I am trying to use the CSI camera Raspberry Pi v.2.1 with the newest Jetson Nano SD Image JP 4.2.2.
If I use python to open the gstreamer pipeline it shows the image.
If I use C++ to open the gstreamer I get following error, altough I am using th exact same gstreamer pipeline.
Does anyone one know why? I believe Python is just a wrapper for underlying C++ libs that have been compiled with OpenCV ++. Using precompiled OpenCV from the SD Image.
C++ Code
std:string pipeline = "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink";
cv::VideoCapture capture(pipeline, cv::CAP_GSTREAMER);
C++ Error Output
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
Unable to stop the stream: Device or resource busy
(Face1:8669): GLib-GObject-WARNING **: 20:01:11.862: cannot register existing type 'GstInterpolationMethod'
(Face1:8669): GLib-GObject-CRITICAL **: 20:01:11.863: g_param_spec_enum: assertion 'G_TYPE_IS_ENUM (enum_type)' failed
(Face1:8669): GLib-GObject-CRITICAL **: 20:01:11.863: validate_pspec_to_install: assertion 'G_IS_PARAM_SPEC (pspec)' failed
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 887
VIDEOIO(cvCreateCapture_GStreamer(CV_CAP_GSTREAMER_V4L2, reinterpret_cast<char *>(index))): raised OpenCV exception:
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:887: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=13608000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Failed to open camera.
GST_ARGUS:
PowerServiceHwVic::cleanupResources
Process finished with exit code 255
Python Code
import sys
import cv2
def read_cam():
cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
if cap.isOpened():
cv2.namedWindow("demo", cv2.WINDOW_AUTOSIZE)
while True:
ret_val, img = cap.read();
cv2.imshow('demo',img)
cv2.waitKey(10)
else:
print "camera open failed"
cv2.destroyAllWindows()
if __name__ == '__main__':
read_cam()
