Hardware - Nvidia Geforce RTX 2060
Hardware - Intel(R) Core™ i7-10750H CPU @ 2.60GHz
Operating System fedora 38
Riva Version 2.12.0
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Currently when I run riva_init.sh it does work however at the end of the output the follow is shown:
qemu-aarch64-static: Could not open ‘/lib/ld-linux-aarch64.so.1’: No such file or directory
[[ tegra != \t\e\g\r\a ]]
[[ tegra == \t\e\g\r\a ]]
‘[’ -d /home/samfarzamfar/Desktop/tests/ngc-cli/riva_quickstart_v2.12.0/model_repository/rmir ‘]’
‘[’ -d /home/samfarzamfar/Desktop/tests/ngc-cli/riva_quickstart_v2.12.0/model_repository/prebuilt ‘]’
echo
echo ‘Riva initialization complete. Run ./riva_start.sh to launch services.’
and when I run the riva_start.sh i get the following message:
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
Waiting for Riva server to load all models…retrying in 10 seconds
Health ready check failed.
Check Riva logs with: docker logs riva-speech
and running docker logs riva-speech does not output anything. below is my configuration file:
Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
NVIDIA CORPORATION and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA CORPORATION is strictly prohibited.
GPU family of target platform. Supported values: tegra, non-tegra
riva_target_gpu_family=“tegra”
Name of tegra platform that is being used. Supported tegra platforms: orin, xavier
riva_tegra_platform=“orin”
Enable or Disable Riva Services
service_enabled_asr=true
service_enabled_nlp=true
service_enabled_tts=true
service_enabled_nmt=true
Enable Riva Enterprise
If enrolled in Enterprise, enable Riva Enterprise by setting configuration
here. You must explicitly acknowledge you have read and agree to the EULA.
RIVA_API_KEY=
RIVA_API_NGC_ORG=
RIVA_EULA=accept
Language code to fetch models of a specify language
Currently only ASR supports languages other than English
Supported language codes: ar-AR, en-US, en-GB, de-DE, es-ES, es-US, fr-FR, hi-IN, it-IT, ja-JP, ru-RU, ko-KR, pt-BR, zh-CN, es-en-US
for any language other than English, set service_enabled_nlp and service_enabled_tts to False
for multiple languages enter space separated language codes.
language_code=(“en-US”)
ASR acoustic model architecture
Supported values are: conformer, conformer_unified (ja-JP and zh-CN only), conformer_xl (en-US + amd64 only), conformer_ml_cs (es-en-US only), citrinet_1024, citrinet_256 (en-US + arm64 only), jasper (en-US + amd64 only), quartznet (en-US + amd64 only)
asr_acoustic_model=(“conformer”)
Decoder type to be used
If you’d like to use greedy decoder for ASR instead of flashlight/os2s decoder then set the below $use_asr_greedy_decoder to true
use_asr_greedy_decoder=false
Specify one or more GPUs to use
specifying more than one GPU is currently an experimental feature, and may result in undefined behaviours.
gpus_to_use=“device=0”
Specify the encryption key to use to deploy models
MODEL_DEPLOY_KEY=“tlt_encode”
Locations to use for storing models artifacts
If an absolute path is specified, the data will be written to that location
Otherwise, a Docker volume will be used (default).
riva_init.sh will create a rmir and models directory in the volume or
path specified.
RMIR ($riva_model_loc/rmir)
Riva uses an intermediate representation (RMIR) for models
that are ready to deploy but not yet fully optimized for deployment. Pretrained
versions can be obtained from NGC (by specifying NGC models below) and will be
downloaded to $riva_model_loc/rmir by riva_init.sh
Custom models produced by NeMo or TLT and prepared using riva-build
may also be copied manually to this location $(riva_model_loc/rmir).
