Hardware - GPU (A100/A30/T4/V100)
**Tesla T4
Hardware - CPU
**I’m using an AWS EC2 instance type of g4dn.xlarge
Operating System
**Amazon Linux 2
Riva Version
**Riva 1.8, using riva_quickstart_v1.8.0-beta
TLT Version (if relevant)
Just for completeness, nvidia-smi gave me this:
| NVIDIA-SMI 495.29.05 Driver Version: 495.29.05 CUDA Version: 11.5 |
| | | MIG M. |
| 0 Tesla T4 Off | 00000000:00:1E.0 Off | 0 |
| N/A 38C P0 26W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
I’m trying to recreate the QuickStart Stock Citrinet Model with Modified Parameters, much like this question Rebuilding the asrset3 citrinet offline pipeline but with larger chunk size .
But it never got a response. I’d like to know how to rebuild the stock file given in the QuickStart and modify some of the parameters.
I tried using this riva-build command given at https://docs.nvidia.com/deeplearning/riva/user-guide/docs/service-asr.html for the Citrinet-1024 Acoustic Model for Streaming High-Throughput:
riva-build speech_recognition \
<rmir_filename>:<key> <riva_filename>:<key> \
--name=citrinet-1024-english-asr-streaming \
--ms_per_timestep=80 \
--featurizer.use_utterance_norm_params=False \
--featurizer.precalc_norm_time_steps=0 \
--featurizer.precalc_norm_params=False \
--vad.residue_blanks_at_start=-2 \
--chunk_size=0.8 \
--left_padding_size=1.6 \
--right_padding_size=1.6 \
--decoder_type=flashlight \
--flashlight_decoder.asr_model_delay=-1 \
--decoding_language_model_binary=<lm_binary> \
--decoding_vocab=<decoder_lexicon> \
--flashlight_decoder.lm_weight=0.2 \
--flashlight_decoder.word_insertion_score=0.2 \
--flashlight_decoder.beam_threshold=20. \
--language_code=en-US
Which has 4 unknowns (to me):
- <rmir_filename>:<key>
- <riva_filename>:<key>
- <lm_binary>
- <decoder_lexicon>
I populated these 4 parameters with the following:
I used my desired name ofcitrinet_v3_stock.rmirfor the .rmir file with a key oftlt_encode - <riva_filename>:<key>
For this I used the .riva NGC file in the Acoustic Model (AM) repository “RIVA Citrinet ASR English” released on Jan 7th, 2022 found at RIVA Citrinet ASR English | NVIDIA NGC
I used the file namedcitrinet-1024-Jarvis-asrset-3_0-encrypted.riva, which seemed to be the most recent deployable AM I could find. The key I used is alsotlt_encode, as indicated in the model’s Overview section. - <lm_binary>
I wanted to use flashlight as the decoder type, since that’s what the user-guide’s riva-build used. And I found the LM repository “Riva ASR English LM”, last modified Jan 7, 2022 at Riva ASR English(en-US) LM | NVIDIA NGC
I used the KenLM-formatted binary file namedmixed-lower.binary. - <decoder_lexicon>
I wasn’t sure what to use for this. Looking around it looks liked I wanted a .txt file, so I used the one included in the language model I found in #3.
The file name iswords.mixed_lm.txt.
So putting it all together, I ended up with this riva-build command:
/data/rmir/citrinet_v3_stock.rmir:tlt_encode speechtotext_en_us_citrinet_vdeployable_v3.0/citrinet-1024-Jarvis-asrset-3_0-encrypted.riva:tlt_encode \
--name=citrinet-v3-stock-1024-english-asr-streaming \
--chunk_size=0.8 \
--decoding_language_model_binary=speechtotext_en_us_lm_vdeployable_v1-1.0/mixed-lower.binary \
--decoding_vocab=speechtotext_en_us_lm_vdeployable_v1-1.0/words.mixed_lm.txt \
--language_code=en-US -f
The build was successful and generated a .rmir file.
2022-01-17 17:20:19,763 [WARNING] Property 'encrypted' is deprecated. Please use 'encryption' instead.
2022-01-17 17:20:19,764 [WARNING] Property 'binary' is deprecated. Please use the callback system instead.
