I’m having problems running the following program (read.for):
PROGRAM READ_ERROR
CHARACTER BUF*1000
INTEGER IO, NSTART, NEND, NCHAR
DIMENSION ISTAT(12)
OPEN(10, FILE=‘./test.run’, FORM=‘UNFORMATTED’, IOSTAT=IO,
1 ACCESS=‘SEQUENTIAL’, ACTION=‘READ’)
IO = FSTAT(10, ISTAT)
NCHAR = ISTAT(8)
NSTART = 1
NEND = NSTART+NCHAR-1
READ(10, IOSTAT=IO) BUF(NSTART:NEND)
CLOSE(10)
STOP
END
on a test.run file containing:
012345678910
and compiled with
pgf95 -g read.for -o read
After the READ statement, IO is -1 and BUF(NSTART:NSTART) is ‘3’. In other words the first three bytes ‘012’ are skipped.
Any ideas why the program would skip the first three bytes of the read?
Thanks,
Brian
I included an error in the previous explanation. The test.run file had a newline before the numbers started. Removing the newline causes buf(1:1) to contain ‘4’, which means that the read is skipping the first 4 bytes.
My apologies,
Brian
Hi Brain,
You need to use formatted I/O since “test.run” is a text file. Unformatted I/O is record based and the first 4 bytes of the line tells the record size.
For example:
% cat read.f90
PROGRAM READ_ERROR
CHARACTER BUF*1000
DIMENSION ISTAT(12)
OPEN(10, FILE='./test.run', FORM='FORMATTED', IOSTAT=IO, &
ACCESS='SEQUENTIAL', ACTION='READ')
NCHAR = ISTAT(8)
NSTART = 1
READ(10,IOSTAT=IO,*) BUF(NSTART:NEND)
CLOSE(10)
write(*,*) BUF(NSTART:NEND)
STOP
END
% pgf90 read.f90
% a.out
012345678910
FORTRAN STOP
Hope this helps,
Mat
When I change the ACCESS to ‘STREAM’ it starts reading at the first byte. I apologize to anyone whose time I’ve taken up with this question. I clearly could have read some documentation from somewhere.