Models ($riva_model_loc/models)
During the riva_init process, the RMIR files in $riva_model_loc/rmir
are inspected and optimized for deployment. The optimized versions are
stored in $riva_model_loc/models. The riva server exclusively uses these
optimized versions.
riva_model_loc=“riva-model-repo”
if [[ $riva_target_gpu_family == “tegra” ]]; then
riva_model_loc=“pwd/model_repository”
fi
The default RMIRs are downloaded from NGC by default in the above $riva_rmir_loc directory
If you’d like to skip the download from NGC and use the existing RMIRs in the $riva_rmir_loc
then set the below $use_existing_rmirs flag to true. You can also deploy your set of custom
RMIRs by keeping them in the riva_rmir_loc dir and use this quickstart script with the
below flag to deploy them all together.
use_existing_rmirs=false
Ports to expose for Riva services
riva_speech_api_port=“50051”
NGC orgs
riva_ngc_org=“nvidia”
riva_ngc_team=“riva”
riva_ngc_image_version=“2.12.0”
riva_ngc_model_version=“2.12.0”
Pre-built models listed below will be downloaded from NGC. If models already exist in $riva-rmir
then models can be commented out to skip download from NGC
########## ASR MODELS ##########
models_asr=()
for lang_code in ${language_code[@]}; do
modified_lang_code=“${lang_code//-/_}”
modified_lang_code=${modified_lang_code,}
decoder=""
if [ "$use_asr_greedy_decoder" = true ]; then
decoder="_gre"
fi
if [[ ${asr_acoustic_model} == "conformer_xl" && ${lang_code} != "en-US" ]]; then
echo "Conformer-XL acoustic model is only available for language code en-US."
exit 1
fi
if [[ ${asr_acoustic_model} == "conformer_unified" && ${lang_code} != "ja-JP" && ${lang_code} != "zh-CN" ]]; then
echo "Unified Conformer acoustic model is only available for language code ja-JP and zh-CN."
exit 1
fi
if [[ ${asr_acoustic_model} == "conformer_ml_cs" && ${lang_code} != "es-en-US" ]]; then
echo "Multilingual Code Switch Conformer acoustic model is only available for language code es-en-US."
exit 1
fi
if [[ $riva_target_gpu_family == "tegra" ]]; then
if [[ ${asr_acoustic_model} == "jasper" || \
${asr_acoustic_model} == "quartznet" || \
${asr_acoustic_model} == "conformer_xl" ]]; then
echo "Conformer-XL, Jasper and Quartznet models are not available for arm64 architecture"
exit 1
fi
if [[ ${asr_acoustic_model} == "citrinet_256" && ${lang_code} != "en-US" ]]; then
echo "For arm64 architecture, citrinet_256 acoustic model is only available for language code en-US."
exit 1
fi
models_asr+=(
### Streaming w/ CPU decoder, best latency configuration
"${riva_ngc_org}/${riva_ngc_team}/models_asr_${asr_acoustic_model}_${modified_lang_code}_str:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
### Offline w/ CPU decoder
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_ofl${decoder}:${riva_ngc_model_version}"
else
if [[ ${asr_acoustic_model} != "conformer" && \
${asr_acoustic_model} != "conformer_unified" && \
${asr_acoustic_model} != "conformer_ml_cs" && \
${asr_acoustic_model} != "conformer_xl" && \
${asr_acoustic_model} != "citrinet_1024" && \
${asr_acoustic_model} != "jasper" && \
${asr_acoustic_model} != "quartznet" ]]; then
echo "For amd64 architecture, valid acoustic models are conformer, conformer_unified, conformer_ml_cs, conformer_xl, citrinet_1024, jasper and quartznet."
exit 1
fi
if [[ (${asr_acoustic_model} == "jasper" || \
${asr_acoustic_model} == "quartznet") && \
echo "jasper and quartznet acoustic models are only available for language code en-US."