2022-01-17 17:20:20,534 [INFO] Packing binaries for nn/ONNX : {'onnx': ('nemo.collections.asr.models.ctc_bpe_models.EncDecCTCModelBPE', 'model_graph.onnx')}
2022-01-17 17:20:20,534 [INFO] Copying onnx:model_graph.onnx -> nn:nn-model_graph.onnx
2022-01-17 17:20:25,276 [INFO] Packing binaries for lm_decoder/ONNX : {'vocab_file': '/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt', 'decoding_language_model_binary': '/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/mixed-lower.binary', 'decoding_vocab': '/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/words.mixed_lm.txt', 'tokenizer_model': ('nemo.collections.asr.models.ctc_bpe_models.EncDecCTCModelBPE', '498056ba420d4bb3831ad557fba06032_tokenizer.model')}
2022-01-17 17:20:25,277 [INFO] Copying vocab_file:/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt -> lm_decoder:lm_decoder-riva_decoder_vocabulary.txt
2022-01-17 17:20:25,277 [INFO] Copying decoding_language_model_binary:/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/mixed-lower.binary -> lm_decoder:lm_decoder-mixed-lower.binary
2022-01-17 17:20:26,177 [INFO] Copying decoding_vocab:/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/words.mixed_lm.txt -> lm_decoder:lm_decoder-words.mixed_lm.txt
2022-01-17 17:20:26,180 [INFO] Copying tokenizer_model:498056ba420d4bb3831ad557fba06032_tokenizer.model -> lm_decoder:lm_decoder-498056ba420d4bb3831ad557fba06032_tokenizer.model
2022-01-17 17:20:26,180 [INFO] Packing binaries for rescorer/ONNX : {'vocab_file': '/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt'}
2022-01-17 17:20:26,180 [INFO] Copying vocab_file:/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt -> rescorer:rescorer-riva_decoder_vocabulary.txt
2022-01-17 17:20:26,181 [INFO] Packing binaries for vad/ONNX : {'vocab_file': '/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt'}
2022-01-17 17:20:26,181 [INFO] Copying vocab_file:/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt -> vad:vad-riva_decoder_vocabulary.txt
2022-01-17 17:20:26,181 [INFO] Saving to /data/rmir/citrinet_v3_stock.rmir
I then did a riva_init and it generated a model successfully:
Logging into NGC docker registry if necessary...
Pulling required docker images if necessary...
Note: This may take some time, depending on the speed of your Internet connection.
> Pulling Riva Speech Server images.
> Image nvcr.io/nvidia/riva/riva-speech:1.8.0-beta-server exists. Skipping.
> Image nvcr.io/nvidia/riva/riva-speech-client:1.8.0-beta exists. Skipping.
> Image nvcr.io/nvidia/riva/riva-speech:1.8.0-beta-servicemaker exists. Skipping.
Downloading models (RMIRs) from NGC...
Note: this may take some time, depending on the speed of your Internet connection.
To skip this process and use existing RMIRs set the location and corresponding flag in config.sh.
=== Riva Speech Skills ===
NVIDIA Release 21.12 (build 30304770)
Copyright (c) 2018-2021, NVIDIA CORPORATION. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION. All rights reserved.
NVIDIA modifications are covered by the license terms that apply to the underlying
project or file.
NOTE: The SHMEM allocation limit is set to the default of 64MB. This may be
insufficient for the inference server. NVIDIA recommends the use of the following flags:
nvidia-docker run --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 ...
/data/artifacts /opt/riva
Directory rmir_asr_citrinet_1024_en_us_str_v1.8.0-beta already exists, skipping. Use '--force' option to override.
Directory rmir_asr_citrinet_1024_en_us_ofl_v1.8.0-beta already exists, skipping. Use '--force' option to override.
Directory rmir_nlp_punctuation_bert_base_v1.8.0-beta already exists, skipping. Use '--force' option to override.
/opt/riva
Converting RMIRs at riva-model-repo/rmir to Riva Model repository.
+ docker run --init -it --rm --gpus '"device=0"' -v riva-model-repo:/data -e MODEL_DEPLOY_KEY=tlt_encode --name riva-service-maker nvcr.io/nvidia/riva/riva-speech:1.8.0-beta-servicemaker deploy_all_models /data/rmir /data/models
project or file.
2022-01-17 17:31:16,131 [INFO] Writing Riva model repository to '/data/models'...
