Xavier hardware 1588
I read Orin NX does not support PTP timestamping due to a driver issue.
Does Xavier?
How do i provide a reference clock to the Xavier SOM?
No, only Orin has it.
Are you sure only Orin has it? Pls see…
Orin NX/Nano not support PTP(IEEE.1588)? - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
I think you mean only Xavier has it.
But more important, how to provide clock, thru SOM GPIO pin?
I mean Orin AGX.
Orin NX/Nano is using ethernet solution from other NIC, Which does not support it.
Your post is talking about Orin NX/Nano.
