I’m encountering network bandwidth issues with my 64GB Orin dev kit connected to a high-end desktop. My end goal is to be able to transfer data via the 10Gbps link from the dev kit to the desktop via NFS. I’m noticing that I’m somehow inducing conditions that reduce overall throughput and seem to correlate to when I see the “mgbe_payload_cs_err” counter increment, as reported by ethtool -S eth0. What conditions in the Orin’s ethernet controller would cause this to happen?
The code in mgbe_core.c (nv-tegra.nvidia Code Review - kernel/nvethernetrm.git/blob - osi/core/mgbe_core.c) increments this counter when it evaluates ((tx_errors & MGBE_MAC_TX_PCE) == MGBE_MAC_TX_PCE) to be true. Where can I find out more information about the MGBE and its registers to understand better what might be happening? I’ve downloaded the TRM but that is pretty scant with MGBE info.
Below are details about my testing and what I’m seeing.
My test setup is a 64GB Orin dev kit that is directly connected (no intervening switch) via a CAT6A cable to an AMD-based desktop. The desktop is equipped with a Chelsio T540 adapter card which provides 4x10GbE ports. Both the Orin and the desktop adapters are configured with jumbo frames (MTU=9000). I’m running the latest JP 5.1.2 with a slightly tweaked kernel to get a full MTU of 9000 (see RGMII issue with Jetpack 5.1.1 (KSZ9131) - #7 by waterbear).
Further, the Orin is configured for maximum performance. Here’s the output of sudo jetson_clocks --show:
SOC family:tegra234 Machine:Jetson AGX Orin Developer Kit
Online CPUs: 0-11
cpu0: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu1: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu2: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu3: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu4: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu5: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu6: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu7: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu8: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu9: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu10: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
cpu11: Online=1 Governor=schedutil MinFreq=2201600 MaxFreq=2201600 CurrentFreq=2201600 IdleStates: WFI=0 c7=0
GPU MinFreq=1300500000 MaxFreq=1300500000 CurrentFreq=1300500000
EMC MinFreq=204000000 MaxFreq=3199000000 CurrentFreq=3199000000 FreqOverride=1
DLA0_CORE: Online=1 MinFreq=0 MaxFreq=1600000000 CurrentFreq=1600000000
DLA0_FALCON: Online=1 MinFreq=0 MaxFreq=844800000 CurrentFreq=844800000
DLA1_CORE: Online=1 MinFreq=0 MaxFreq=1600000000 CurrentFreq=1600000000
DLA1_FALCON: Online=1 MinFreq=0 MaxFreq=844800000 CurrentFreq=844800000
PVA0_VPS0: Online=1 MinFreq=0 MaxFreq=1152000000 CurrentFreq=1152000000
PVA0_AXI: Online=1 MinFreq=0 MaxFreq=832000000 CurrentFreq=832000000
FAN Dynamic Speed control=active hwmon4_pwm1=54
NV Power Mode: MAXN
The Chelsio adapter on the desktop can either be in standard “NIC” mode or “TCP-Offload Engine” (TOE) mode where TCP operations are offloaded to hardware. In NIC mode, I get the speed I expect although I do see worse performance when running iperf3 in zerocopy mode on the Orin which I can’t explain. I have also observed on occasion retransmits reported by iperf3, and while they are uncommon, do coincide with mgbe_payload_cs_err incrementing.
iperf3 standard mode:
~$ iperf3 --client 10.0.3.1
Connecting to host 10.0.3.1, port 5201
[ 5] local 10.0.3.10 port 52314 connected to 10.0.3.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 1.15 GBytes 9.89 Gbits/sec 0 1.66 MBytes
[ 5] 1.00-2.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 2.00-3.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 3.00-4.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 4.00-5.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 5.00-6.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 6.00-7.00 sec 1.15 GBytes 9.92 Gbits/sec 0 1.66 MBytes
[ 5] 7.00-8.00 sec 1.15 GBytes 9.90 Gbits/sec 0 1.66 MBytes
[ 5] 8.00-9.00 sec 1.15 GBytes 9.92 Gbits/sec 0 1.66 MBytes
[ 5] 9.00-10.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.66 MBytes
[ 5] 0.00-10.00 sec 11.5 GBytes 9.91 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 11.5 GBytes 9.91 Gbits/sec receiver
iperf Done.
