Pls check MAC is right, and if go through switch see MTU match.
MAC is correct on server side. No switch, direct peer to peer connection via optics cable. SFP28 transceiver is used.
Available MAC addresses for server:
enp33s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 20.4.3.220 netmask 255.255.255.0 broadcast 20.4.3.255
inet6 fe80::7228:63dd:1b93:ae80 prefixlen 64 scopeid 0x20<link>
ether 08:c0:eb:cb:93:52 txqueuelen 1000 (Ethernet)
RX packets 1811 bytes 109550 (109.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 85 bytes 8994 (8.9 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp33s0f1np1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 08:c0:eb:cb:93:53 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
Available MAC addresses for client:
enp6s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 20.4.3.219 netmask 255.255.255.0 broadcast 20.4.3.255
inet6 fe80::83fa:cf69:55a5:5cfa prefixlen 64 scopeid 0x20<link>
ether 08:c0:eb:cb:93:82 txqueuelen 1000 (Ethernet)
RX packets 73 bytes 7942 (7.9 KB)
TX packets 1918 bytes 118122 (118.1 KB)
enp6s0f1np1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 08:c0:eb:cb:93:83 txqueuelen 1000 (Ethernet)
gids of server:
$ show_gids
DEV PORT INDEX GID IPv4 VER DEV
mlx5_0 1 0 fe80:0000:0000:0000:0ac0:ebff:fecb:9352 v1 enp33s0f0np0
mlx5_0 1 1 fe80:0000:0000:0000:0ac0:ebff:fecb:9352 v2 enp33s0f0np0
mlx5_0 1 2 fe80:0000:0000:0000:7228:63dd:1b93:ae80 v1 enp33s0f0np0
mlx5_0 1 3 fe80:0000:0000:0000:7228:63dd:1b93:ae80 v2 enp33s0f0np0
mlx5_0 1 4 0000:0000:0000:0000:0000:ffff:1404:03dc 20.4.3.220 v1 enp33s0f0np0
mlx5_0 1 5 0000:0000:0000:0000:0000:ffff:1404:03dc 20.4.3.220 v2 enp33s0f0np0
mlx5_1 1 0 fe80:0000:0000:0000:0ac0:ebff:fecb:9353 v1 enp33s0f1np1
mlx5_1 1 1 fe80:0000:0000:0000:0ac0:ebff:fecb:9353 v2 enp33s0f1np1
n_gids_found=8
gids of client:
$ show_gids
mlx5_0 1 0 fe80:0000:0000:0000:0ac0:ebff:fecb:9382 v1 enp6s0f0np0
mlx5_0 1 1 fe80:0000:0000:0000:0ac0:ebff:fecb:9382 v2 enp6s0f0np0
mlx5_0 1 2 fe80:0000:0000:0000:83fa:cf69:55a5:5cfa v1 enp6s0f0np0
mlx5_0 1 3 fe80:0000:0000:0000:83fa:cf69:55a5:5cfa v2 enp6s0f0np0
mlx5_0 1 4 0000:0000:0000:0000:0000:ffff:1404:03db 20.4.3.219 v1 enp6s0f0np0
mlx5_0 1 5 0000:0000:0000:0000:0000:ffff:1404:03db 20.4.3.219 v2 enp6s0f0np0
mlx5_1 1 0 fe80:0000:0000:0000:0ac0:ebff:fecb:9383 v1 enp6s0f1np1
mlx5_1 1 1 fe80:0000:0000:0000:0ac0:ebff:fecb:9383 v2 enp6s0f1np1
n_gids_found=8
ping test from server:
$ ping -c 1 -I 20.4.3.220 20.4.3.219
PING 20.4.3.219 (20.4.3.219) from 20.4.3.220 : 56(84) bytes of data.
64 bytes from 20.4.3.219: icmp_seq=1 ttl=64 time=0.383 ms
--- 20.4.3.219 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.383/0.383/0.383/0.000 ms
ping test from client:
$ ping -c 1 -I 20.4.3.219 20.4.3.220
PING 20.4.3.220 (20.4.3.220) from 20.4.3.219 : 56(84) bytes of data.
64 bytes from 20.4.3.220: icmp_seq=1 ttl=64 time=0.788 ms
--- 20.4.3.220 ping statistics ---
rtt min/avg/max/mdev = 0.788/0.788/0.788/0.000 ms
mst status from server:
$ sudo mst status -v
MST modules:
MST PCI module is not loaded
MST PCI configuration module loaded
PCI devices:
DEVICE_TYPE MST PCI RDMA NET NUMA
ConnectX4LX(rev:0) /dev/mst/mt4117_pciconf0.1 21:00.1 mlx5_1 net-enp33s0f1np1 -1
ConnectX4LX(rev:0) /dev/mst/mt4117_pciconf0 21:00.0 mlx5_0 net-enp33s0f0np0 -1
mst status from client:
MST modules:
PCI devices:
ConnectX4LX(rev:0) /dev/mst/mt4117_pciconf0.1 06:00.1 mlx5_1 net-enp6s0f1np1 -1
ConnectX4LX(rev:0) /dev/mst/mt4117_pciconf0 06:00.0 mlx5_0 net-enp6s0f0np0 -1
