Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hello, we have 4 cameras Sekonix SF3324 and I am trying to rectify the images with dwRectifier_warpNvMedia. We are using the pinhole model.
Here is how I warp the images :
bool UndistortWrapper::undistortImage(const dwImageHandle_t& in_image, dwImageNvMedia& out_image)
dwImageNvMedia* in_image_nvmedia;
CHECK_DW_ERROR_ROS(dwImage_getNvMedia(&in_image_nvmedia, in_image))
CHECK_DW_ERROR_ROS(dwRectifier_warpNvMedia(&out_image, in_image_nvmedia, rectifier_))
return true;
And here’s how I call it :
undistortWrapper_->undistortImage(imageHandle_, *image_nvmedia);
But this function is slow and I cannot run it at 30Hz. I looked at the cpu usage with htop and the process is maxing out one thread and processing the images at only 8hz per camera.
I have created a thread pool and I rectify the images in different threads and I now reach 22 Hz but still not 30 Hz.
Am I missing something here ? Why is this function so slow and why is the CPU under so much load. I understood that dwRectifier_warpNvMedia would use the Tegra VIC engine and be pretty fast.
Do you have any idea to improve the speed so we can reach 30 Hz publishing rate ?
Thanks !
