Riva quickstart 2.11 fails on xavier nx
Hardware - Jetson Xavier NX
Hardware - CPU
Operating System jetpack 5.1.1
Riva Version 2.11.0
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
$ sudo bash riva_init.sh
[sudo] password for valentin:
Please enter API key for ngc.nvidia.com:
Logging into NGC docker registry if necessary…
Pulling required docker images if necessary…
Note: This may take some time, depending on the speed of your Internet connection.
Pulling Riva Speech Server images.
Image nvcr.io/nvidia/riva/riva-speech:2.11.0-l4t-aarch64 exists. Skipping.
Downloading models (RMIRs) from NGC…
Note: this may take some time, depending on the speed of your Internet connection.
To skip this process and use existing RMIRs set the location and corresponding flag in config.sh.
Downloaded 356.06 MB in 2m 18s, Download speed: 2.58 MB/s
Transfer id: models_asr_conformer_en_us_str_v2.11.0-tegra-orin
Download status: Completed
Downloaded local path: /data/artifacts/models_asr_conformer_en_us_str_v2.11.0-tegra-orin
Total files downloaded: 1
Total downloaded size: 356.06 MB
Started at: 2023-06-08 17:39:44.382684
Completed at: 2023-06-08 17:42:02.610823
Duration taken: 2m 18s
Downloaded 384.61 MB in 3m 1s, Download speed: 2.12 MB/s
Transfer id: models_nlp_punctuation_bert_base_en_us_v2.11.0-tegra-orin
Downloaded local path: /data/artifacts/models_nlp_punctuation_bert_base_en_us_v2.11.0-tegra-orin
Total downloaded size: 384.61 MB
Started at: 2023-06-08 17:42:08.944543
Completed at: 2023-06-08 17:45:10.223970
Duration taken: 3m 1s
Downloaded 191.1 MB in 1m 28s, Download speed: 2.17 MB/s
Transfer id: models_nlp_intent_slot_misty_bert_base_v2.11.0-tegra-orin
Downloaded local path: /data/artifacts/models_nlp_intent_slot_misty_bert_base_v2.11.0-tegra-orin
Total downloaded size: 191.1 MB
Started at: 2023-06-08 17:45:17.094875
Completed at: 2023-06-08 17:46:45.234243
Duration taken: 1m 28s
Downloaded 186.47 MB in 1m 19s, Download speed: 2.36 MB/s
Transfer id: models_tts_fastpitch_hifigan_en_us_ipa_v2.11.0-tegra-orin
Downloaded local path: /data/artifacts/models_tts_fastpitch_hifigan_en_us_ipa_v2.11.0-tegra-orin
Total downloaded size: 186.47 MB
Started at: 2023-06-08 17:46:51.252053
Completed at: 2023-06-08 17:48:10.373128
Duration taken: 1m 19s
  • [[ tegra != \t\e\g\r\a ]]
  • [[ tegra == \t\e\g\r\a ]]
  • ‘[’ -d ‘/home/valentin/Downloads/riva3/files(2)/model_repository/rmir’ ‘]’
  • ‘[’ -d ‘/home/valentin/Downloads/riva3/files(2)/model_repository/prebuilt’ ‘]’
  • echo ‘Converting prebuilts at /home/valentin/Downloads/riva3/files(2)/model_repository/prebuilt to Riva Model repository.’
  • docker run -it -d --rm -v ‘/home/valentin/Downloads/riva3/files(2)/model_repository:/data’ --name riva-models-extract nvcr.io/nvidia/riva/riva-speech:2.11.0-l4t-aarch64
  • docker exec riva-models-extract bash -c ‘mkdir -p /data/models;
    for file in /data/prebuilt/*.tar.gz; do tar xf $file -C /data/models/ &> /dev/null; done’
  • docker container stop riva-models-extract
  • ‘[’ 0 -ne 0 ‘]’
  • echo
  • echo ‘Riva initialization complete. Run ./riva_start.sh to launch services.’
    valentin@ubuntu:~/Downloads/riva3/files(2)$ sudo bash riva_start.sh
    Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
    Waiting for Riva server to load all models…retrying in 10 seconds
    Health ready check failed.
