Hi vidyas
i use flash.sh to update my dtb. and the result as below
- tegra210-jetson-cv-base-p2597-2180-a00.dts
pinctrl@7009f000 {
status = "okay";
pinctrl-0 = <&tegra_padctl_uphy_pinmux_default>;
pinctrl-names = "default";
tegra_padctl_uphy_pinmux_default: pinmux {
usb2-micro-AB-xusb {
nvidia,lanes = "otg-0";
nvidia,function = "xusb";
nvidia,port-cap =
<TEGRA_PADCTL_PORT_OTG_CAP>;
nvidia,usb3-port-fake = <2>;
usb2-std-A-port0 {
nvidia,lanes = "otg-2";
nvidia,port-cap =
<TEGRA_PADCTL_PORT_HOST_ONLY>;
usb3-std-A-port0 {
nvidia,lanes = "uphy-lane-5";
nvidia,function = "usb3";
nvidia,usb3-port = <1>;
nvidia,usb2-map = <2>;
nvidia,port-cap =
usb2-eth {
nvidia,lanes = "otg-1";
nvidia,port-cap =
usb3-eth {
nvidia,lanes = "uphy-lane-6";
nvidia,usb3-port = <0>;
nvidia,usb2-map = <1>;
nvidia,port-cap =
hsic {
nvidia,lanes = "hsic-0";
nvidia,function = "hsic";
pcie {
nvidia,lanes = "uphy-lane-4";
nvidia,function = "pcie";
nvidia,pcie-controller = <0>;
nvidia,pcie-lane-select =
<TEGRA_PADCTL_PCIE_LANE_X1>;
pcie-m2 {
nvidia,lanes = "uphy-lane-0";
nvidia,pcie-controller = <1>;
sata {
nvidia,lanes = "uphy-lane-7";
nvidia,function = "sata";
e3325-usb2-std-A {
nvidia,lanes = "otg-3";
nvidia,port-cap =
e3325-usb3-std-A {
nvidia,lanes = "uphy-lane-3";
nvidia,usb3-port = <2>;
nvidia,usb2-map = <3>;
nvidia,port-cap =
xusb@70090000 {
status = "okay";
extcon-cables = <&vbus_gpio_extcon 1>;
extcon-cable-names = "id";
#extcon-cells = <1>;
phys = <&tegra_padctl_uphy TEGRA_PADCTL_UPHY_UTMI_P(2)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_USB3_P(1)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_UTMI_P(1)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_USB3_P(0)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_UTMI_P(0)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_UTMI_P(3)>,
<&tegra_padctl_uphy TEGRA_PADCTL_UPHY_USB3_P(2)>;
phy-names = "utmi-2", "usb3-1", "utmi-1", "usb3-0", "utmi-0", "utmi-3", "usb3-2";
nvidia,pmc-wakeup =
<&tegra_pmc
PMC_WAKE_TYPE_EVENT 41 PMC_TRIGGER_TYPE_HIGH>,
<&tegra_pmc
PMC_WAKE_TYPE_EVENT 44 PMC_TRIGGER_TYPE_HIGH>;
- console log
[ 4.739916] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 4.739927] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x71c6c0e
[ 4.739936] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 4.741301] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 4.741311] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 4.741319] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 4.741335] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 4.741352] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 4.741359] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 4.741374] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 4.741389] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 4.741407] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x10
[ 4.741428] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x11
[ 4.741450] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 4.741457] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-3 is used by XUSB
[ 4.741470] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set usb3_lanes = 0x68
[ 4.741484] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 2 maps to USB2 port 3
[ 4.742297] usb-vbus1: supplied by vdd-3v3
[ 4.744921] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 4.747653] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 4.747881] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 4.748595] clk_cbus_round_rate: no gbus parent
[ 4.748602] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 4.748978] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 4.749235] tegra-ahci 70027000.sata: Missing devslp-active state
[ 4.750169] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 4.750374] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 4.750386] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 4.751060] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 4.760050] scsi host0: tegra_ahci
[ 4.764581] scsi host1: tegra_ahci
[ 4.764824] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[ 4.764828] ata2: DUMMY
[ 4.768004] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 4.768180] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.768797] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 4.769179] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.769825] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.771533] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.771964] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 4.772657] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 4.775623] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 4.775625] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 4.779219] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 4.779221] xhci-tegra 70090000.xusb: Falling back to user helper
[ 4.781898] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.823106] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:26:53 UTC (946690013)
[ 4.827357] vi 54080000.vi: vi_probe: ++
[ 4.833286] vi 54080000.vi: initialized
[ 4.835757] vi 54080000.vi: all channel register failed
[ 4.836626] Disable partitions left on by BL
[ 4.836628] disb
[ 4.846128] DRAM derating cdev registered.
