Hey guys I am have bee having some driver stability issues for a while and made a post on Manjaros forum about it asking if anyone else has been having issues here: Gnome Stability issues/GDM Disconnecting behaviour on my Asus ROG Strix - Support - Manjaro Linux Forum at the 9th January 2024
I have a ROG Strix G512 gaming laptop with a GTX 1660TI running Manjaro Gnome and currently have the 545.29.06 driver installed, ever since one of the updates my whole UI and OS will freeze up and in the logs to mentions the gpu disconnecting in xorg
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): EDID vendor "CMN", prod id 5409
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): Using hsync ranges from config file
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): Using vrefresh ranges from config file
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): Printing DDC gathered Modelines:
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): Modeline "1920x1080"x0.0 342.06 1920 1968 2000 2080 1080 1090 1095 1142 -hsync -vsync (164.5 kHz eP)
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (II) modeset(0): Modeline "1920x1080"x0.0 142.53 1920 1968 2000 2080 1080 1090 1095 1142 -hsync -vsync (68.5 kHz e)
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Jan 08 23:46:51 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
Jan 08 23:46:52 corey-rogstrixg512lug512lu /usr/lib/gdm-x-session[1420]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
Jan 08 23:46:53 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5641eb8d34e0] is on because it needs an allocation.
Jan 08 23:46:53 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5641ec3ebc00] is on because it needs an allocation.
Jan 08 23:46:53 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5641e7d0bcd0] is on because it needs an allocation.
Jan 08 23:46:53 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5641ea2edad0] is on because it needs an allocation.
Jan 08 23:46:53 corey-rogstrixg512lug512lu gnome-shell[1524]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x3e0000a
Jan 08 23:46:53 corey-rogstrixg512lug512lu rtkit-daemon[1129]: Successfully made thread 160249 of process 160226 owned by '1000' high priority at nice level -15.
Jan 08 23:46:53 corey-rogstrixg512lug512lu rtkit-daemon[1129]: Supervising 7 threads of 4 processes of 1 users.
Jan 08 23:47:00 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5641e7d0bcd0] is on because it needs an allocation.
Jan 08 23:47:00 corey-rogstrixg512lug512lu gnome-shell[1524]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5641ea2edad0] is on because it needs an allocation.
Jan 08 23:47:04 corey-rogstrixg512lug512lu gnome-shell[1524]: invalid (NULL) pointer instance