    Check Riva logs with: docker logs riva-speech
HI @exaflo16
Thanks for your interest in Riva
Apologies you are facing issue,
Request to kindly share the output of command
and share with us the config.sh used
We have seen riva_start in past with customer due to Jetpack Version, you JetPack version seems to be correct - JetPack 5.1.1
One Check,
can you kindly verify the default runtime is set to nvidia
You have set the default runtime to nvidia on the Jetson platform by adding the following line in the /etc/docker/daemon.json file. Restart the Docker service using sudo systemctl restart docker after editing the file.
"default-runtime": "nvidia"
here and the default time is nvidia:
sudo docker logs riva-speech
=== Riva Speech Skills ===
NVIDIA Release 23.04 (build 59018715)
Copyright (c) 2018-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
NVIDIA Tegra driver detected.
Warning: ‘–strict-model-config’ has been deprecated! Please use ‘–disable-auto-complete-config’ instead.
Riva waiting for Triton server to load all models…retrying in 1 second
Error: Failed to initialize NVML
W0609 14:54:17.102185 109 metrics.cc:785] DCGM unable to start: DCGM initialization error
I0609 14:54:17.103258 109 metrics.cc:757] Collecting CPU metrics
I0609 14:54:17.104303 109 tritonserver.cc:2264]
| Option | Value |
| server_id | triton |
| server_version | 2.27.0 |
| server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data statistics trace logging |
| model_control_mode | MODE_NONE |
| strict_model_config | 1 |
| rate_limit | OFF |
| pinned_memory_pool_byte_size | 268435456 |
| cuda_memory_pool_byte_size{0} | 1000000000 |
| response_cache_byte_size | 0 |
| min_supported_compute_capability | 6.0 |
| strict_readiness | 1 |
| exit_timeout | 30 |
I0609 14:54:17.104423 109 server.cc:261] No server context available. Exiting immediately.
error: creating server: Invalid argument - --model-repository must be specified
Triton server died before reaching ready state. Terminating Riva startup.
Check Triton logs with: docker logs
/opt/riva/bin/start-riva: line 1: kill: (109) - No such process
config.sh
Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
NVIDIA CORPORATION and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA CORPORATION is strictly prohibited.
GPU family of target platform. Supported values: tegra, non-tegra
riva_target_gpu_family=“non-tegra”
Name of tegra platform that is being used. Supported tegra platforms: orin, xavier
riva_tegra_platform=“orin”
Enable or Disable Riva Services
service_enabled_asr=true
service_enabled_nlp=true
service_enabled_tts=true
service_enabled_nmt=true
Enable Riva Enterprise
If enrolled in Enterprise, enable Riva Enterprise by setting configuration
here. You must explicitly acknowledge you have read and agree to the EULA.
RIVA_API_KEY=
RIVA_API_NGC_ORG=
RIVA_EULA=accept
Language code to fetch models of a specify language
Currently only ASR supports languages other than English
Supported language codes: ar-AR, en-US, en-GB, de-DE, es-ES, es-US, fr-FR, hi-IN, it-IT, ja-JP, ru-RU, ko-KR, pt-BR, zh-CN
for any language other than English, set service_enabled_nlp and service_enabled_tts to False
for multiple languages enter space separated language codes.
language_code=(“en-US”)
ASR acoustic model architecture
Supported values are: conformer, conformer_unified (ja-JP only), conformer_xl (en-US + amd64 only), citrinet_1024, citrinet_256 (en-US + arm64 only), jasper (en-US + amd64 only), quartznet (en-US + amd64 only)
asr_acoustic_model=(“conformer”)
Specify one or more GPUs to use
specifying more than one GPU is currently an experimental feature, and may result in undefined behaviours.
gpus_to_use=“device=0”
Specify the encryption key to use to deploy models
MODEL_DEPLOY_KEY=“tlt_encode”
Locations to use for storing models artifacts
If an absolute path is specified, the data will be written to that location
Otherwise, a docker volume will be used (default).
riva_init.sh will create a rmir and models directory in the volume or
path specified.
