is there a way to remove swap file or set swap to 0 ?
As i don’t use much memory, is it a good idea to remove swap ?
Many thanks for your highlights.
Alain
Alain
Hi Alain,
There is a part of RAM that is used as several zram disks swap.
This compression allows a greater memory space, and it may also limit the available RAM reported so that applications may not try to allocate too much.
Unless you need all the available RAM (which is not tiny in a AGX Orin), you’d better let it as such.
If you really want to remove that, just disable service nvzramconfig:
sudo systemctl disable nvzramconfig
and reboot.
Ok, I understand.
So I will let it as it is.
Many thanks for your help.
Alain
