Rejoining the Jetson Ecosystem: Ethernet hardware timestamping?
The Xavier NX using the EQOS nvethernet driver supported hardware timestamping …
$ ethtool -T eth0
Time stamping parameters for eth0:
Capabilities:
	hardware-transmit     (SOF_TIMESTAMPING_TX_HARDWARE)
	software-transmit     (SOF_TIMESTAMPING_TX_SOFTWARE)
	hardware-receive      (SOF_TIMESTAMPING_RX_HARDWARE)
	software-receive      (SOF_TIMESTAMPING_RX_SOFTWARE)
	software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
	hardware-raw-clock    (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
	off                   (HWTSTAMP_TX_OFF)
	on                    (HWTSTAMP_TX_ON)
	one-step-sync         (HWTSTAMP_TX_ONESTEP_SYNC)
Hardware Receive Filter Modes:
	none                  (HWTSTAMP_FILTER_NONE)
	ptpv1-l4-sync         (HWTSTAMP_FILTER_PTP_V1_L4_SYNC)
	ptpv1-l4-delay-req    (HWTSTAMP_FILTER_PTP_V1_L4_DELAY_REQ)
	ptpv2-l4-sync         (HWTSTAMP_FILTER_PTP_V2_L4_SYNC)
	ptpv2-l4-delay-req    (HWTSTAMP_FILTER_PTP_V2_L4_DELAY_REQ)
	ptpv2-l2-sync         (HWTSTAMP_FILTER_PTP_V2_L2_SYNC)
	ptpv2-l2-delay-req    (HWTSTAMP_FILTER_PTP_V2_L2_DELAY_REQ)
	ptpv2-event           (HWTSTAMP_FILTER_PTP_V2_EVENT)
I was hoping that since the Nano Super inherited much of the Xavier NX specs it might also have inherited its ethernet controller but I guess not. The Nano Super seems to have an ordinary RTL8168 PCIe controller…
$ ethtool -T enP8p1s0
Time stamping parameters for enP8p1s0:
Capabilities:
	software-transmit
	software-receive
PTP Hardware Clock: none
Hardware Transmit Timestamp Modes: none
Hardware Receive Filter Modes: none
The developer guide however says that PTP is supported and references Eqos …
EthernetControllerFeaturesEqos: IEEE 1588-2008 (PTP)
There are also posts in the Orin NX category that say it IS supported on the Orin NX…
But then…
Then there’s this…
So the bottom line is what? No ethernet hardware timestamping on either the Orin NX (which would be a step DOWN from the Xavier NX) or Orin Nano?
Based on the provided context, it appears that there is some confusion regarding the support for Precision Time Protocol (PTP) on the Jetson Orin NX and Nano modules.
According to the documentation, the Jetson Orin NX and Nano modules do not support hardware timestamping, which is a requirement for PTP. The developer guide mentions that PTP is supported, but it seems to be referring to software-based PTP, not hardware-based.
In contrast, the Jetson Xavier NX, which is an older module, does support hardware timestamping using the EQOS nvethernet driver.
The Jetson Orin NX and Nano modules use a different ethernet controller, the RTL8168 PCIe controller, which does not support hardware timestamping.
There are several forum posts and discussions that confirm this information. One post mentions that PTP is not supported on the Orin NX, while another post states that PTP is supported on the AGX Orin series, but not on the Orin NX and Orin Nano series.
In summary, the Jetson Orin NX and Nano modules do not support hardware timestamping and therefore do not support PTP in the same way as the Jetson Xavier NX. However, software-based PTP may still be possible, but it would not provide the same level of accuracy as hardware-based timestamping.
Comparison:
  • Jetson Xavier NX: Supports hardware timestamping using EQOS nvethernet driver
  • Jetson Orin NX: Does not support hardware timestamping, uses RTL8168 PCIe controller
  • Jetson Orin Nano: Does not support hardware timestamping, uses RTL8168 PCIe controller
In conclusion, if you need hardware-based PTP support, the Jetson Xavier NX may be a better option. However, if you can work with software-based PTP, the Jetson Orin NX or Nano modules may still be suitable for your needs.
Not according to this post by @WayneWWW
My last command on that Orin NX port is wrong. Just updated.
To clarify, Orin AGX MGBE is using our dedicated driver and it supports PTP (hardware timestamp only).
Orin NX/Nano does not use our dedicated driver and we don’t guarantee PTP would work.
For example, the document mentioned “IEEE 1588-2008 (PTP)” under “EthernetControllerFeaturesEqos”. This is NVIDIA EQOS driver. And Orin NX/Nano does not use it. It is a pure PCIe device based on Realtek driver.
@WayneWWW Thanks for clarifying.