RMIR ($riva_model_loc/rmir)
Riva uses an intermediate representation (RMIR) for models
that are ready to deploy but not yet fully optimized for deployment. Pretrained
versions can be obtained from NGC (by specifying NGC models below) and will be
downloaded to $riva_model_loc/rmir by riva_init.sh
Custom models produced by NeMo or TLT and prepared using riva-build
may also be copied manually to this location $(riva_model_loc/rmir).
Models ($riva_model_loc/models)
During the riva_init process, the RMIR files in $riva_model_loc/rmir
are inspected and optimized for deployment. The optimized versions are
stored in $riva_model_loc/models. The riva server exclusively uses these
optimized versions.
riva_model_loc=“riva-model-repo”
if [[ $riva_target_gpu_family == “tegra” ]]; then
riva_model_loc=“pwd/model_repository”
fi
The default RMIRs are downloaded from NGC by default in the above $riva_rmir_loc directory
If you’d like to skip the download from NGC and use the existing RMIRs in the $riva_rmir_loc
then set the below $use_existing_rmirs flag to true. You can also deploy your set of custom
RMIRs by keeping them in the riva_rmir_loc dir and use this quickstart script with the
below flag to deploy them all together.
use_existing_rmirs=false
Ports to expose for Riva services
riva_speech_api_port=“50051”
NGC orgs
riva_ngc_org=“nvidia”
riva_ngc_team=“riva”
riva_ngc_image_version=“2.11.0”
riva_ngc_model_version=“2.11.0”
Pre-built models listed below will be downloaded from NGC. If models already exist in $riva-rmir
then models can be commented out to skip download from NGC
########## ASR MODELS ##########
models_asr=()
for lang_code in ${language_code[@]}; do
modified_lang_code=“${lang_code/-/_}”
modified_lang_code=${modified_lang_code,}
# Setting default Conformer Mandarin and Japanese models to greedy decoder due to high high latency in os2s.
decoder=""
if [[ ${asr_acoustic_model} == "conformer" ]]; then
  if [[ ${lang_code} == "zh-CN" ]]; then
      decoder="_gre"
  fi
fi
if [[ ${asr_acoustic_model} == "conformer_xl" && ${lang_code} != "en-US" ]]; then
  echo "Conformer-XL acoustic model is only available for language code en-US."
  exit 1
fi
if [[ ${asr_acoustic_model} == "conformer_unified" && ${lang_code} != "ja-JP" ]]; then
  echo "Unified Conformer acoustic model is only available for language code ja-JP."
  exit 1
fi
if [[ $riva_target_gpu_family  == "tegra" ]]; then
  if [[ ${asr_acoustic_model} == "jasper" || \
        ${asr_acoustic_model} == "quartznet" || \
        ${asr_acoustic_model} == "conformer_xl" ]]; then
      echo "Conformer-XL, Jasper and Quartznet models are not available for arm64 architecture"
      exit 1
  fi
  if [[ ${asr_acoustic_model} == "citrinet_256" && ${lang_code} != "en-US" ]]; then
    echo "For arm64 architecture, citrinet_256 acoustic model is only available for language code en-US."
    exit 1
  fi
  models_asr+=(
  ### Streaming w/ CPU decoder, best latency configuration
      "${riva_ngc_org}/${riva_ngc_team}/models_asr_${asr_acoustic_model}_${modified_lang_code}_str:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
  ### Offline w/ CPU decoder
  #    "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_ofl${decoder}:${riva_ngc_model_version}"
else
  if [[ ${asr_acoustic_model} != "conformer" && \
        ${asr_acoustic_model} != "conformer_unified" && \
        ${asr_acoustic_model} != "conformer_xl" && \
        ${asr_acoustic_model} != "citrinet_1024" && \
        ${asr_acoustic_model} != "jasper" && \
        ${asr_acoustic_model} != "quartznet" ]]; then
    echo "For amd64 architecture, valid acoustic models are conformer, conformer_unified, conformer_xl, citrinet_1024, jasper and quartznet."
    exit 1
  fi
  if [[ (${asr_acoustic_model} == "jasper" || \
        ${asr_acoustic_model} == "quartznet") && \
    echo "jasper and quartznet acoustic models are only available for language code en-US."
