
[0000.764] GSC MC Settings done
[0000.767] TOS old plaintext Image length 65536
[0000.774] *** Secure OS image signature not verified ***
[0000.779] Loading and Validation of Secure OS Successful
[0000.784] NvTbootPackSdramParams: start.
[0000.789] NvTbootPackSdramParams: done.
[0000.793] Tegraboot started after 119154 us
[0000.797] Basic modules init took 302422 us
[0000.801] Sec Bootdevice Read Time = 194 ms, Read Size = 8464 KB
[0000.806] Sec Bootdevice Write Time = -1940251267 ms, Write Size = 343597383 KB
[0000.814] Next stage binary read took 12267 us
[0000.818] Carveout took 253039 us
[0000.821] CPU initialization took 125209 us
[0000.825] Total time taken by TegraBoot 692937 us
[0000.830] Starting CPU & Halting co-processor
64b[0000.937] RamCode = 0
[0000.952] LPDDR4 Training: Read DT: Number of tables = 10
[0000.957] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0000.963] EMC Training Skipped
[0000.965] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0000.970] EMC Training Skipped
[0000.973] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0000.979] EMC Training Skipped
[0000.981] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0000.987] EMC Training Skipped
[0000.989] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0000.996] EMC Training Successful
[0000.999] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.004] EMC Training Successful
[0001.007] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.019] EMC Training Successful
[0001.022] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.045] EMC Training Successful
[0001.048] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.069] EMC Training Successful
[0001.072] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.092] EMC Training Successful
[0001.095] Switching to 800000 KHz Success
[0001.101] DT Write: emc-table@40800 succeeded
[0001.108] DT Write: emc-table@68000 succeeded
[0001.114] DT Write: emc-table@102000 succeeded
[0001.120] DT Write: emc-table@204000 succeeded
[0001.127] DT Write: emc-table@408000 succeeded
[0001.133] DT Write: emc-table@665600 succeeded
[0001.139] DT Write: emc-table@800000 succeeded
[0001.146] DT Write: emc-table@1065600 succeeded
[0001.152] DT Write: emc-table@1331200 succeeded
[0001.158] DT Write: emc-table@1600000 succeeded
[0001.163] LPDDR4 Training: Write DT: Number of tables = 10
U-Boot 2015.07-rc2-g78c8468 (Nov 09 2016 - 19:39:36 -0800)
TEGRA210
DRAM: 4 GiB
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x0000000012000000-0x0000000012010000
tegra-pcie: non-prefetchable memory: 0x0000000013000000-0x0000000020000000
tegra-pcie: prefetchable memory: 0x0000000020000000-0x0000000040000000
tegra-pcie: 4x1, 1x1 configuration
tegra-pcie: probing port 0, using 4 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
starting USB...
USB0: USB EHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-tegra210
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
Tegra210 (P2371-2180) #
[0000.154] Power-up reason: reset button
[0000.166] max77620 disabling SD1 Remote Sense
[0000.188] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.233] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.259] Platform-DebugCarveout: 0
[0000.374] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.381] Bootloader downloaded successfully.
[0000.400] CPU clock enabled
[0000.645] GPT: Partition NOT found !
[0000.652] Find Partition via PT Failed
[0000.709] WB0 init successful
[0000.735] Bpmp FW successfully loaded
[0000.750] GSC2 address : ff600000
[0000.761] GSC5 address : ff300000
[0000.768] TOS old plaintext Image length 65536
[0000.793] Tegraboot started after 119159 us
[0000.797] Basic modules init took 302712 us
[0000.807] Sec Bootdevice Write Time = -1940251267 ms, Write Size = 343597383 KB
[0000.818] Carveout took 253035 us
[0000.821] CPU initialization took 125208 us
[0000.825] Total time taken by TegraBoot 693222 us
[0000.953] LPDDR4 Training: Read DT: Number of tables = 10
[0000.958] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0000.966] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0000.971] EMC Training Skipped
[0000.974] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0000.982] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0000.990] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.005] EMC Training Successful
[0001.008] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.073] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.121] DT Write: emc-table@204000 succeeded
[0001.140] DT Write: emc-table@800000 succeeded
[0001.159] DT Write: emc-table@1600000 succeeded
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
starting USB...
USB0: USB EHCI 1.10
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
It looks as if there was some bootfile missing. But I’m not too familiarize with the boot log yet.
