Record nvdsanalytics results into MariaDB
Hi there! I’m testing “deepstream-nvdsanalytics-test” with DeepStream 6.0 on Jetson Nano.
Is it possible to write nvdsanalytics results into MariaDB ?
Thanks for your help.
yes, you can write the analysis results to DB, please refer to sample opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-nvdsanalytics-test, it will show how to get the analysis results.
I have read the code but I didn’t see any code to write results into MariaDB.
Can you point the file source and lines please?
Thanks again
I mean you can do your custom processing after getting analysis results, there is no code to write results into MariaDB.
