i have a need to read from i2c in cboot. Right now I have a temp sensor hooked up to the 40pin header and it works fine
root@jetson-xavier-nx-devkit:~# i2cget -y 1 0x48 0x01 w
0x0100
I’d like to do the same in cboot and here is my test code
struct tegrabl_i2c_dev *hi2c2 =
tegrabl_i2c_dev_open(TEGRABL_INSTANCE_I2C2, 0x48, 1, 2);
if (!hi2c2)
pr_info("CBOOT invalid i2c2 handle\n");
else
pr_info("CBOOT valid i2c2 handle\n");
err = tegrabl_i2c_dev_read(hi2c2, buf, 1, 1);
if (err != TEGRABL_NO_ERROR)
pr_info("CBOOT i2c2 error\n");
else
pr_info("CBOOT 0x%02x 0x%02x\n", buf[0], buf[1]);
pr_info("CBOOT done\n");
Unfortunately for some reason it seems to want to do a write, which I don’t understand, and the read also fails
[0004.301] I> CBOOT i2c ...
[0004.301] I> CBOOT valid i2c2 handle
[0004.302] E> I2C: slave not found in slaves.
[0004.302] E> I2C: Could not write 0 bytes to slave: 0x0048 with repeat start tr
ue.
[0004.303] E> I2C_DEV: Failed to send register address 0x00000001.
[0004.304] E> I2C_DEV: Could not read 1 registers of size 2 from slave 0x48 at 0
x00000001 via instance 1.
[0004.309] I> CBOOT i2c2 error
[0004.312] I> CBOOT done
Does anyone see anything obviously wrong with my code?