[ 4.846951] vdd-cpu-fixed: disabling
[ 4.846961] vdd-cam-hv: disabling
[ 4.847047] avdd-ts-hv: disabling
[ 4.847112] vdd-ts: disabling
[ 4.847177] max77620-gpio7: disabling
[ 4.847339] lcd-bl-en: disabling
[ 4.847343] en-vdd-cam: disabling
[ 4.847346] aux-3v3: disabling
[ 4.847348] snsr_pm: disabling
[ 4.847350] vdd-disp-3v0: disabling
[ 4.847352] vdd-fan: disabling
[ 4.847354] usb-vbus1: disabling
[ 4.847355] en-vdd-ts-1v8: disabling
[ 4.847356] en-vdd-ts-hv-3v3: disabling
[ 4.847358] en-vdd-disp-3v3: disabling
[ 4.847473] en-mdm-pwr-3v7: disabling
[ 4.847474] en-vdd-disp-1v8: disabling
[ 4.847584] en-vdd-cam-hv-2v8: disabling
[ 4.847586] rtl-5v0: disabling
[ 4.847588] en-usb-vbus2: disabling
[ 4.847590] en-vdd-cam-1v2: disabling
[ 4.847591] en-vdd-vcm-2v8: disabling
[ 4.848470] ALSA device list:
[ 4.848473] #0: tegra-hda at 0x70038000 irq 348
[ 4.848474] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.087254] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.170281] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.374592] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 5.384702] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 5.581249] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.772065] EXT4-fs (mmcblk0p1): 13 orphan inodes deleted
[ 5.778080] EXT4-fs (mmcblk0p1): recovery complete
[ 5.790719] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.800042] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.809678] devtmpfs: mounted
[ 5.813633] Freeing unused kernel memory: 1208K (ffffffc001175000 - ffffffc0012a3000)
[ 5.826501] Freeing alternatives memory: 76K (ffffffc0012a3000 - ffffffc0012b6000)
[ 5.891023] systemd[1]: System time before build time, advancing clock.
[ 5.914509] random: systemd: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[ 5.927293] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.948503] systemd[1]: Detected architecture arm64.
[ 5.965074] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.981331] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 5.985488] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 5.985564] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 5.985583] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 5.985702] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 6.002711] random: lvm2-activation: uninitialized urandom read (4 bytes read, 100 bits of entropy available)
[ 6.014213] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[ 6.014331] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[ 6.014441] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[ 6.045223] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.047205] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 6.047392] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 6.047396] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 6.047399] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 6.047402] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.047404] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 6.047668] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.048190] pci 0000:00:02.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 6.048195] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 6.048216] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 6.048221] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 6.048348] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 6.048350] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.299889] systemd[1]: Listening on udev Control Socket.
[ 6.307428] systemd[1]: Listening on Journal Socket.
[ 6.314279] systemd[1]: Created slice System Slice.
[ 6.324934] systemd[1]: Starting Load Kernel Modules...
[ 6.332020] systemd[1]: Listening on udev Kernel Socket.
[ 6.339619] systemd[1]: Listening on Syslog Socket.
[ 6.346385] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.354288] systemd[1]: Created slice system-getty.slice.
[ 6.361601] systemd[1]: Reached target Swap.
[ 6.368560] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.377309] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.386101] systemd[1]: Mounting Debug File System...
[ 6.393226] systemd[1]: Created slice User and Session Slice.
[ 6.401134] systemd[1]: Listening on Journal Audit Socket.
[ 6.409399] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.421652] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.433311] systemd[1]: Starting Journal Service...
[ 6.440308] systemd[1]: Reached target Encrypted Volumes.
[ 6.447796] systemd[1]: Reached target Slices.
[ 6.454341] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.462611] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.470834] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.478619] systemd[1]: Reached target User and Group Name Lookups.
[ 6.487172] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.497804] systemd[1]: Reached target Remote File Systems.
[ 6.506162] systemd[1]: Started Braille Device Support.
[ 6.513863] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.523184] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.538815] systemd[1]: Mounted Debug File System.
[ 6.546577] systemd[1]: Started Load Kernel Modules.
[ 6.554103] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.563373] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 6.588774] systemd[1]: Started LVM2 metadata daemon.
[ 6.597040] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.606794] systemd[1]: Starting Load/Save Random Seed...
[ 6.617307] systemd[1]: Starting udev Coldplug all Devices...
[ 6.626805] systemd[1]: Mounting Configuration File System...
[ 6.635782] systemd[1]: Starting Apply Kernel Variables...
[ 6.644479] systemd[1]: Mounting FUSE Control File System...
[ 6.654192] systemd[1]: Mounted Configuration File System.
[ 6.662019] systemd[1]: Mounted FUSE Control File System.
