Jetson nano zram swap limits
Hello, i followed the procedure in the Jetson AI Fundamentals - S1E1 - First Time Setup with JetPack, and increased zram swap limits from 2 to 4 GB, Is there a way to undo the procedure that is done on the video?
thank you
Hi @jcass358, remove the swap entry from /etc/fstab and run sudo systemctl enable nvzramconfig