2022-01-17 17:31:16,131 [INFO] The riva model repo target directory is /data/models
2022-01-17 17:31:23,471 [INFO] Using tensorrt
2022-01-17 17:31:23,471 [WARNING] /data/models/riva-trt-citrinet-1024-en-US-asr-streaming-am-streaming already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/riva-trt-citrinet-1024-en-US-asr-streaming-am-streaming
2022-01-17 17:31:23,471 [WARNING] /data/models/citrinet-1024-en-US-asr-streaming-feature-extractor-streaming already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-streaming-feature-extractor-streaming
2022-01-17 17:31:23,471 [WARNING] /data/models/citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming
2022-01-17 17:31:23,471 [WARNING] /data/models/citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming
2022-01-17 17:31:23,471 [WARNING] /data/models/citrinet-1024-en-US-asr-streaming already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-streaming
2022-01-17 17:31:28,617 [INFO] Using tensorrt
2022-01-17 17:31:28,618 [WARNING] /data/models/riva-trt-citrinet-1024-en-US-asr-offline-am-streaming-offline already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/riva-trt-citrinet-1024-en-US-asr-offline-am-streaming-offline
2022-01-17 17:31:28,618 [WARNING] /data/models/citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline
2022-01-17 17:31:28,618 [WARNING] /data/models/citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline
2022-01-17 17:31:28,618 [WARNING] /data/models/citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline
2022-01-17 17:31:28,618 [WARNING] /data/models/citrinet-1024-en-US-asr-offline already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/citrinet-1024-en-US-asr-offline
2022-01-17 17:31:33,872 [WARNING] /data/models/riva-trt-riva_punctuation-nn-bert-base-uncased already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/riva-trt-riva_punctuation-nn-bert-base-uncased
2022-01-17 17:31:33,872 [WARNING] /data/models/punctuation_tokenizer already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/punctuation_tokenizer
2022-01-17 17:31:33,872 [WARNING] /data/models/punctuation_punctuation_postprocessor already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/punctuation_punctuation_postprocessor
2022-01-17 17:31:33,872 [WARNING] /data/models/riva_punctuation already exists, skipping deployment. To force deployment rerun with -f or remove the /data/models/riva_punctuation
2022-01-17 17:32:04,025 [INFO] Using tensorrt
2022-01-17 17:32:04,046 [INFO] Extract_binaries for nn -> /data/models/riva-trt-citrinet-v3-stock-1024-english-asr-streaming-am-streaming/1
2022-01-17 17:32:04,046 [INFO] extracting {'onnx': ('nemo.collections.asr.models.ctc_bpe_models.EncDecCTCModelBPE', 'model_graph.onnx')} -> /data/models/riva-trt-citrinet-v3-stock-1024-english-asr-streaming-am-streaming/1
2022-01-17 17:32:11,578 [INFO] Printing copied artifacts:
2022-01-17 17:32:11,578 [INFO] {'onnx': '/data/models/riva-trt-citrinet-v3-stock-1024-english-asr-streaming-am-streaming/1/model_graph.onnx'}
2022-01-17 17:32:11,578 [INFO] Building TRT engine from ONNX file
[W] colored module is not installed, will not use colors when logging. To enable colors, please install the colored module: python3 -m pip install colored
[W] 'Shape tensor cast elision' routine failed with: None
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:604] Reading dangerously large protocol message. If the message turns out to be larger than 2147483647 bytes, parsing will be halted for security reasons. To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in google/protobuf/io/coded_stream.h.