    exit 1
  fi
  models_asr+=(
      "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_str${decoder}:${riva_ngc_model_version}"
  ### Streaming w/ CPU decoder, best throughput configuration
  #    "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_str_thr${decoder}:${riva_ngc_model_version}"
fi
### Punctuation model
if [[ ${asr_acoustic_model} != "conformer_unified" ]]; then
    models_asr+=(
        "${riva_ngc_org}/${riva_ngc_team}/models_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
  else
    models_asr+=(
        "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}"
  fi
fi
done
Speaker diarization model
models_asr+=(
“${riva_ngc_org}/${riva_ngc_team}/rmir_diarizer_offline:${riva_ngc_model_version}”
########## NLP MODELS ##########
models_nlp=(
BERT Base Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
  "${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_bert_base:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
DistilBERT Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
“${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_distilbert:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}”
else
models_nlp=(
Bert base Punctuation model
  "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_en_us:${riva_ngc_model_version}"
BERT base Named Entity Recognition model fine-tuned on GMB dataset with class labels LOC, PER, ORG etc.
  "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_named_entity_recognition_bert_base:${riva_ngc_model_version}"
BERT Base Intent Slot model fine-tuned on weather dataset.
  "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_intent_slot_bert_base:${riva_ngc_model_version}"
BERT Base Question Answering model fine-tuned on Squad v2.
  "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_bert_base:${riva_ngc_model_version}"
Megatron345M Question Answering model fine-tuned on Squad v2.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_megatron:${riva_ngc_model_version}”
Bert base Text Classification model fine-tuned on 4class (weather, meteorology, personality, nomatch) domain model.
  "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_text_classification_bert_base:${riva_ngc_model_version}"
fi
########## TTS MODELS ##########
models_tts=(
This model has been trained with energy conditioning and International Phonetic Alphabet (IPA) for inference and training.
  "${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us_ipa:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
#"${riva_ngc_org}/${riva_ngc_team}/models_tts_radtts_hifigan_en_us_ipa:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
This model uses the ARPABET for inference and training.
“${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}”
else
models_tts=(
These models have been trained with energy conditioning and use the International Phonetic Alphabet (IPA) for inference and training.
  "${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us_ipa:${riva_ngc_model_version}"
  "${riva_ngc_org}/${riva_ngc_team}/rmir_tts_radtts_hifigan_en_us_ipa:${riva_ngc_model_version}"
“${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us:${riva_ngc_model_version}”
fi
######### NMT models ###############
Only models specified here get loaded, commented models (preceded with #) are skipped.
models follow Source language _ One or more target languages model architecture
e.g., rmir_de_en_24x6 is a German to English 24x6 bilingual model
models_nmt=(
Bilingual models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_de_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_es_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_zh_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_ru_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_fr_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_de_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_es_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_ru_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_zh_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_fr_en_24x6:${riva_ngc_model_version}”
Multilingual models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_deesfr_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_deesfr_12x2:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_deesfr_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_deesfr_en_12x2:${riva_ngc_model_version}”
Megatron models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_megatronnmt_any_en_500m:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_megatronnmt_en_any_500m:${riva_ngc_model_version}”
NGC_TARGET=${riva_ngc_org}
if [[ ! -z ${riva_ngc_team} ]]; then
NGC_TARGET=“${NGC_TARGET}/${riva_ngc_team}”
else
team=“""”
fi
Specify paths to SSL Key and Certificate files to use TLS/SSL Credentials for a secured connection.
If either are empty, an insecure connection will be used.
Stored within container at /ssl/servert.crt and /ssl/server.key
Optional, one can also specify a root certificate, stored within container at /ssl/root_server.crt
ssl_server_cert=“”
ssl_server_key=“”
ssl_root_cert=“”
define docker images required to run Riva
image_speech_api=“nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}”
define docker images required to setup Riva
image_init_speech=“nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}-servicemaker”
daemon names
riva_daemon_speech=“riva-speech”
if [[ $riva_target_gpu_family != “tegra” ]]; then
riva_daemon_client=“riva-client”
fi
can you please answer?
