hello urielom8ug,
we don’t support disable the recovery mode. please also check Topic 64984 for reference.
moreover, if you’d enable secureboot, the RCM code will be signed.
hello urielom8ug,
| Ways to prevent data accessing in the recovery mode | 6 | 816 | May 18, 2021 | |
| Secure OS / Rootfs Encryption | 5 | 2632 | December 11, 2018 | |
| How to verify that secure boot with kernel encryption and disc encryption is enabled in Jetson TX2? | 18 | 1701 | September 13, 2023 | |
| Disabling flash rear/write in recovery mode | 7 | 742 | July 12, 2020 | |
| Securing data access | 4 | 923 | February 7, 2021 | |
| Data encryption using secure boot and odm_reserved fuse in Jetson Nano | 10 | 3271 | August 12, 2021 | |
| Disk Encryption on TX2 | 3 | 1502 | March 29, 2021 | |
| Not able to use LUKS Disk Encryption on Jetson NX | 1 | 1071 | February 8, 2021 | |
| Disk encryption key in EKS partition | 12 | 514 | December 13, 2024 | |
| How Can I Encrypt Rootfs with SD Boot? | 2 | 755 | April 9, 2021 |