exit 1
fi
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_str${decoder}:${riva_ngc_model_version}"
### Streaming w/ CPU decoder, best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_str_thr${decoder}:${riva_ngc_model_version}"
fi
### Punctuation model
if [[ ${asr_acoustic_model} != "conformer_unified" ]]; then
pnc_lang=$(echo $modified_lang_code | cut -d "_" -f 1)
pnc_region=${modified_lang_code##*_}
modified_lang_code=${pnc_lang}_${pnc_region}
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/models_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
else
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}"
fi
fi
done
Speaker diarization model
models_asr+=(
“${riva_ngc_org}/${riva_ngc_team}/rmir_diarizer_offline:${riva_ngc_model_version}”
########## NLP MODELS ##########
models_nlp=(
BERT Base Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
"${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_bert_base:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
DistilBERT Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
“${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_distilbert:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}”
else
models_nlp=(
Bert base Punctuation model
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_en_us:${riva_ngc_model_version}"
BERT base Named Entity Recognition model fine-tuned on GMB dataset with class labels LOC, PER, ORG etc.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_named_entity_recognition_bert_base:${riva_ngc_model_version}”
BERT Base Intent Slot model fine-tuned on weather dataset.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_intent_slot_bert_base:${riva_ngc_model_version}”
BERT Base Question Answering model fine-tuned on Squad v2.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_bert_base:${riva_ngc_model_version}”
Megatron345M Question Answering model fine-tuned on Squad v2.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_megatron:${riva_ngc_model_version}”
Bert base Text Classification model fine-tuned on 4class (weather, meteorology, personality, nomatch) domain model.
“${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_text_classification_bert_base:${riva_ngc_model_version}”
fi
########## TTS MODELS ##########
models_tts=(
These models have been trained with energy conditioning and use the International Phonetic Alphabet (IPA) for inference and training.
"${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us_ipa:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}"
“${riva_ngc_org}/${riva_ngc_team}/models_tts_radtts_hifigan_en_us_ipa:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}”
This model uses the ARPABET for inference and training.
“${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us:${riva_ngc_model_version}-${riva_target_gpu_family}-${riva_tegra_platform}”
else
models_tts=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us_ipa:${riva_ngc_model_version}"
“${riva_ngc_org}/${riva_ngc_team}/rmir_tts_radtts_hifigan_en_us_ipa:${riva_ngc_model_version}”
“${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us:${riva_ngc_model_version}”
fi
######### NMT models ###############
Only models specified here get loaded, commented models (preceded with #) are skipped.
models follow Source language _ One or more target languages model architecture
e.g., rmir_de_en_24x6 is a German to English 24x6 bilingual model
models_nmt=(
Bilingual models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_de_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_es_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_zh_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_ru_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_fr_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_de_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_es_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_ru_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_zh_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_fr_en_24x6:${riva_ngc_model_version}”
Multilingual models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_deesfr_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_en_deesfr_12x2:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_deesfr_en_24x6:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_nmt_deesfr_en_12x2:${riva_ngc_model_version}”
Megatron models
#“${riva_ngc_org}/${riva_ngc_team}/rmir_megatronnmt_any_en_500m:${riva_ngc_model_version}”
#“${riva_ngc_org}/${riva_ngc_team}/rmir_megatronnmt_en_any_500m:${riva_ngc_model_version}”
NGC_TARGET=${riva_ngc_org}
if [[ ! -z ${riva_ngc_team} ]]; then
NGC_TARGET=“${NGC_TARGET}/${riva_ngc_team}”
else
team=“""”
fi
Specify paths to SSL Key and Certificate files to use TLS/SSL Credentials for a secured connection.
If either are empty, an insecure connection will be used.
Stored within container at /ssl/servert.crt and /ssl/server.key
Optional, one can also specify a root certificate, stored within container at /ssl/root_server.crt
ssl_server_cert=“”
ssl_server_key=“”
ssl_root_cert=“”
define Docker images required to run Riva
image_speech_api=“nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}”
define Docker images required to setup Riva
image_init_speech=“nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}-servicemaker”
daemon names
riva_daemon_speech=“riva-speech”
if [[ $riva_target_gpu_family != “tegra” ]]; then
riva_daemon_client=“riva-client”
fi
