hello ManuelLeiva,
we’re under investigate for the ISP pipeline,
could you please share the raw file again with standard resolution (720p, 1080p, or 4K).
or, a tool which can downsize to the standard resolution as well is fine.
thanks
hello ManuelLeiva,
thanks
Hi JerryChang,
do you have any news?
hello d.kristofic,
unfortunately, we don’t support RAW8 input for nvcamerasrc. there’s still no short-term plans to support this.
it might be helpful to push our internal investigation if you could share the raw files as I mentioned in comment #21.
thanks
hi JerryChang,
you can download raw dump of 1080p taken with:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG8 --stream-mmap --stream-count=150 -d /dev/video0 --stream-to=test.raw
thanks