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:81] The total number of bytes read was 564431790
[TensorRT] WARNING: onnx2trt_utils.cpp:362: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[TensorRT] WARNING: Detected invalid timing cache, setup a local cache instead
2022-01-17 17:34:39,407 [INFO] Extract_binaries for featurizer -> /data/models/citrinet-v3-stock-1024-english-asr-streaming-feature-extractor-streaming/1
2022-01-17 17:34:39,412 [INFO] Extract_binaries for vad -> /data/models/citrinet-v3-stock-1024-english-asr-streaming-voice-activity-detector-ctc-streaming/1
2022-01-17 17:34:39,412 [INFO] extracting {'vocab_file': '/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt'} -> /data/models/citrinet-v3-stock-1024-english-asr-streaming-voice-activity-detector-ctc-streaming/1
2022-01-17 17:34:39,414 [INFO] Extract_binaries for lm_decoder -> /data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1
2022-01-17 17:34:39,414 [INFO] extracting {'vocab_file': '/tmp/tmp8hinuqiw/riva_decoder_vocabulary.txt', 'decoding_language_model_binary': '/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/mixed-lower.binary', 'decoding_vocab': '/root/Downloads/speechtotext_en_us_lm_vdeployable_v1-1.0/words.mixed_lm.txt', 'tokenizer_model': ('nemo.collections.asr.models.ctc_bpe_models.EncDecCTCModelBPE', '498056ba420d4bb3831ad557fba06032_tokenizer.model')} -> /data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1
2022-01-17 17:34:40,804 [INFO] {'vocab_file': '/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/riva_decoder_vocabulary.txt', 'decoding_language_model_binary': '/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/mixed-lower.binary', 'decoding_vocab': '/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/words.mixed_lm.txt', 'tokenizer_model': '/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/498056ba420d4bb3831ad557fba06032_tokenizer.model'}
2022-01-17 17:34:40,804 [INFO] Model config has vocab file and tokenizer specified. Will create subword lexicon file from vocab_file /data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/words.mixed_lm.txt and tokenizer model /data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/498056ba420d4bb3831ad557fba06032_tokenizer.model
2022-01-17 17:34:40,955 [INFO] processed 10000 lines
2022-01-17 17:34:41,108 [INFO] processed 20000 lines
2022-01-17 17:34:41,260 [INFO] processed 30000 lines
2022-01-17 17:34:41,414 [INFO] processed 40000 lines
2022-01-17 17:34:41,568 [INFO] processed 50000 lines
2022-01-17 17:34:41,720 [INFO] processed 60000 lines
2022-01-17 17:34:41,873 [INFO] processed 70000 lines
2022-01-17 17:34:42,024 [INFO] processed 80000 lines
2022-01-17 17:34:42,176 [INFO] processed 90000 lines
2022-01-17 17:34:42,331 [INFO] processed 100000 lines
2022-01-17 17:34:42,487 [INFO] processed 110000 lines
2022-01-17 17:34:42,642 [INFO] processed 120000 lines
2022-01-17 17:34:42,801 [INFO] processed 130000 lines
2022-01-17 17:34:42,957 [INFO] processed 140000 lines
2022-01-17 17:34:43,115 [INFO] processed 150000 lines
2022-01-17 17:34:43,273 [INFO] processed 160000 lines
2022-01-17 17:34:43,431 [INFO] processed 170000 lines
2022-01-17 17:34:43,588 [INFO] processed 180000 lines
2022-01-17 17:34:43,747 [INFO] processed 190000 lines
2022-01-17 17:34:43,904 [INFO] processed 200000 lines
2022-01-17 17:34:44,065 [INFO] processed 210000 lines
2022-01-17 17:34:44,222 [INFO] processed 220000 lines
2022-01-17 17:34:44,245 [INFO] skipped 0 empty lines
2022-01-17 17:34:44,245 [INFO] filtered 0 lines
2022-01-17 17:34:44,248 [INFO] Extract_binaries for self -> /data/models/citrinet-v3-stock-1024-english-asr-streaming/1
+ echo
+ echo 'Riva initialization complete. Run ./riva_start.sh to launch services.'
When I do a riva_start, it fails in the following logs:
NVIDIA Release 21.12 (build 30304767)
project or file.