iperf3 zerocopy mode:
~$ iperf3 --client 10.0.3.1 -Z
[ 5] local 10.0.3.10 port 46158 connected to 10.0.3.1 port 5201
[ 5] 0.00-1.00 sec 935 MBytes 7.84 Gbits/sec 0 2.31 MBytes
[ 5] 1.00-2.00 sec 938 MBytes 7.86 Gbits/sec 0 2.31 MBytes
[ 5] 2.00-3.00 sec 936 MBytes 7.85 Gbits/sec 0 2.31 MBytes
[ 5] 3.00-4.00 sec 939 MBytes 7.87 Gbits/sec 0 2.31 MBytes
[ 5] 4.00-5.00 sec 940 MBytes 7.89 Gbits/sec 0 2.31 MBytes
[ 5] 5.00-6.00 sec 936 MBytes 7.85 Gbits/sec 0 2.31 MBytes
[ 5] 6.00-7.00 sec 939 MBytes 7.87 Gbits/sec 0 2.31 MBytes
[ 5] 7.00-8.00 sec 934 MBytes 7.83 Gbits/sec 0 2.31 MBytes
[ 5] 8.00-9.00 sec 938 MBytes 7.86 Gbits/sec 0 2.54 MBytes
[ 5] 9.00-10.00 sec 939 MBytes 7.87 Gbits/sec 0 2.54 MBytes
[ 5] 0.00-10.00 sec 9.15 GBytes 7.86 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 9.15 GBytes 7.86 Gbits/sec receiver
iperf Done.
Any ideas why zerocopy mode performs worse for the Orin here? I’ve got another non-Orin device connected to one of the other Chelsio ports and it operates at full speed regardless of the zerocopy configuration.
When I enable TOE mode on the Chelsio adapter, iperf3 in standard mode continues to operate more or less as expected (retransmits occur but are uncommon). When I enable zero-copy, iperf3 reports a huge number of TCP retransmits. The biggest correlation is that mgbe_payload_cs_err consistently increments when this happens.
iperf3 standard mode w/TOE:
[ 5] local 10.0.3.10 port 39076 connected to 10.0.3.1 port 5201
[ 5] 0.00-1.00 sec 1.15 GBytes 9.87 Gbits/sec 0 1.04 MBytes
[ 5] 1.00-2.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 2.00-3.00 sec 1.15 GBytes 9.92 Gbits/sec 0 1.04 MBytes
[ 5] 3.00-4.00 sec 1.15 GBytes 9.90 Gbits/sec 0 1.04 MBytes
[ 5] 4.00-5.00 sec 1.15 GBytes 9.92 Gbits/sec 0 1.04 MBytes
[ 5] 5.00-6.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 6.00-7.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 7.00-8.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 8.00-9.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 9.00-10.00 sec 1.15 GBytes 9.91 Gbits/sec 0 1.04 MBytes
[ 5] 0.00-10.00 sec 11.5 GBytes 9.90 Gbits/sec receiver
iperf Done.
iperf3 zercopy mode w/TOE:
[ 5] local 10.0.3.10 port 47698 connected to 10.0.3.1 port 5201
[ 5] 0.00-1.00 sec 540 MBytes 4.53 Gbits/sec 118 8.75 KBytes
[ 5] 1.00-2.00 sec 949 MBytes 7.96 Gbits/sec 114 1.04 MBytes
[ 5] 2.00-3.00 sec 744 MBytes 6.24 Gbits/sec 116 1.04 MBytes
[ 5] 3.00-4.00 sec 515 MBytes 4.32 Gbits/sec 232 1.03 MBytes
[ 5] 4.00-5.00 sec 729 MBytes 6.11 Gbits/sec 117 1.03 MBytes
[ 5] 5.00-6.00 sec 525 MBytes 4.40 Gbits/sec 231 788 KBytes
[ 5] 6.00-7.00 sec 740 MBytes 6.21 Gbits/sec 116 1.02 MBytes
[ 5] 7.00-8.00 sec 651 MBytes 5.46 Gbits/sec 117 1.04 MBytes
[ 5] 8.00-9.00 sec 376 MBytes 3.16 Gbits/sec 347 1.06 MBytes
[ 5] 9.00-10.00 sec 819 MBytes 6.87 Gbits/sec 1 1.06 MBytes
[ 5] 0.00-10.00 sec 6.43 GBytes 5.53 Gbits/sec 1509 sender
[ 5] 0.00-10.00 sec 6.43 GBytes 5.52 Gbits/sec receiver
iperf Done.
In the first test above, viewing mgbe_payload_cs_err via ethtool -S eth0 showed that it did not increment. In the latter case, it incremented by 14 counts. Those 14 counts seem to correlate with the huge amount of retransmitted packets reported.
I’d be inclined to think the issue is with the Chelsio adapter and its TOE mode, but the other non-Orin test device I have does not exhibit this behavior at all. It suffers little to no retransmits in either NIC or TOE mode and does not exhibit any reduced performance when zerocopy is enabled.
The long and short of all of this is that when I have NFS enabled and the Chelsio card configured for TOE mode, the throughput from the Orin to the desktop gets greatly reduced and is not consistent - I see transfer rates ranging from 500MB/s to 800MB/s for a 60s test run. The other test device in the system does not exhibit any of these issues – it reports a transfer rate of ~1000MB/s regardless of the Chelsio mode. This leads me to believe the issues is with the Orin’s ethernet controller.
Any ideas? Circling back to my original question above – is there additional documentation available detailing the MGBE operation?
