Random log error: gdm-x-session[1434]: (--) NVIDIA(GPU-0): DFP-0: disconnected..
I keep getting the following error in my log at random times.
Mostly every 5-30min
I’m running a GTX 1080ti on an Asus ROG PQ278QR Monitor @144Hz
NVIDIA Driver Version: 430.40
Linux 5.2.21-1-MANJARO
Gnome Version 3.34.1
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-0: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-1: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-2: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-3: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-4: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): AUS ROG PG278QR (DFP-5): connected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): AUS ROG PG278QR (DFP-5): Internal DisplayPort
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): AUS ROG PG278QR (DFP-5): 1440.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): AUS ROG PG278QR (DFP-5): supports NVIDIA 3D Vision stereo.
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-6: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-7: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-7: 1440.0 MHz maximum pixel clock
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-8: disconnected
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-8: Internal TMDS
/usr/lib/gdm-x-session[1434]: (–) NVIDIA(GPU-0): DFP-8: 165.0 MHz maximum pixel clock
That’s no error, this always logged when something queries displays/resolutions, e.g. by calling xrandr. Do you have any Gnome-Shell plugin enabled handling displays?
Not as far at I can tell.
I have the following extensions:
Arc menu
Dash to dock
Kstatusnotifieritem
Pacman updates indicator
Removable drive menu
User themes
I had the same issue, but it was logged every second on my machine. So I told my rsyslog (on ubuntu) to ignore those messages:
$ cat /etc/rsyslog.d/40-gdm-x-session.conf
# Stop messages that contain "NVIDIA"
:rawmsg, contains, "NVIDIA" stop
This is quick and dirty, there is probably a better way to do this.
I have same issue, my environment is ubuntu20.04+ v535, high performance mode,
the logging make syslog getting huge