> Riva waiting for Triton server to load all models...retrying in 1 second
I0117 17:37:07.136213 70 metrics.cc:290] Collecting metrics for GPU 0: Tesla T4
I0117 17:37:07.177269 70 onnxruntime.cc:1970] TRITONBACKEND_Initialize: onnxruntime
I0117 17:37:07.177296 70 onnxruntime.cc:1980] Triton TRITONBACKEND API version: 1.4
I0117 17:37:07.177304 70 onnxruntime.cc:1986] 'onnxruntime' TRITONBACKEND API version: 1.4
I0117 17:37:07.370592 70 pinned_memory_manager.cc:240] Pinned memory pool is created at '0x7f1048000000' with size 268435456
I0117 17:37:07.371749 70 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 1000000000
I0117 17:37:07.393491 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline:1
I0117 17:37:07.493756 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline:1
I0117 17:37:07.528150 70 ctc-decoder-library.cc:20] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline (version 1)
W:parameter_parser.cc:118: Parameter forerunner_start_offset_ms could not be set from parameters
W:parameter_parser.cc:119: Default value will be used
W:parameter_parser.cc:118: Parameter max_num_slots could not be set from parameters
I0117 17:37:07.532198 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline",
"platform": "",
"backend": "riva_asr_decoder",
"version_policy": {
"latest": {
"num_versions": 1
"max_batch_size": 128,
"input": [
"name": "CLASS_LOGITS",
"data_type": "TYPE_FP32",
"format": "FORMAT_NONE",
"dims": [
-1,
1025
"is_shape_tensor": false,
"allow_ragged_batch": false
"name": "END_FLAG",
"data_type": "TYPE_UINT32",
"dims": [
1
"name": "SEGMENTS_START_END",
"data_type": "TYPE_INT32",
"dims": [
-1,
2
"name": "CUSTOM_CONFIGURATION",
"data_type": "TYPE_STRING",
"dims": [
-1,
2
"output": [
"name": "FINAL_TRANSCRIPTS",
"dims": [
-1
"label_filename": "",
"name": "FINAL_TRANSCRIPTS_SCORE",
"dims": [
-1
"name": "FINAL_WORDS_START_END",
"dims": [
-1,
2
"name": "PARTIAL_TRANSCRIPTS",
"dims": [
-1
"name": "PARTIAL_TRANSCRIPTS_STABILITY",
"dims": [
-1
"name": "PARTIAL_WORDS_START_END",
"dims": [
-1,
2
"batch_input": [],
"batch_output": [],
"optimization": {
"priority": "PRIORITY_DEFAULT",
"cuda": {
"graphs": false,
"busy_wait_events": false,
"graph_spec": [],
"output_copy_stream": true
"input_pinned_memory": {
"enable": true
"output_pinned_memory": {
"enable": true
"gather_kernel_buffer_threshold": 0,
"eager_batching": false
"sequence_batching": {
"oldest": {
"max_candidate_sequences": 128,
"preferred_batch_size": [
32,
64
"max_queue_delay_microseconds": 1000
"max_sequence_idle_microseconds": 60000000,
"control_input": [
"name": "START",
"control": [
"kind": "CONTROL_SEQUENCE_START",
"int32_false_true": [
0,
1
"fp32_false_true": [],
"data_type": "TYPE_INVALID"
"name": "READY",
"control": [
"kind": "CONTROL_SEQUENCE_READY",
0,
1
"name": "END",
"control": [
"kind": "CONTROL_SEQUENCE_END",
0,
1
"name": "CORRID",
"control": [
"kind": "CONTROL_SEQUENCE_CORRID",
"int32_false_true": [],
"data_type": "TYPE_UINT64"
"instance_group": [
"name": "citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline_0",
"kind": "KIND_CPU",
"count": 1,
"gpus": [],
"secondary_devices": [],
"profile": [],
"passive": false,
"host_policy": ""
"default_model_filename": "",
"cc_model_filenames": {},
"metric_tags": {},
"parameters": {
"use_vad": {
"string_value": "True"
"lm_weight": {
"string_value": "0.2"
"blank_token": {
"string_value": "#"
"vocab_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline/1/riva_decoder_vocabulary.txt"
"ms_per_timestep": {
"string_value": "80"
"use_subword": {
"streaming": {
"beam_size": {
"string_value": "16"
"right_padding_size": {
"string_value": "0.0"
"beam_size_token": {
"sil_token": {
"string_value": "▁"
"beam_threshold": {
"string_value": "20.0"
"language_model_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline/1/jarvis_asr_train_datasets_noSpgi_noLS_gt_3gram.binary"
"max_execution_batch_size": {
"string_value": "1024"
"forerunner_use_lm": {
"string_value": "true"
"forerunner_beam_size_token": {
"string_value": "8"
"forerunner_beam_threshold": {
"string_value": "10.0"
"asr_model_delay": {
"string_value": "-1"
"decoder_num_worker_threads": {
"word_insertion_score": {
"left_padding_size": {
"decoder_type": {