[ 6.669746] systemd[1]: Started Journal Service.
[ 6.715033] systemd-journald[210]: Received request to flush runtime journal from PID 1
[ 6.899219] random: nonblocking pool is initialized
[ 6.935283] cfg80211: World regulatory domain updated:
[ 6.941258] cfg80211: DFS Master region: unset
[ 6.947183] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.960250] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[ 6.960638] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.960640] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.960642] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.960645] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.960648] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.960651] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.960653] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.960655] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.179056] dhd_module_init in
[ 7.185066] found wifi platform device bcmdhd_wlan
[ 7.194475] Power-up adapter 'DHD generic adapter'
[ 7.201335] wifi_platform_set_power = 1
[ 7.407219] wifi_platform_bus_enumerate device present 1
[ 7.423470] wifi_platform_bus_enumerate device present 0
[ 7.423890] F1 signature read @0x18000000=0x17214354
[ 7.439551] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.448141] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.457112] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.464875] wifi_platform_get_mac_addr
[ 7.471759] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.496710] wl_create_event_handler(): thread:wl_event_handler:1c0 started
[ 7.504786] CFG80211-ERROR) wl_event_handler : [ 7.504930] dhd_attach(): thread:dhd_watchdog_thread:1c2 started
[ 7.504959] dhd_attach(): thread:dhd_dpc:1c3 started
[ 7.504990] dhd_attach(): thread:dhd_rxf:1c4 started
[ 7.504995] dhd_deferred_work_init: work queue initialized
[ 7.505212] Dongle Host Driver, version 1.201.82 (r)
[ 7.505212] Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:39:01
[ 7.505522] tegra_sysfs_register
[ 7.505553] Register interface [wlan0] MAC: 00:04:4b:8f:c0:c5
[ 7.505553]
[ 7.505556] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.505645] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 46
[ 7.506680] wifi_platform_set_power = 0
[ 7.589262] tsk Enter, tsk = 0xffffffc07a7a1a70
[ 7.918459] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.925362]
[ 7.925362] Dongle Host Driver, version 1.201.82 (r)
[ 7.925362] Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:39:01
[ 7.944093] wl_android_wifi_on in
[ 7.948437] wifi_platform_set_power = 1
[ 7.960992] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 7.974363] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.974383] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 7.975276] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 7.975304] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 7.975430] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.975433] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.975436] usb usb1: Product: xHCI Host Controller
[ 7.975438] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.975440] usb usb1: SerialNumber: 70090000.xusb
[ 7.976015] hub 1-0:1.0: USB hub found
[ 7.976148] hub 1-0:1.0: 5 ports detected
[ 7.991256] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.991266] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 7.991462] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.991465] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.991468] usb usb2: Product: xHCI Host Controller
[ 7.991470] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.991472] usb usb2: SerialNumber: 70090000.xusb
[ 7.992076] hub 2-0:1.0: USB hub found
[ 7.992212] hub 2-0:1.0: 4 ports detected
[ 8.226895] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 8.287226] usb 1-4: new full-speed USB device number 2 using xhci-tegra
[ 8.303966] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.314383] usb 1-4: feature bit otg_vbus_off set
[ 8.319877] usb 1-4: New USB device found, idVendor=8087, idProduct=07dc
[ 8.327475] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.337115] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.345207] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 8.353248] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 8.361332] usb 2-1: Product: USB 10/100/1000 LAN
[ 8.366953] usb 2-1: Manufacturer: Nvidia
[ 8.372334] usb 2-1: SerialNumber: 000001000000
[ 8.380763] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.397583] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 46
[ 8.408352] F1 signature read @0x18000000=0x17214354
[ 8.419330] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.426308] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.486905] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 8.500061] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 8.535860] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 8.542459] wifi_platform_get_mac_addr
[ 8.547667] Firmware up: op_mode=0x0005, MAC=00:04:4b:8f:c0:c5
[ 8.559420] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 8.571244] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[ 8.583170] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 8.589704] tegra_sysfs_on
[ 8.652735] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 8.662739] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
[ 8.662739] US6,570,884, US6,115,776, and US6,327,625.
[ 8.662739]
[ 8.763417] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Ubuntu 16.04 LTS tegra-ubuntu ttyS0
nvidia@tegra-ubuntu:~$
nvidia@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
|__ Port 2: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
|__ Port 3: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/5p, 480M
|__ Port 4: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Wireless, Driver=, 12M
|__ Port 2: Dev 3, If 1, Class=Wireless, Driver=, 12M
nvidia@tegra-ubuntu:~$ lspci
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01)
i can see the usb storage from lane3 and lane5 but the lane4 pcie port is fail to bring up.
how to fix this issue?
R28.1 can support config 4 ?