"string_value": "flashlight"
"compute_timestamps": {
"forerunner_beam_size": {
"string_value": "8"
"chunk_size": {
"string_value": "900.0"
"max_supported_transcripts": {
"string_value": "1"
"lexicon_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline/1/lexicon.txt"
"smearing_mode": {
"string_value": "max"
"model_warmup": [],
"model_transaction_policy": {
"decoupled": false
I0117 17:37:07.532280 70 ctc-decoder-library.cc:23] TRITONBACKEND_ModelInstanceInitialize: citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline_0 (device 0)
I0117 17:37:07.594105 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline:1
I0117 17:37:07.694390 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming:1
I0117 17:37:07.794736 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-streaming-feature-extractor-streaming:1
I0117 17:37:07.894997 70 model_repository_manager.cc:1045] loading: citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming:1
I0117 17:37:07.995284 70 model_repository_manager.cc:1045] loading: citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming:1
I0117 17:37:08.095555 70 model_repository_manager.cc:1045] loading: citrinet-v3-stock-1024-english-asr-streaming-feature-extractor-streaming:1
I0117 17:37:08.195899 70 model_repository_manager.cc:1045] loading: citrinet-v3-stock-1024-english-asr-streaming-voice-activity-detector-ctc-streaming:1
I0117 17:37:08.296171 70 model_repository_manager.cc:1045] loading: punctuation_punctuation_postprocessor:1
I0117 17:37:08.396452 70 model_repository_manager.cc:1045] loading: punctuation_tokenizer:1
I0117 17:37:08.496721 70 model_repository_manager.cc:1045] loading: riva-trt-citrinet-1024-en-US-asr-offline-am-streaming-offline:1
I0117 17:37:08.597012 70 model_repository_manager.cc:1045] loading: riva-trt-citrinet-1024-en-US-asr-streaming-am-streaming:1
I0117 17:37:08.697360 70 model_repository_manager.cc:1045] loading: riva-trt-citrinet-v3-stock-1024-english-asr-streaming-am-streaming:1
I0117 17:37:08.797717 70 model_repository_manager.cc:1045] loading: riva-trt-riva_punctuation-nn-bert-base-uncased:1
I0117 17:37:08.889152 70 model_repository_manager.cc:1212] successfully loaded 'citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-streaming-offline' version 1
I0117 17:37:08.895136 70 feature-extractor.cc:402] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline (version 1)
I0117 17:37:08.930179 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline",
"platform": "",
"backend": "riva_asr_features",
"version_policy": {
"latest": {
"num_versions": 1
"max_batch_size": 1,
"input": [
"name": "AUDIO_SIGNAL",
"dims": [
-1
"name": "SAMPLE_RATE",
"dims": [
1
"output": [
"name": "AUDIO_FEATURES",
"dims": [
80,
-1
"name": "AUDIO_PROCESSED",
"dims": [
1
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"oldest": {
"max_candidate_sequences": 1,
1
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"name": "END",
"control": [
0,
1
"name": "CORRID",
"control": [
"instance_group": [
"name": "citrinet-1024-en-US-asr-offline-feature-extractor-streaming-offline_0",
"kind": "KIND_GPU",
"count": 1,
"gpus": [
0
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"precalc_norm_params": {
"string_value": "False"
"dither": {
"norm_per_feature": {
"mean": {
"string_value": "-11.4412, -9.9334, -9.1292, -9.0365, -9.2804, -9.5643, -9.7342, -9.6925, -9.6333, -9.2808, -9.1887, -9.1422, -9.1397, -9.2028, -9.2749, -9.4776, -9.9185, -10.1557, -10.3800, -10.5067, -10.3190, -10.4728, -10.5529, -10.6402, -10.6440, -10.5113, -10.7395, -10.7870, -10.6074, -10.5033, -10.8278, -10.6384, -10.8481, -10.6875, -10.5454, -10.4747, -10.5165, -10.4930, -10.3413, -10.3472, -10.3735, -10.6830, -10.8813, -10.6338, -10.3856, -10.7727, -10.8957, -10.8068, -10.7373, -10.6108, -10.3405, -10.2889, -10.3922, -10.4946, -10.3367, -10.4164, -10.9949, -10.7196, -10.3971, -10.1734, -9.9257, -9.6557, -9.1761, -9.6653, -9.7876, -9.7230, -9.7792, -9.7056, -9.2702, -9.4650, -9.2755, -9.1369, -9.1174, -8.9197, -8.5394, -8.2614, -8.1353, -8.1422, -8.3430, -8.6655"
"stddev": {
"string_value": "2.2668, 3.1642, 3.7079, 3.7642, 3.5349, 3.5901, 3.7640, 3.8424, 4.0145, 4.1475, 4.0457, 3.9048, 3.7709, 3.6117, 3.3188, 3.1489, 3.0615, 3.0362, 2.9929, 3.0500, 3.0341, 3.0484, 3.0103, 2.9474, 2.9128, 2.8669, 2.8332, 2.9411, 3.0378, 3.0712, 3.0190, 2.9992, 3.0124, 3.0024, 3.0275, 3.0870, 3.0656, 3.0142, 3.0493, 3.1373, 3.1135, 3.0675, 2.8828, 2.7018, 2.6296, 2.8826, 2.9325, 2.9288, 2.9271, 2.9890, 3.0137, 2.9855, 3.0839, 2.9319, 2.3512, 2.3795, 2.6191, 2.7555, 2.9326, 2.9931, 3.1543, 3.0855, 2.6820, 3.0566, 3.1272, 3.1663, 3.1836, 3.0018, 2.9089, 3.1727, 3.1626, 3.1086, 2.9804, 3.1107, 3.2998, 3.3697, 3.3716, 3.2487, 3.1597, 3.1181"
"chunk_size": {
"string_value": "1"
"sample_rate": {
"string_value": "16000"
"num_features": {
"window_size": {
"string_value": "0.025"
"window_stride": {
"string_value": "0.01"
"streaming": {
"transpose": {
"stddev_floor": {
"string_value": "1e-05"
"gain": {
"string_value": "1.0"
"use_utterance_norm_params": {
"precalc_norm_time_steps": {
"string_value": "0"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.935731 70 vad_library.cc:18] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline (version 1)
W:parameter_parser.cc:118: Parameter max_execution_batch_size could not be set from parameters
I0117 17:37:08.938619 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline",
"platform": "",
"backend": "riva_asr_vad",
"version_policy": {
"latest": {
"num_versions": 1
"max_batch_size": 2048,
"input": [
"dims": [
-1,
1025
"output": [
"dims": [
-1,
2
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"instance_group": [
"name": "citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline_0",
"kind": "KIND_CPU",
"count": 1,
"gpus": [],
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"residue_blanks_at_start": {
"string_value": "0"
"streaming": {
"use_subword": {
"residue_blanks_at_end": {
"string_value": "0"
"vad_stop_history": {
"string_value": "800"
"vad_start_history": {
"string_value": "300"
"chunk_size": {
"vad_start_th": {
"vad_stop_th": {
"string_value": "0.98"
"vad_type": {
"string_value": "ctc-vad"
"vocab_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-offline-voice-activity-detector-ctc-streaming-offline/1/riva_decoder_vocabulary.txt"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.938700 70 feature-extractor.cc:402] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-streaming-feature-extractor-streaming (version 1)
I0117 17:37:08.940068 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-streaming-feature-extractor-streaming",
"platform": "",
"version_policy": {
"latest": {
"num_versions": 1
"input": [
"dims": [
-1
"dims": [
1
"output": [
"dims": [
80,
-1
"dims": [
1
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"oldest": {
"max_candidate_sequences": 2048,
256,
512
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"name": "END",
"control": [
0,
1
"name": "CORRID",
"control": [
"instance_group": [
"name": "citrinet-1024-en-US-asr-streaming-feature-extractor-streaming_0",
"kind": "KIND_GPU",
"count": 1,
"gpus": [
0
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"sample_rate": {
"num_features": {
"window_size": {
"window_stride": {
"streaming": {
"transpose": {
"stddev_floor": {
"string_value": "1.92"
"gain": {
"string_value": "0"
"dither": {
"mean": {
"stddev": {
"chunk_size": {
"string_value": "0.16"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.940129 70 ctc-decoder-library.cc:20] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming (version 1)
I0117 17:37:08.943110 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming",
"platform": "",
"version_policy": {
"latest": {
"num_versions": 1
"input": [
"dims": [
-1,
1025
"name": "END_FLAG",
"dims": [
1
"dims": [
-1,
2
"dims": [
-1,
2
"output": [
"dims": [
-1
"dims": [
-1
"dims": [
-1,
2
"dims": [
-1
"dims": [
-1
"dims": [
-1,
2
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"oldest": {
32,
64
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"name": "END",
"control": [
0,
1
"name": "CORRID",
"control": [
"instance_group": [
"name": "citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming_0",
"kind": "KIND_CPU",
"count": 1,
"gpus": [],
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"use_subword": {
"streaming": {
"beam_size": {
"sil_token": {
"string_value": "▁"
"beam_threshold": {
"string_value": "/data/models/citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming/1/jarvis_asr_train_datasets_noSpgi_noLS_gt_3gram.binary"
"string_value": "8"
"decoder_type": {
"string_value": "8"
"string_value": "1"
"chunk_size": {
"lexicon_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming/1/lexicon.txt"
"smearing_mode": {
"use_vad": {
"blank_token": {
"string_value": "#"
"lm_weight": {
"vocab_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-streaming-ctc-decoder-cpu-streaming/1/riva_decoder_vocabulary.txt"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.943189 70 vad_library.cc:18] TRITONBACKEND_ModelInitialize: citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming (version 1)
I0117 17:37:08.945221 70 backend_model.cc:255] model configuration:
"name": "citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming",
"platform": "",
"version_policy": {
"latest": {
"num_versions": 1
"input": [
"dims": [
-1,
1025
"output": [
"dims": [
-1,
2
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"instance_group": [
"name": "citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming_0",
"kind": "KIND_CPU",
"count": 1,
"gpus": [],
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"chunk_size": {
"vad_start_th": {
"vad_stop_th": {
"vad_type": {
"vocab_file": {
"string_value": "/data/models/citrinet-1024-en-US-asr-streaming-voice-activity-detector-ctc-streaming/1/riva_decoder_vocabulary.txt"
"string_value": "-2"
"streaming": {
"use_subword": {
"string_value": "0"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.945664 70 ctc-decoder-library.cc:20] TRITONBACKEND_ModelInitialize: citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming (version 1)
I0117 17:37:08.947745 70 backend_model.cc:255] model configuration:
"name": "citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming",
"platform": "",
"version_policy": {
"latest": {
"num_versions": 1
"input": [
"dims": [
-1,
1025
"name": "END_FLAG",
"dims": [
1
"dims": [
-1,
2
"dims": [
-1,
2
"output": [
"dims": [
-1
"dims": [
-1
"dims": [
-1,
2
"dims": [
-1
"dims": [
-1
"dims": [
-1,
2
"batch_input": [],
"batch_output": [],
"optimization": {
"cuda": {
"graphs": false,
"graph_spec": [],
"enable": true
"enable": true
"oldest": {
32,
64
"control_input": [
"name": "START",
"control": [
0,
1
"name": "READY",
"control": [
0,
1
"name": "END",
"control": [
0,
1
"name": "CORRID",
"control": [
"instance_group": [
"name": "citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming_0",
"kind": "KIND_CPU",
"count": 1,
"gpus": [],
"profile": [],
"passive": false,
"host_policy": ""
"metric_tags": {},
"parameters": {
"decoder_type": {
"string_value": "8"
"chunk_size": {
"string_value": "0.8"
"string_value": "1"
"lexicon_file": {
"string_value": "/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/lexicon.txt"
"smearing_mode": {
"use_vad": {
"blank_token": {
"string_value": "#"
"lm_weight": {
"vocab_file": {
"string_value": "/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/riva_decoder_vocabulary.txt"
"streaming": {
"use_subword": {
"beam_size": {
"string_value": "1.6"
"sil_token": {
"string_value": "▁"
"beam_threshold": {
"string_value": "/data/models/citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming/1/mixed-lower.binary"
"string_value": "8"
"model_warmup": [],
"decoupled": false
I0117 17:37:08.947884 70 ctc-decoder-library.cc:23] TRITONBACKEND_ModelInstanceInitialize: citrinet-v3-stock-1024-english-asr-streaming-ctc-decoder-cpu-streaming_0 (device 0)
terminate called after throwing an instance of 'std::invalid_argument'
what(): Unknown entry in dictionary: '221540'
/opt/riva/bin/start-riva: line 4: 70 Aborted (core dumped) tritonserver --log-verbose=0 --strict-model-config=true $model_repos --cuda-memory-pool-byte-size=0:1000000000
> Triton server died before reaching ready state. Terminating Riva startup.
Check Triton logs with: docker logs
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
I believe the relevant portion of the error is
I’d like to know :
1. If I’m doing anything wrong or if there’s an error in the files available in NGC.
2. If this is all that’s required to create the stock models. Do I need to use the rescorer?
Thanks in advance!
